Hi, All -
I have had this problem for some time. To an old-timey mechanic, it would seem that the O2 sensor fault may be leaning out the engine under certain conditions, leading the the misfiring. What do I need to replace? Thanks!
- Rob
- Rob
Saturday,08,June,2019,06:44:24:61379
VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4437.4
VIN: WAUDF78E68A163103 License Plate:
Mileage: 102440km-63653mi Repair Order: A4 6.8.19
67 69 75 76 77
VIN: WAUDF78E68A163103 Mileage: 102440km-63653miles
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 8E1 910 115 G HW: 8E0 907 115 D
Component: 2.0l R4/4V TFSI 0010
Revision: 5EH15--- Serial number: XXXXXXXXXXXXXX
Coding: 0104010A180F0120
Shop #: WSC 65728 1018 854933
VCID: 2616FE2564E9F107C41-8072
P0300 - 001 - - Intermittent
Fault Status: 00100001
Mileage: 99693 km
RPM: 3730 /min
Load: 100.0 %
Speed: 78.0 km/h
Temperature: 89.0°C
Temperature: 22.0°C
Absolute Pres.: 840.0 mbar
Voltage: 14.097 V
000769 - Cylinder 1
P0301 - 001 - Misfire Detected - Intermittent
Mileage: 99693 km
RPM: 1311 /min
Load: 45.9 %
Temperature: 14.0°C
Temperature: 14.0°C
Absolute Pres.: 780.0 mbar
Voltage: 14.224 V
000772 - Cylinder 4
P0304 - 001 - Misfire Detected - Intermittent
Mileage: 102006 km
RPM: 3730 /min
Load: 100.0 %
Speed: 78.0 km/h
Temperature: 89.0°C
Temperature: 22.0°C
Voltage: 14.097 V
004372 - Oxygen (Lambda) Sensor; B1 S2
P1114 - 008 - Internal Resistance too High - Intermittent
Mileage: 102310 km
RPM: 2535 /min
Load: 7.1 %
Speed: 116.0 km/h
Temperature: 93.0°C
Temperature: 12.0°C
Absolute Pres.: 670.0 mbar
Voltage: 14.224 V
000320 - Oxygen (Lambda) Sensor B1 S2
P0140 - 004 - No Activity - Intermittent
Mileage: 102310 km
RPM: 2535 /min
Load: 6.3 %
Speed: 116.0 km/h
Temperature: 93.0°C
Temperature: 12.0°C
Voltage: 14.224 V
