Errors with '07 Beetle
atc98092
Washington, USA
C?ID=240299
Greetings all!
Finally got around to buying the cable. With all the VWs I have in the family, it's silly I hadn't bought it earlier.
So, my daughter's '07 Beetle. Air bag and seat belt warning lights on. Also, the key fob will not lock/unlock remotely. Below is the auto-scan results:
Wednesday,04,March,2015,14:16:59:55621
VCDS Version: 14.10.1.1 (x64)
Data version: 20150130
VIN: 3VWEW31C77M5xxxxx   License Plate: Yes :)
Mileage: 127980km-79523mi   Repair Order:
Chassis Type: 1C (1C - VW New Beetle (1998 > 2010))
Scan: 01 02 03 08 15 17 19 22 25 26 29 35 37 39 46 54 56 65 75
VIN: 3VWEW31C77M5xxxxx   Mileage: 127980km-79523miles
Address 01: Engine        Labels: 06A-906-032-BGP.lbl
   Part No SW: 07K 906 032 AD    HW: 07K 906 032 AA
   Component: NB/C R5 MT      G   9657
   Revision: --H01---    Serial number: VWZ5Z0F9257069
   VCID: 6BD5F85E4A5CB579AB2-803E
001796 - Clutch Switch (F36)
               P0704 - 004 - Implausible Signal
                    Mileage: 116562 km
                    RPM: 1711 /min
                    Load: 43.1 %
                    Speed: 65.0 km/h
                    Temperature: 86.0*C
                    Temperature: 27.0*C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 13.843 V
Address 03: ABS Brakes        Labels: 1C0-907-37x-ESP-F.lbl
   Part No: 1C0 907 379 Q
   Coding: 0019978
   VCID: 387F1712488ACEE1960-5140
Address 15: Airbags        Labels: 1T0-909-605.lbl
   Part No: 6Q0 909 605 AK
   Component: 01 AIRBAG VW71      0911
   Coding: 0012337
   VCID: 000FBFF257DA46216E0-8055
   Subsystem 1 - Component: BF-Gewichtsens.
00591 - Seat Belt Switch; Driver (E24)
Address 17: Instruments        Labels: None
   Part No: 1C0 920 803 B
   Component: KOMBI+WEGFAHRS. M73 V02
   Coding: 11232
   Shop #: WSC 00066
   VCID: 1C37EB828C7282C1928-4B00
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    V022
   Coding: 00006
   Shop #: WSC 00066
   VCID: 70EFEF32307A56A19E0-4B00
Address 25: Immobilizer        Labels: 1C0-920-xxx-25.clb
   Part No SW: 1C0 920 803 B    HW: 1C0 920 803 B
   Component: IMMO                X007
   Revision: xxxxxxxx    Serial number: VWZ5Z0F9257069
   Shop #: WSC 23328 444 52435
   VCID: 1C37EB82DC7282C1928-5140
   Part No: 1C0 959 799 G
   Component: 2K Komfortgerát HLO 0004
   Coding: 00064
   Shop #: WSC 00066
   VCID: 3B75081E29BCE5F97B2-4B00
   Subsystem 1 - Part No: 1C2959802A
   Component: 2K Tõrsteuer.FS KLO 0202
   Subsystem 2 - Part No: 1C2959801A
   Component: 2K Tõrsteuer.BF KLO 0202
Address 56: Radio        Labels: 1J0-035-18x-56.lbl
   Part No: 1C0 035 196 BF
   Component:  RADIO DE2         0006
   Coding: 00401
   Shop #: WSC 00066
   VCID: 64C79362F482FA01EA8-51D4
End-------------------------(Elapsed Time: 04:44)--------------------------
I have a hunch the address 46 error is why the key fob won't work. As an aside, I did try reprogramming the fob, and the horn beeped as expected. Still won't work. What I don't know is where to start looking for this. Where on the front passenger side would I find what it's referring to? Does it mean the actual power actuator within the door?
It looks like the air bag light illuminates even with the seat belt switch error. I have no idea what is meant by "Implausible Signal", and that crops up with the clutch error as well. Doesn't seem to be any issue with the clutch operations. But I'm guessing that replacing the driver's seat belt switch will resolve the airbag light.
Any other suggestions on where I should be looking, based on this scan? I've been around cars a long time, and can usually fix almost anything if I know where to look.
Thanks!
Jef
HQ
IBJ
The (E24) is the driver's seat belt latch, right there at your right side hip. These fail since the head mounted on top of flexable steel cables, thus the wiring that runs into the belt latch get stressed a lot from wiggling around. MVB 003.3 should show the belt latch status. Buckle up the driver's seat and wiggle it around and see if values change as you do so.
The F221 is a switch with the d̶r̶i̶v̶e̶r̶'̶s̶ passenger's door latch. I doubt it is the issue with your remote. If you did the relearn for the remote and the car gives you a confirmation of a learned value *beep* yet the remote still doesn't work, this tends to be a bad remote. I suspect the issue is how remotes have a rolling code each time you click a button. The rolling code is a predictable pattern and when you learn a remote, the car knows the starting point of the pattern. However, the remote may be screwing up the rolling code, so the next click of the remote is outside of what the car is expecting. My theory.... that and the government mind control.
*edit a small mistake... tinfoil cap was not fitted correctly.
atc98092
Washington, USA
C?ID=240299
Thanks for the insight Jef. I am curious though, you say the F221 switch is in the driver's door, while the scan says Front Passenger Side. Is the car confused about which side the steering wheel is on? :)
Should be fairly simple to replace that seat belt buckle, assuming I can get it from somewhere besides a dealer. I also am suspicious of the key fob being defective. Is there anything I can monitor in the system to observe what the car receives when the button is pushed? We only have one fob for the car, so I can't confirm if it works with anything else.
I wonder if that clutch switch error is why the cruise control won't engage? Just remembered that it didn't work right either...
Thanks!
Jef
HQ
Not really... if you have a friend with a VW that uses the same part number remote, try learning that remote to your car. You can have a single remote matched to 100 cars, the remote wouldn't know the difference, so it won't effect said friend's remote or vehicle.
The ECM has to be able to trust the clutch switch, that is one of the inputs the ECM will use to end operation of the cruise control. Note that there are two clutch switches, one for the first few mm of pedal travel to stop the cruise control, and a second for when the pedal is on the floor so the car knows it is safe to crank over.
Right, and an "implausible" signal would be the lower one being seen before or without the upper one.
atc98092
Washington, USA
C?ID=240299
Thanks to you both. Now I know where to look. Sounds like the upper clutch switch may be the culprit there.
My Passat has remote start, so I probably can't program that fob for her car. Maybe my son-in-law's 09 Jetta TDI would work. I know the Routan key won't :p
Found a thread in the Vortex forum about bad solder joints in the F221 switch. They were talking about much older models, but who knows. I've assembled many a Heathkit back in my youth, so I know my way around a solder gun. :D
atc98092
Washington, USA
C?ID=240299
Fix one, another appears
UPDATE: I disassembled the driver's seat belt latch per some instructions found on another forum. Found a broken wire as expected. Repaired break and cleared codes. Seat belt and air bag light out. Yahoo! :thumbs:
Removed right door panel, but discovered there's another metal panel beneath that covers the locking module. Since it was already 3PM, I didn't want to get into a lengthy disassembly so I closed it back up. After taking a drive to test my seat belt latch repair, I ran another auto-scan. The locking module error self-cleared! Go figure... :confused:
However, a new error popped up. Same module, but telling me I had "incorrect key programming". I had attempted to clear all the fobs yesterday, and today I was going to try the fob from my son-in-law's 09 Jetta. However, I can't get it to accept any changes now. When I first select code 1 to see the key count, it shows one, and the test & save buttons are enabled. If I change the number to zero or two, both test and save are disabled. I've tried to a number of times, disconnected and reconnected, rescanned, but I can't seem to do anything with the key fob now. Any ideas here? :banghead:
Between fixing the seat belt latch, enabling the aux in on the Jetta, and making some tweaks to my Passat, the VCDS cable has already paid for itself. Thanks for everything! :D
First thing I'd do is try to clear it again using Adaptation Channel 0.
atc98092
Washington, USA
C?ID=240299
OK, tried channel zero, but nothing happened. I notice something strange compared to when I've been tweaking my '14 Passat. When I'm in the Beetle 46 module, there's no "Do it!" button, only a test and save.
As I said, when I open the Coding section and select channel 1, the test and save button is enabled. It shows one fob assigned. If I change it to zero or two (my only two options) both the test and save buttons are disabled. If I leave it at one and click save, then hit the button on the fob, the horn beeps, but still won't unlock the door.
I was thinking on replacing the fob battery, as I have no idea how old it might be. Still, getting the beep acknowledgement makes me think it is communicating with the car. :banghead:
roth
C?ID=242642
I think 2007 Beetle and 2009 Jetta remotes are different. Get remotes with the correct part number.
You saw this video???
I think you got 15 seconds to complete the procedure after you press SAVE (press lock / unlock on each remote).
Power door locks work with the button and / or the mechanical key ????
BR, Andy
atc98092
Washington, USA
C?ID=240299
No I had not seen that video. Thanks!
I gave up on the Jetta fob. But I had followed the instructions from the video pretty much identical, except I believe I hit the unlock (not lock) button. I'll try it again just to be sure. However, I do get the honk acknowledgement from the car when I pushed the button on the fob. It just won't unlock the car. To your other question, yes the interior lock button will lock and unlock, as will using the key in the mechanical lock outside.
roth
C?ID=242642
I'm feeling that there is nothing wrong with the remote. Probably its the drivers door latch or lock.
Can you log n post ALL MVBs in 46 Comfort system? Do it under 3 conditions: 1. all doors closed and locked, 2. all door closed but unlocked, 3. all doors open.
Thanks, Andy.
atc98092
Washington, USA
C?ID=240299
I would love to, if you tell me what an MVB is :)
See how MVB is green and bold? Hover your cursor over it. ;)
atc98092
Washington, USA
C?ID=240299
Yeah, I saw that after I posted my response. Sneaky little forum you have here. :)
I found a new battery in the cupboard this morning for the fob, so I'm going to replace it and give it another go. Since the interior lock switch works, and both doors will unlock using the key in the door, the electronics in the car seem to be communicating correctly. Just have to see why it won't accept the fob signal.
If it makes any difference, it stopped working when my granddaughter was playing with the fob outside the car range. She was likely pounding all the buttons one after another. I've heard that will cause issues, but was hoping I could reset it. We have two keys for the car, but only one is a fob. The other is the valet key I would imagine.
atc98092
Washington, USA
C?ID=240299
MVBs
OK, replaced the fob battery. Used Channel Zero to reset, then set channel one to one (any other number, test and save was grayed out). Saved, then hit a button on the fob. Car beeps, but fob still doesn't work. :banghead:
Attached are the MVBs requested by Andy. Whoops, I see I can't post attachments. So, I'll copy the results here.
Closed and locked:
Sunday,15,March,2015,16:28:13:55621
VIN: 3VWEW31C77M508372   License Plate:
Mileage: 128840km-80057mi   Repair Order:
                Address 46: Central Conv.  (1C0 959 799 G)
16:28:07 Group 001: Driver's door
  Not Oper.  Electric window hall signal
  No  Electric window thermal protection
  Not Installed  Child safety switch
  N/A
16:28:07 Group 002: Driver's door (driver's switch for electric windows)
  Not Oper.  Passenger side electric window
  Not Installed  Rear left electric window
  Not Installed  Rear right electric window
  N/A
16:28:07 Group 003: Driver's door
  Not Oper.  Mirror adjustment switch driver
  Not Oper.  Mirror selection switch driver
  Not Installed  Mirror folding switch
  OFF  Mirror heating
16:28:36 Group 004: Passenger's door (electric window)
  Not Oper.  Switch passenger (E107)
  No  Thermal protection passenger
  Not Installed  Working speed control switch
  N/A
16:28:36 Group 005: Rear door's (electric windows)
  Not Installed  Switch rear left (E52)
  Not Installed  Thermal protection rear left
  Not Installed  Switch rear right (E54)
  Not Installed  Thermal protection rear right
16:28:36 Group 006
  12.21 V  Supply Voltage (terminal 30)
  Term 15 On  Ignition
  Activated  S-Terminal
  0.0 km/h  Speed signal
16:28:57 Group 007
  Not Oper.  Central locking key switch driver
  Not Oper.  Central locking key switch pass.
  Not Oper.  Interior locking driver switch
  Not Oper.  Interior locking passenger switch
16:28:57 Group 008
  Closed  Hood contact switch (F120)
  Not Oper.  Rear lid/tailgate key switch
  Closed  Rear lid/tailgate contact switch
  No  Central locking thermal protection
16:28:57 Group 009: Central locking feedback
  Locked  Driver's side
  Locked  Passenger's side
16:29:15 Group 010: Rotary latch switches
  Door Closed  Driver's side
  Door Closed  Passenger's side
16:29:15 Group 011
  No  Immobilizer key recognition
  Not Oper.  Automatic lock/unlock switch
  Yes  Sliding/tilting sunroof released
  2-Wire  Status CAN-Databus
16:29:15 Group 012: CAN-Databus communication
  Dr. Door 1  Door contr. module Driver side
  Pas. Door 1  Door contr. module Passenger side
     Door contr. module rear left
     Door contr. module rear right
16:29:32 Group 013
  Not Oper.  Rear lid button rear lid handle
  Closed  Rear first detent
  0.0 %  Instrument illumination
  N/A
16:29:32 Group 014
  no Value  Permanent code known
  no Value  Code within effective range
  no Value  Algorithm
  0  Key number
16:29:32 Group 015
   0 0 0 0  Remote control button
  Not Installed  Interior monitor sensor (G273)
  Not Installed  Interior monitoring switch-off (E267)
  N/A
16:29:45 Group 016: Alarm Sources
  2  1st Alarm Source
  16  2nd Alarm Source
  16  3rd Alarm Source
  16  4th Alarm Source
Closed and unlocked:
Sunday,15,March,2015,16:30:26:55621
Mileage: 128840km-80057mi   Repair Order: 2
16:30:13 Group 001: Driver's door
  N/A
16:30:13 Group 002: Driver's door (driver's switch for electric windows)
  N/A
16:30:13 Group 003: Driver's door
  OFF  Mirror heating
16:30:36 Group 004: Passenger's door (electric window)
  N/A
16:30:36 Group 005: Rear door's (electric windows)
16:30:36 Group 006
  Term 15 On  Ignition
16:30:48 Group 007
16:30:48 Group 008
16:30:48 Group 009: Central locking feedback
  Unlocked  Driver's side
  Unlocked  Passenger's side
16:30:58 Group 010: Rotary latch switches
16:30:58 Group 011
16:30:58 Group 012: CAN-Databus communication
16:31:11 Group 013
  N/A
16:31:11 Group 014
  no Value  Algorithm
  0  Key number
16:31:11 Group 015
  N/A
16:31:22 Group 016: Alarm Sources
  2  1st Alarm Source
  16  2nd Alarm Source
  16  3rd Alarm Source
  16  4th Alarm Source
Doors open and unlocked:
Sunday,15,March,2015,16:32:02:55621
Mileage: 128840km-80057mi   Repair Order: 3
16:31:57 Group 001: Driver's door
  N/A
16:31:57 Group 002: Driver's door (driver's switch for electric windows)
  N/A
16:31:57 Group 003: Driver's door
  OFF  Mirror heating
16:32:10 Group 004: Passenger's door (electric window)
  N/A
16:32:10 Group 005: Rear door's (electric windows)
16:32:10 Group 006
  12.10 V  Supply Voltage (terminal 30)
  Term 15 On  Ignition
16:32:18 Group 007
16:32:18 Group 008
16:32:18 Group 009: Central locking feedback
16:32:25 Group 010: Rotary latch switches
  Door Open  Driver's side
  Door Open  Passenger's side
16:32:25 Group 011
16:32:25 Group 012: CAN-Databus communication
16:32:33 Group 013
  N/A
16:32:33 Group 014
  no Value  Algorithm
  0  Key number
16:32:33 Group 015
  N/A
16:32:43 Group 016: Alarm Sources
  2  1st Alarm Source
  16  2nd Alarm Source
  16  3rd Alarm Source
  16  4th Alarm Source
