Hi just scanned the Polo and these have come up ive had issues with the car loosing all power for a few seconds then it resets.
thanks in addvance
thanks in addvance
Wednesday,15,January,2020,22:42:35:27233
VCDS Version: Release 19.6.2 (x64) Running on Windows 10 x64
Address 01: Engine Labels:
Control Module Part Number:
Component and/or Version:
Software Coding:
Work Shop Code:
VCID: 55F488331C07F0BFCA1-FFFE
25796 - Body Control Module (Central Electric)
U0140 00 [036] - No Communications
Mileage: 67954 km
Date: 2000.01.00
Time: 00:00:00
Engine speed: 833.50 /min
Normed load value: 30.2 %
Coolant temperature: 67 °C
Intake air temperature: 26 °C
Voltage terminal 30: 15.023 V
Accelerator pedal travel: raw value: 0.00 %
CAN status - engine control module: 0
Cruise Control System (CCS): status: main switch off
selected gear: Shifting process active
25113 - Databus
U1123 00 [036] - Received Error Message
Mileage: 67954 km
Date: 2000.01.00
Time: 00:00:00
Engine speed: 835.75 /min
Voltage terminal 30: 14.898 V
Acceleration: 0.000 m/s²
Cruise Control System (CCS): status: Non-reversible off
Status irriversible shutoff condition cruise control and limiter-Status: 4
Cruise control system: temporary deactivation: No switch-off
Cruise control switch actuation-Bit 0: main switch off
Cruise control switch actuation-Bit 1: No Cancel
Cruise control switch actuation-Bit 2: No tip delay
Cruise control switch actuation-Bit 3: No tip accelerate
Cruise control switch actuation-Bit 4: no setting
Cruise control switch actuation-Bit 5: No resumption
Cruise control switch actuation-Bit 6: No control malfunction
Cruise control switch actuation-Bit 7: main switch off
Cruise control switch actuation-Bit 8: Control code plausible
Cruise control switch actuation-Bit 9: Limiter not selected
Readiness: N/A
