New user here asking the question
busterboy
C?ID=383133
Been a long time lurker here seeing what magic folks can do with the wonderful Ross-Tech VCDS HEX-V2 Professional UnlimitedVIN + Hard Case and Printed Manual so expecting a package delivered today from ilexa here in the UK.
My question is like most surely worry about.
I paid £70k for my 2017 Audi A8L two years ago and obviously frightened to death of "Bricking" my expensive car. :facepalm:
I would like to know is there any facilities on the program that can make a full "original / default" backup before I start making changes myself then should it go wrong I can restore it similar to a Windows PC should it go wrong.
Looking forward to making small changes / little tweaks as most do starting with the needle sweep, I would like to decrease the cars tick over if possible as it drags slightly when in drive stood with the brake pedal on.
Regards Tim.
HMC
C?ID=28246
" so expecting a package delivered today from ilexa here in the UK." Good choice, I am sure Derek would always give advice if you are in trouble. The first thing to do is a full autoscan and save it somewhere safe, that will give you your base starting point. The other thing I would say is make changes one at a time and check they are correct and what you want before moving on. Take an autoscan every time you have made a successful change and name it accordingly.
Regards HMC
PetrolDave
Westbury, UK
C?ID=1423
IIRC the new VCDS software has a feature to save a complete map of the car? Can't check as I'm not with my HEX-NET at present, but I'm sure someone will confirm with details...
busterboy
C?ID=383133
Well it's just arrived. :D
busterboy
C?ID=383133
Apologies for continuing in this post, I just been out and activated "Needle Sweep" and reset the service interval (just because I can) :D
Also did a scan so hopefully it can be read here before I start the long learning process. :cool:
Wednesday,09,October,2019,15:10:00:17234
VIN: WAUZZZ4H4HN020264   License Plate: KX17 ZGG
Mileage: 62323km-38725mi   Repair Order: Full Scan
Chassis Type: 4H-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 15 16 17 19 28 30 34 36 3B 42 44 46 47
          52 53 55 56 57 5F 62 6C 6D 6F 72 81 85 88 89 8F 90 AC
VIN: WAUZZZ4H4HN020264   Mileage: 62323km-38725miles
Address 01: Engine (J623-CTBA)       Labels:. 059-907-401-V2.clb
   Part No SW: 4H0 907 401 Q    HW: 4G0 907 401 E
   Component: 3.0TDI EDC17  X14 0006
   Revision: 58X14---
   Coding: 0A2A4032052601030800
   Shop #: WSC 92521 052 00000
   ASAM Dataset: EV_ECM30TDI0114H0907401Q 001006
   ROD: EV_ECM30TDI0114H0907401Q.rod
   VCID: 323CE13E34AB54B70F3-8066
   Part No SW: 4H1 927 158 CL    HW: 0BK 927 156 AD
   Component: 0BK 30TDIRdW  H22 1010
   Revision: --H22---
   Coding: 000001
   ASAM Dataset: EV_TCMALX51011 002022
   ROD: EV_TCMALX51011_002_AU64.rod
   VCID: 7CA00F06A66F52C795F-8028
   Part No SW: 4H0 907 379 AB    HW: 4H0 907 379 AB
   Component: ESP PREMIUM   H10 0930
   Coding: 60E5EB8006A7D701E300
   ASAM Dataset: EV_ESPPremi 005025
   ROD: EV_ESPPremi_005_AU64.rod
   VCID: 72BC213EF42B14B7CF3-8026
0563 - Supply Voltage for ABS Valves
          C106A 01 [136] - Electrical Failure
                    Reset counter: 33
                    Mileage: 58595 km
                    Date: 2019.09.20
                    Time: 14:18:05
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 02
                    Bit Info 3: 80
                    Bit Info 4: 00
                    F-Path: 02
                    F-Type: 81
                    Uz: 98
   Part No SW: 4H0 907 064 HB    HW: 4H0 907 064 HB
   Component: BCM2 2.0      H61 0825
   Coding: 05B76F4E000000000000
   VCID: 70B82B36FAA726A7397-8024
   Serial number: 3217000018256009
   Component: MEM-BFS       H08 0156
   Revision: AA000000    Serial number: 00000245068453
   Coding: 0038320000047201000001010101112131313333283333
   VCID: 3430E726CE3F5A871DF-8060
03325 - Switch for Backrest Angle Adjustment: Back
                    Fault Status: 00100011
                    Reset counter: 42
                    Mileage: 59698 km
                    Date: 2019.09.26
                    Time: 09:25:24
03327 - Switch for Headrest Adjustment: Down
                    Reset counter: 42
                    Mileage: 59698 km
                    Date: 2019.09.26
                    Time: 09:25:24
Address 08: Auto HVAC (J255)       Labels:| 4H0-820-043.clb
   Part No SW: 4H0 820 043 N    HW: 4H0 820 043 N
   Component: Klima 4 Zonen H20 0210
   Coding: 362102BE3C0000
   ASAM Dataset: EV_AirCondiFront 003001
   ROD: EV_AirCondiFront_002.rod
   VCID: 2B02FC5A1381057F4C5-807E
   Part No SW: 4H0 907 063 GB    HW: 4H0 907 063 AB
   Component: BCM1 2.0      H20 0368
   Revision: 1902003S    Serial number: 00001624426601
   Coding: 0105001440349FE0C9014087A0001800009DC30A2F080201800008946100170000400034030000
   VCID: 6E84354EE09330572BB-803A
   Subsystem 1 - Part No SW: 4H2 955 119 D    HW: 4H2 955 119 A
   Component: WWS641 161220  H38 0100
   Serial number:         170109145514
   Coding: 0045F7
   Serial number: 20173521X81A955547A0
   Coding: 02004E
   Component: E1 - LDS  H07 0044
   Serial number: 29 03 2017  00000716
   Subsystem 4 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA126451000028834772
   Coding: 020300
   Subsystem 5 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Serial number: 0F088C9800PAG0MUFU03
03455 - Function Restriction due to Faults in Other Modules
                    Reset counter: 34
                    Mileage: 58129 km
                    Date: 2019.09.18
                    Time: 04:08:47
   Part No SW: 4H0 959 655 H    HW: 4H0 959 655 H
   Component: Airbag10.43   H82 0092
   Revision: --------    Serial number: 003P100DAGN5
   Coding: 30333045313430303038554A305234483053
   VCID: 3B22CC1AE3E195FFDC5-806E
   Serial number: 3575HRB405T468HIAP1U
   Serial number: 3585HRB405R468HI59LS
   Serial number: 3515JRB4012597JML9FD
   Serial number: 3525JRB4014597JM89UI
   Serial number: 3554VRB401659GF2IPDS
   Serial number: 3564VRB401659GF2OOV9
   Part No SW: 4H0 953 568 G    HW: 4H0 953 568 G
   Component: Lenks.Modul   H05 0005
   Revision: --------    Serial number: 01335QD6000MQ
   Coding: 000034
   VCID: 372AD02ADF49B19F38D-8062
   Subsystem 1 - Part No SW: 4H0 951 528 J    HW: 4H0 951 528 J
   Component: E221 - MFL  H09 0010
   Serial number: 16 12 2016  H0035393
   Part No SW: 4H0 920 910 T    HW: 4H0 920 910 T
   Component: TDieGB------- H55 0903
   Revision: 44081303    Serial number: 658080417592008
   Coding: 33A608001B412600010000
   ASAM Dataset: EV_RBD4K 004050
   ROD: EV_RBD4K_AU64.rod
   VCID: 3536DA22C5C5438F2A1-8060
   Analog_clock:
   Subsystem 1 - Part No SW: 4H0 919 204 Q    HW: 4H0 919 204 Q
   Component: Analoguhr D4  H05 0225
   Serial number: 2170227000937
   Part No SW: 4H0 907 468 AH    HW: 4H0 907 468 AC
   Component: J533--Gateway H15 0096
   Revision: --------    Serial number: 00000002576217
   Coding: C0CD077F08
   VCID: 77AA102A9F49719FF8D-8022
   Subsystem 1 - Part No SW: 4H0 915 181 G    HW: 4H0 915 181 G
   Component: J367-BDM  H08 0270
   Serial number: 54038025081481182402
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 C    HW: 8K0 959 663 C
   Serial number: 17087002207011200410
12290 - Quiescent Current
          U1406 00 [008] - Too High
                    Fault Frequency: 17
                    Reset counter: 41
                    Mileage: 58764 km
                    Date: 2019.09.21
                    Time: 00:56:50
                    Voltage terminal 30: 12.4 V
                    Voltage terminal 15: 0.0 V
                    Control Module temperature: 17 °C
                    System status: LIN_active
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status: OFF
                    Datenfeld: 0
          U140B 00 [008] - -
          [Powermanagement active]
                    Fault Frequency: 7
                    Reset counter: 41
                    Mileage: 59113 km
                    Date: 2019.09.21
                    Time: 20:55:55
                    Voltage terminal 30: 12.5 V
                    Control Module temperature: 20 °C
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 1
Address 28: HVAC, Rear (E265)       Labels:| 4H0-919-158.clb
   Part No SW: 4H0 919 158 K    HW: 4H0 919 158 K
   Component: Klima Fond    H17 0200
   Coding: 2800000000
   Shop #: WSC 02313 785 00200
   ASAM Dataset: EV_AirCondiHeck 002001
   ROD: EV_AirCondiHeck_AU64.rod
   VCID: 3828D316D2D7BEE7317-806C
   Part No SW: 4H0 907 440     HW: 4H0 907 440
   Component: STS           H06 0030
   Revision: S0H06000    Serial number: 00000000002795
   Coding: 01010101000000000001000202
   VCID: 649057663E5F8A074DF-8030
   Part No SW: 4G0 907 553 G    HW: 4G0 907 553 F
   Component: LUFE-DAEMPFER H19 0783
   Coding: 008000
   ASAM Dataset: EV_AirSuspe 003025
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2F3AE84A2799795F60D-807A
          C10C8 00 [008] - -
                    Reset counter: 59
                    Mileage: 58180 km
                    Date: 2019.09.18
                    Time: 11:49:25
   Component: MEM-FS        H08 0156
   Revision: AA000000    Serial number: 00000244721443
   Coding: 00383B0000057201000001010101112131313333203333
00459 - Control Module for Display and Input; Front (J523)
                    Reset counter: 51
                    Mileage: 60966 km
                    Date: 2019.10.01
                    Time: 12:00:31
   Part No SW: 4H0 907 637 K    HW: 4H0 907 637 F
   Component: SARA 6D       H04 0056
   Revision: --------    Serial number: EJ1BPA7703TDDN
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 372AD02ADFC9B19F38D-8062
   Part No SW: 4H0 959 793 R    HW: 4H0 959 793 G
   Component: TSG FA        H08 0280
   Revision: --------    Serial number: 0000247627063
   Coding: 011F1E015E0162C202083006
   VCID: 48C8A3D6A2B7CE67417-801C
   Component: RCevo         H54 0202
   Revision: 00000001    Serial number: 0000627986
   Coding: 101000010001
   ASAM Dataset: EV_RCEPS 106007
   ROD: EV_RCEPS_106.rod
   VCID: 3A2CC91EECDBACF7C73-806E
   Revision: 00002001    Serial number: 0438557057
   Coding: 011B0E2280B93985F320C7C40A0316470000000000000000000000000000
   Subsystem 1 - Part No: 4H0 951 177
   Subsystem 3 - Part No SW: 4H0 959 591 B    HW: 8V3 959 591 A
   Component: J245 PS50.402  H03 0004
   Serial number: 0000FST001J16RI00000
   Coding: 901F00
   Subsystem 4 - Part No SW: 4H0 947 135 G    HW: 4H0 947 135 G
   Component: Dachelektroni  H13 0080
   Serial number: A2017000000000155033
   Subsystem 5 - Part No SW: 4H0 959 591 A    HW: 4H0 959 591 A
   Component: V252 PS014  H06 0005
   Serial number:     WOO1000KP4O
   Subsystem 6 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Serial number: 66001288
   Revision: CJ007001    Serial number: 00000000209450
   Coding: 030000
   VCID: 1D6622825DB5FBCFC21-8048
   Part No SW: 4H0 959 792 G    HW: 4H0 959 792 G
   Component: TSG BF        H08 0280
   Revision: --------    Serial number: 0000246267884
   VCID: 3C20CF06E66F92C7D5F-8068
   Part No SW: 4H0 907 801 M    HW: 4H0 907 801 M
   Component: EPB-4         H01 0018
   Revision: --------    Serial number: 00000002158373
   ROD: EV_ParkiBrake_VW51.rod
   Coding: 02F6022022130200
   VCID: 3430E726CEBF5A871DF-8060
   Subsystem 1 - Part No SW: 7PP 941 472 K    HW: 7PP 941 472 K  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H07 7570
   Coding: E00300
   Subsystem 2 - Part No SW: 7PP 941 472 K    HW: 7PP 941 472 K  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H07 7570
   Coding: E00300
   Matrix Headlamp Powermodule 1 Left:
   Subsystem 3 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo li.  H03 0031
   Coding: E00300
   Matrix Headlamp Powermodule 1 Right:
   Subsystem 4 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo re.  H03 0031
   Coding: E00300
13706001 - Databus
          [Empfangener Fehlerwert im Signal Kamera_FDD_Funktionsstatus: CAN Message Kamera_Status]
                    Reset counter: 51
                    Mileage: 58128 km
                    Date: 2019.09.18
                    Time: 04:07:45
5353456 - Fog mode active
          C118E 00 [008] - -
                    Fault Frequency: 21
                    Reset counter: 58
                    Mileage: 58777 km
                    Date: 2019.09.21
                    Time: 03:35:34
   Part No SW: 4G0 035 061 S    HW: 4G0 035 061
   Component: Radio U DAB   H60 0154
   Revision: AB001007    Serial number: 109CQ0H5019221
   Coding: 010103010000000001
   VCID: 2D06F2422D150B4F521-8078
Address 57: TV Tuner (R78)       Labels: None
   Part No SW: 4G0 919 129 C    HW: 4G0 919 129
   Component: NGTV-DVB      H04 0690
   Revision: R0043000    Serial number: 06801302534001
   Coding: 03000000
   Part No SW: 4H0 035 654 D    HW: 4H0 035 654 D
   Component: H-BNT-EU      H51 1072
   Revision: --------    Serial number: 449D$0HB004073
   Coding: 02010100000BF1EF45908B1E00000003000101000000000000
   VCID: 270A006A0FE9211FA8D-8072
   Subsystem 1 - Part No: 8R0 060 884 FK
   Component: EUR 2018/2019  2702
   Subsystem 2 - Part No SW: 4H0 919 604 H    HW: 4H0 919 604 H
   Component: DU8 D4 SV NB  H63 0060
   Serial number: AUZ8ZDHY901B62$
   Subsystem 3 - Part No SW: 4H2 919 600 L    HW: 4H2 919 600
   Component: E380 BDT D4  H11 0110
   Serial number: 00000000238757
   Component: CD-Database  9040
                    Reset counter: 236
                    Mileage: 56894 km
                    Date: 2019.09.09
                    Time: 14:30:58
                    Text: DU902A,Front,M,0,0,6
03623 - Invalid Security/Release Code
                    Reset counter: 236
                    Mileage: 56894 km
                    Date: 2019.09.09
                    Time: 14:30:57
                    Hex Value: 0x0004
                    Hex Value: 0x0009
                    Count: 7
   Part No SW: 4H0 959 795 D    HW: 4H0 959 795 D
   Component: TSG HL        H08 0280
   Revision: --------    Serial number: 0000250127716
   Coding: 010F1E01400062C202083006
Address 6C: Back-up Cam. (J772)       Labels:| 5Q0-907-441.clb
   Part No SW: 4S0 907 441 B    HW: 5Q0 907 441 A
   Component: D4-PA RVC Mid H07 0050
   Coding: 024611010201000300
   ASAM Dataset: EV_CamSysRearPANAAU914 002002
   ROD: EV_CamSysRearPANAAU914_AU64.rod
Address 6D: Trunk Elect. (----)       Labels:* None
   Part No SW: 4H0 959 107 AC    HW: 4H0 959 107 AC
   Component: HDSG-Modul    H12 0049
   Revision: 10012001    Serial number: 090701351
   Coding: 021004C020
   ASAM Dataset: EV_DeckLidContrUnit 001032
   ROD: EV_DeckLidContrUnit.rod
   VCID: 6FBA284AE719395F20D-803A
Address 6F: Centr. Conv. II (J773)       Labels:* None
   Revision: --------    Serial number: 000000229387
   Coding: 220000
   ASAM Dataset: EV_Ambie 001008
   ROD: EV_Ambie.rod
   VCID: 6392547A3BD18D3FB45-8036
   Component: TSG HR        H08 0280
   Revision: --------    Serial number: 0000250127711
Address 81: Gear Shift (J587)       Labels: 3Y0-927-731.clb
   Part No SW: 4H2 927 731 A    HW: 4H2 927 731 A
   Component: GSM-RL        H09 0083
   Revision: 0R0D5015    Serial number: SN170123  0022
   ROD: EV_GSM2x3Mono.rod
   VCID: 2C00FF46168F024745F-8078
   Part No SW: 4H0 907 217 F    HW: 4H0 907 217 A
   Component: DPC-SG        H28 0081
   Coding: E0140000
   ROD: EV_OnBoardCamerDPC.rod
   Serial number: 00030660119201
   Coding: 672FF2
   ROD: EV_IVBDriveSideFrnt.rod
   Serial number: 00030660179801
   Coding: 272FF2
   Component: RGS-VL        H16 0080
   Coding: 00060000031F030000030800424CDA010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 313EEE3231AD6FAF769-8064
   Component: RGS-VR        H16 0080
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0013
   Revision: 00000000    Serial number: 170600241
   ROD: EV_RDCMA00100_008.rod
End----------(Elapsed Time: 02:54, VBatt start/end: 12.1V/12.0V)-----------
Dana
Western PA, USA
I would connect a battery charger (or idle the engine for a while) and run a full set of maps as Dave mentioned. This may be helpful:
https://www.youtube.com/watch?v=au4FR1FCrHU
Before you make too many mods.. I would recommend:
  • Factory condition Auto-Scan (Already done)
  • Whole Vehicle Raw HEX maps on the Adaptation Function
  • Whole Vehicle traditional Measuring Values -and- Adaptation maps set to Pre-label file.
https://www.ross-tech.com/vcds/tour/controller-channels-map.php
Also, if you use one PC then the Debug folder contents may save the day if you create any problems when tweaking:
https://forums.ross-tech.com/showthread.php?1029-CodingLog-and-AdpLog-little-safety-nets-for-you
Edit, all of the fault codes are Intermittent in the above scan so I would clear them for now.
busterboy
C?ID=383133
Thank you for those tips and links Dana. I really appreciate it.
After saving the fault codes above I erased them while it was plugged in. :)
