2006 jetta tdi no power
Boot
C?ID=323824
hello all. my names joe. first time here. i just got my vcds a few weeks. I have my own shop but never got into computer issues like this. Usually work on diesel trucks and equipment, boats , American v8 power etc.
Brief history.. The wifes car 06 jetta tdi BRM engine. Lost power.(it comes and goes intermittently) basic scanner told me temp sensor. Then boost sensor, then n75 valve, then low voltage to turbo position sensor. decided to do egr delete as its been leaking exhaust on the lower valve. discussed my problems with a dealer for the Malone tuning. He said check the cam. Yes it was bad so I replaced it. Drove it to him to do egr tune and tune out the turbo position sensor problem. He put several tunes in it and still no power. It feels like the turbo isn't working. but once in a while it will come back for a few seconds. I have checked the turbo. there is no visual ware or play. actuator works smooth with vacuum pump. no vacuum leaks, fuses are good , battery is good fuel pump in tank is good.shudder valve is good also.
When I first went to Malone dealer, I had egr codes on the vcds and Turbocharger Boost Control Position Sensor Circuit P2564 - 000 - Signal too Low. That's it. Now after returning from him I have TONS of faults for communication errors and sporadic communication.... He said to check ECM for corrosion in the plugs. Nothing noticeable but cleaned them anyway. Still the same. Here is latest scan. Can anyone help as to why the power is so sporadic. Mostly not there...
Monday,12,March,2018,15:29:36:22519
VCDS Version: 18.1.0.2 (x64)  HEX-V2 CB: 0.4411.4
VIN: 3VWST71K06M029820   License Plate:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 0F 15 16 17 19 25 42 44 46 52 56 62 65 72 7D
VIN: 3VWST71K06M029820   Mileage: 264900km-164601miles
01-Engine -- Status: Sporadic communication error 1000
Address 01: Engine        Labels: 038-906-016-BEW.lbl
   Part No SW: 03G 906 016 AB    HW: 028 101 223 8
   Component: R4 1,9L EDC G000SG  7550
   Revision: --H02---    Serial number: VWZ7Z0F4474234
   Coding: 0050071
   Shop #: WSC 66565 257 00032
   VCID: 639352942750C76F157-8036
Readiness: 0 0 0 0 X
   Revision: 00H11001
   Coding: 0021122
   VCID: 73B322D497B057EF657-8026
   Part No: 1K0 820 047 FQ
   Component: Climatic PQ35   120 0606
   VCID: 78A915F88ED634B7505-802C
00532 - Supply Voltage B+
            001 - Upper Limit Exceeded
Address 09: Cent. Elect.        Labels:. 3C0-937-049-23-M.lbl
   Part No SW: 3C0 937 049 P    HW: 3C0 937 049 P
   Revision: 00H46000    Serial number: 00000000416513
   Coding: 14018E234004150007140000001400000008730B5C0000
   VCID: 3635DBC0C44202C7829-8062
   Component: Wischer 150806 020  0501
   Coding: 00038805
   Shop #: WSC 00066
                    Fault Status: 00100001
                    Reset counter: 158
                    Mileage: 264315 km
                    Voltage: 15.55 V
                    Fault Frequency: 10
                    Reset counter: 151
                    Mileage: 264464 km
                    Voltage: 13.30 V
00447 - Function Limitation due to Over-Voltage
                    Reset counter: 140
                    Mileage: 264315 km
                    Voltage: 15.45 V
   Part No SW: 8E0 035 593 D    HW: 8E0 035 593 D
   Component: SDAR SIRIUS     H03 0060
   Revision: 00000000    Serial number: AUZ4Z7F6019164
   VCID: 2A0DFFB000FA5627161-807E
                    Reset counter: 158
                    Mileage: 264905 km
                    Time: 01:38:17
                    Voltage: 15.60 V
                    Reset counter: 117
                    Mileage: 264905 km
   Revision: 05034000    Serial number: 003B6D056G8P
   Coding: 0013889
   VCID: 6C8139A8CA8E8817A4D-8038
   Subsystem 2 - Serial number: 6332MSME1139687CI
   Subsystem 3 - Serial number: 6342MSME10066F000
   Subsystem 4 - Serial number: 6351HSME0A201B685
   Subsystem 5 - Serial number: 6361HSME0A1B400E8
   Subsystem 6 - Serial number: 63727SME093258760
   Subsystem 7 - Serial number: 63827SME0A175870%
   Part No SW: 1K0 953 549 AR    HW: 1K0 953 549 AR
   Component: J0527           035 0070
   Coding: 0000021
   VCID: 025D7710D80A6E677E1-8056
   Part No SW: 1K0 920 953 J    HW: 1K0 920 953 J
   Component: KOMBIINSTRUMENT 3HL 1610
   Revision: V0003000    Serial number: VWZ7Z0F4474234
   Coding: 0023203
   VCID: 323DE7D0282A1EE7AE1-8066
                    Fault Frequency: 11
                    Reset counter: 151
                    Mileage: 264464 km
                    Time: 01:47:06
   Part No SW: 1K0 907 530 H    HW: 1K0 907 951
   Component: J533__Gateway   H12 0150
   Revision:   H12       Serial number: 31001066260464
   Coding: 3DBF0B6007001002
   VCID: 2C01F9A80A0E4817E4D-8078
                    Reset counter: 151
                    Mileage: 264464 km
                    Time: 01:47:07
                    Reset counter: 158
                    Mileage: 264905 km
                    Time: 01:38:15
   Component: IMMO            3HL 1610
   Component: J386  TUER-SG FT    1125
   Revision: 12006001    Serial number: 00000500268728
   Coding: 0001205
   VCID: 3B23CAF4FF60DFAF7D7-806E
                    Reset counter: 158
                    Mileage: 264905 km
                    Fault Status: 01100101
                    Reset counter: 118
                    Mileage: 264315 km
00914 - Window Regulator Switch; Rear Left; Driver (E53)
                    Reset counter: 118
                    Mileage: 264315 km
   Part No: 1K1 909 144 L
   Component: EPS_ZFLS Kl.069 H07 1806
   VCID: 3431E1C8D23E10D7BCD-8060
                    Mileage: 264460 km
                    Temperature: 22.0°C
                    Voltage: 13.30 V
                    Voltage: 13.10 V
   Part No SW: 1K0 959 433 CD    HW: 1K0 959 433 CD
   Component:    KSG PQ35 RDK 051 0215
   Revision: 00051000    Serial number: 00000000000000
   Coding: 13900F880186281B0904058FB0880F0488DCA0
   VCID: 74B121C892BE50D77CD-8020
                    Reset counter: 158
                    Mileage: 264905 km
                    Time: 01:38:14
   Part No SW: 1K0 959 702 P    HW: 1K0 959 792 L
   Component: J387  TUER-SG BT    1125
   Revision: 12006001    Serial number: 00000184168724
   Coding: 0001204
   VCID: 3C21C9E8FA6ED89774D-8068
                    Reset counter: 158
                    Mileage: 264905 km
                    Reset counter: 118
                    Mileage: 264315 km
   Part No SW: 1K0 035 180 G    HW: 1K0 035 180 G
   Component: Radio ZSW       017 0019
   Revision: 00017000    Serial number: VWZ5Z7F6042613
   Coding: 0040401
   VCID: 2411118862DE80572CD-8070
   Part No SW: 1K0 959 703 Q    HW: 1K0 959 795 J
   Component: J388   TUER-SG HL   1115
   Revision: 12005001    Serial number: 00000000371525
   Coding: 0001168
   VCID: 3E25C3E0EC72CA875A9-806A
   Component:    RDK              0420
   Coding: 0100101
   Part No SW: 1K0 959 704 Q    HW: 1K0 959 794 J
   Component: J389   TUER-SG HR   1115
   Revision: 12004001    Serial number: 00000000239761
   Coding: 0001168
   VCID: 3FDBBEE4EB78C38F51F-806A
   Revision: 00800000    Serial number:
   VCID: 2D07F4AC3114411FF33-8078
            014 - Defective
End----------(Elapsed Time: 01:27, VBatt start/end: 12.6V/12.5V)-----------
Boot
C?ID=323824
This may be misleading too. I had the battery charger on during this test. I can post several other previous scans if it would help. Thanks.
Hello OP and welcome to the VCDS forum.
But car back to stock and remove the FOD, then post an actual auto-scan without deletes, follow stack and RTFB to correct conditions properly.
JPPSG
http://forums.ross-tech.com/showthr...essional-Problem-Solver-Guide-quot-JPPSG-quot
Although I have never been onboard with the EGR device & as an ass to mouth theory, I still don't delete it!
I just don't see the health benefits of either!
Looks to me like the ECU is occasionally dropping off-line. Possible power problem to the ECU?
That might be during flash sessions encountered .......... :D
With FOD code written it will hide the deviation codes for boost and make it much harder for you to diagnose.
You should log boost and see what request is verse actual after a DTC reset.
Voltage: 15.55 V
Are those voltages from a battery charger or your actual charging system because if they are from alternator that will block things.
Boot
C?ID=323824
The boost I checked. actual was just a bit higher then requested. The voltage was on the charger, not running. I can post scans prior to egr tuning if it helps. Thanks.
That is a positive deviation than & which indicates either a plugged intake with carbon or a turbo charger WG setting which is mechanically incorrect or N75 valve which isn't doing its job to regulate the WG proper.
Boot
C?ID=323824
heres a scan prior to tuning:
Tuesday,13,February,2018,00:09:59:22519
VIN: 3VWST71K06M029820   Mileage: 264310km-164234miles
   Coding: 0050071
001031 - EGR Sensor 2
               P0407 - 000 - Signal too Low
                    Mileage: 264318 km
                    Time: 20:17:23
                    Lambda: -25.0 %
                    Mass Air / Rev.: 1000.0 mg/str
                    Mass Air / Rev.: 0.0 mg/str
                    Bin. Bits: 00000000
009572 - Turbocharger Boost Control Position Sensor Circuit
                    Mileage: 264318 km
                    Time: 20:17:23
                    Lambda: -3.7 %
                    Absolute Pres.: 1213.8 mbar
                    Absolute Pres.: 1020.0 mbar
                    Duty Cycle: 101.6 %
   Revision: 00H11001
   Coding: 0021122
   Coding: 00038805
   Shop #: WSC 00066
                    Reset counter: 140
                    Mileage: 264315 km
                    Voltage: 15.55 V
                    Reset counter: 140
                    Mileage: 264315 km
                    Voltage: 15.45 V
                    Reset counter: 140
                    Mileage: 264315 km
                    Time: 00:56:43
                    Voltage: 15.60 V
                    Reset counter: 100
   Coding: 0013889
   Coding: 0000021
   Coding: 0023203
   Coding: 0001205
                    Fault Status: 00100101
                    Reset counter: 141
                    Mileage: 264315 km
                    Reset counter: 101
                    Mileage: 264315 km
   Coding: 0001204
                    Reset counter: 141
                    Mileage: 264315 km
   Coding: 0040401
   Coding: 0001168
   Component:    RDK              0420
   Coding: 0100101
   Coding: 0001168
            014 - Defective
End----------(Elapsed Time: 01:25, VBatt start/end: 12.0V/12.1V)-----------
Boot
C?ID=323824
n75 replaced. Took shudder valve off. intake looks clean. or am I missing something there. I did start to reset the stop screw under the actuator arm but didn't get to finish.
Boot
C?ID=323824
Like I said, the power comes and goes. WHen it comes back it realy takes off, then falls on its face... The day I drove 2 hours to tune it, it had power most of the way there. That day his computer broke and I had to drive back with out the tune and happened to have no power.... Had to return a few days later to get the tuning. But the power has been mostly not there. since coming back the first day.
Boot
C?ID=323824
Those are WD related electrical faults from ECU to N75 or a bad N75 or ECU.
Since you did timing when cam was swapped are you sure is it correct and you are aligned for all base settings and taper or key-way offsets on hub to cam belt sprocket?
What about cam ramps lash for injectors?
JPPSG.............. Amendment!
http://forums.ross-tech.com/showthr...uot-JPPSG-quot&p=123510&viewfull=1#post123510
Good moring jack. Remember Im a newbie to the vcds and its term. Going from memory (not at the shop yet) but I think the cam timing is "torsion value" ? Its 0.0 which I believe is right.
Not sure what you mean by taper and keyway offset but the gear is back on the way it came off unless I overlooked something. Can you elaborate ?
Thanks,joe
   Coding: 0050071
                    Mileage: 264318 km
                    Time: 20:17:23
                    Lambda: -25.0 %
                    Bin. Bits: 00000000
                    Mileage: 264318 km
                    Time: 20:17:23
                    Lambda: -3.7 %
                    Duty Cycle: 101.6 %
So you tuned a car with pre-existing faults and now you're wondering why it doesn't run right after being tuned?
Hello Joe,
Yes Torsion value but can still be out, while in, are you looking at corrected values or basic settings? 08 vs 04!
That is why I ref taper fit pulleys and virtual key-ways then injector cam ramp timing lash.
To me it sounds like you have an over boost condition or a plugged intake not allowing air made by turbo charger popping the MAP sensor to read higher than expected hence limp mode.
It is time you ref RTFB please on how hub is fit on cam and then timing gear on hub.
0x01-08-011 Log Boost...........
http://forums.ross-tech.com/showthread.php?3147-What-is-Jack-talking-about-0x01-08-000
UN-PIMP the FOD!
Boot
C?ID=323824
The egr system was in bad shape so I did a delete on it. then had to have it tuned out.
Boot
C?ID=323824
As the money issue of a new cooler and valve.
So you're telling us you know this car is no longer legal to use on public roads? ;)
And what about the "Turbocharger Boost Control Position Sensor Circuit" fault? One of the problems with certain "tuner" software is that it plays hide-the-sausage games with fault conditions that would set DTCs in the stock software. This can make it much harder to diagnose and fix problems.
Boot
C?ID=323824
Hello Joe,
If I clear codes and rescan, the codes are back without starting or driving the car....
Also the power is not there right off the bat. I would think power would start to build(boost) then fall off when MAP see's too much.
I am on my way to the shop to watch boost.
Am I missing something? when I looked at the graph comparing actual boost and requested, it shows the 2 but there is no reference on the graph for the actual value. I see the actual is slightly more but I don't know if its 1psi or 20...
Joe
WTF see Uwe this is what I mean?
That's too funny......... Sausage fest! :rolleyes:
Joe
A tune is not a tune if it isn't CARB/EPA certified, it is a defeat device!
You mean to tell me you can pay for a defeat vs this?
BULLSHIT!
NEW 150-400
https://www.ebay.com/itm/New-EGR-CO...561303?hash=item4668b76997:g:xFsAAOSwsDxZ4ENY
https://www.ebay.com/itm/New-Oem-VW...322792&hash=item2384bf2a93:g:MqEAAOxyZzlTc-Mq
https://www.ebay.com/itm/A5-VW-VOLK...322792&hash=item25ca7bb3a9:g:9isAAOSwubRXNhHx
USED 100
https://www.ebay.com/itm/Volkswagen...349237?hash=item362d5db275:g:xDwAAOSwk75anvFI
Joe
Which is why I said check timing and lash.........just have a look at the last BRM fiasco related to timing in forum.
Boot
C?ID=323824
Hi Uwe, I'm learning here... Have mercy on me, if not pitty... LOL. My first instinct due to lack of funds was delete. However, before hand, the code shows signal too low. It seams there should be 5volts to the sensor. first I found 2.8 volts.... traced back to ecu and found no problem. when I checked at sensor AGAIN it was 4.8v. the tuner guy "told me" they are problematic but can be tuned out. I assumed that made sense since he does this....:(
WHats your experience with this low signal?
Thanks,Joe
