The subject, a 2012 Jetta. Owner started up car, ABS and airbag lights come on, dash beeping away.
01130 - ABS Operation
This code will not clear out of the ABS module, verified powers/grounds for the ABS module are to factory design, so odds are a failed ABS. MK60EC1 module, so no surprises here. I was asked about the airbag light:
B10B3 00 [137] - Function Restriction due to Implausible Message(s)
[Bladder Mat: functional restriction because of message unplausible]
This code will not clear out as well, but lets not worry about it. In many cases, you can get POD module type fault codes causes by the ABS module (or EPB if the vehicle is equipped). I don't know why this happens, but IMHO it is best to sort out the ABS issue first and then see if you still issues in the airbag system.
A new ABS module was installed, I copy/pasted coding into the new unit and did all the basic settings. Once the ABS module was all sorted out, I did have to do the Basic Settings for the POD (details here) and then there were no codes in the airbag.
EXTRA BONUS:
When trying to sort out the 00003 fault code in the ABS module, you have to do the Basic Settings 025 and 026 while the engine is running. But this heats up the ABS module and at some point, too much heat in the ABS will prevent the 025 or 026 Basic Settings from being carried out. We shoved an aerated aluminum plate between the ABS module and engine to act as a heat shield. And as I was doing the test, I had the owner of the vehicle spray brake cleaner on the valve block a few times. This kept the temp of the ABS down and as a result, I got both 025 and 026 Basic Settings "Calibrated" back to back. If you have some sort of heat shield material (the stuff used for firewalls), then see about shielding the ABS module to help keep it cool while doing the Basic Settings.
Monday,09,December,2019,19:12:07:14741
VCDS Version: 19.10.0.0 (x64) HEX-NET CB: 0.4517.4
Data version: 20190930 DS316.0
VIN: 3VWDP7AJ5CM326422 License Plate:
Chassis Type: AJ-VW36 (6N0)
Scan: 01 02 03 08 09 15 17 19 25 2E 56 77
VIN: 3VWDP7AJ5CM326422 Mileage: 412800km-256502miles
Address 01: Engine (CBU) Labels: 07K-906-055-CBT.clb
Part No SW: 07K 906 055 CJ HW: 07K 907 309 B
Component: 2,5l R5/4V G01 1156
Revision: T4H04--- Serial number:
Coding: 0000075
Shop #: WSC 00066 000 00000
VCID: F8A203AA9ED0529151AB-80AC
000262 - Manifold / Barometric Pressure Sensor (G71) / (F96)
P0106 - 000 - Implausible Signal
Mileage: 412780 km
Date: 2014.05.01
Time: 06:36:43
RPM: 2221 /min
Load: 31.0 %
Speed: 110.0 km/h
Temperature: 85.0°C
Temperature: 32.0°C
Absolute Pres.: 970.0 mbar
Voltage: 13.970 V
Part No SW: 09G 927 750 LF HW: 09G 927 750 LF
Component: AQ 250 6F 2041
Revision: 00H97000 Serial number:
Coding: 0000840
VCID: 80526B4AC6001A51691B-80D4
013 - Check DTC Memory
Fault Status: 01101101
Fault Frequency: 15
Reset counter: 201
Mileage: 333110 km
Date: 2012.07.23
Time: 04:56:42
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: B14B440C492408008D0F22E6921B1061A70000
VCID: FBA81CA6A3E679893CC9-80AE
Fault Status: 01101000
Reset counter: 22
Mileage: 412692 km
Count: 2
Count: 14
Count: 12288
Count: 124
Count: 37632
Count: 2
Reset counter: 26
Mileage: 411906 km
Date: 2014.04.08
Time: 23:48:07
Count: 32768
Count: 4608
Count: 8193
Count: 51201
Count: 508
Address 08: Auto HVAC Labels: 5C0-820-047.clb
Part No SW: 5C0 820 047 AQ HW: 5C0 820 047 AQ
Component: J301 Klimaanlage 0203
Revision: 2001010S Serial number: 00000000547483
VCID: EFB038F6EB9E15298041-80BA
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 5C0 937 087 E HW: 5C0 937 087 A
Component: BCM25 JLB H3 H66 0251
Revision: B2066001 Serial number: 04371246111387
Coding: 7B994B9A08AB0B0008382000240884C500C2502E60000000300000000000
VCID: AF30F8F6271E5529C0C1-80FA
Subsystem 1 - Part No SW: 6R0 959 801 M HW: 6R0 959 801 M Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 002 3464
Coding: 820000
Subsystem 2 - Part No SW: 6R0 959 802 P HW: 6R0 959 802 P Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 002 3464
Coding: 820000
Subsystem 3 - Part No SW: 5K0 959 591 HW: 5K0 959 591
Component: J245 PS41.019 H08 0006
Serial number: WRH00032HWO
Coding: 180000
Subsystem 4 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A
Component: E221__MFL-TAS H09 0013
Serial number: 0438150
Coding: 020000
Subsystem 5 - Part No SW: 6R0 959 811 D HW: 6R0 959 811 D
Component: J388__TSG_HL 002 3464
Coding: 800000
Subsystem 6 - Part No SW: 6R0 959 812 D HW: 6R0 959 812 D
Component: J389__TSG_HR 002 3464
Coding: 800000
Part No SW: 5C0 959 655 E HW: 5C0 959 655 E
Component: AirbagVW10G 013 0807
Serial number: 003GTM01N5T%
Coding: 00003936
ASAM Dataset: EV_AirbaVW10SMEVW360 A01020
ROD: EV_AirbaVW10SMEVW360.rod
VCID: B43AF79ACEB876F1BD13-80E0
Subsystem 1 - Part No SW: 5C6 959 339 HW: 5C6 959 339
Component: BF-Gewichtss. H10 0027
Serial number: 6940000Y1100006VFX0B
Coding: 303241
Serial number: 3572MSME23291461ZZZL
Serial number: 3582MSME53340442ZZZJ
Serial number: 3516KSME15633811ZZZH
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3526KSME2B4D4B11ZZZ.
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME6E1B5910ZZZ+
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3566LSME6D195910ZZZ$
Reset counter: 26
Mileage: 412692 km
Date: 2019.12.06
Time: 23:04:05
Part No SW: 5C6 920 951 B HW: 5C6 920 951 B
Component: KOMBI H04 0604
Coding: 270201
Shop #: WSC 00066 000 00125
VCID: AA06E9E21C7C300117BF-80FE
Part No SW: 6N0 909 901 HW: 5C0 937 087 A
Component: GW-K-CAN TP20 H66 0251
Revision: B2066001
Coding: 102200
VCID: F0B23B8AFAA00AD1997B-80A4
Component: IMMO H04 0604
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: EA8629E2DCFCF001D73F-80BE
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Revision: A1001003 Serial number: 7660504981
VCID: A90416EE19FA3B191E85-80FC
Part No SW: 1K0 035 180 AE HW: 1K0 035 180 AE
Component: Radio Prem-8 H02 0016
Revision: -----16S Serial number: VWZ4Z7L3199959
Coding: 01000400020006
VCID: E39844C63B56A14914F9-80B6
Reset counter: 16
Mileage: 125769 km
Date: 2014.06.06
Time: 11:01:59
Part No SW: 7P6 035 730 F HW: 7P6 035 730 F
Component: TELEFON H09 2902
Revision: 1B001001 Serial number: 00007660434699
Coding: 0A10040000010110
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_UHVNA A01719
ROD: UHVNA.rod
VCID: B53CCA9EC5C26FF98A0D-80E0
End----------(Elapsed Time: 01:24, VBatt start/end: 12.6V/12.5V)-----------
Friday,20,December,2019,22:03:22:14741
VIN: 3VWDP7AJ5CM326422 Mileage: 413520km-256949miles
Coding: 0000075
Coding: 0000840
Revision: 00H31001
Coding: 820000
Coding: 820000
Coding: 180000
Coding: 020000
Coding: 800000
Coding: 800000
Coding: 00003936
Coding: 303241
Coding: 270201
Revision: B2066001
Coding: 102200
Reset counter: 16
Mileage: 125769 km
Date: 2014.06.06
Time: 11:01:59
ROD: UHVNA.rod
End----------(Elapsed Time: 01:47, VBatt start/end: 12.4V/12.3V)-----------
EXTRA BONUS:
