Tire Pressure Too low
chacaocop
C?ID=391697
Good day:
I had an issue with the front TPMS and I took it to the tire shop. They replaced it. They say that it should auto program itself. It hasn't.
I accessed the tire pressure module and these are the results:
Monday,03,February,2020,13:08:22:38365
VCDS Version: Release 19.6.2 (x64) Running on Windows 10 x64
                Address 65: Tire Pressure       Labels: 3C0-959-433-65.lbl
Control Module Part Number: 1K0 959 433 CD    HW: 1K0 959 433 CD
  Component and/or Version:    RDK              0420
           Software Coding: 0100101
            Work Shop Code: WSC 12345 123 12345
                      VCID: F4A47E66972E72EF33-80A0
                    Reset counter: 153
                    Mileage: 395530 km
                    Time: 01:02:57
01487 - System Function Test
                    Fault Status: 01100101
                    Mileage: 395530 km
                    Time: 01:05:39
I am playing with the module and it seems that the sensors can give you more than the pressure, they can give you temperature, pressure, position and more.
Monday,03,February,2020,13:17:01:38365
                Address 65: Tire Pressure  (1K0 959 433 CD)
13:16:42
      Wheel Pressure (actual)
  2.47 bar   Wheel Pressure (actual)
  14.0°C   Wheel 1
  15.2°C   Wheel 2
  40.0°C   Wheel 3
  15.2°C   Wheel 4
  teilbel.   Current Load
  Reifen-Satz 1   Current Tire Set
13:17:03
  14.0°C   Wheel 1
  15.2°C   Wheel 2
  40.0°C   Wheel 3
  15.2°C   Wheel 4
I need assistance with the following:
My TPMS light is on.
There is a message stating tire pressure too low but the pressure is fine on all tires.
My assumption is that the sensors need to be programmed.
Any help is appreciatted
What exactly did the shop replace?
Please drive the car a few miles to make sure the sensors have woken up, then immediately make a Measuring Value map from the TPMS module:
[Applications]
[Controller Channel Map]
Single Controller address = 65
Login or security access code: leave blank
Function: Measuring Values
Output: CSV file
[Go]
Jef
HQ
Please post a full Auto-Scan.
I have no clue what kind of car this is, the Auto-Scan lets everyone know details about the car as a whole, one of the reasons we want them posted. The part that was replaced, where was it sourced from? I will point out we've fielded many cases where "junk" sensors have been installed and they simply do not work with VW/Audi.
Regards.
chacaocop
C?ID=391697
These are the results obtained.
This is a Jetta TDI 2006 BTW.
;SW:1K0-959-433-CD HW:1K0-959-433-CD --- Tire Pressure
;Component: RDK 0420 Coding:0100101
;Monday3February202020:02:50:38365
;VCDS Version: Release 19.6.2 (x64) Data version: 20190930 DS308.0
;VCID: F4A47E66972E72EF33-80A0
[td]GroupField 1Data typeField 2Data typeField 3Data typeField 4Data type
1Wheel 1 Not Recogn. 2.30 barPressure
2Wheel 1 Not Recogn. N/AN/A
3Rad1271222846Transmitter Status
4Wheel 2 Not Recogn. 2.30 barPressure
5Wheel 2 Not Recogn. N/AN/A
6Rad23362499220Transmitter Status
7Wheel 3 Not Recogn. 2.30 barPressure
8Wheel 3 Not Recogn. N/AN/A
9Rad33362499225Transmitter Status
10Wheel 4 Not Recogn. 2.30 barPressure
11Wheel 4 Not Recogn. N/AN/A
12Rad43362287200Transmitter Status
1339(no units)37(no units)38(no units)0(no units)
163362499220; Park M. P.cha.; 237barWheel Sensor
1720.0°CTemperature2.37 barPressure0(no units)N/A
2012.40 VVoltage0.0 km/hSpeed18.0°CTemperature
2114.0°CTemperature15.2°CTemperature40.0°CTemperature15.2°CTemperature
22teilbel.Current Load
232.30 barPressure2.30 barPressure2.30 barPressure2.30 barPressure
245.50 barPressure5.50 barPressure5.50 barPressure5.50 barPressure
25Reifen-Satz 1Current
26Yes N/AN/AN/A
128-201.92 97(no units)N/AN/A
131-144 mbarPressure50.8 NmTorqueN/AN/A
13480178Work Shop Code-65 mbarPressureN/AN/A
13780178Work Shop Code-58 mbarPressureN/AN/A
[/td]
chacaocop
C?ID=391697
Regards.
Here is your full scan:
And to answer your question, They replaced the front left tire pressure sensor and I took the opportunity to place new tires today as well. Not sure if this is relevant but since you are asking, that is the response.
Monday,03,February,2020,21:10:43:38365
VIN: 3VWCT71K56M055379   License Plate:
Mileage: 395530km-245770mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 0F 15 16 17 19 1C 25 42 44 46 47 52 56 62 65 72
          7D
VIN: 3VWCT71K56M055379   Mileage: 395530km-245770miles
Address 01: Engine        Labels: 038-906-016-BEW.lbl
   Part No SW: 03G 906 016 AB    HW: 028 101 223 8
   Component: R4 1,9L EDC G000SG  7550
   Revision: --H05---    Serial number: VWZ7Z0F4537706
   Coding: 0050071
   VCID: E3860D3A22C0E5575A-80B6
   Revision: 00H11001
   Coding: 0021122
   VCID: F3A67D7A922075D72A-80A6
   Part No: 1K0 820 047 FQ
   Component: Climatic PQ35   120 0606
   VCID: F8BC4A568B46168F1F-80AC
   Revision: 00H46000    Serial number: 00000000447657
   Coding: 04018E234004150007140000001400000028770B5C0000
   Shop #: WSC 00066 123 12345
   VCID: B73E896AC6D8D9F7D6-80E2
   Component: Wischer 250906 020  0501
   Coding: 00038805
   Shop #: WSC 00066
                    Reset counter: 153
                    Mileage: 392460 km
                    Voltage: 12.25 V
   Part No SW: 8E0 035 593 D    HW: 8E0 035 593 D
   Component: SDAR SIRIUS     H03 0060
   Revision: 00000000    Serial number: AUZ4Z7F2041018
   VCID: AA18A01E056A741F59-80FE
                    Reset counter: 77
                    Mileage: 392460 km
                    Time: 08:00:57
   Revision: 05034000    Serial number: 003B6D05SUFP
   Coding: 0013889
   VCID: EC946606CF1EAA2FEB-80B8
   Subsystem 2 - Serial number: 6332MSME12264D717
   Subsystem 3 - Serial number: 6342MSME12031677%
   Subsystem 4 - Serial number: 6351HSME0A68065DF
   Subsystem 5 - Serial number: 6361HSME0A68170FF
   Subsystem 6 - Serial number: 63727SME0A600B3C2
   Subsystem 7 - Serial number: 63827SME0A600720T
   Part No SW: 1K0 953 549 AS    HW: 1K0 953 549 AS
   Component: J0527           035 0070
   Coding: 0002021
   VCID: 83462DBAC28045573A-80D6
   Part No SW: 1K0 920 973 D    HW: 1K0 920 973 D
   Component: KOMBIINSTRUMENT 3HL 1610
   Revision: V0003000    Serial number: VWZ7Z0F4537706
   Coding: 0023203
   Shop #: WSC 25019 444 54605
   VCID: AE10AC0E3982183F85-80FA
   Part No SW: 1K0 907 530 H    HW: 1K0 907 951
   Component: J533__Gateway   H12 0150
   Revision:   H12       Serial number: 31001068020021
   Coding: 3DBF0B620F001002
   VCID: AC14A6060F9E6A2FAB-80F8
   Component: Kompass         005 0003
   Revision: 00005000    Serial number: 1293324T242C03
   Coding: 0000003
   VCID: B93A8F52F0CCCF8720-80EC
   Component: IMMO            3HL 1610
   Shop #: WSC 20200 993 55616
   Component: J386  TUER-SG FT    1125
   Revision: 12006001    Serial number: 00000118468828
   Coding: 0001205
   VCID: BB36955AFAF0FD9732-80EE
                    Fault Status: 00101100
                    Reset counter: 193
                    Mileage: 392460 km
                    Fault Status: 01111000
                    Fault Frequency: 94
                    Reset counter: 153
                    Mileage: 392460 km
   Part No: 1K1 909 144 L
   Component: EPS_ZFLS Kl.069 H07 1806
   VCID: B424BE66D7AE32EFF3-80E0
   Part No SW: 1K0 959 433 CD    HW: 1K0 959 433 CD
   Component:    KSG PQ35 RDK 051 0215
   Revision: 00051000    Serial number: 00000000000000
   Coding: 13900F880186281B0904058FB0880F0488DC00
   Part No: 1K6 035 456 A
   Component: 08K Audioverst.     0005
   Revision: 00003000    Serial number: 00000000013026
   Part No SW: 1K0 959 702 P    HW: 1K0 959 792 L
   Component: J387  TUER-SG BT    1125
   Revision: 12006001    Serial number: 00000052666105
   Coding: 0001204
   VCID: BC349646FFFEFAAF3B-80E8
   Part No SW: 1K0 035 180 G    HW: 1K0 035 180 G
   Component: Radio DE2       145 0175
   Revision: 00145000    Serial number: VWZ4Z7F2122179
   Coding: 0010402
   VCID: A4044E26674EA26F63-80F0
00857 - CD Changer Unit (R41)
   Part No SW: 1K0 959 703 Q    HW: 1K0 959 795 J
   Component: J388   TUER-SG HL   1115
   Revision: 12004001    Serial number: 00000000297863
   Coding: 0001168
   VCID: BE309C4EE9E2E8BF15-80EA
                    Fault Frequency: 41
                    Reset counter: 153
                    Mileage: 392460 km
                    Fault Status: 01111100
                    Reset counter: 153
                    Mileage: 392460 km
   Component:    RDK              0420
   Coding: 0100101
                    Fault Status: 00101110
                    Reset counter: 153
                    Mileage: 395530 km
                    Time: 01:02:57
                    Mileage: 395530 km
                    Time: 01:05:39
   Part No SW: 1K0 959 704 Q    HW: 1K0 959 794 J
   Component: J389   TUER-SG HR   1115
   Revision: 12005001    Serial number: 00000000366520
   Coding: 0001168
   VCID: BFCEE14AEEE8E1B71E-80EA
   Revision: 00800000    Serial number:
   VCID: AD12AB0234846327BC-80F8
End----------(Elapsed Time: 01:50, VBatt start/end: 12.3V/12.3V)-----------
chacaocop
C?ID=391697
Regards.
One questions Jeff:
Assuming that the sensors are junk, (Discount Tire is the shop I used and I do not know where they source their parts) Where can I purchase the proper sensors so they can replace them for me?
Jef
HQ
Thank you for posting the Auto-Scan! The type of TPMS on this vehicle is "dumb" which is a good thing, easy to work with. I'm willing to bet you have a junk sensor. When the tyre shop stated "it should auto program itself", that is more or less correct, just worded incorrectly. I'd say generally after maybe 25 miles things should be matched up and the TPMS light off.
Since you posted the Auto-Scan, that let me do some quick digging... this car uses TPMS sensor part number 1K0 907 253 D to which your VW dealer can get.
Note, if you search for that part number, you will get a lot of Chinese replacement auto part hits.... but I think you have an idea of what to expect from those cheap things.
You can let the tyre shop toss another sensor in, but I'd not hold my breath on it working.
Few other pointers... normally the sensors go to sleep after 15 minutes or so of being parked. Test drive and hit maybe 30MPH to wake them up. The map you provided looks like sensors maybe be sleeping. As a rule of thumb, it is best to replace them in matching sets if they are old (weak batteries).
Agreed, I would interpret that map as none of the sensors currently talking.
chacaocop
C?ID=391697
Few other pointers... normally the sensors go to sleep after 15 minutes or so of being parked. Test drive and hit maybe 30 MPH to wake them up. The map you provided looks like sensors maybe be sleeping. As a rule of thumb, it is best to replace them in matching sets if they are old (weak batteries).
Well, I am now starting to see the issues. The car has 3 "old sensors" and a new one replaced two days ago. After the replacement, they are not responding. I see the "tire pressure too low" message on the dash even though all tires have the right pressure. I have driven the car on the highway, but not 25 miles yet since I dropped it on the shop to be aligned.
I will go ahead and drive 25 miles it and see the results.
If, and only if, the sensors do not wake up, I want to try a plan B which is to replace all the sensors for original VW/AUDI ones. I found a set of 4 online for 100 bucks. The dealer wants almost 90 bucks per sensor.
https://www.shopdap.com/make-model-year/volkswagen/passat/b6-2006-2010/wheels/tire-pressure-sensors.html
Should I go ahead and replace them now or wait until I drive the 25 miles? Your opinion on the matter is greatly appreciated.
Thanks!!!
Jef
HQ
It is "free" to get 25 miles on the odometer and there is a 0.001% chance it will resolve itself. So the 99.998% failure isn't really going to cost you anything to try. :) But I think the long term solution is to get known good sensors installed.
chacaocop
C?ID=391697
Well, the Mrs. took the car to work and back. The ride was 23 miles each way. The 0.001% chance has been exhausted.
I will let you know when I replace the sensors.
chacaocop
C?ID=391697
All four sensors were replaced by original VW TPMS sensors 1K0-998-253-D. As soon as they were replaced it only took 1 mile driving at 60 MPH. All codes cleared and no dash indicator light was present anymore.
Thanks a lot for your help.
Jef
HQ
Thanks for the update. Did you get your money back for the CRAP sensors?
chacaocop
C?ID=391697
Well, they only replaced one sensor when I took the car originally, but the irony was that after I took it the second time, they replaced all 4 TPMS with the original VW sensors which I just bought brand new. They returned me the ones the vehicle had. All the sensors were different, none were the same brand. Any way lesson learned. I will get my own sensors next time. Every time I let non VW mechanic replace parts these sort of thing happen.
Never CRAP parts again!
