2016 Bentley Flying Spur W12 ABS Module VCDS communication error
DF390
CA, USA
C?ID=375585
New member here and really need some help to solve this puzzle :)
This car came in for body repair and both batteries are replaced as well. It seems like steering wheel angle sensor need to be recalibrated as there's a fault(G85) on the backup camera and bunch of others.
However, ABS module would not communicate at all and eventually timed out with " too many communication errors ". Per Ross-Tech support, I've tried adjust the scan time(slow or fast) and still not working. I also made sure both batteries are fully charged to rule out any low voltage issue.:banghead:
Address 03: ABS Brakes Labels: None
VCID: 55E290A7B8FFEC2E08-8000
No Faults Found
Full scan attached, please help. Thanks in advance!
 Chassis Type: ZA-BY62 (3W0)
Scan: 01 02 03 05 06 07 08 09 11 31 13 15 16 17 19 23 28 2E 34 36
          37 38 46 47 48 53 56 5D 65 66 68 6C 6D 71 76 77
VIN: SCBEC9ZA0GC053452
48-Seat, Rear, DS -- Status: OK 0000
5D-Operations -- Status: Malfunction 0010
66-Seat, Rear -- Status: OK 0000
68-Wiper Electr. -- Status: OK 0000
71-Battery Charger -- Status: OK 0000
Address 01: Engine (J623-DBDB)       Labels: None
   Part No SW: 07C 906 023 AS    HW: 07C 907 309
   Component: ME17.1.6      H17 1471
   Revision: MHH17---    Serial number: VWX3Z0P7010499
   Coding: 0D2A0032436E00020006
   Shop #: WSC 00083 790 00197
   ASAM Dataset: EV_ECM60TMP11107C906023AS 001002
   ROD: EV_ECM60TMP11107C906023AS.rod
   VCID: 72A8CB3BA5519B160D-8026
4327 - Function Restriction due to Faults in Other Modules
          U1113 00 [047] - -
                    Fault Frequency: 19
                    Mileage: 28116 km
                    Date: 2020.05.27
                    Time: 17:35:35
                    Coolant temperature: 50 °C
                    Intake air temperature: 39 °C
                    Voltage terminal 30: 12.086 V
                    Acceleration: 0.000 m/s²
                    ACC control module received status-Bits 0-7: 7
                    Brake actuated status-Bits 0-7: 0
                    Active brake system error status-Bits 0-7: 33
                    Cruise Control System (CCS): switch position-Bits 0-7: 0
16672 - Please Check DTC Memory of ECU Number 2
          P1923 00 [032] - -
4483 - Function Restriction due to Faults in Other Modules
          U1113 00 [032] - -
                    Mileage: 28116 km
                    Date: 2020.05.27
                    Time: 19:08:50
                    Coolant temperature: 91 °C
                    Intake air temperature: 71 °C
                    Voltage terminal 30: 12.203 V
                    Cruise Control System (CCS): status-Bits 0-7: 212
                    Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 0
                    Cruise control switch-off: reversible-Bits 0-7: 255
Readiness: 1110 1101
Address 02: Auto Trans (J217)       Labels:* None
   Part No SW: 4W0 927 158 G    HW: 0CU 927 760 A
   Component: 0BL 60 MPIUSA H19 0001
   Revision: --H19---    Serial number: VWX3Z0P7010499
   Coding: 000001
   Shop #: WSC 00083 790 00174
   ASAM Dataset: EV_TCMAL450211 002010
   ROD: EV_TCMAL450211_BY62.rod
   VCID: 42C85BFBD5716B965D-8016
No Faults Found
   Part No SW: 3D0 909 137 G    HW: 3D0 909 137 G
   Component: C0 Kessy            6850
   Revision: 00H24072    Serial number: VWX3Z0P7010499
   Coding: 0405741
   Shop #: WSC 00083 790 00191
   VCID: 2B16165F8EFB8ADE8E-807E
   Part No SW: 4W0 959 760 A    HW: 4W0 959 760
   Component: MEM-BFS       H04 0700
   Revision: AA000000    Serial number: 00000158514067
   Coding: D0081F0085070090090001010101002100012727000000
   Shop #: WSC 00083 790 00242
   VCID: 40CC51F3D77D79864B-8014
Address 07: Control Head        Labels: 3D0-907-048.clb
   Part No SW: 3D0 907 048     HW: 3D0 907 048
   Component: J127 KBT vorn       0100
   Revision: ABH23001    Serial number: VWZ6Z7R0197078
   VCID: 6386BE7FA6AB029E76-8036
   Part No: 3W5 907 040 K
   Component: Climatronic BY621   3030
   Coding: 0000101
   VCID: 3E302F0B6D890F7639-806A
Address 09: Cent. Elect.        Labels:. 3D0-937-049-V2.clb
   Part No SW: 3D0 937 049 Q    HW: 3D0 937 049 Q
   Component: J519                7700
   Revision: -4007---    Serial number: --------------
   Coding: 40820000AB2A11C02508030000000000
   VCID: 383C39134FAD3146F3-806C
Address 11: Engine II (J624)       Labels: None
   ASAM Dataset: EV_ECM60TMP21107C906023AS 001002
   ROD: EV_ECM60TMP07C906023AS.rod
Address 13: Auto Dist. Reg        Labels: None
   Part No SW: 4W0 907 567 B    HW: 4W0 907 567 B
   Component: AC201  NAR BY681   00951
   Revision: 00041000    Serial number: 00000000663462
   Coding: 0020681
   Shop #: WSC 00083 790 00168
   VCID: 3FCE520F6A83067E32-806A
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 226
                    Mileage: 28116 km
                    Date: 2020.05.28
                    Time: 09:18:40
                    Count: 4
                    Reset counter: 226
                    Mileage: 28116 km
                    Date: 2020.05.28
                    Time: 09:18:40
                    Count: 38
   Part No SW: 3W3 959 655 A    HW: 3W3 959 655 A
   Component: VW10Airbag22Q H01 0004
   Revision: --------    Serial number: 003FW000DS8D
   Coding: 000000000000000000000000000000003251
   ASAM Dataset: EV_AirbaVW10BPABY62X 001002
   ROD: EV_AirbaVW10BPABY62X.rod
   VCID: 45C240E7C45F5CAE78-8010
   Subsystem 1 - Part No SW: 4W0 959 339 A    HW: 4W0 959 339 A
   Component: BF-Gewichtss.  H03 0201
   Serial number: 5850000R158030CV2F
   Serial number: 3572DRB40000F8892A4%
   Serial number: 3582DRB40000F8CCF97M
   Serial number: 35128RB40000741FF84T
   Serial number: 35228RB4000074475D2I
   Serial number: 35547RB40000735D1C8T
   Serial number: 35647RB400007396C15O
   Part No: 7L6 953 549 K
   Component: J527                3601
   Coding: 0000042
   Shop #: WSC 00083 790 00244
   VCID: 47DE4AEF32534EBE8A-8012
Address 17: Instruments        Labels: 3Wx-920-xxx-17.lbl
   Part No SW: 3W0 920 852 B    HW: 3W0 920 852 B
   Component: J285 KOMBI-INST.    6666
   Revision: KPH10V06
   Coding: 0034214
   Shop #: WSC 44041 001 1048576
   VCID: 3620372B41B9C736E1-8062
Address 19: CAN Gateway        Labels: None
   Part No SW: 3W0 909 901     HW: 3W0 920 852 B
   Component: J533  GW-K-CAN TP20 6666
   Revision: KPH10V06
   Coding: DFFBFFFFEB551702
   VCID: 76A0F72B0139873621-8022
Address 23: Brake Booster        Labels: None
   Part No: 3W0 907 563 B
   Component: BREMSBOOSTER    007 0430
   Revision: 00007000    Serial number: 00000000034953
   VCID: 3A38231B71A1235605-806E
Address 28: HVAC, Rear (J524)       Labels: None
   Part No SW: 4W0 035 008 B    HW: 4W0 035 008 B
   Component: CLIMATE ECU   H07 0073
   Revision: P0H07004    Serial number: 51500285837001
   Coding: 00000002010102
   VCID: 2D12184770EF84EE90-8078
   Subsystem 1 - Part No SW: 4W0 907 042 A    HW: 4W0 907 042
   Component: RBM-BY621  H09 0055
   Serial number: WA121257000014398319
                    Fault Frequency: 15
                    Reset counter: 11
                    Fault Status: 00101110
                    Fault Frequency: 23
                    Reset counter: 10
                    Reset counter: 10
04047 - Charger for Remote Display and Operating Unit
                    Reset counter: 3
                    Mileage: 28114 km
                    Date: 2020.05.08
                    Time: 00:01:15
   Revision: A1001003    Serial number: 7670417346
   Coding: 030100
   VCID: 2B16165F4AFB8ADE8E-807E
Address 34: Level Control        Labels: None
   Part No: 4W0 907 553
   Component: LUFTFDR.-CDC- 3C3V0 7705
   Coding: 0005541
   VCID: 78BCF9130F2DF14633-802C
   Component: MEM-FS        H04 0700
   Revision: AA000000    Serial number: 00000158509610
   Coding: D0081F0085870090090001010101012100012727000000
   Shop #: WSC 00083 790 00236
Address 37: Navigation (J0506)       Labels: None
   Part No SW: 3W0 035 017 Q    HW: 3W0 035 017 Q
   Component: RNS-MID       H23 0584
   Revision: AB001001    Serial number: VWZ6Z7R0197078
   Coding: 04010002000000040000
   VCID: 3B36261FBA9B1A5E1E-806E
   Subsystem 1 - Part No: 3W0 919 859 BR
   Component: NAR V5  8112
Address 38: Roof Electronics        Labels: None
   Part No: 3W0 907 135 H
   Component: Dachmodul           0910
   Coding: 0020493
   VCID: 3B36261F7E9B1A5E1E-806E
Address 46: Central Conv.
Address 47: Sound System        Labels: None
   Part No SW: 4W0 035 465     HW: 4W0 035 465
   Component: DSP 10 Kanal        0010
   Revision: 00H08001    Serial number: 75824014706207
   VCID: 72A8CB3B6D519B160D-8026
Address 48: Seat, Rear, DS
Address 53: Parking Brake (J540)       Labels: None
   Part No SW: 4W0 907 801     HW: 4W0 907 801
   Component: EPB-4         H01 0002
   Revision: --------    Serial number: 00000000013308
   ASAM Dataset: EV_BY62XParkiBrake 001008
   ROD: EV_BY62XParkiBrake.rod
   VCID: 74A4CD23DF4595261F-8020
Address 56: Radio (J0506)       Labels: None
Address 5D: Operations
Address 65: Tire Pressure        Labels: Redir Fail!
   Part No SW: 3W7 907 273 E    HW: 3W7 907 273 E
   Component: J0502 RDK           0008
   Revision:   004008    Serial number: 00000600002550
   Coding: Long Coding
   VCID: 42C85BFB19716B965D-8016
Address 66: Seat, Rear (J877)       Labels: None
   Component: MEM-BFS-Fond  H04 0700
   Revision: AA000000    Serial number: 00000157363710
   Coding: C0081E8085810000090021000001000000002727000000
   Shop #: WSC 00083 790 00189
Address 68: Wiper Electr.        Labels: 3Wx-955-023.clb
   Part No: 3W5 955 023 M
   Component: Wischermodul       ª0401
   Shop #: WSC 00000 725 65552
   VCID: 44C45DE3036565A66F-8010
Address 6C: Back-up Cam.        Labels: None
   Part No SW: 4W0 907 441     HW: 4W0 907 441
   Revision: 00H13000    Serial number: 525 PA8JA60206
   Coding: 2020003
   VCID: 74A4CD23174595261F-8020
                    Fault Frequency: 18
                    Reset counter: 226
                    Mileage: 28116 km
                    Date: 2020.05.27
                    Time: 17:37:00
                        Reverse OFF
                    Count: 3
Address 6D: Trunk Elect. (----)       Labels:* None
   Part No SW: 4W0 959 107 A    HW: 4W0 959 107 A
   Component: HDSG-Modul    H05 0806
   Revision: 00000000    Serial number: 152500054
   Coding: 170206C120
   ASAM Dataset: EV_HDSGBY621 001002
   ROD: EV_HDSGBY621.rod
   VCID: 3B36261FB29B1A5E1E-806E
Address 71: Battery Charger (J367)       Labels:* None
   Part No SW: 3W3 915 181 B    HW: 3W3 915 181 B
   Component: EMM Batt Man  H05 0570
   Coding: 5E0100
   Shop #: WSC 00083 790 00211
   ASAM Dataset: EV_BatteChargVaria1 002019
   ROD: EV_BatteChargVaria1_002.rod
   VCID: 383C391383AD3146F3-806C
   Subsystem 1 - Part No SW: 8K0 915 181 C    HW: 8K0 915 181 C
   Component: J367-BDM  H07 0141
   Serial number: 22189B04001041377794
   Part No SW: 3W0 919 283 H    HW: 3W0 919 283 E
   Component: J446  ST Parkhilfe  0115
   Revision: 11H02001    Serial number: 58131519700495
   Coding: 0300066
01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 226
                    Mileage: 28116 km
                    Date: 2020.05.27
                    Time: 17:51:16
                    Temperature: 0.0°C
Address 77: Telephone (J412)       Labels:* None
   Part No SW: 3D0 035 730 E    HW: 3D0 035 730 E
   Component: Telefon       026 0983
   Revision: --------    Serial number: 35502105280954
   Coding: 020106010100010000000001
   ASAM Dataset: EV_UHVPremi 002709
   ROD: EV_UHVPremi.rod
   VCID: 1E70CF8B01496F7619-804A
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
ABS communicate , but it looks like not showing faulty codes , if they are not in data base of VCDS , it will show that message .
Did you drive car at all , or this is scan after you put new batteries.
If you did not drive car , I suggest drive around block , then clear all codes and post it here to see what will come back.
rich222
H11-028163
Try setting Bypass Can Init just incase it will only talk on the K line? Doubtful on a more recent car but worth a shot.
Dana
Western PA, USA
I switched your HEX-NET ending in serial number 56 (which is the one that was used in the above scan) to the Beta Channel so it can obtain a higher CB version the next time you use VCIConfig to update it. If the above suggestions do not help please try with the newer interface versions and let us know if there was any improvement.
DF390
CA, USA
C?ID=375585
Sorry for the late reply, it has been quite crazy with everything going on in our lives. We checked everything again and drove the car around the block, clear the code, re-scan, viola! All is well afterwards and customer is happy :)
Thanks again for everyone's help and Ross-Tech's exceptional customer service :thumbs:
