Audi a6 control module not coded
sufister
C?ID=275619
Hi guys esp warning light is on steering has gone heavy any help thx
Thursday,21,December,2017,16:25:47:31334
VCDS Version: 17.8.1.0
VIN: WAUZZZ4G6BN031409   License Plate: J4NU
Mileage: 120357km-74786mi   Repair Order:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 03 05 08 09 10 15 16 17 19 3B 42 44 46 52 53 5F 62 72
VIN: WAUZZZ4G6BN031409   Mileage: 120357km-74786miles
44-Steering Assist -- Status: Malfunction 0110
Address 01: Engine (J623-CGLC)       Labels:. 03L-906-018-CGL.clb
   Part No SW: 03L 906 018 LA    HW: 03L 906 018 JL
   Component: R4 2,0L EDC   H23 0756
   Revision: 45H23---
   Coding: 0A194012242401080000
   Shop #: WSC 02311 785 00200
   ASAM Dataset: EV_ECM20TDI01103L906018LA 003005
   ROD: EV_ECM20TDI01103L906018GT.rod
   VCID: 74E7ABC5DFC149E685-8020
          U1113 00 [047] - -
                    Fault Frequency: 7
                    Mileage: 119584 km
                    Date: 2017.12.18
                    Time: 18:09:00
                    Engine speed: 857.00 /min
                    Normed load value: 15.3 %
                    Coolant temperature: 84 °C
                    Intake air temperature: 8 °C
                    Voltage terminal 30: 12.120 V
                    Cruise Control System (CCS): switch position-Bit 0: 10000001
                    Cruise Control System (CCS): status-Bit 0: 00101100
                    Cruise control switch-off: irreversible-Bit 0: 11111111
                    Cruise control switch-off: reversible-Bit 0: 11111111
                    Engine control module reset status-Bit 0: 00000000
                    Engine control module reset status-Bit 8: 00000000
                    Cruise control switch-off: irreversible w. brake intervention-Bit 0: 00000000
          U1113 00 [047] - -
                    Fault Frequency: 7
                    Mileage: 119584 km
                    Date: 2017.12.18
                    Time: 18:09:00
   Part No SW: 4G0 907 379     HW: 4G0 907 379
   Component: ESP PREMIUM   H08 0190
   Coding: 06A087006005E1008B00
   ASAM Dataset: EV_ESPPremiAU57X 003013
   ROD: EV_ESPPremiAU57X_003.rod
   VCID: 6ED3B9ADB1ED633673-803A
0674 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 235
                    Mileage: 120357 km
                    Date: 2017.12.21
                    Time: 15:58:24
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 42
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: DA
                    Uz: BE
0469 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 235
                    Mileage: 120357 km
                    Date: 2017.12.21
                    Time: 15:58:24
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 42
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: DB
                    Uz: BE
0788 - Control Module Incorrectly Coded
          U1014 00 [137] - -
                    Reset counter: 235
                    Mileage: 120357 km
                    Date: 2017.12.21
                    Time: 16:16:44
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 0F
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 01
                    F-Type: AC
                    Uz: AD
   Part No SW: 4H0 907 064 AG    HW: 4H0 907 064 AG
   Component: BCM2 2.0      H24 0217
   Coding: 03B83000000000000000
   VCID: 6ED3B9ADB9ED633673-803A
   Serial number: 2311000097445005
   Part No SW: 4G0 820 043 G    HW: 4G0 820 043 G
   Component: KLIMA 2 ZONEN H10 0056
   Serial number: 04051100040164
   Coding: 34210008A0
   ASAM Dataset: EV_AirCondiBasisUDS 002033
   VCID: 234598992AAF9E5EAC-8076
   Part No SW: 4H0 907 063 H    HW: 4H0 907 063 A
   Component: BCM1 2.0      H12 0092
   Revision: 12012002    Serial number: 00000000894677
   Coding: 690000108034A7600405008000005F5F0F9D820827080101000004402000
   VCID: 2D517EA1746B582E0A-8078
   Component: WWS57X 110404  H35 0051
   Serial number:         110407090408
   Coding: 0045F7
   Component: RLS  H04 0003
   Serial number: 11417887
   Coding: 02512B
   Subsystem 3 - Part No SW: 4G0 941 531     HW: 4G0 941 531
   Component: E1 - LDS  H07 0044
   Serial number: 02 05 2011  00000195
   Component: Humidity_Sens  H02 0002
   Serial number: 7E3847A5000000000001
                    Fault Frequency: 22
                    Reset counter: 235
                    Mileage: 119527 km
                    Date: 2017.12.18
                    Time: 16:11:00
   Part No SW: 4H0 919 475 H    HW: 4H0 919 475 C
   Component: PARKHILFE ACC H07 0030
   Revision: 11001001    Serial number: 55901108101294
   Coding: 100205
   ASAM Dataset: EV_EPHVA18AU57X0000 001002
   ROD: EV_EPHVA18AU57X0000_001.rod
   VCID: 377D5CC98E37E2FE60-8062
Address 15: Airbags (J234)       Labels:| 4H0-959-655.clb
   Component: Airbag10.43   H40 0040
   Revision: --------    Serial number: 003JG002BFE.
   Coding: 30323436313230303235554A305234473053
   VCID: 366351CD893D1BF67B-8062
   Serial number: 3575HRB404V0H0LU50O$
   Serial number: 3585HRB405H0H0LUB12C
   Serial number: 3515JRB405R0H4DUJPLL
   Serial number: 3525JRB405F0G94441FK
   Serial number: 3554VRB40550GA464GVF
   Serial number: 3564VRB40550GA46797V
   Revision: 00000000    Serial number: 20110509000405
   Coding: 000014
   VCID: 306F67D5635935C621-8064
   Subsystem 1 - Part No SW: 4G0 951 528 D    HW: 4G0 951 528 D
   Component: E221 - MFL  H07 0009
Address 17: Instruments (J285)       Labels:| 4H0-920-xxx-17.clb
   Part No SW: 4G8 920 950 D    HW: 4G8 920 950 D
   Component: MDieGb        H29 0084
   Revision: 18420081    Serial number: 658150411593059
   Coding: 33A4080003012600010000
   ASAM Dataset: EV_RBC7KMID 004040
   ROD: EV_RBC7KMID.rod
   VCID: 306F67D56B5935C621-8064
16776978 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 235
                    Mileage: 119527 km
                    Date: 2017.12.18
                    Time: 16:10:58
   Part No SW: 4G0 907 468 B    HW: 4G0 907 468
   Component: J533--Gateway H08 0204
   Revision: --------    Serial number: 00000000138343
   Coding: 00CD074400
   ROD: EV_GatewUDS_AU57.rod
   VCID: 2F6D64A976672A3E38-807A
   Component: J367-BDM  H07 0140
   Serial number: 00000000005650364606
   Voltage stabilizer:
4906 - Power Steering Control Module
          U101D 00 [009] - No Communication
                    Reset counter: 235
                    Mileage: 119527 km
                    Date: 2017.12.18
                    Time: 16:10:58
                    Voltage terminal 30: 14.3 V
                    Voltage terminal 15: 14.5 V
                    Control Module temperature: 29 °C
                    System status: Terminal 15 on
                    Engine running: On
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
   Part No SW: 4G0 907 637     HW: 4G0 907 637
   Component: SARA 3D       H02 0004
   Revision: --------    Serial number: EJ1BPA32005LJ10
   ASAM Dataset: EV_SARA 006014
   ROD: EV_SARA_006.rod
   VCID: 6BD5B0B982FF961E54-803E
   Part No SW: 4G8 959 793 C    HW: 4G8 959 793 A
   Component: TSG FA        H04 0210
   Coding: 011C06204001620002080002
   Shop #: WSC 02312 785 00200
   VCID: 408F3715D3F9A546D1-8014
Address 44: Steering Assist
   Revision: 00002001    Serial number: 0147983071
   Coding: 011B062200B9044083200804000100000000000000000000000000000000
   Part No SW: 4G8 959 792 C    HW: 4G8 959 792 A
   Component: TSG BF        H04 0210
   VCID: 3F8D34E9AE07DABEA8-806A
   Revision: --------    Serial number: 00000000070455
   ROD: EV_ParkiBrake_AU57.rod
   VCID: 2A5B75BD4D854F16EF-807E
   Part No SW: 4G0 035 193 B    HW: 4G0 035 193 B
   Component: RMC Cnct Nav  H50 0647
   Coding: 0101000001415B47002B060301010000010000
   VCID: 224B9D9D3DB59756A7-8076
   Subsystem 1 - Part No SW: 4G0 919 603     HW: 4G0 919 603
   Component: DU6 Basic  H42 0084
   Serial number: 9464CS0B0032578
   Subsystem 2 - Part No SW: 4G2 919 615 K    HW: 4G2 919 615 K
   Component: E380 BDT C7  H08 0120
   Serial number: 90349KE500012
00862 - Antenna for GPS Navigation (R50/R52)
                    Reset counter: 234
                    Mileage: 119516 km
                    Date: 2017.12.18
                    Time: 14:38:58
   Part No SW: 4G8 959 795 C    HW: 4G8 959 795 A
   Component: TSG HL        H03 0210
   Coding: 010804204001620002080002
   VCID: 428B3D1DDDF5B756C7-8016
   Component: TSG HR        H03 0210
End-------------------------(Elapsed Time: 04:05)--------------------------
sufister
C?ID=275619
Hi is the abs control module coding correct
