005 - No or Incorrect Basic Setting / Adaptation 02588 - Swiveling Trailer Hitch Q7
ottotorvik
Norway
C?ID=333027
Audi Q7 2007
I need the correct coding for the swiveling trailer hitch. Anyone know where I can find this information?
VIN: WAUZZZ4L57D023585   License Plate: BR33464
Address 69: Trailer        Labels: None
   Part No SW: 4L0 910 383     HW: 4L0 907 383
   Component: ANHAENGERELEKTR 003 0020
   Coding: 0000111
   VCID: 688944AA4E70E927DA8-803C
01507 - Initialization Not Successful
                    Fault Status: 01100101
                    Reset counter: 246
                    Mileage: 197656 km
                    Date: 2018.03.13
                    Time: 17:20:00
                    Fault Status: 01111000
                    Reset counter: 1
                    Mileage: 198160 km
                    Date: 2018.03.26
                    Time: 19:23:00
PetrolDave
Westbury, UK
C?ID=1423
We'll need you to post a full Auto-Scan, not just a small section, to help you with the correct coding.
ottotorvik
Norway
C?ID=333027
Sorry,
Below is the full scan.
Thanks for quick response!
Wednesday,04,April,2018,19:53:43:13094
Mileage: 187000   Repair Order:
Gateway Installation List:  4L0 910 468
00-Steering Angle Sensor -- Status: Cannot be reached 1100
02-Auto Trans -- Status: Cannot be reached 1100
03-ABS Brakes -- Status: Cannot be reached 1100
07-Control Head -- Status: Cannot be reached 1100
0E-Media Player 1 -- Status: Cannot be reached 1100
15-Airbags -- Status: Cannot be reached 1100
34-Level Control -- Status: Cannot be reached 1100
55-Headlight Range -- Status: Cannot be reached 1100
Chassis Type: 4L0
Scan: 01 02 03 05 07 08 09 0E 15 16 17 18 19 34 37 42 46 47 4F 52
          55 56 61 62 69 6D 6F 72 76 77
   Mileage: 198160km-123130miles
Address 01: Engine
Address 02: Auto Trans
Address 03: ABS Brakes
   Component: FBSAUDIC6 ELV   H31 0220
   Revision: 31050601    Serial number: 10601000451281
   Coding: 0000131
   Shop #: WSC 00610 218 72587
   VCID: 63935386B7568A7F0FA-8036
   Subsystem 1 - Part No: 4F0 910 131 E
   Component: FBSAUDIC6 IDG   H01 0040
00956 - Key 2
                    Fault Status: 00110010
                    Reset counter: 40
                    Mileage: 197865 km
                    Date: 2018.03.22
                    Time: 08:45:40
00288 - Steering Column Lock Actuator (N360)
            014 - Defective
                    Fault Status: 01111110
                    Reset counter: 1
                    Mileage: 198160 km
                    Date: 2018.03.25
                    Time: 09:20:47
Address 07: Control Head        Labels: 4L0-910-7xx-07-H.clb
   Part No SW: 4L0 910 729 S    HW: 4E0 035 729
   Component: Interfacebox    H43 2830
   Revision: 00000000    Serial number: 386FT067513075
   Coding: 0002001
   Shop #: WSC 31414 790 00001
   VCID: 3FDBBFF67B7E8E9F4B2-806A
   Component: E0380 BedienteilH01 0050
   Subsystem 2 - Serial number: 00000000426411
   Subsystem 3 - Serial number: 0124.05.060000000100010899ˇ
   Subsystem 4 - Serial number: 010899ˇ
   Part No SW: 4L0 910 043     HW: 4L0 820 043 F
   Component: KLIMABETAETIGUNGH05 0040
   Revision: 00---008    Serial number: 00000000037877
   Coding: 0002070
   VCID: 619F598EAD4A986F1D6-8034
01207 - Control Module for Auxiliary Heater (J364)
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 246
                    Mileage: 197657 km
                    Date: 2018.03.13
                    Time: 16:49:34
   Part No SW: 4F0 910 279 K    HW: 4F0 907 279
   Coding: 0002121
   VCID: 313FE9CEBD2A68EFCD6-8064
   Subsystem 1 - Component: Fehler Lin-Slave 01
   Subsystem 2 - Component: Fehler Lin-Slave 02
   Part No SW: 4L0 910 111 A    HW: 4L0 035 111
   Component: CD-Changer      H41 0100
   Revision: 00000000    Serial number: AUZ5ZBF3021208
   VCID: 1E652272DCB4E797604-804A
Address 15: Airbags
   Component: Lenks‰ulenmodul H08 0230
   Revision: 00H08000    Serial number: 90054061490030
   Coding: 0002042
   VCID: 66954A924464FF57E84-8032
Address 17: Instruments        Labels: 4L0-910-xxx-17.lbl
   Part No SW: 4F0 910 930 C    HW: 4L0 920 930 H
   Component: KOMBIINSTR. M73 H17 0090
   Revision: 00100000    Serial number: 5HG327666
   Coding: 2593043
   Shop #: WSC 00210 218 186747
   VCID: 23131386F7D6CA7F4FA-8076
Address 18: Aux. Heat        Labels: None
   Part No SW: 4L0 910 105     HW: 4L0 265 105 E
   Component: Heizgeraet      H07 0050
   Revision: 0000000D    Serial number: 00000009011043
   Coding: 0000101
   VCID: 60995C8AA6409167128-8034
02245 - Connection; RF Remote Control
00664 - Fuel gauge
   Part No SW: 4L0 910 468     HW: 4L0 907 468
   Component: J533__Gateway   H06 0040
   Revision: 00H06000    Serial number: 0900B065298037
   Coding: F75BBE7F303202
   VCID: 6C8138BA5A88C507BE0-8038
Address 34: Level Control
   Part No SW: 4E0 910 887 Q    HW: 4E0 919 887 D
   Component: MNS ECE         H47 0850
   Revision: 00000000    Serial number: 399EW067525162
   VCID: 3B23CBE66F6692BF67A-806E
Address 46: Central Conv.
Address 47: Sound System        Labels: 4F0-910-223-AS.lbl
   Part No SW: 4L0 910 223 B    HW: 4L0 035 223
   Component: DSP-AU716       H20 0100
   Revision: 10S00001    Serial number: 00106060286869
            000 -  -  - Intermittent
                    Fault Frequency: 9
                    Reset counter: 1
   Part No SW: 4F0 910 280     HW: 4F0 907 280
   Revision:             Serial number: 00000000149511
   Coding: 0011001
   VCID: 5EE562729C34A797204-800A
Address 52: Door Elect, Pass.
Address 55: Headlight Range
   Part No SW: 4E0 910 541 M    HW: 4E0 035 541 P
   Component: TUNER EU/US/RDW H42 0570
   Revision: 00000000    Serial number: 388EY067530467
   VCID: 2A0DFEA290FC1B370CC-807E
   Part No SW: 4L0 910 181 A    HW: 4L0 915 181
   Component: J0644 BEM       H12 0690
   Revision: --------    Serial number: 00000000001825
   Shop #: WSC 53834 000 1048576
   VCID: 25170D9EF9E2344F21E-8070
   Subsystem 1 - Part No: 009 2S5 015 0
   Component: von 404  7024016989
   Coding: 303039325335303135302034303437303234303136393839
   Shop #: WSC 80093 222 69422
02256 - Quiescent Current
                    Fault Status: 00100001
                    Fault Frequency: 18
                    Reset counter: 41
                    Mileage: 197657 km
                    Date: 2018.03.14
                    Time: 00:38:02
                    Fault Frequency: 11
                    Mileage: 197657 km
                    Date: 2018.03.15
                    Time: 05:41:00
Address 62: Door, Rear Left
   Coding: 0000111
                    Reset counter: 246
                    Mileage: 197656 km
                    Date: 2018.03.13
                    Time: 17:20:00
                    Reset counter: 1
                    Mileage: 198160 km
                    Date: 2018.03.26
                    Time: 19:23:00
   Part No SW: 4L0 910 945     HW: 4L0 827 851 A
   Component: ValeoHeckdeckel H20 0280
   Revision: --H20001    Serial number: E5030000B
   Shop #: WSC 98765 666 38354
   Subsystem 3 - Serial number: RD02.06.06--H20001001B0129ˇ
   Subsystem 4 - Serial number: 1B0129ˇ
Address 6F: Centr. Conv. II
Address 72: Door, Rear Right
   Part No SW: 4F0 910 283 E    HW: 4F0 919 283 E
   Component: Parkhilfe 8-Kan H12 0030
   Revision: 00H12000    Serial number: 11820615801792
   Coding: 0211046
   VCID: 26150A9284E43F57284-8072
Address 77: Telephone        Labels: 4E0-910-333.lbl
   Part No SW: 4E0 910 333 F    HW: 4E0 862 333 C
   Component: TELEFONMODUL EU     0770
   Revision: 00000008    Serial number: T2AUDX0806JHTZ
   Coding: 0000003
   VCID: 221D1682E8CCC37744C-8076
End----(Elapsed Time: 01:35, VBatt start/end: 11.9V/11.8V. VIgn 0.0V)------
Address 69,4L0 910 383 ,recoded (Short coding),from,0000111,to,0000011,(00000/000/00000),
Address 69,4L0 910 383 ,recoded (Short coding),from,0000011,to,0000011,(00000/000/00000),
Chassis Type: 4L0
Address 01: Engine
   Coding: 0000131
00956 - Key 2
                    Reset counter: 40
                    Mileage: 197865 km
                    Date: 2018.03.22
                    Time: 08:45:40
            014 - Defective
                    Reset counter: 1
                    Mileage: 198160 km
                    Date: 2018.03.25
                    Time: 09:20:47
   Coding: 0002001
   Coding: 0002070
                    Reset counter: 246
                    Mileage: 197657 km
                    Date: 2018.03.13
                    Time: 16:49:34
   Coding: 0002121
Address 15: Airbags
   Coding: 0002042
   Coding: 2593043
   Coding: 0000101
00664 - Fuel gauge
                    Fault Frequency: 9
                    Reset counter: 1
   Coding: 0011001
                    Fault Frequency: 18
                    Reset counter: 41
                    Mileage: 197657 km
                    Date: 2018.03.14
                    Time: 00:38:02
                    Fault Frequency: 19
                    Mileage: 197657 km
                    Date: 2018.03.15
                    Time: 05:41:00
   Coding: 0000011
                    Reset counter: 246
                    Mileage: 197656 km
                    Date: 2018.03.13
                    Time: 17:20:00
                    Reset counter: 1
                    Mileage: 198160 km
                    Date: 2018.03.26
                    Time: 19:23:00
   Coding: 0211046
   Coding: 0000003
End----(Elapsed Time: 01:51, VBatt start/end: 11.8V/11.5V. VIgn 0.0V)------
Chassis Type: 4L (4L0)
VIN: WAUZZZ4L57D023585   Mileage: 198160km-123130miles
Address 01: Engine        Labels: 059-907-401-ASB.clb
   Part No SW: 4L0 910 401 K    HW: 4L0 907 401
   Component: 3.0L V6TDI  G001AG  0030
   Revision: --H03---    Serial number:
   Coding: 0011775
   Shop #: WSC 35110 210 01865
Readiness: 0 0 0 X 0
   Part No SW: 09D 927 750 DG    HW: 09D 927 750 DG
   Component: AL 750 6A           0867
   Revision: 00H52000    Serial number:
   Coding: 0000504
   VCID: 76B51AD214C40FD7584-8022
18010 - Power Supply Terminal 30
            P1602 - 007 - Voltage too Low
Address 03: ABS Brakes        Labels:. 4L0-910-517-V1.clb
   Part No SW: 4L0 910 517 A    HW: 4L0 614 517 A
   Component: ESP ALLRAD MK25E1   0130
   Revision: 00H21001
   Coding: 0038017
   VCID: 280904AA8EF029271A8-807C
   Coding: 0000131
   Coding: 0002070
                    Reset counter: 1
                    Mileage: 198160 km
                    Date: 2018.04.04
                    Time: 20:29:47
   Coding: 0002121
   Component: Wischer AU716   H11 0030
   Coding: 00064792
   Shop #: WSC 31414
   Component: REGENLICHTSENSORH12 0090
   Coding: 00150059
   Shop #: WSC 31414
   Part No SW: 4L0 910 655 B    HW: 4L0 959 655
   Component: 30 AIRBAG AUDI8RH38 0120
   Revision: 05H38000    Serial number: 0037GD067G2R
   Coding: 0013104
   VCID: 2C01F8BA9A080507FE0-8078
   Subsystem 1 - Serial number: 6332QSME10294C5DL
   Subsystem 2 - Serial number: 6342QSME1031330D0
   Subsystem 3 - Serial number: 6352QSME0B44221BC
   Subsystem 4 - Serial number: 6362QSME0F79415BU
   Subsystem 5 - Serial number: 63734SME0C261179$
   Subsystem 6 - Serial number: 63834SME0C2F107B7
   Coding: 0002042
   Coding: 2593043
   Coding: 0000101
00664 - Fuel gauge
Address 34: Level Control        Labels: None
   Part No SW: 4L0 910 553 B    HW: 4L0 907 553
   Component: LUFTFDR.-CDC    H03 7550
   Revision: --H03001    Serial number: 15.1528-0082.2
   Coding: 0015520
   VCID: 290F01AE95FA102F056-807C
00142 - Left Front Dampening Adjustment Valve (N336)
                    Fault Status: 11101100
                    Fault Frequency: 40
                    Reset counter: 1
                    Mileage: 197054 km
                    Date: 2018.02.27
                    Time: 17:26:44
                    Error Code: 210
01577 - Turn-Off due to Over-Temp
                    Reset counter: 30
                    Mileage: 197056 km
                    Date: 2018.03.01
                    Time: 10:08:19
                    Error Code: 68
                    Fault Status: 11100010
                    Reset counter: 1
                    Mileage: 197657 km
                    Date: 2018.03.17
                    Time: 09:24:53
                    Error Code: 13
Address 42: Door Elect, Driver        Labels: 4L0-910-793-42.lbl
   Part No SW: 4L0 910 793 B    HW: 4L0 959 793 B
   Component: TSG FA          H12 0130
   Revision: 00-00000
   Coding: 0000523
   VCID: 2F3BEFB6AB1E7E1FDB2-807A
   Part No SW: 4L0 910 289 D    HW: 4L0 907 289 A
   Component: Komfortgeraet   H05 0020
   Revision: 0020 ---    Serial number: 01014081030000
   Coding: 7602309
   Coding: 0011001
Address 52: Door Elect, Pass.        Labels: 4L0-910-793-52.lbl
   Part No SW: 4L0 910 793 B    HW: 4L0 959 792 B
   Component: TSG BF          H12 0130
   Revision: 00-00000
   Coding: 0000523
   Part No: 8P0 907 357 F
   Coding: 0000008
   VCID: 3D27C5FE71729C8F59E-8068
Address 56: Radio
                    Mileage: 198160 km
                    Date: 2018.04.04
                    Time: 20:32:35
Address 62: Door, Rear Left        Labels: 4L0-910-795.lbl
   Part No SW: 4L0 910 795 C    HW: 4L0 959 795 C
   VCID: 323DE6C2B82C53F7B4C-8066
   Coding: 0000011
                    Reset counter: 246
                    Mileage: 197656 km
                    Date: 2018.03.13
                    Time: 17:20:00
                    Reset counter: 1
                    Mileage: 198160 km
                    Date: 2018.03.26
                    Time: 19:23:00
   Component: ILM HINTEN 2    H05 0040
   Revision: AAH05044    Serial number: 001690956-----
   Coding: 0003587
   Component: J_245_EE16_SKB10H14 0220
   Component: J_394_EE14_SKB09H10 0160
   Component: J_392_EE14_SKB09H10 0160
Address 72: Door, Rear Right        Labels: 4L0-910-795.lbl
   Part No SW: 4L0 910 795 C    HW: 4L0 959 794 C
   Coding: 0211046
End----(Elapsed Time: 01:47, VBatt start/end: 11.0V/11.1V. VIgn 11.1V)-----
VCDS Release 18.2.0:  SRI Reset
Control Module Part Number: 4F0 910 930 C       Labels:  4L0-910-xxx-17.lbl
Component:KOMBIINSTR. M73 H17 0090, Coding:2593043
Channel  	Description                                       	Unit      	Current val.  	New val.
02       	Service Reminder Status                           	          	0             	---
40       	Mileage since Service                             	DIST x100 	0             	---
41       	Time since Service                                	Days      	121           	---
42       	Min Mileage to Service                            	km x100   	150           	---
43       	Max Mileage to Service                            	km x100   	150           	---
44       	Max Time to Service                               	Days      	365           	---
45       	Oil Quality                                       	          	1             	---
47       	Soot Quantity                                     	km x100   	79            	---
48       	Thermal Load                                      	km x100   	44            	---
49       	Min Time to Service                               	Days      	365           	---
Operation: Service Reset
02       	Service Reminder Status                           	          	0             	0
Address 17,4F0 910 930 C,channel 2,adapted from,0,to,00000,
Address 69,4L0 910 383 ,recoded (Short coding),from,0000011,to,0000111,(00000/000/00000),
PetrolDave
Westbury, UK
C?ID=1423
There are an awful lot of "Cannot be reached" errors in that scan, did you make it with the ignition on?
If not then please post another one taken with the ignition turned on so that all the controller data can be seen.
ottotorvik
Norway
C?ID=333027
New scan, ignition on, as it was the first time.
Sunday,14,October,2018,15:18:26:13094
VCDS Version: 18.9.0.2  HEX-V2 CB: 0.4436.4
Mileage: 206890km-128555mi   Repair Order:
VIN: WAUZZZ4L57D023585   Mileage: 206890km-128555miles
0E-Media Player 1 -- Status: Malfunction 0010
69-Trailer -- Status: Malfunction 1010
   Coding: 0011775
   VCID: 2A0DFEA290FC1B37E01-807E
005746 - Coolant Fan Control 1
               P1672 - 001 - Open or Short to Ground - Intermittent
                    Mileage: 206874 km
                    Date: 2018.10.09
                    Time: 12:00:48
                    RPM: 756 /min
                    Torque: 74.1 Nm
                    Duty Cycle: 28.8 %
                    Voltage: 14.14 V
                    Duty Cycle: 28.8 %
                    Duty Cycle: 28.8 %
   Coding: 0000504
   VCID: 76B51AD214C40FD7B49-8022
   Revision: 00H21001
   Coding: 0038017
   VCID: 280904AA8EF02927F65-807C
                    Reset counter: 44
                    Mileage: 206871 km
                    Date: 2018.10.09
                    Time: 10:34:27
                    Count: 192
                    Count: 6913
                    Count: 297
                    Count: 34560
   Coding: 0000131
   VCID: 63935386B7568A7FE37-8036
02401 - Terminal 75x
                    Fault Status: 00100110
                    Reset counter: 44
                    Mileage: 206874 km
                    Date: 2006.01.24
                    Time: 18:31:23
   Coding: 0002001
   VCID: 3FDBBFF67B7E8E9FA7F-806A
00384 - Optical Databus
                    Fault Status: 00101011
                    Fault Frequency: 86
                    Reset counter: 46
                    Time Indication: 15
02259 - Information Display and Control Head (Front) (J685)
                    Reset counter: 44
                    Mileage: 206874 km
                    Date: 2018.10.09
                    Time: 14:32:07
                    Bin. Bits:  0000010
00658 - Control Head
                    Reset counter: 40
                    Mileage: 206874 km
                    Date: 2018.10.09
                    Time: 14:36:49
   Coding: 0002070
   VCID: 619F598EAD4A986FF1B-8034
                    Reset counter: 3
                    Mileage: 206871 km
                    Date: 2018.10.09
                    Time: 07:38:35
   Coding: 0002121
   VCID: 313FE9CEBD2A68EF21B-8064
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
   VCID: 1E652272DCB4E7978C9-804A
02261 - Data Medium
                    Fault Status: 00101110
                    Reset counter: 44
                    Mileage: 206873 km
                    Date: 2006.01.23
                    Time: 12:00:23
                    Text: 00000000
   Coding: 0013104
   VCID: 2C01F8BA9A08050712D-8078
   Coding: 0002042
   VCID: 66954A924464FF57049-8032
   Coding: 2593043
   VCID: 23131386F7D6CA7FA37-8076
02759 - Operating Switch for Instrument Cluster
                    Fault Status: 00101010
                    Reset counter: 44
                    Mileage: 206874 km
                    Date: 2018.10.09
                    Time: 14:14:03
   Coding: 0000101
   VCID: 60995C8AA6409167FE5-8034
   VCID: 6C8138BA5A88C50752D-8038
01517 - Control Module for Trailer/Towing Sensor (J345)
                    Reset counter: 43
                    Mileage: 206871 km
                    Date: 2018.10.09
                    Time: 09:07:52
                    Fault Frequency: 7
                    Reset counter: 46
                    Mileage: 206871 km
                    Date: 2018.10.09
                    Time: 09:07:58
Address 34: Level Control        Labels: 4L0-910-553.lbl
   Coding: 0015520
   VCID: 290F01AE95FA102FE9B-807C
                    Fault Frequency: 17
                    Reset counter: 6
                    Mileage: 206871 km
                    Date: 2018.10.09
                    Time: 07:39:01
                    Error Code: 210
                    Reset counter: 46
                    Mileage: 206873 km
                    Date: 2018.10.09
                    Time: 10:40:15
                    Error Code: 68
                    Reset counter: 44
                    Mileage: 206874 km
                    Date: 2018.10.09
                    Time: 14:36:58
                    Error Code: 13
   VCID: 3B23CBE66F6692BF8B7-806E
   Revision: 00-00000
   Coding: 0000523
   VCID: 2F3BEFB6AB1E7E1F37F-807A
   Coding: 7602309
   Coding: 0011001
   VCID: 5EE562729C34A797CC9-800A
   Revision: 00-00000
   Coding: 0000523
   Coding: 0000008
   VCID: 3D27C5FE71729C8FB53-8068
   VCID: 25170D9EF9E2344FCD3-8070
   Subsystem 1 - Part No: 000 915 105 DL
   Component: von VA0  070928S0TJ
   Coding: 303030393135313035444C5641303037303932385330544A
                    Fault Frequency: 9
                    Mileage: 206871 km
                    Date: 2018.10.09
                    Time: 07:45:19
   VCID: 323DE6C2B82C53F7581-8066
   Coding: 0000111
   VCID: 688944AA4E70E927365-803C
                    Reset counter: 3
                    Mileage: 206868 km
                    Date: 2018.10.09
                    Time: 07:38:00
   Coding: 0003587
   VCID: 26150A9284E43F57C49-8072
02914 - Sensor 1 for Trunk/Hatch Closed (G525)
                    Reset counter: 43
                    Mileage: 206871 km
                    Date: 2018.10.09
                    Time: 09:07:52
02915 - Sensor 2 for Trunk/Hatch Closed (G526)
                    Reset counter: 43
                    Mileage: 206871 km
                    Date: 2018.10.09
                    Time: 09:07:52
   Coding: 0211046
   Coding: 0000003
   VCID: 221D1682E8CCC377A81-8076
02387 - Telephone Mount (R126)
                    Reset counter: 4
                    Mileage: 206874 km
                    Date: 2018.10.09
                    Time: 13:34:37
End----(Elapsed Time: 02:07, VBatt start/end: 11.6V/11.6V. VIgn 11.6V)-----
I would guess the first time, lots of stuff had shout down due to low voltage: 11.0V/11.1V. VIgn 11.1V
ottotorvik
Norway
C?ID=333027
There is a lot of "Malfunction" going on. Is it a good or bad Idea to erase faults and do a complete new scan?
PetrolDave
Westbury, UK
C?ID=1423
IMHO a good idea, so you are able to see what faults exist now.
ottotorvik
Norway
C?ID=333027
New scan. Cleared all faults before doing a complete new scan.
Monday,15,October,2018,17:45:16:13094
Mileage: 206910km-128567mi   Repair Order:
VIN: WAUZZZ4L57D023585   Mileage: 206910km-128567miles
   Coding: 0011775
                    Mileage: 206874 km
                    Date: 2018.10.09
                    Time: 12:00:48
                    RPM: 756 /min
                    Torque: 74.1 Nm
                    Duty Cycle: 28.8 %
                    Voltage: 14.14 V
                    Duty Cycle: 28.8 %
                    Duty Cycle: 28.8 %
   Coding: 0000504
   Revision: 00H21001
   Coding: 0038017
   Coding: 0000131
   Coding: 0002001
   Coding: 0002070
                    Reset counter: 8
                    Mileage: 206912 km
                    Date: 2006.01.28
                    Time: 21:54:04
   Coding: 0002121
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
   Coding: 0013104
   Coding: 0002042
   Coding: 2593043
   Coding: 0000101
   Coding: 0015520
                    Reset counter: 8
                    Mileage: 206912 km
                    Date: 2006.01.28
                    Time: 21:54:38
                    Error Code: 210
   Revision: 00-00000
   Coding: 0000523
   Coding: 7602309
   Coding: 0011001
   Revision: 00-00000
   Coding: 0000523
   Coding: 0000008
   Coding: 0000111
                    Reset counter: 8
                    Mileage: 206912 km
                    Date: 2006.01.28
                    Time: 21:53:00
   Coding: 0003587
   Coding: 0211046
   Coding: 0000003
                    Reset counter: 8
                    Mileage: 206912 km
                    Date: 2006.01.28
                    Time: 21:54:04
End----(Elapsed Time: 02:05, VBatt start/end: 12.3V/12.0V. VIgn 11.9V)-----
