Case Study: B10B3 Seat Occupied Recognition with ABS issue
Jef
HQ
The subject, a 2012 Jetta. Owner started up car, ABS and airbag lights come on, dash beeping away.
Monday,09,December,2019,19:12:07:14741
VCDS Version: 19.10.0.0 (x64)  HEX-NET CB: 0.4517.4
Data version: 20190930 DS316.0
VIN: 3VWDP7AJ5CM326422   License Plate:
Chassis Type: AJ-VW36 (6N0)
Scan: 01 02 03 08 09 15 17 19 25 2E 56 77
VIN: 3VWDP7AJ5CM326422   Mileage: 412800km-256502miles
Address 01: Engine (CBU)       Labels: 07K-906-055-CBT.clb
   Part No SW: 07K 906 055 CJ    HW: 07K 907 309 B
   Component: 2,5l R5/4V      G01 1156
   Revision: T4H04---    Serial number:
   Coding: 0000075
   VCID: F8A203AA9ED0529151AB-80AC
000262 - Manifold / Barometric Pressure Sensor (G71) / (F96)
               P0106 - 000 - Implausible Signal
                    Mileage: 412780 km
                    Date: 2014.05.01
                    Time: 06:36:43
                    RPM: 2221 /min
                    Load: 31.0 %
                    Speed: 110.0 km/h
                    Temperature: 85.0°C
                    Temperature: 32.0°C
                    Absolute Pres.: 970.0 mbar
                    Voltage: 13.970 V
   Part No SW: 09G 927 750 LF    HW: 09G 927 750 LF
   Component: AQ 250 6F           2041
   Revision: 00H97000    Serial number:
   Coding: 0000840
   VCID: 80526B4AC6001A51691B-80D4
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Fault Frequency: 15
                    Reset counter: 201
                    Mileage: 333110 km
                    Date: 2012.07.23
                    Time: 04:56:42
   Revision: 00H31001
   Coding: B14B440C492408008D0F22E6921B1061A70000
   VCID: FBA81CA6A3E679893CC9-80AE
01130 - ABS Operation
                    Reset counter: 22
                    Mileage: 412692 km
                    Count: 2
                    Count: 14
                    Count: 12288
                    Count: 124
                    Count: 37632
                    Count: 2
                    Reset counter: 26
                    Mileage: 411906 km
                    Date: 2014.04.08
                    Time: 23:48:07
                    Count: 32768
                    Count: 4608
                    Count: 8193
                    Count: 51201
                    Count: 508
   Part No SW: 5C0 820 047 AQ    HW: 5C0 820 047 AQ
   Component: J301  Klimaanlage   0203
   Revision: 2001010S    Serial number: 00000000547483
   VCID: EFB038F6EB9E15298041-80BA
   Part No SW: 5C0 937 087 E    HW: 5C0 937 087 A
   Component: BCM25 JLB H3  H66 0251
   Revision: B2066001    Serial number: 04371246111387
   Coding: 7B994B9A08AB0B0008382000240884C500C2502E60000000300000000000
   VCID: AF30F8F6271E5529C0C1-80FA
   Subsystem 1 - Part No SW: 6R0 959 801 M    HW: 6R0 959 801 M  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  002 3464
   Coding: 820000
   Subsystem 2 - Part No SW: 6R0 959 802 P    HW: 6R0 959 802 P  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  002 3464
   Coding: 820000
   Subsystem 3 - Part No SW: 5K0 959 591     HW: 5K0 959 591
   Component: J245 PS41.019  H08 0006
   Serial number:     WRH00032HWO
   Coding: 180000
   Subsystem 4 - Part No SW: 5K0 959 542 A    HW: 5K0 959 542 A
   Serial number: 0438150
   Coding: 020000
   Subsystem 5 - Part No SW: 6R0 959 811 D    HW: 6R0 959 811 D
   Component: J388__TSG_HL  002 3464
   Coding: 800000
   Subsystem 6 - Part No SW: 6R0 959 812 D    HW: 6R0 959 812 D
   Component: J389__TSG_HR  002 3464
   Coding: 800000
   Part No SW: 5C0 959 655 E    HW: 5C0 959 655 E
   Component: AirbagVW10G   013 0807
   Serial number: 003GTM01N5T%
   Coding: 00003936
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01020
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: B43AF79ACEB876F1BD13-80E0
   Subsystem 1 - Part No SW: 5C6 959 339     HW: 5C6 959 339
   Component: BF-Gewichtss.  H10 0027
   Serial number: 6940000Y1100006VFX0B
   Coding: 303241
   Serial number: 3572MSME23291461ZZZL
   Serial number: 3582MSME53340442ZZZJ
   Serial number: 3516KSME15633811ZZZH
   Serial number: 3526KSME2B4D4B11ZZZ.
   Serial number: 3556LSME6E1B5910ZZZ+
   Serial number: 3566LSME6D195910ZZZ$
9483008 - Seat Occupied Recognition
          B10B3 00 [137] - Function Restriction due to Implausible Message(s)
          [Bladder Mat: functional restriction because of message unplausible]
                    Reset counter: 26
                    Mileage: 412692 km
                    Date: 2019.12.06
                    Time: 23:04:05
   Part No SW: 5C6 920 951 B    HW: 5C6 920 951 B
   Component: KOMBI         H04 0604
   Coding: 270201
   Shop #: WSC 00066 000 00125
   VCID: AA06E9E21C7C300117BF-80FE
   Part No SW: 6N0 909 901     HW: 5C0 937 087 A
   Component: GW-K-CAN TP20 H66 0251
   Revision: B2066001
   Coding: 102200
   VCID: F0B23B8AFAA00AD1997B-80A4
   Component: IMMO          H04 0604
   VCID: EA8629E2DCFCF001D73F-80BE
   Revision: A1001003    Serial number: 7660504981
   VCID: A90416EE19FA3B191E85-80FC
   Part No SW: 1K0 035 180 AE    HW: 1K0 035 180 AE
   Component: Radio Prem-8  H02 0016
   Revision: -----16S    Serial number: VWZ4Z7L3199959
   Coding: 01000400020006
   VCID: E39844C63B56A14914F9-80B6
                    Fault Frequency: 10
                    Reset counter: 16
                    Mileage: 125769 km
                    Date: 2014.06.06
                    Time: 11:01:59
   Part No SW: 7P6 035 730 F    HW: 7P6 035 730 F
   Component: TELEFON       H09 2902
   Revision: 1B001001    Serial number: 00007660434699
   Coding: 0A10040000010110
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_UHVNA A01719
   ROD: UHVNA.rod
   VCID: B53CCA9EC5C26FF98A0D-80E0
End----------(Elapsed Time: 01:24, VBatt start/end: 12.6V/12.5V)-----------
This code will not clear out of the ABS module, verified powers/grounds for the ABS module are to factory design, so odds are a failed ABS. MK60EC1 module, so no surprises here. I was asked about the airbag light:
This code will not clear out as well, but lets not worry about it. In many cases, you can get POD module type fault codes causes by the ABS module (or EPB if the vehicle is equipped). I don't know why this happens, but IMHO it is best to sort out the ABS issue first and then see if you still issues in the airbag system.
A new ABS module was installed, I copy/pasted coding into the new unit and did all the basic settings. Once the ABS module was all sorted out, I did have to do the Basic Settings for the POD (details here) and then there were no codes in the airbag.
Friday,20,December,2019,22:03:22:14741
VIN: 3VWDP7AJ5CM326422   Mileage: 413520km-256949miles
   Coding: 0000075
   Coding: 0000840
   Revision: 00H31001
   Coding: 820000
   Coding: 820000
   Coding: 180000
   Coding: 020000
   Coding: 800000
   Coding: 800000
   Coding: 00003936
   Coding: 303241
   Coding: 270201
   Revision: B2066001
   Coding: 102200
                    Fault Frequency: 10
                    Reset counter: 16
                    Mileage: 125769 km
                    Date: 2014.06.06
                    Time: 11:01:59
   ROD: UHVNA.rod
End----------(Elapsed Time: 01:47, VBatt start/end: 12.4V/12.3V)-----------
EXTRA BONUS:
When trying to sort out the 00003 fault code in the ABS module, you have to do the Basic Settings 025 and 026 while the engine is running. But this heats up the ABS module and at some point, too much heat in the ABS will prevent the 025 or 026 Basic Settings from being carried out. We shoved an aerated aluminum plate between the ABS module and engine to act as a heat shield. And as I was doing the test, I had the owner of the vehicle spray brake cleaner on the valve block a few times. This kept the temp of the ABS down and as a result, I got both 025 and 026 Basic Settings "Calibrated" back to back. If you have some sort of heat shield material (the stuff used for firewalls), then see about shielding the ABS module to help keep it cool while doing the Basic Settings.
