ERROR:00 UNKNOWN (0X0)
vagcom pro
Verified VCDS-User
C?ID=342235
HI i have coded this car few days back trying to change the longcoding back to original it just gives me odd error and freeze at long coding helper so far i have tried uninstalling the vcd restarted the computer did ignition cycle but it wont let me code any module giving me same error on all modules any possibility you can help
Saturday,02,March,2019,13:10:08:22147
VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4436.4
Workshop Code: 000 17485 000000
VIN: WAUZZZ8VXKA059486   License Plate:
Mileage: 107km-66mi   Repair Order:
Chassis Type: 8V-AU37 (3Q0)
Scan: 01 02 03 08 09 10 13 15 17 19 29 39 3C 42 44 47 4B 52 5F 6C
          A5 BB BC CF D6 D7
VIN: WAUZZZ8VXKA059486   Mileage: 107km-66miles
Address 01: Engine (J623-DADA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 05E 906 018 AL    HW: 05E 907 309
   Component: R4 1.5l TFS   H22 6084
   Revision: 81H22000
   Coding: 022500322364010820000000000000000000000000000000
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_ECM15TFS01105E906018AL 003002
   ROD: EV_ECM15TFS01105E906018AL.rod
   VCID: 6FBBD0BE4718644F777-803A
Address 02: Auto Trans (J743)       Labels: None
   Part No SW: 0CW 300 043 D    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 1604
   Revision: 00005008    Serial number: CU501901135242
   Shop #: WSC 17734 418 534600
   ROD: EV_TCMDQ200021_VW31.rod
   VCID: 38292BE272D6E3F766D-806C
   Part No SW: 5Q0 614 517 EF    HW: 5Q0 614 517 BP
   Component: ESC           H35 0107
   Revision: 00000000    Serial number: 63568000001887
   Coding: 12F18AA2202522758B7B0E0860C92848510444D1700614731821507492A84A0B0000000012121212B835351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 038007
   ROD: EV_Brake1UDSContiMK100IPB_038_AU37.rod
   VCID: 79AFEEE6095C3AFFD93-802C
   Part No SW: 8V0 820 043 AF    HW: 8V0 820 043 AF
   Component: AC Automat    H03 0150
   Revision: 20003000    Serial number: 00000001742084
   Coding: 03100014000000011000000000001100
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008025
   VCID: 76B5E5DA38425587B41-8022
   Subsystem 1 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Component: AQ_Hum_Sensor  H02 0007
   Serial number: EBD1946900PAG0MUFU03
   Part No SW: 5Q0 937 084 DC    HW: 5Q0 937 084 CF
   Component: BCM MQBAB M+  H38 0273
   Serial number: 00001901500942
   ASAM Dataset: EV_BCMMQB 019001
   ROD: EV_BCMBOSCH_019_VW37.rod
   VCID: 7CA1F7F2066E0FD7C25-8028
   Subsystem 1 - Part No SW: 8V2 955 119 A    HW: 8V2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 181101  043 0580
   Serial number:         181121182025
   Coding: 0A47F7
   Coding: 00006C
   Light switch:
   Subsystem 3 - Part No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
   Component: E1 - LDS MQB  H06 0032
   Serial number: 27 10 2018  20000533
   Serial number: 000000000ZY183300L4D
   Serial number: 00000000000046221310
   Sun Roof:
   Subsystem 6 - Part No SW: 8V3 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS73.404  H04 0005
   Serial number: 0000FST0028ON8T00000
   Coding: 901E00
   Steering Column Switch:
   Subsystem 7 - Part No SW: 82A 953 521 J    HW: 5Q1 953 549
   Component: J527 SMLS MQB  004 0060
   Serial number: 00000003011920240700
   Serial number: 000308418019004
   Coding: 0470155811
   VCID: 4CC16732164E7F57325-8018
   Part No SW: 5Q0 907 572 P    HW: 5Q0 907 572 J
   Component: ACC BOSCH MQB H11 0682
   Coding: 3500E7C15DFFC728949C814580402600000000000000000004
   ASAM Dataset: EV_ACCBOSCHVW416 002008
   VCID: 44D14F123E1EB717FA5-8010
   Part No SW: 5Q0 959 655 BT    HW: 5Q0 959 655 BT
   Component: AirbagVW21    007 0403
   Serial number: 003FNR4XX1S
   Coding: 98CCC0000C0000005C5400CA00C8000000C5
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 1373BC4E0BF0E0AF33F-8046
   Subsystem 1 - Part No SW: -----------    HW: 480 001 501 19
   Serial number: 357000000006A548163F
   Subsystem 2 - Part No SW: -----------    HW: 480 001 501 19
   Serial number: 35800000000559D8C73Z
   Subsystem 3 - Part No SW: -----------    HW: 480 401 701 19
   Component: SideSensor_Dr  004 6149
   Serial number: 3510001202B805C3757T
   Subsystem 4 - Part No SW: -----------    HW: 480 401 701 19
   Component: SideSensor_Pr  004 6149
   Serial number: 3520001202B805C4963U
   Subsystem 5 - Part No SW: -----------    HW: 480 402 012 18
   Component: FrontSensor_D  004 6149
   Serial number: 3550001182BF79B324CD
   Pedestrian Protection Driver:
   Subsystem 6 - Part No SW: -----------    HW: 480 400 901 19
   Component: PedP_Sensor_D  004 6149
   Serial number: 2280001182BFB753E6EO
   Subsystem 7 - Part No SW: -----------    HW: 480 400 901 19
   Component: PedP_Sensor_P  004 6149
   Serial number: 2290001182BFB7540710
   Subsystem 8 - Part No SW: -----------    HW: 480 001 201 19
   Serial number: I0M00000000E6BE8273J
   Subsystem 9 - Part No SW: -----------    HW: 480 001 201 19
   Serial number: I0N00000000F6BE8273L
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI2
   Part No SW: 8V0 920 790 C    HW: 8V0 920 790 C
   Component: FBenRDW       H19 0109
   Coding: 248409406F8C06000180E8001000000000000000
   ASAM Dataset: EV_DashBoardFPKAU37X 001032
   ROD: EV_DashBoardFPKAU37X.rod
   VCID: 3C2137F246EECFD7825-8068
   Part No SW: 3Q0 907 530 AA    HW: 3Q0 907 530 C
   Component: GW MQB High   442 4367
   Revision: --------    Serial number: 0008971891
   Coding: 030100043F0856005B00025A1C0B00000001010000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 6E85CDBA40126D477C1-803A
   Component: 0-00-00-00-00
   Subsystem 2 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
   Component: J453 MFL  H04 0004
   Serial number: 20190113232123 30048
   Component: J367-BDMConti  H03 1051
   Serial number: 75886003911901140550
Address 29: Left Light (J1018)       Labels: 8S0-907-397.clb
   Part No SW: 8S0 907 397 D    HW: 8S0 907 397 D
   Component: LCM_MQB       H07 0022
   ASAM Dataset: EV_LCMLeftCONTIAU426 001009
   ROD: EV_LCMLeftCONTIAU426_VW41.rod
   VCID: 42DD490A240AB927C89-8016
Address 39: Right Light (J1023)       Labels: 8S0-907-397.clb
   ASAM Dataset: EV_LCMRightCONTIAU426 001009
Address 3C: Lane Change (J769)       Labels:| 3Q0-907-566.clb
   Part No SW: 3Q0 907 566 H    HW: 3Q0 907 566
   Component: MRR1Rear      H23 0630
   Revision: --------
   Coding: 44C002
   VCID: 3D273AF65DF4C6DFB5B-8068
   Part No SW: 5Q0 959 593 F    HW: 5Q0 959 593 F
   Component: TSG FS001 0287
   Serial number: YE007RJQ18323
   Coding: 005E8A205001000000001002
   Part No SW: 5Q0 909 144 AB    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  130 1082
   Coding: 911F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 74B1DFD22E3E47978A5-8020
   Part No SW: 81A 035 466 B    HW: 81A 035 466
   Component: MIB2_amp_P_A3 H10 0440
   Revision: 00000001    Serial number: AUZ8ZAJ5F022YQG
   Coding: 0173030000AAAA2AAA0000010000
   ASAM Dataset: EV_AMPMst16C9Gen2ALPI 001002
   ROD: EV_AMPMst16C9Gen2ALPI.rod
   VCID: 2411EF92DE5E9717DA5-8070
   Part No SW: 3Q0 907 338 C    HW: 3Q0 907 338 C
   Component: FCM MQB Low   002 0345
   Serial number: 13011911600711
   Coding: 000000050900146E00102B03020000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 002006
   ROD: EV_MultiModulContiVW48X_002_VW37.rod
   VCID: 353722D665C41E9F7DB-8060
   Part No SW: 5Q0 959 592 F    HW: 5Q0 959 592 F
   Component: TSG BFS001 0287
   Serial number: YE007RJP0172A
   Coding: 005E82205C01000000001002
   VCID: 43D34C0E3B10B02FC3F-8016
   Part No SW: 8V1 035 035 C    HW: 8V1 035 035 C
   Component: MU-P-LND-EU   055 1326
   Serial number: A698A0KB007815
   Coding: 017303010000000011111102000A00312F0026E7017001009E
   VCID: 323D19CA94AA09A7589-8066
   Subsystem 1 - Part No SW: V03 959 802 DD    HW: -----------
   Component: ECE 2018/2019  --- 0169
   Component: DU High  H49 0014
   Serial number: AUZ8Z9J1Y0FT6N
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8V0 919 614 BJ    HW: 8V0 919 614 BJ
   Component: ControlUnit_H  H85 0855
   Serial number: ALJAL112101800050446
   Component: Gracenote2  --- 1017
   Component: RVC Compact   H15 0231
   Coding: 0273100102002001400040
   VCID: 392F2EE649DCFAFF993-806C
   Part No SW: 3Q0 980 654 L    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H10 0610
   Serial number: 15011915P14353
   Coding: 040307030000040101022346814EA90098000E20002000
   ASAM Dataset: EV_MFKBoschMQBB 002041
   ROD: EV_MFKBoschMQBB_002.rod
   VCID: 40D943022A06AB37DED-8014
   Part No SW: 8W1 959 595 D    HW: 8W1 959 595 D
   Component: TSG HFS003 0187
   Serial number: YE007RLL12393
   Coding: 000C82204001000000001002
   ROD: EV_DCU2RearDriveMAXHCONT.rod
   VCID: 4EC56D3AE0524D475C1-801A
   Component: TSG HBFS003 0187
   Serial number: YE007RLL1243B
   ROD: EV_DCU2RearPasseMAXHCONT.rod
Address CF: Lane Chge Asst 2 (J770)       Labels:. 3Q0-907-566.clb
   Part No SW: 3Q0 907 590 H    HW: 3Q0 907 590
   Revision: --------
   Coding: 44C002
   VCID: 3A2D31EA4CDAF1E7909-806E
   Part No SW: 7PP 941 572 AC    HW: 7PP 941 572 A
   Component: LED1L         H09 0008
   VCID: 176BC85E1F08CC8F4F7-8042
   Component: LED1R         H09 0008
End----------(Elapsed Time: 01:58, VBatt start/end: 12.3V/12.3V)-----------
For laughs, try opening the car's hood.
PS: Can you make maps from 19-CAN Gateway for us please?
vagcom pro
Verified VCDS-User
C?ID=342235
Thanks for your message i didn’t need it when I coded it first time I have just updated the firmware on cable and tested on my old Audi and its working this a3 is brand new I will update you next time
If this is what I think it is ("Diagnostic Firewall") then it would not yet have been active when you coded the car the first time, because the car did not yet have 200 km on it. And your old Audi would not have had such a "feature" at all. However, a 2019 model Audi (which this is) might.
vagcom pro
Verified VCDS-User
C?ID=342235
Ok thank you for heads up much appreciated
vagcom pro
Verified VCDS-User
C?ID=342235
crazy hats off to you it worked like a charm
hadez16
C?ID=289891
I thought that this is a MLBevo platform thing, but it seems that it also applies to 2019 MQB
Not all. Yanping got a 2019 MQB (Golf "Alltrack" wagon) and doesn't have this. So it may be limited to 2019 Audi MQB?
In any case, we'd really appreciate Gateway maps from it (or one that has it) so we can add the warning to VCDS for them.
hadez16
C?ID=289891
You mean adaptation map or measurement map? How does the diagnosis firewall manifest itself in those maps?
I believe it's a measuring value. But we got a received a bunch of data over the weekend.
