Car auto transmission
khaledabdulaziz
Israel
C?ID=394371
hello all
i have a skoda octavia 2011
this car was using auto transmission and now its using manual, but im not sure if the ecu knows its using manual
how can i check what transmission the ecu know and if still using automatic how to make it manual
here the auto scan of the car
Sunday,16,February,2020,09:01:28:04619
VIN: TMBCT61Z4B2159759   License Plate:
Chassis Type: 1Z-SK35 (7N0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: TMBCT61Z4B2159759   Mileage: 172830km-107391miles
15-Airbags -- Status: Not registered 0011
Address 01: Engine (J623-CAYC)       Labels:. 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 LP    HW: 03L 906 023 JH
   Component: 1,6l R4 CR td H43 8810
   Revision: --H43---    Serial number:
   Coding: 00114016032400080000
   Shop #: WSC 73430 031 00066
   ASAM Dataset: EV_ECM16TDI02103L906023LP 003005
   ROD: EV_ECM16TDI02103L997557A.rod
   VCID: 7F5B05C7977C5C4FB0F-802A
Readiness: 1110 1000
   Part No SW: 1K0 907 379 BD    HW: 1K0 907 379 BD
   Component: ESP MK60EC1   H31 0108
   Revision: 00H31001
   Coding: 113B201C09270003881204E990220041300000
   Shop #: WSC 73430 790 00066
   VCID: 75B7E7EFA5C0161FEA3-8020
   Part No SW: 3T0 907 044 BD    HW: 3T0 907 044 BD
   Component: Climatronic   H16 0402
   Revision: 00006001
   Coding: 0000000002
   VCID: 75B7E7EFA540161FEA3-8020
9481748 - High Pressure Sensor
          B10AE 14 [009] - Open or Short to Ground
                    Reset counter: 195
                    Mileage: 172839 km
                    Date: 2020.02.16
                    Time: 17:03:17
   Part No SW: 1K0 937 087 J    HW: 1K0 937 087 J
   Component: BCM PQ35  H   103 0615
   Revision: 00103 AE
   Coding: 40000AB8A00508C040100080110001E4430000AE520081605C8440000040
   VCID: 38292EDBF252AB77315-806C
   Subsystem 1 - Part No: 1Z1 955 119 D  Labels: 1KX-955-119.CLB
   Component: Wischer 21041  26  0601
   Coding: 00D7B7
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 195
                    Mileage: 172839 km
                    Date: 2014.07.09
                    Time: 17:03:33
                    Voltage: 12.30 V
                        Term 50 Off
                    Reset counter: 195
                    Mileage: 172839 km
                    Date: 2014.07.09
                    Time: 17:03:33
                    Voltage: 12.30 V
                        Term 50 Off
   Component: Q6 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PC2549J1
   Coding: 0020790
   VCID: 3D273FCFD1708E5FE23-8068
   Subsystem 1 - Serial number: 6332MSME5F103220%
   Subsystem 2 - Serial number: 6342MSME5F04504EJ
   Subsystem 3 - Serial number: 6351HSME2701413E%
   Subsystem 4 - Serial number: 6361HSME2701504B+
00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
01217 - Side Airbag Igniter; Driver Side (N199)
   Part No SW: 1K5 953 521 AG    HW: 5K0 953 569
   Revision: FF010040    Serial number: 20110426201382
   Coding: 4080140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 72BDDCF3D42E0127CF1-8026
226839 - Turn Signal Switch
          B1144 11 [009] - Short to Ground
                    Reset counter: 195
                    Mileage: 172839 km
                    Date: 2020.02.16
                    Time: 17:03:58
   Part No SW: 1Z0 920 803 M    HW: 1Z0 920 803 M
   Component: KOMBI         H05 0405
   Coding: 110800
   ROD: EV_Kombi_UDS_VDD_RM09_004_SK34.rod
   VCID: 3E2538C3D0F69547FB9-806A
9453841 - Oil Level Thermal Sensor
          B1041 33 [009] - Signal low time > maximum
                    Fault Frequency: 9
                    Reset counter: 195
                    Mileage: 172559 km
                    Date: 2020.02.11
                    Time: 21:52:33
9453842 - Oil Level Thermal Sensor
          B1041 35 [008] - Signal high time > maximum
                    Fault Frequency: 9
                    Reset counter: 235
                    Mileage: 172559 km
                    Date: 2020.02.11
                    Time: 21:39:51
12718592 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät für Lenksäulenelektronik: keine Kommunikation]
                    Reset counter: 229
                    Mileage: 172559 km
                    Date: 2020.02.11
                    Time: 23:45:40
   Part No SW: 7N0 907 530 C    HW: 1K0 907 951
   Component: J533  Gateway H37 0614
   Revision:   H37       Serial number: 250411F1002226
   Coding: 351302
   Shop #: WSC 73430 444 00550
   VCID: 303916FB1A227337795-8064
                    Fault Frequency: 57
                    Reset counter: 195
                    Mileage: 172559 km
                    Date: 2014.07.04
                    Time: 21:31:06
                    Fault Status: 00110100
                    Reset counter: 229
                    Mileage: 172559 km
                    Date: 2014.07.04
                    Time: 23:45:40
                    Fault Frequency: 107
                    Mileage: 172559 km
                    Date: 2014.07.04
                    Time: 21:31:05
   Component: IMMO          H05 0405
   VCID: 6A8DC493FCFEC9E7771-803E
   Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
   Coding: 0000244
   VCID: 48C95E1B8EB2DBF7415-801C
   Part No: 1K0 909 144 H
   Component: EPS_ZFLS Kl. 69     2901
   Revision: 00H17000
   Shop #: WSC 73430 790 00000
   VCID: 2F3B15870B1C6CCF60F-807A
   Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
   Coding: 0000244
   VCID: 47CB5D2783ACD48F48F-8012
   Part No SW: 1Z0 035 161 F    HW: 1Z0 035 161 F
   Component: SWING         009 0065
   Revision: 0I001001    Serial number: SKZ1Z2L9051551
   Coding: 050004000001
   VCID: 313F13FF11287A3F76B-8064
03138 - Input AUX IN
                    Reset counter: 189
                    Mileage: 172559 km
                    Date: 2014.07.04
                    Time: 21:15:55
   Part No SW: 5K0 959 703 A    HW: 5K0 959 703 A
   Coding: 0000144
   Shop #: WSC 73430 790 1012546
   VCID: 323D1CF3182E41270F1-8066
   Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
   Coding: 0000144
   VCID: 333319F7E734482F047-8066
End----------(Elapsed Time: 00:51, VBatt start/end: 12.3V/12.3V)-----------
The microfiche and take this to retrofit area.
Get a subscription to partslink24 and research it.
If the ECU thought there should be an Automatic transmission in this car, I would expect to see "missing messages" and/or "incorrectly coded" fault codes. Since you have neither of these, I think it is OK.
PS: Moved to Retrofits.
khaledabdulaziz
Israel
C?ID=394371
Thanks a lot
