Škoda Superb MY20 - Activate high beam assistant
Super-VAG
Israel
C?ID=292490
Hello everyone,
I'm trying to activate high beam assistant,
But I get different results from what is written in the instructions:
The instructions I have are:
Control unit: 09 , Adaptation:
Fernlicht_assistent-Menuesteuerung Fernlichtassistent Werkseinstellung
set to: present
set to: present
Fernlicht_assistent-Erweiterte_Fernlichtsteuerung
If the initial value here is:
"AFS, Fernlicht ueber AFS"
set to:
"AFS, FLA, Fernlicht ueber AFS"
or
"AFS, BCM-Fernlicht"
set to:
"AFS, FLA, BCM-Fernlicht"
But in my case the value that appears is:
Basis
What should I write on this channel?
or
Thanks!:)
Thursday,27,February,2020,17:04:59:56248
VCDS Version: 19.6.2.2 (x64)  HEX-NET CB: 0.4508.4
VIN: TMBAN7NPXL7031966   License Plate: YAKIR SUPERB
Mileage: 1123km-697mi   Repair Order:
Chassis Type: NP-SK48 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 23 2B 36 3C 42 44 52 5F 6C
          A5 BB BC
VIN: TMBAN7NPXL7031966   Mileage: 1123km-697miles
Address 01: Engine (J623-DPCA)       Labels: None
   Part No SW: 05E 906 018 BE    HW: 05E 907 309 H
   Component: R4 1.5l TFS   H20 9598
   Revision: 8AH20000
   Coding: 012500322364050830000000000000000000000000000000
   ASAM Dataset: EV_ECM15TFS01105E906018BE 003003
   ROD: EV_ECM15TFS01105E906018BE_SK48.rod
   VCID: 699A9B2288A25A0712-803C
   Part No SW: 0CW 300 050 A    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 1703
   Revision: 00005008    Serial number: CU501910255825
   Shop #: WSC 00033 790 00158
   ROD: EV_TCMDQ200021_VW31.rod
   VCID: 3326394A9AEED0D768-8066
   Part No SW: 5Q0 614 517 FA    HW: 5Q0 614 517 BR
   Component: ESC           H82 0190
   Revision: 00000000    Serial number: 62909000000927
   Coding: 1D077A9C31233B6D4780060660C949B85E8CDCE2600692753821F078D2824A0B0003000012121212B835351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 038007
   ROD: EV_Brake1UDSContiMK100IPB_038.rod
   VCID: 75A2C752D41A8EE786-8020
   Part No SW: 3Q0 959 435 N    HW: 3Q0 959 435 N
   Component: VWKESSYMQB    037 1307
   Revision: 00037000    Serial number: 0531581301
   Coding: 0F20000723
   ASAM Dataset: EV_KessyHellaMQBAB 004052
   VCID: 45C27792C47A5E67D6-8010
   Part No SW: 3V0 907 044 FJ    HW: 3V0 907 044 FJ
   Component: AC Automat    H34 4803
   Revision: 20K10000    Serial number: 00000B01524887
   Coding: 11010004000110011005000000101026
   ASAM Dataset: EV_ACClimaPrehVW37X 002027
   ROD: EV_ACClimaPrehVW37X.rod
   VCID: 014AA38290D2B247AA-8054
   Subsystem 1 - Part No SW: 5Q0 907 659 C    HW: 5Q0 907 659 C
   Component: G238 _AQS  H30 0119
   Serial number: 95109976
   Part No SW: 5Q0 937 086 CE    HW: 5Q0 937 086 BQ
   Component: BCM PQ37BOSCH 038 0303
   Revision: --------    Serial number: J53F12101900D5
   ASAM Dataset: EV_BodyContrModul1UDSBosc 020001
   ROD: EV_BCMBOSCH_020_VW27.rod
   VCID: 7F4E257AE626C4B7DC-802A
   Subsystem 1 - Part No SW: 3V1 955 119     HW: 3V1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: 48x LL 041019  032  0121
   Serial number: 00000001910020306562
   Coding: 165DDD
   Subsystem 2 - Part No SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Labels: 5Q0-955-547.CLB
   Component: RLHS  051  0206
   Serial number: S6Y19M10D22H23M51S46
   Coding: 00084D
   Steering Column Switch:
   Subsystem 4 - Part No SW: 5Q1 953 521 CJ    HW: 5Q1 953 569 A
   Component: Lenks.Modul  H13  0170
   Serial number: 0100101020190C203454
0531 - Footwell Illumination
          B11FF 01 [009] - Electrical Failure
                    Fault Frequency: 161
                    Reset counter: 103
                    Mileage: 145 km
                    Date: 2020.01.12
                    Time: 21:38:25
   Part No SW: 5QA 919 283 E    HW: 5QA 919 283
   Component: PDC 4 Kanal   H08 0061
   Serial number: 000150059319291
   Coding: 0601154011
   Shop #: WSC 00033 790 00120
   ASAM Dataset: EV_EPHVA14AU3700000 009044
   ROD: EV_EPHVA14AU3700000_009.rod
   VCID: 4CD442B6E710AF2F09-8018
   Part No SW: 5Q0 907 572 R    HW: 3Q0 907 567 A
   Component: ACC BOSCH MQB H01 0771
   Coding: 3204675111FFC728949C812480400600000000000000000046
   Shop #: WSC 00033 790 00121
   ASAM Dataset: EV_ACCBOSCHVW416 003014
   ROD: EV_ACCBOSCHVW416_003.rod
   VCID: 46C0709EF97C557FDF-8012
0858 - Databus
          [FAULT_KAMERA_SYSTEMZUSTAND_KAMERA_IM_INIT]
                    Fault Frequency: 38
                    Reset counter: 179
                    Mileage: 792 km
                    Date: 2020.02.03
                    Time: 13:12:45
                    Control Module temperature: 38 °C
                    Voltage terminal 15-Voltage: 14.2 V
                    Vehicle speed: 7.28 m/s
                    Longitudinal acceleration: 0.27 m/s²
                    Adaptive distance regulation: status: ACC_reversible_error
1232 - Databus
          [FAULT_VIDEO_SIGNAL_LIST]
                    Fault Frequency: 25
                    Reset counter: 218
                    Mileage: 792 km
                    Date: 2020.02.03
                    Time: 13:12:43
                    Voltage terminal 15-Voltage: 14.1 V
                    Vehicle speed: 5.74 m/s
                    Longitudinal acceleration: 1.13 m/s²
                    Adaptive distance regulation: status: ACC_Off_MainSwitch_Off
   Part No SW: 5Q0 959 655 BS    HW: 5Q0 959 655 BS
   Component: AirbagVW21    008 0403
   Serial number: 003FMR5U7Y5J
   Coding: 98CCC0C0000000005C5400CF000800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 12689CCEC5B439DF03-8046
   Subsystem 1 - Part No SW: -----------    HW: 480 001 910 19
   Serial number: 357000000009BB98414T
   Subsystem 2 - Part No SW: -----------    HW: 480 001 810 19
   Serial number: 35800000000828297F3R
   Subsystem 3 - Part No SW: -----------    HW: 480 401 910 19
   Component: SideSensor_Dr  005 6149
   Serial number: 3510001A6F203242D11Q
   Subsystem 4 - Part No SW: -----------    HW: 480 401 410 19
   Component: SideSensor_Pr  004 6149
   Serial number: 35200010C2CA45C3D132
   Subsystem 5 - Part No SW: -----------    HW: 480 401 510 19
   Component: FrontSensor_D  005 6149
   Serial number: 3550001A0F2FD2081396
   Part No SW: 3V0 920 740 E    HW: 3V0 920 740 E
   Component: KOMBI         203 6700
   Coding: 07A5011A6788000801882A0B1001000080000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009069
   ROD: EV_DashBoardVDDMQBAB_SK48.rod
   VCID: 34243A569FE0D7EF71-8060
   Part No SW: 3Q0 907 530 AC    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5388
   Serial number: 25101910802820
   Coding: 0B0100047F08570021100250100F00010001070000000000000000000000
   Shop #: WSC 00033 790 00138
   ASAM Dataset: EV_GatewNF 013026
   ROD: EV_GatewNF.rod
   VCID: 70ACF646AB78ABCF55-8024
   Component: 5-01-14-01-04
   Subsystem 2 - Part No SW: 3V0 919 719 E    HW: 3V0 919 719 E
   Component: E221__MFL-PR6  H03 0180
   Serial number: 000000000D0730211019
   Serial number: 3608302905
   Power Converter DC AC:
   Subsystem 4 - Part No SW: 5Q0 907 155 B    HW: 5Q0 907 155 B
   Component: U13DCAC  H27 0810
   Serial number: 2175302
Address 23: Brake Booster (J539)       Labels: None
   Part No SW: 3Q0 909 059 G    HW: 3Q0 909 059 A
   Component: EBKV          H06 0069
   Serial number: BPA085091019013
   Coding: 0102C100340000C618638C31000049922449920400
   ASAM Dataset: EV_BrakeBoostG2BoschVW48X 011019
   ROD: EV_BrakeBoostG2BoschVW48X_011_VW41.rod
   VCID: 3B36116AB2BE1897B0-806E
   Part No SW: 3Q0 905 861 B    HW: 3Q0 905 861 B
   Component: ELV-MQBB      H05 0020
   Serial number: 19000278009010
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_AU37.rod
   Part No SW: 5Q0 959 760 E    HW: 5Q0 959 760 E
   Component: Sitzmemory    H09 0026
   Serial number: Y0007SIJ30934
   Coding: 0010000000000500018480808080000000008181000000D400
   ASAM Dataset: EV_SeatMemorDriveSide 002022
   VCID: 3FCE657AA6A604B79C-806A
Address 3C: Lane Change (J1086)       Labels:* None
   Part No SW: 2Q0 907 686 B    HW: 2Q0 907 686 B
   Component: HRE3_Kl15_Mst H06 0149
   Serial number: 00000529260546
   Coding: 52954640
   ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
   ROD: EV_HREntryHellaGen3Kl15.rod
   VCID: 393A0B62B8822A87A2-806C
Address 42: Door Elect, Driver (J386)       Labels:* Redir Fail!
   Part No SW: 5Q4 959 593 K    HW: 5Q4 959 593 K
   Component: TSG FS        007 0485
   Serial number: 0000393741661
   Coding: 001D8120DE00020000001100
   VCID: 4DD24FB21C0AA6271E-8018
Address 44: Steering Assist (J500)       Labels:| 5Q0-910-143.clb
   Part No SW: 5Q0 910 143 C    HW: 5Q0 910 143
   Component: MQB_VWBS_GEN2 212 2211
   Serial number: 958040 00
   Coding: 0100001100400010
   ASAM Dataset: EV_SteerAssisVWBSMQBGen2 002119
   ROD: EV_SteerAssisVWBSMQBGen2_VW37.rod
   VCID: 2B16212A42DE881720-807E
Address 52: Door Elect, Pass. (J387)       Labels:* Redir Fail!
   Part No SW: 5Q4 959 592 K    HW: 5Q4 959 592 K
   Component: TSG BFS       007 0485
   Serial number: 0000394157163
   ROD: EV_DCU2PasseSideMAXHCONT_SK37.rod
   Part No SW: 565 035 842     HW: 565 035 842
   Component: MU-S-D-ER     H41 0478
   Serial number: SKZAZ2W1079111
   Coding: 03840100FF0000004111000100810A232F0208C40120050003
   ROD: EV_MUStd4CTSAT_VW41.rod
   VCID: 56E0A0DE29DCE5FFAF-8002
   Subsystem 1 - Part No SW: 3V0 919 605 E    HW: 3V0 919 605 E
   Component: ABT_Std-2  H53 8130
   Serial number: SKZ6ZHW3022798
   Component: RVC Compact   H18 0231
   Coding: 04840101A2002017000040
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* None
   Part No SW: 2Q0 980 653     HW: 2Q0 980 653
   Component: MQB MFK 3.0   H11 1027
   Serial number: E33417011192960
   Coding: 0002018800684028B09F00000020000001210000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 005035
   ROD: EV_MFK3ValeoMQB_005_AU37.rod
   VCID: 72A8FC4EA57499DFA3-8026
1124116 - Internal Fault
          B200F F0 [008] - Unknown Error Elaboration
          [SPI_communication_to_EyeQ_timout]
                    Fault Frequency: 10
                    Reset counter: 18
                    Mileage: 1027 km
                    Date: 2020.02.23
                    Time: 16:44:38
1124105 - Internal Fault
          B200F F4 [008] - Unknown Error Elaboration
          [EyeQ_Init_error]
                    Reset counter: 33
                    Mileage: 982 km
                    Date: 2020.02.17
                    Time: 12:11:11
   Part No SW: 8W0 959 595 M    HW: 8W0 959 595 J
   Component: TSG HFS       010 0384
   Serial number: 0000393979683
   Coding: 001881208000020000001100
   Component: TSG HBFS      010 0384
   Serial number: 0000393978899
End----------(Elapsed Time: 01:34, VBatt start/end: 12.2V/12.2V)-----------
golfi_vend
Tartu, Estonia
C?ID=195131
Where is autoscan?
Halogen Headlights?
Super-VAG
Israel
C?ID=292490
I added the autoscan,I have LED Headlights.
dark5had0w
Australia
C?ID=356542
the MY20 Superb, which i believe is the Facelift version, has an entirely different headlight setup altogether - so i would not be surprised at all that the instructions for HBA does not work for you.
Super-VAG
Israel
C?ID=292490
it is the Facelift version,
Another strange thing is that according to the instructions it should look like this:
Control unit: A5
Long coding
Activate byte 21 - bit 5-7
Change to: (20) Fernlichtassistent/High Beam Assist
But I found it on:
byte 15 - bit 5-7
:confused:
TBAx
C?ID=287144
You have a MFK 3.0, not much is known about it. So it's expected, that bytes have changed. Glad you found it anyway.
