Sticky Jacks Professional Problem Solver Guide. "JPPSG"
Sticky
Make / Model / Year / Edition.
Step 1 Tag of PR-Build data picture posted ( Last 6 of VIN can be omitted for privacy )
Step 2 Status of car stock or modified in any way? If so list!
Step 3 "VCDS" COMPLETE Auto-Scan in code tags!
Step 4 Describe recent repairs or services, problem at hand, & attempts at repair.
Step 5 Are parts OEM or AFT? If so, "what", and what origin?
Step 6 Identify specific issues to be addressed/concerned about, or say ALL.
Step 7 Now that you jumped through the first few hoops of fire, did you check the FUSES/Battery connections?
Good Information Guideline.
1 Focus discussion on symptom description!
2 Ask questions that clarify what, when, where, & frequency.
3 Summarize your understanding & get agreement in forum or from colleagues.
4 Explain what you will do to proceed, & get forum acknowledgement.
5 Do you have a proper repair manual? If not get one!
http://forums.ross-tech.com/showthread.php?5999-Where-do-I-get-a-Wiring-Diagram
6 Do you know how to read a schematic? If not see "How to read WD section" or link to Jef.
http://forums.ross-tech.com/showthr...ead-wiring-diagrams-the-videos-(final-version)
7 Check part numbers are accurate, & firmware versions of VCDS + respective controllers are of latest release.
8 Did you check CHARGING SYSTEM HEALTH, BATTERY & FUSES "YET"?
Diagnosing, Brain storming, & the Final Solution!
1 Describe problem ( List known symptoms ) Nix opinions or disguised solutions
2 Verify & Analyze ( Duplicate if possible, & list possible causes...... RTFB! the trouble tree, TSB's & for FOD )
Further..... FOD of hardware, & or electronically modified firmware/software/emissions defeat/delete devices is essential now...... do not negate this! Look for any discrepancies in codification when compared to other modules. Actually review Time Stamps Miles and the information made available in a DTC, such as a G or N destinations and use as a search in WD.
3 Locate the problem ( Prioritize and identify work times + safety limits, the use of chemicals or tool requirements )
4 Repair the Problem ( Determine the cause & not just treat an effect )
5 Conduct a quality Check of your work and verify you fixed it!
Always follow up reporting back to the Forum to help the next guy.
IF ANY OF THE ABOVE IS TOO MUCH TO COMPLY WITH, YOU SHOULD CONSIDER SEEKING A PROFESSIONAL SHOP VISIT.
Zenerdiode
Newcastle, England
C?ID=24330
...and your fee schedule? :)
Naa, Jack like many others, gives of his knowledge for free. Truly free as he asks for nothing in return. The only thing I'd like to ask in return; is when you [eventually] find the fault or solution to your problem, please close the thread with a follow-up post. I hate to be left han...
Please add to list for no starts.......
In no start situation's............
Is vehicle actually cranking verse cranking and not starting.......?
Is vehicle cranking and does it have fuel or spark missing, compression or obstructed intake or exhaust with a no start......?
rayms69
idaho
C?ID=197413
I use only audi parts, audi manuals, VCDS. Why are you trying to bust my head with all the acronyms?! I will check the fuses and yes I know how to read a wiring diagram, pictures help. PR?
PPP
Sketchy
Cambodia
C?ID=242293
I think Jack got the point.
Rule amendment..........
If car is outside warranty and you are doing a repair/diagnosis.
Read codes via auto-scan and archive from JPPSG rule 3
Advanced users!
Read 0x08-000>255 block value adaptions, to see where the thresholds are, during last DCY & reference last learned value...... log them/archive.
Example 0x01-08-034 what's 3'rd field say of OXS..........or trims or CAT amplitude etc. etc..
Clear codes see what immediately comes back/address them if needed..... if clear....... do the reset of all adaptions ..........then commence readiness tests for two DCY's.
NostraJackAss Has Spoken!
Rule amendment..........JPPSG
Anytime doing and auto-scan, an additional scan should be done of the OBD2 mode with VCDS.
This is done for comparison of the data reported on the proprietary side or lack there of.
Additionally this helps cross check errors in the ECU diagnostic stack for FOD, Firmware revision, and helps to possibly debug VCDS if an inconsistency issue should arise.
Do your part and join the collective........."resistance is futile!"
Rule amendment..........JPPSG!
Always verify that your VCDS tester has been configured in the VCDS configuration screen....... for WSC number, tester number and importer number.
If this key basic is not checked, a module may not accept a coding & which is valid.
Additionally if this function is not checked, it could cause a disruption for defaulting a control module in adaption or other security access requirements.
Be sure to do it.......
In general annoyance this week for JPPSG protocol failure, I have an analogy from a childhood show I really aligned myself with.
Let me be clear here ........."I have four pyramids" which is a superior hand to three pyramids.
The "JPPSG" "Use Case guide" is here to help you.
If you feel that your hand of three pyramids is superior to four pyramids I will never be able to help you and it will only disappoint me.
Please see the clip below and picture me as the dumb Cylon & which dies in the end before it's too late but falls on his sword to try and help you with his last final act.
In some cases the index code number listed after the fault code may aid in the diagnosis path.
Below is a list of current index numbers and the meaning of each:
XXXXX-
001
Upper Limit exceeded
XXXXX-
002
Lower Limit exceeded
XXXXX-
003
Mechanical Fault
XXXXX-
004
No signal/communication
XXXXX-
005
no or wrong basic
settings/adaptation
XXXXX-
006
short to B+ (loss of ground)
XXXXX-
007
Short to Ground
XXXXX-
008
Implausible signal
XXXXX-
009
open/short to ground
XXXXX-
010
open/short to B+
XXXXX-
011
Open circuit
XXXXX-
012
electrical fault in circuit
XXXXX-
013
check fault memory
XXXXX-
014
Defective (faulty)
XXXXX-
015
Cannot be checked at the moment
Contact
Meaning
Old terminal designition[SUP][1][/SUP]
[TR]
[TH="colspan: 3"]Ignition system
[/TH]
[/TR]
[TR]
[TD]1
[/TD]
[TD]ignition coil, distributor, low voltage
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]1a, 1b
[/TD]
[TD]distributor with two separate circuits
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]2
[/TD]
[TD]breaker points magneto ignition
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]4
[/TD]
[TD]coil, distributor, high voltage
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]4a, 4b
[/TD]
[TD]distributor with two separate circuits, high voltage
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]7
[/TD]
[TD]terminal on ballast resistor, to distributor
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]15
[/TD]
[TD]battery+ from ignition switch
[/TD]
[TD]16
[/TD]
[/TR]
[TR]
[TD]15a
[/TD]
[TD]from ballast resistor to coil and starter motor
[/TD]
[TD]16
[/TD]
[/TR]
[TR]
[TH="colspan: 3"]Preheat (Diesel engines)
[/TH]
[/TR]
[TR]
[TD]15
[/TD]
[TD]preheat in
[/TD]
[TD]+
[/TD]
[/TR]
[TR]
[TD]17
[/TD]
[TD]start
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]19
[/TD]
[TD]preheat (glow)
[/TD]
[TD][/TD]
[/TR]
[TR]
[TH="colspan: 3"]Starter
[/TH]
[/TR]
[TR]
[TD]45
[/TD]
[TD]starter relay
[/TD]
[TD]30f, 30h
[/TD]
[/TR]
[TR]
[TD]45a
[/TD]
[TD]starter 1 output
[/TD]
[TD]30h, 30h I
[/TD]
[/TR]
[TR]
[TD]45b
[/TD]
[TD]starter 2 output
[/TD]
[TD]30h II
[/TD]
[/TR]
[TR]
[TD]50
[/TD]
[TD]starter control
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]50a
[/TD]
[TD]starter control
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]50b
[/TD]
[TD]starter control
[/TD]
[TD]50
[/TD]
[/TR]
[TR]
[TD]50c
[/TD]
[TD]starter control
[/TD]
[TD]50 II
[/TD]
[/TR]
[TR]
[TD]50d
[/TD]
[TD]starter control
[/TD]
[TD]50b, 50k
[/TD]
[/TR]
[TR]
[TD]50e
[/TD]
[TD]starter control
[/TD]
[TD]50a
[/TD]
[/TR]
[TR]
[TD]50f
[/TD]
[TD]starter control
[/TD]
[TD]50
[/TD]
[/TR]
[TR]
[TD]50g
[/TD]
[TD]starter control
[/TD]
[TD]50a
[/TD]
[/TR]
[TR]
[TD]50h
[/TD]
[TD]starter control
[/TD]
[TD]50
[/TD]
[/TR]
[TR]
[TH="colspan: 3"]Battery
[/TH]
[/TR]
[TR]
[TD]15
[/TD]
[TD]battery+ through ignition switch
[/TD]
[TD]16, 54/15
[/TD]
[/TR]
[TR]
[TD]30
[/TD]
[TD]from battery+ direct
[/TD]
[TD]30/51
[/TD]
[/TR]
[TR]
[TD]30a
[/TD]
[TD]from 2nd battery and 12/24 V relay
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]31
[/TD]
[TD]return to battery- or direct to ground
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]31a
[/TD]
[TD]return to battery- 12/24 V relay
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]31b
[/TD]
[TD]return to battery- or ground through switch
[/TD]
[TD]85d
[/TD]
[/TR]
[TR]
[TD]31c
[/TD]
[/TD]
[TD]31, 31a
[/TD]
[/TR]
[TR]
[TH="colspan: 3"]Electric motors
[/TH]
[/TR]
[TR]
[TD]32
[/TD]
[TD]return
[/TD]
[TD]31
[/TD]
[/TR]
[TR]
[TD]33
[/TD]
[TD]main terminal (swap of 32 and 33 is possible)
[/TD]
[TD]30
[/TD]
[/TR]
[TR]
[TD]33a
[/TD]
[TD]limit
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]33b
[/TD]
[TD]field
[/TD]
[TD]54e
[/TD]
[/TR]
[TR]
[TD]33f
[/TD]
[TD]2. slow rpm
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]33g
[/TD]
[TD]3. slow rpm
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]33h
[/TD]
[TD]4. slow rpm
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]33L
[/TD]
[TD]rotation left
[/TD]
[TD]30L
[/TD]
[/TR]
[TR]
[TD]33R
[/TD]
[TD]rotation right
[/TD]
[TD]30R
[/TD]
[/TR]
[TR]
[TH="colspan: 3"]Turn indicators
[/TH]
[/TR]
[TR]
[TD]49
[/TD]
[TD]flasher unit in
[/TD]
[TD]15, 15+, 15/54, +, +15
[/TD]
[/TR]
[TR]
[TD]49a
[/TD]
[TD]flasher unit out, indicator switch in
[/TD]
[TD]54L, S, S4
[/TD]
[/TR]
[TR]
[TD]49b
[/TD]
[TD]out 2. flasher circuit
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]49c
[/TD]
[TD]out 3. flasher circuit
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]C
[/TD]
[TD]1st flasher indicator light
[/TD]
[TD]K, K1, P
[/TD]
[/TR]
[TR]
[TD]C2
[/TD]
[TD]2nd flasher indicator light
[/TD]
[TD]K1, K2, K3, K4
[/TD]
[/TR]
[TR]
[TD]C3
[/TD]
[TD]3rd flasher indicator light
[/TD]
[TD]K3, K4
[/TD]
[/TR]
[TR]
[TD]L
[/TD]
[TD]indicator lights left
[/TD]
[TD]HL, L54, VL
[/TD]
[/TR]
[TR]
[TD]R
[/TD]
[TD]indicator lights right
[/TD]
[TD]HR, R54, VR
[/TD]
[/TR]
[TR]
[TD]L54
[/TD]
[TD]lights out, left
[/TD]
[TD]SBL
[/TD]
[/TR]
[TR]
[TD]R54
[/TD]
[TD]lights out, right
[/TD]
[TD]SBR
[/TD]
[/TR]
[TR]
[TH="colspan: 3"]AC generator
[/TH]
[/TR]
[TR]
[TD]51
[/TD]
[TD]DC at rectifiers
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]51e
[/TD]
[TD]as 51, with choke coil
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]59
[/TD]
[TD]AC out, rectifier in, light switch
[/TD]
[TD]51, 51-, 51a
[/TD]
[/TR]
[TR]
[TD]59a
[/TD]
[TD]charge, rotor out
[/TD]
[TD]59
[/TD]
[/TR]
[TR]
[TD]64
[/TD]
[TD]generator control light
[/TD]
[TD][/TD]
[/TR]
[TR]
[TH="colspan: 3"]Generator, voltage regulator
[/TH]
[/TR]
[TR]
[TD]61
[/TD]
[TD]charge indicator (charge control light)
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]B+
[/TD]
[TD]battery +
[/TD]
[TD]51, 51B+, B+30, B+51
[/TD]
[/TR]
[TR]
[TD]B-
[/TD]
[TD]battery -
[/TD]
[TD]31B-
[/TD]
[/TR]
[TR]
[TD]D+
[/TD]
[TD]dynamo/alternator diode+
[/TD]
[TD]D+/61
[/TD]
[/TR]
[TR]
[TD]D-
[/TD]
[TD]dynamo/alternator diode-
[/TD]
[TD]D-/61
[/TD]
[/TR]
[TR]
[TD]DF
[/TD]
[TD]dynamo field
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]DF1
[/TD]
[TD]dynamo field 1
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]DF2
[/TD]
[TD]dynamo field 2
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]U, V, W
[/TD]
[TD]AC three phase terminals
[/TD]
[TD][/TD]
[/TR]
[TR]
[TH="colspan: 3"]Lights
[/TH]
[/TR]
[TR]
[TD]54
[/TD]
[TD]brake lights
[/TD]
[TD]15/54,
[/TD]
[/TR]
[TR]
[TD]54g
[/TD]
[TD]lights
[/TD]
[TD]54
[/TD]
[/TR]
[TR]
[TD]55
[/TD]
[TD]fog light
[/TD]
[TD]N
[/TD]
[/TR]
[TR]
[TD]56
[/TD]
[TD]spot light
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]56a
[/TD]
[TD]headlamp high beam and indicator light
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]56b
[/TD]
[TD]low beam
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]56d
[/TD]
[TD]signal flash
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]57
[/TD]
[TD]parking lights
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]57a
[/TD]
[TD]parking lights
[/TD]
[TD]P
[/TD]
[/TR]
[TR]
[TD]57L
[/TD]
[TD]parking lights left
[/TD]
[TD]PL
[/TD]
[/TR]
[TR]
[TD]57R
[/TD]
[TD]parking lights right
[/TD]
[TD]PR
[/TD]
[/TR]
[TR]
[TD]58
[/TD]
[TD]licence plate lights, instrument panel
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]58d
[/TD]
[TD]panel light dimmer
[/TD]
[TD]58b
[/TD]
[/TR]
[TR]
[TD]58L
[/TD]
[TD]parking light
[/TD]
[TD]58
[/TD]
[/TR]
[TR]
[TD]58R
[/TD]
[TD]parking light
[/TD]
[TD]58
[/TD]
[/TR]
[TR]
[TH="colspan: 3"]Window wiper/washer
[/TH]
[/TR]
[TR]
[TD]53
[/TD]
[TD]wiper motor + in
[/TD]
[TD]1, 3, 54d, S
[/TD]
[/TR]
[TR]
[TD]53a
[/TD]
[TD]limit stop +
[/TD]
[TD]54, +2
[/TD]
[/TR]
[TR]
[TD]53b
[/TD]
[TD]limit stop field
[/TD]
[TD]3, 54e
[/TD]
[/TR]
[TR]
[TD]53c
[/TD]
[TD]washer pump
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]53e
[/TD]
[TD]stop field
[/TD]
[TD]1, 2
[/TD]
[/TR]
[TR]
[TD]53i
[/TD]
[TD]wiper motor with permanent magnet, third brush for high speed
[/TD]
[TD][/TD]
[/TR]
[TR]
[TH="colspan: 3"]Acoustic warning
[/TH]
[/TR]
[TR]
[TD]71
[/TD]
[TD]beeper in
[/TD]
[TD]H
[/TD]
[/TR]
[TR]
[TD]71a
[/TD]
[TD]beeper out, low
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]71b
[/TD]
[TD]beeper out, high
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]72
[/TD]
[TD]hazard lights switch
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]85c
[/TD]
[TD]hazard sound on
[/TD]
[TD][/TD]
[/TR]
[TR]
[TH="colspan: 3"]Switches
[/TH]
[/TR]
[TR]
[TD]81
[/TD]
[TD]opener
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]81a
[/TD]
[TD]1 out
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]81b
[/TD]
[TD]2 out
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]82
[/TD]
[TD]lock in
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]82a
[/TD]
[TD]1st out
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]82b
[/TD]
[TD]2nd out
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]82z
[/TD]
[TD]1st in
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]82y
[/TD]
[TD]2nd in
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]83
[/TD]
[TD]multi position switch, in
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]83a
[/TD]
[TD]out position 1
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]83b
[/TD]
[TD]out position 2
[/TD]
[TD][/TD]
[/TR]
[TR]
[TH="colspan: 3"]Relay
[/TH]
[/TR]
[TR]
[TD]85
[/TD]
[TD]relay coil -
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]86
[/TD]
[TD]relay coil +
[/TD]
[TD][/TD]
[/TR]
[TR]
[TH="colspan: 3"]Relay contacts
[/TH]
[/TR]
[TR]
[TD]87
[/TD]
[TD]common contact
[/TD]
[TD]30/51
[/TD]
[/TR]
[TR]
[TD]87a
[/TD]
[TD]normally closed contact
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]87b
[/TD]
[TD]normally open contact
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]88
[/TD]
[TD]common contact 2
[/TD]
[TD]30/51 (relay)
[/TD]
[/TR]
[TR]
[TD]88a
[/TD]
[TD]normally closed contact 2
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]88b
[/TD]
[TD]normally open contact 2
[/TD]
[TD][/TD]
[/TR]
[TR]
[TH="colspan: 3"]Additional
[/TH]
[/TR]
[TR]
[TD]52
[/TD]
[TD]signal from trailer
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]54g
[/TD]
[TD]magnetic valves for trailer brakes
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]75
[/TD]
[TD]radio, cigarette lighter
[/TD]
[TD]R
[/TD]
[/TR]
[TR]
[TD]77
[/TD]
[TD]door valves control
[/TD]
[/TR]
The above attachment is a great explanation of tables and WD in use to train oneself............
Readiness code, creating 96 > 1999 ABA AAA
Don't skip work steps!
http://forums.ross-tech.com/showthread.php?3147-What-is-Jack-talking-about-0x01-08-000
Note for vehicles all M.Y. 96>99!
If using the procedure to verify a repair, go to the appropriate work step and verify that
repair but, if creating a readiness code from scratch, follow the work steps in sequence and do not
switch the ignition off until the sequence has been completed.
Note:
If a particular bit that you are watching in the Readiness code is obtained sooner than
the time specified in the procedure, you can immediately proceed to the next work step.
An "x" in the diagnostic status means the display can be either a "0" or a "1"
There must not be a malfunction stored in DTC memory and there must not be any
malfunctions detected during diagnostic test!
Work Step 1 compounded work procedure!
Hook up VCDS and with ignition ON "not running", check for DTC's and even if none present, erase DTC's after doing an Output diagnostic test mode. Do this to at least hear the SAI pump or combi & N80 EVAP solenoid click!
0x01-03 > GO
These steps will ensure clearing the EEPROM.
0x01-02-05
Now recode the model with an alternate WSC, other than what is present & be sure your VCDS is configured for WSC Importer # and Tester #..... You with me so far?
0x01-07-SAME codification data and your new WSC should be displayed in main ID of 0x01 follow it up being observed!
0x01-10-00 SAVE clear all ADP data!
KEY off 1 minute and wait!
Step 2
Open hood and observe the throttle cable is set correctly & for full basic setting sweep offset and that the TV is clean + Lubricated
You with me so far? Now check the battery health or at very least assist with battery charger if under 12.5 after 15 minutes static on the stop watch during your aforementioned TV clean up!
Check the SAI fuse condition by the battery because it always gets corroded!
Now get your ass back in the car turn Ignition ON "engine not running" check DTC's.
0x01-02 >No codes proceed stupid!
0x01-04-098 ADP TV
Wait stupid & until the TV stops buzzing!
Turn off the key for 1 minute to ensure a saved consistent EEPROM.
Step 3
Turn Key ON again, "engine not running" yet and scan for DTC's
0x01-02 NONE GOOD >
Now check the TV status in blocks.
0x01-08-098 ADP-OK 4TH field >
Now check the battery voltage
0x01-08-004 and if OK start engine let idle.
0x01-04-000 Basics ON initiated 1 minute at idle.
Shared bit for EVAP and LDP so pay attention!
At idle Immediately switch to LDP test if supported at 0x01-04-153 ON > Wait for Binary display XXXXX100 If a 1 is indicated in last binary location you have a DTC so stop and go fix it!
0x01-04-150 EVAP XXXXX100 Good proceed > or same as aforementioned in LDP
Step 4
Prepare for short slow road test in second gear and the following queried.
Do this at 2000 RPM and up to 3500 and get the 1 to be there for 1 minute during steady RPM to achieve the below binary result.
0x01-08-103
Field 4 xx1x xx00 <<<<<<<<<<<<<< The one is what you are looking for to indicate the OXS control has become active.
Be advised you are to be in blocks 08, not 04 basic settings when doing this observation test!
Once achieved OXS control pull over and idle for 30 seconds before commencing next step!
Step 5
SAI Command
0x1-04-160 at idle.
Result should be : XX11X100
Step 6
TWC Aging using OXS control.
Again road test in second gear and limit steady speed to RPM value for 2 minutes @ 2100-2400 RPM range.
0x01-04-103
This time yes we are in basic settings, very good for realizing & FYI the book is wrong asking for blocks again!
Your catching on.........now they are dumbass's and you are matriculating in the school of hard NOX.
Now after you have the binary XX1XXX00 and a temp in field 3 of 360 Celsius or better pull over!
Not driving parked idling switch to 0x01-04-131 ON and more aging the OXS test commences.
Result XXXXX100
Note:
Avoid deceleration fuel cut-off during this diagnostic test. It causes the three way catalytic
converter to store oxygen, diagnostic test will then be blocked for at least 10 seconds
Step 7
OXS adaption mean value!
0x01-04-125
Okay back on the road second gear again and RPM range 2000-4000 RPM until binary until shows 01X1XXXX
Now stop again and pull over to let it idle with basics still active & binary should complete XXXXX100
Note:
converter to store oxygen, diagnostic test will then be blocked for at least 10 seconds.
Step 8
Car parked.
The slope 0x01-04-130 at 2200-2800 RPM & in less than 15 seconds should be at least 0-4 in field 3
XXXXX100
Step 9
Car Parked.
CAT test 0x01-04-136
RPM range 2500-4500 observe the amplitude in field 3 and temp in field 2 must be above 360 C
before starting this test.
I recommend running the car at 3000 RPM steady for 1 minute before engaging this test!
Step 10
Throttle test......offset and lift after acceleration.
Road test again using second gear RPM value 3200-4000 RPM for 15 seconds!
0x01-04-180
XXXXX100
Step 11
Parked!
Knock sensor amplification factor.
2500 RPM steady.
0x01-04-145 Field 3 should count to about 5-6 7 max
XXXXX100
Step 12
Parked!
OXS heaters 0x01-04-115
RPM 2100-2800 range to initiate test steady throttle
XXXXX100
Step 13
Parked!
OXS after CAT
0x01-04-116
XXXXX100
Step 14
Parked!
OXS heating before TWC
0x01-04-120 & 121
XXXXX100
Step 15
Parked!
0x01-04-140, 141, 142 at idle in each for at least 1 minute each!
Step 16
0x01-15- 00000000
You should be a READY winner & no longer a readiness loser .......Congratulations! :D
Codes [login-11] ou [security access-16]
[0x01]
- 26231 - V6 2.5 AFB/AKN
- 26242 - V6 2.5 AFB, AKE
- 26261 - V6 2.5 AFB AKE
- 26262 - V6 2.5 TDI AFB
- 26281 -
- 22158 - R5 2.5 TDI AAT
- 24262 - V6 2.5 AFB
- 40168 - Passat ,AYH
- 01283 - 2,0 MPI (ABA)
- 12233 - TDI 4 cylinders 1Z, AHU, AHH, AFN, ALH, ASV, AXR, ASZ ,ATD...
- 02879 - 2,5 4VT EDC
- 35342- V6 2,5L type BDG (Passat Break 3BG de 2004) Manuel Trans
- 35341- V6 2,5L type BDG (Passat Break 3BG de 2004) Auto Trans
EDC15/16
- 10000 - Fuel Cooling Activation
- 10001 - Deactivation of fuel cooling
- 10008 - learning FMA card remove
- 10011 - EGR off next cycle or DCY
- 10012 -
- 10013 -
- 10014 -
- 10015 -
- 10016 - DPF GEN CR- 10019 -
- 10111 - Remove Commercial carrier code
- 11463 - 1.9 tdi BKC,APH, (activation Cruise Control)
- 13681 - Adjust Odometer
- 11971 - Clients désactiver HGB (Dodierung II) (ajuster HGB Logement 2 canal 14)
- 13265 - Activate fuel pump prime for lift
- 13625 - Enable oil pump 01q 11q 13625 04q 024q or 01q 11q 04q 035q
- 13377 -
- 13647 -
- 16167 - GRA Disable
- 16360 - AGR Coding 2 Disable Next DCY
- 19676 -
- 20973 - Disable HGB (AP18)
- 21295 - REGEN DPF & PD Access Calibration
- 22433 - Disable AVS
- 22466 - Activate AVS
- 22764 - AGR OFF Next DCY
- 27833 -
- 28575 - Disable Commercial carrier code (AP07)
- 30475 - Reset modification Airbag Touareg AYH
- 30579 -
- 30605 - Adapt DPS
- 31111 -
- 31564 - AYH (groupe 34 test et recalibrage suspension pneumatique)
- 50904 -
- 22158 - Adapt Timing chain adjuster AEL
- 26231- EGR ON Next DCY 2,5L AKN
- 26262 - Adaption access 3/3
- 13647 -
EDC17
- 12233 - Code Access Security CAN TP 1.6 2.0 UDS, TDI 4 cylindres 1Z, AHU, AHH, AFN, ALH, ASV, AXR,
ASZ...
- 27971 -
ME7 Logins
- 07825 -
- 01283 -
- 11500 - Default control unit BASELINE
- 11223 -
- 11463 - Pour les calculateurs P/N : 038 906 012 CP (1,9 R4 EDC 0764SG 2839) 19 TDi BKC code(s)
moteur(s) AGR,
- 11501 -
- 12233 - ATD (1,9 100ch injecteur pompe) EEProm Login
- 33162 - Development Access (1.8T )& -45678-
- 34855 -
- 45678 -
- 50000 - HOT Climate OFF
- 60000 - HOT Climate ON
- 60301 - FAN 1 CONTROL ON
- 60302 - FAN 2 CONTROL ON
- 60303 - FAN 3 CONTROL ON
- 10011 - FS Golf Login SAC 1,6
Larry Manton
C?ID=112505
Jack, great point about scan on the OBD2 side also, not totally sure of the concept but infered a double check to see if everyone is playing fair, but a great point, thanks.
Larimore.
