01312 data bus error
Patryk11113
Pirate
Walking the Plank
Hello. I have a problem with the error after replacing bcm1 with xenon support + leveling headlight (8k0907063DH), 01312 powertrain data bus 004 no signal, no communication + yellow icon defective adjustment of the range of lights .everything connected according to elsa win , audi a4 b8.5 avant 2012. .Please help me solve the problem
Viking
C?ID=151455
Please post an autoscan so that people know what modules and suchlike your vehicle has.
Your particular situation may not be the same as someone else. Linking to their thread is little help.
Patryk11113
Pirate
Walking the Plank
exactly the same problem
Viking
C?ID=151455
Yet still the problem remains.... No Autoscan.
You're unlikely to gain any assistance until the simple task outlined is completed. :thumbs:
Patryk11113
Pirate
Walking the Plank
scan
Viking
C?ID=151455
You should update your VCDS software, it's a bit out of date.
Patryk11113
Pirate
Walking the Plank
will the error disappear as it updates? , I do not think so
Viking
C?ID=151455
I have a feeling something will disappear...
Patryk11113
Pirate
Walking the Plank
the scan was done by a mechanic, I do not know if he has an original program or not, I received such a scan
I guess you should find an more honest mechanic then.
stef_cta
Romania
I have the same problem with 8k0907063 DG
Viking
C?ID=151455
This thread is in the section for people who use pirate versions of the vcds system. If you have a genuine vcds cable and software then you could start a new thread in the New Users section and include an autoscan.
Edit: I can see now that you're a verified user so perhaps there's a better section for your new thread, again include an autoscan.
razvyx
New Member
Romania
Same problem here after a complete xenon retrofit on a B8.5 2013 Avant. I changed the BCM1 with the DH one, OEM xenon headlights, and installed the auto-level sensor in the rear left of the car as specified in Etka. After the retrofit, the xenon lamps are working correctly but everytime I start the engine, I receive the error “ Headlight range control defective” with no specific error in VCDS on the 09 Central Electric, just the “01312- Powertrain data bus”. I think it has something to do with the codings. I noticed that the headlights does not perform the self-test (up and down max limits) when I start the engine as it supposed to do, they only do this test when I try to reset the 01312 error. The error appears again instantly after reset.
Please help!
I will return with a full scan in a few hours.
Thank you in advance,
Razvan
Dana
Western PA, USA
Hello Razvan,
This thread is in the Hall of Shame for the reasons Viking mentioned above. For that reason assistance will not be provided here. Please see this thread to determine what's necessary to get registered for support and become a Verified VCDS User in our forum:
https://forums.ross-tech.com/showthread.php?2601-How-to-get-Verified
After doing so you can create a new thread in the Retrofits section with the before and after BCM1 replacement Auto-Scans.
