5211 - Fuel Rail/System Pressure Too Low
Znippie
Norway
C?ID=328489
Hello!
I tried to search in the forums for a thread but could not find any relevant for my issue
I also have a couple of questions regarding my troubleshooting
According to RossTech Wiki P0087 there are several solutions for this faultcode.
The HPFP was replaced last month, and the fuelfilter was replaced yesterday.
The old HPFP pump was inspected for metal shavings, nothing to be found.
I can read from the rosstech wiki that
"When found in Audi Common Rail V6, V8 and V12 TDI engines, please see TPI 2020693 for Contaminated fuel found in fuel system concerns. After mechanical all repairs are made N276 may need to be adapted and the EDC may need to be flash updated on the Audi Dealer level. When a dealer level update applies SVM code 01A036 is used."
Im not sure if the new pump was adapted, nor am I sure if this needs to be done.
I have tried to log IDE00188 -- Fuel high pressure; actual value and IDE00201 -- High fuel pressure; specified value, but as you can see in the faultcode in the full scan, the actual value differences aprox 200bar from the specified value at the time it throws the fault code.
Is there any way I can use this method belowto check for pressure leak in the fuel system, or is this for gasoline cars only? I tried to follow those steps but the actual fuel pressure value is not moving when the engine is off (and ignition on)
Is there also any way to log or test the lift pump inside the dieseltank?
Last question is regarding the VC scope, im not so familiar with that.
Why wont the green line scale like the red one? I notice that it says "100" top left corner, but I cant change that. I have also tried to type in dozens of different values in the "vertical scale min/max" bottom right corner, but its only the red line that changes. What am I doing wrong?
Wednesday,25,March,2020,20:25:15:21245
VCDS Version: 19.6.2.0 (x64)  HEX-NET CB: 0.4513.4
VIN: WAUZZZ4L9DD009457   License Plate: JIMETTER
Mileage: 184060km-114369mi   Repair Order:
Chassis Type: 4L-AU56 (4F0)
Scan: 01 02 03 05 08 09 10 15 16 17 18 19 20 28 34 42 46 4C 4F 52
          55 56 5F 62 69 6D 6F 72
VIN: WAUZZZ4L9DD009457   Mileage: 184060km-114369miles
Address 01: Engine (J623-CRCA)       Labels:. 059-907-401-V2.clb
   Part No SW: 4L2 910 401 B    HW: 4L0 907 401 C
   Component: 3.0TDI EDC17  H39 0001
   Revision: 53H39---    Serial number:
   Coding: 2A2A401A253601020000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_ECM30TDI0114L2910401B 001001
   ROD: EV_ECM30TDI0114L1910401H.rod
   VCID: A306830BAA8785571A-80F6
          P0087 00 [167] - Too Low
                    Mileage: 184064 km
                    Date: 2020.03.25
                    Time: 20:18:26
                    Engine speed: 2948.00 /min
                    Normed load value: 99.2 %
                    Vehicle speed: 122 km/h
                    Coolant temperature: 71 °C
                    Intake air temperature: 11 °C
                    Voltage terminal 30: 14.720 V
                    Unlearning counter according OBD: 80
                    Fuel temperature: 10.1 °C
                    Mean injection quantity: 68.85 mg/stroke
                    Rail pressure regulation: status-Bits 0-7: 5
                    Fuel high pressure: actual value: 1.7754e+006 hPa
                    High fuel pressure: specified value: 1.963e+006 hPa
                    Pressure control valve adaptation factor: 1.1549
                    Fuel level: 98.00 l
   Part No SW: 0C8 927 750 AL    HW: 0C8 927 750 AL
   Component: AL1000 AISIN  001 2096
   Coding: 001578
   Shop #: WSC 26176 001 1048576
   ROD: EV_TCMAL991031_002.rod
   VCID: F6A08A5F499540FF0D-80A2
   Revision: 00H02001
   Coding: 2200673
   VCID: B4247057D76912EFF3-80E0
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 H
   Component: FBSAUDIC6 ELV   H08 0200
   Revision: 00H08000    Serial number: 10603702012499
   Coding: 0000131
   VCID: A5029D136CB37B6774-80F0
   Subsystem 1 - Part No: 4F0 910 132 E
   Component: FBSAUDIC6 EZS   H04 0020
   Component: FBSAUDIC6 IDG   H01 0054
   Part No SW: 4L0 910 043 D    HW: 4L0 820 043 AH
   Revision: 00---026    Serial number: 00000030251205
   Coding: 01029816
   VCID: A5029D13ACB37B6774-80F0
   Part No SW: 4F0 910 279 AH    HW: 4F0 907 279 D
   Component: ILM Fahrer      H31 0400
   Coding: 0023221
   VCID: EFAEBF3BFECF7137CE-80BA
   Component: Wischer AU716   H18 0110
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
Address 10: Park/Steer Assist (J446)       Labels:| 4L0-919-475-7X2.clb
   Part No SW: 4L0 919 475 A    HW: 4H0 919 475 C
   Component: PARKHILFE 8K  H07 0011
   Revision: 11001001    Serial number: 55901218700352
   Coding: 05031F
   ASAM Dataset: EV_EPHVA18AU7160000 001001
   ROD: EV_EPHVA18AU7160000.rod
   VCID: B42470571F6912EFF3-80E0
   Part No SW: 4L0 910 655 D    HW: 4L0 959 655 C
   Component: 70 AIRBAG AUDI8RH43 0230
   Revision: 04H43000    Serial number: 00399D09G40K
   Coding: 0014128
   VCID: AE10623F3945383F85-80FA
   Subsystem 1 - Serial number: 6332QSME001B32462
   Subsystem 2 - Serial number: 6342QSME181C1B46K
   Subsystem 3 - Serial number: 6352QSME7D1A4B60T
   Subsystem 4 - Serial number: 6362QSME001B194EI
   Subsystem 5 - Serial number: 63734SME0A17245E1
   Subsystem 6 - Serial number: 63834SME4A182C769
   Part No SW: 4F0 910 549 B    HW: 4F0 953 549 E
   Component: J0527               0830
   Revision: 00H08000    Serial number: 90055121490111
   Coding: 0002142
   VCID: A81C94271BA1660F4F-80FC
   Component: E0221           H03 0030
   Part No SW: 4L0 920 933 H    HW: 4L0 920 933 H
   Component: KOMBIINSTR.   H35 0316
   Revision: 00000000    Serial number: NGA22KR7D
   Coding: 1356630401010008000004
   VCID: B228764FED7D1CDFE1-80E6
Address 18: Aux. Heat        Labels: 4L0-910-105.lbl
   Part No SW: 4L0 910 105     HW: 4L0 265 105 P
   Component: Heizgeraet      H09 0140
   Revision: 0000000C    Serial number: 00000009021078
   Coding: 0000101
   VCID: E08CCC073311DE4F47-80B4
   Part No SW: 4F0 907 468 S    HW: 4F0 907 468 G
   Component: GW-BEM 5CAN-M H06 0058
   Revision: MB700037    Serial number: 3700M127130103
   Coding: 00CF07
   VCID: BFCE2F7B2E2FC1B71E-80EA
   Component: J367-BDM  H07 0125
   Serial number: 00000000002790776793
   Serial number: 12195000141011200181
   Part No SW: 4F0 857 511 K    HW: 4F0 857 511 K
   Revision: AA001002
   Coding: 02019064747464545425363E
   VCID: B02C7C47E3712ECF97-80E4
   Part No SW: 4L0 910 158     HW: 4L0 919 158 AA
   Revision: 00---010    Serial number: 00000030251691
   Coding: 0000006
   VCID: E89CD427DB21A60F8F-80BC
Address 34: Level Control        Labels: 4L0-910-553.lbl
   Part No SW: 4L0 910 553 L    HW: 4L0 907 553 E
   Component: LUFTFDR.-CDC    H04 7890
   Revision: --H04001    Serial number: 15.1528-0194.2
   Coding: 0015520
   Shop #: WSC 12515 002 1048576
   VCID: B326734BD26715D7EA-80E6
   Component: TSG FA        H12 0362
   Revision:             Serial number: 0000034509798
   Coding: 011C02205040440004
   VCID: C8DC34A77BE1860FAF-809C
   Part No SW: 4L0 910 289 K    HW: 4L0 907 289 K
   Component: Komfortgeraet   H12 0130
   Revision: 0130 ---    Serial number: 01793982550000
   Coding: 3277189
   VCID: B83C4467CB01F68FDF-80EC
   Part No SW: 4F0 910 274 B    HW: 4F0 907 274
   Component: J793  RKA+      H04 0110
   Revision: 00000519    Serial number: 00005190187276
   Coding: 0758729
   VCID: A306830B628785571A-80F6
   Part No SW: 4F0 910 280     HW: 4F0 907 280
   Component: ILM Beifahrer   H16 0100
   Revision:             Serial number: 00000000648413
   Coding: 0011001
   VCID: DEF0F2FF0965E8BF75-808A
   Component: TSG BF        H12 0362
   Revision:             Serial number: 0000034534144
   VCID: C7DE379B76FF8977A6-8092
   Component: ****LWR12**** H02 0012
   Serial number: 120718-0002-095
   Coding: 11476F1010020500
   ROD: EV_HeadlRegulBasic.rod
   VCID: C2C8268F55DDAC5F71-8096
   Part No SW: 4G0 035 056 E    HW: 4G0 035 056
   Component: Radio U STD   H60 0093
   Revision: AB001007    Serial number: 230G/0C2566939
   Coding: 010003020100000000
   VCID: A306830BA28785571A-80F6
            007 - Short to Ground
                    Fault Status: 01100111
                    Reset counter: 241
                    Mileage: 184063 km
                    Date: 2020.03.25
                    Time: 20:13:33
                    Voltage: 15.00 V
   Part No SW: 4L2 035 666 E    HW: 4L2 035 666 D
   Component: H-BN-EU       H44 0528
   Revision: --------    Serial number: 219GZ0C7500961
   Coding: 180100060004B3ED010023556F632003E40000020100000000
   VCID: B12A7943E87B27C798-80E4
   Subsystem 1 - Part No: 8R0 060 884 AH
   Component: EUR 2012  1308
   Component: DU7 High  H41 0104
   Serial number: A130GQ0C2503386
   Subsystem 3 - Part No SW: 4L0 919 614 B    HW: 4L0 919 614 B
   Component: E0380 Bedient  H01 0060
   Serial number: 00000002031740
   Component: CD-Database  3638
   Part No SW: 4F0 959 795 Q    HW: 8K0 959 795 F
   Component: TSG HL        H11 0362
   Revision:             Serial number: 0000031577288
   Coding: 010800204040230004
Address 69: Trailer (J345)       Labels: None
   Part No SW: 4L0 907 383 D    HW: 4L0 907 383 D
   Revision: 2C001001    Serial number: 00000179758228
   Coding: 0101010000000000
   Part No SW: 4L0 910 945     HW: 4L0 827 851 E
   Component: ValeoHeckdeckel H57 0500
   Revision: --H57001    Serial number: E5030000B
   Shop #: WSC 98765 666 38354
   VCID: EC94A837CFD98A2FEB-80B8
   Subsystem 2 - Serial number: 0
ó
   Subsystem 3 - Serial number: RD18.07.12--H57001002G0368ÿ
   Subsystem 4 - Serial number: 2G0368ÿ
   Part No SW: 4L0 910 290     HW: 4L0 907 290
   Component: ILM HINTEN 2    H08 0080
   Revision: AAH08080    Serial number: 128756140-----
   VCID: E582DD132C33BB67B4-80B0
   Component: TSG HR        H11 0362
   Revision:             Serial number: 0000031577289
End----------(Elapsed Time: 02:09, VBatt start/end: 14.9V/14.8V)-----------
You must click on the item in question before you can change its scaling.
Znippie
Norway
C?ID=328489
Thanks! Now I got it right.
But now a new problem accured;
Everytime it exceeds a certain value the graph goes to zero in the graph window.
Why? is it because the values recieves a letter (e+) when exceeding 1000bar?
Its impossible to log the acceleration when it suddently drops to the floor during thepull
That is a distinct possibility. It would not be completely shocked if VC-Scope did not handle a dynamic data format change gracefully.
In that case, the most expedient solution might be to log the data and graph it in Excel.
Dana
Western PA, USA
I don't believe that TPI applies. No doubt, there appear to have been 2 flash updates over the years for that 4L2 910 401 B EDC and SVM code 01A183 would likely bump it from SWL 0001 to 0004 ... but the 2042993 TPI I located was glow plug specific. I don't think getting a dealer level flash is going to help in this case.
The procedure in the video is gasoline specific but you can verify that injectors (or high side components) aren't stuck wide open by shutting it off and making sure the fuel pressure doesn't drop off immediately.
You can run this procedure:
http://wiki.ross-tech.com/wiki/index.php/Fuel_Pump_Basic_Settings_for_PD,_PPD,_and_CR_TDI_Engines
Although it is intended for fuel filter replacement rather than pump testing that will operate the in-tank (and any in-line) pumps.
Znippie
Norway
C?ID=328489
Thanks for the reply. As mentioned the actual fuel pressure value is not moving when the engine is off and ignition on, its standing on defualt 2500hpa.
I did some test runs last night, and the ecu is asking for 2000bar but it only measures 1800 on actual pressure.
The car was previously tuned (chip tune) but later overwritten to stock, but Im starting to think that there is a problem with that chiptuning.
I have read somewhere that the 204hp V6 HPFH delivers 2000bar and the 245 V6 HPFP delivers 1800 bar, so there might be something worth checking out
Znippie
Norway
C?ID=328489
Newest flash update (0004) did not help, and that kills my theori about a bad chip file.
Next up is to find out if the pressure regulator valve is somehow leaking or is faulty.
Pressure valve was changed 2 years ago
Have you measured actual fuel PSI/Volume?
JPPSG
https://forums.ross-tech.com/showth...uot-JPPSG-quot&p=125791&viewfull=1#post125791
Mechanical issues must be qualified with actual test equipment to qualify block data as reported or basic isolated tests.
Have you tried an isolation plug at each injector path on rail & to see if rail PSI is achieved during cranking in blocks or mechanical gauge?
Did you know a fuel rail injection isolation cap can be made with an old line from junk yard cheap or purchased from any quality injection rebuild outfit for Bosch?
This should be in any serious EU diesel shop tool box!
Example:
https://www.store.joma-tools.com/en...s-to-check-common-rail-injectors-leakage.html
