2008 Audi S8 Direct short somewhere. Any Advise on where to start?
Sandbullet
Utah, USA
C?ID=297733
2008 Audi S8 V10 Car
Driving on the freeway today at 75mph. EPC, traction control, and check engine light all come on. Pull over and find that a main ECM fuse #5 has blown. I had this issue a few months ago but thought it was fixed after I found that the plug on the right motor mount had been damaged. I cut the wires and covered them until I can properly fix the plug and reconnect.
Haven't had an issue with a short to ground since. Been driving the car for 6 weeks without any issues and thought I was good. But something in that circuit appears to still be shorting. I'm just not sure of the best place to start or if there is a good starting point. Full scan below. Any suggestions are greatly appreciated!
Replaced the blown fuse and everything was fine again. Drove home. Really want to find out what is shorting.
Thank you...
Saturday,20,May,2017,20:20:43:16718
VCDS Version: 17.1.3.0 (x64)  HEX-V2 CB: 0.4334.4
VIN: WAUPN94E78N002494   License Plate:
Mileage: 88360km-54904mi   Repair Order: 05202017
Chassis Type: 4E (4L0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 11 31 13 15 16 17 19 1E 28 34
          36 37 38 3C 42 46 47 4F 52 53 55 56 5C 61 62 65 67 6C 72 76
          77
VIN: WAUPN94E78N002494   Mileage: 88360km-54904miles
11-Engine II -- Status: Malfunction 0010
31-Engine other -- Status: Malfunction 0010
5C-Lane Maintain. -- Status: OK 0000
Address 01: Engine (BSM)       Labels: Redir Fail!
   Part No SW: 4E0 910 552 K    HW: 4E0 907 552 A
   Component: 5.2L V10/4V FSI    ª0040
   Revision: 5IH02---    Serial number: AUX3Z0G8731216
   Coding: 01060009190F0260
   Shop #: WSC 34413 001 1048576
   VCID: 2A0E086610FB3DB753D-807E
15 Faults Found:
005495 - Right Engine Mount Solenoid Valve (N145)
               P1577 - 004 - Open Circuit
                    Fault Frequency: 12
                    Mileage: 86859 km
                    Date: 2017.02.28
                    Time: 09:15:24
                    RPM: 143 /min
                    Load: 59.6 %
                    Temperature: 52.0°C
                    Temperature: 19.0°C
                    Absolute Pres.: 850.0 mbar
                    Voltage: 10.033 V
012312 - Valve for Exhaust Flap 1 (N321)
               P3018 - 002 - Short to Ground - Intermittent
                    Mileage: 88310 km
                    Date: 2017.05.20
                    Time: 16:24:18
                    RPM: 2926 /min
                    Load: 85.1 %
                    Speed: 127.0 km/h
                    Temperature: 99.0°C
                    Temperature: 30.0°C
                    Voltage: 13.335 V
001112 - Evap System Purge Control Valve (N80)
               P0458 - 002 - Short to Ground - Intermittent
                    Mileage: 88310 km
                    Date: 2017.05.20
                    Time: 16:24:18
                    RPM: 2926 /min
                    Load: 85.1 %
                    Speed: 127.0 km/h
                    Temperature: 99.0°C
                    Temperature: 30.0°C
                    Voltage: 13.335 V
009217 - EVAP Leak Detection Pump Control Circuit
               P2401 - 002 - Short to GND - Intermittent - MIL ON
                    Fault Status: 10100010
                    Mileage: 88310 km
                    Date: 2017.05.20
                    Time: 16:24:18
                    RPM: 2926 /min
                    Load: 85.1 %
                    Speed: 127.0 km/h
                    Temperature: 99.0°C
                    Temperature: 30.0°C
                    Voltage: 13.081 V
005224 - EVAP Canister Solenoid Valve 2 (N115)
               P1468 - 002 - Short to Ground - Intermittent - MIL ON
                    Mileage: 88310 km
                    Date: 2017.05.20
                    Time: 16:24:18
                    RPM: 2926 /min
                    Load: 85.1 %
                    Speed: 127.0 km/h
                    Temperature: 99.0°C
                    Temperature: 30.0°C
                    Voltage: 13.081 V
004199 - Intake Air Switch-Over Valve (N335)
               P1067 - 002 - Short to Ground - Intermittent
                    Mileage: 88310 km
                    Date: 2017.05.20
                    Time: 16:24:18
                    RPM: 2926 /min
                    Load: 85.1 %
                    Speed: 127.0 km/h
                    Temperature: 99.0°C
                    Temperature: 30.0°C
                    Voltage: 13.081 V
005173 - Secondary Air Pump Relay (J299)
               P1435 - 002 - Short to Ground - Intermittent - MIL ON
                    Mileage: 88310 km
                    Date: 2017.05.20
                    Time: 16:24:18
                    RPM: 2926 /min
                    Load: 85.1 %
                    Speed: 127.0 km/h
                    Temperature: 99.0°C
                    Temperature: 30.0°C
                    Voltage: 13.081 V
005153 - Secondary Air Injection Solenoid Valve (N112)
               P1421 - 002 - Short to Ground - Intermittent - MIL ON
                    Mileage: 88310 km
                    Date: 2017.05.20
                    Time: 16:24:18
                    RPM: 2926 /min
                    Load: 85.1 %
                    Speed: 127.0 km/h
                    Temperature: 99.0°C
                    Temperature: 30.0°C
                    Voltage: 13.081 V
000258 - Mass Air Flow Sensor (G70)
               P0102 - 002 - Signal too Low - Intermittent
                    Mileage: 88310 km
                    Date: 2017.05.20
                    Time: 16:24:18
                    RPM: 2774 /min
                    Load: 79.2 %
                    Speed: 127.0 km/h
                    Temperature: 99.0°C
                    Temperature: 30.0°C
                    Voltage: 13.462 V
008853 - Fuel Pressure Regulator Valve (N276)
               P2295 - 002 - Short to Ground - Intermittent
                    Mileage: 88310 km
                    Date: 2017.05.20
                    Time: 16:24:18
                    RPM: 2774 /min
                    Load: 79.2 %
                    Speed: 127.0 km/h
                    Temperature: 99.0°C
                    Temperature: 30.0°C
                    Voltage: 13.462 V
000055 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
               P0037 - 002 - Short to Ground - Intermittent
                    Mileage: 88311 km
                    Date: 2017.05.20
                    Time: 16:24:19
                    RPM: 2802 /min
                    Load: 72.9 %
                    Speed: 128.0 km/h
                    Temperature: 99.0°C
                    Temperature: 30.0°C
                    Voltage: 13.208 V
000087 - Oxygen (Lambda) Sensor B2 S2: Heating Circuit
               P0057 - 002 - Short to Ground - Intermittent
                    Mileage: 88311 km
                    Date: 2017.05.20
                    Time: 16:24:19
                    RPM: 2802 /min
                    Load: 72.9 %
                    Speed: 128.0 km/h
                    Temperature: 99.0°C
                    Temperature: 30.0°C
                    Voltage: 13.208 V
000049 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit
               P0031 - 002 - Short to Ground - Intermittent
                    Mileage: 88311 km
                    Date: 2017.05.20
                    Time: 16:24:19
                    RPM: 2802 /min
                    Load: 72.9 %
                    Speed: 128.0 km/h
                    Temperature: 99.0°C
                    Temperature: 30.0°C
                    Voltage: 13.208 V
000081 - Oxygen (Lambda) Sensor B2 S1: Heating Circuit
               P0051 - 002 - Short to Ground - Intermittent
                    Mileage: 88311 km
                    Date: 2017.05.20
                    Time: 16:24:19
                    RPM: 2802 /min
                    Load: 72.9 %
                    Speed: 128.0 km/h
                    Temperature: 99.0°C
                    Temperature: 30.0°C
                    Voltage: 13.208 V
006435 - Please Check DTC Memory of ECU Number 2
               P1923 - 008 -
                    Mileage: 88368 km
                    Temperature: 110.0°C
                    Temperature: 39.0°C
                    Voltage: 11.684 V
   Part No SW: 4E2 910 156 C    HW: 09E 927 156 B
   Component: AG6 09E 5,2 FSI USA 0030
   Revision: --H03---    Serial number:        0111307
   Shop #: WSC 02313 785 00200
   VCID: 2412E65E72DFEBC7691-8070
006231 - Load Signal
               P1857 - 001 - Error Message from ECU - Intermittent
                    Fault Status: 00100001
                    Mileage: 88311 km
                    Date: 2017.05.20
                    Time: 16:24:22
Address 03: ABS Brakes        Labels: 4E0-910-517.lbl
   Part No SW: 4E0 910 517 K    HW: 4E0 614 517 BT
   Component: ESP 5.7 allrad  H49 0650
   Coding: 0001627
   Shop #: WSC 02313 000 00000
   VCID: 2B000D621F0124BFA8B-807E
18265 - Load Signal
            P1857 - 000 - Error Message from ECU - Intermittent
Address 05: Acc/Start Auth.        Labels: 4E0-910-131.lbl
   Part No SW: 4E0 910 131     HW: 4E0 907 181 C
   Component:     FBS AUDID3  H12 0200
   Revision: 02005112    Serial number: AUX3Z0G8731216
   Coding: 0410624
   Shop #: WSC 02311 785 00200
   VCID: 58EA82AE7E177F27359-800C
   Subsystem 1 - Part No: 4E0 905 852 E
   Component: ELV                 2040
   Part No SW: 4E0 910 760 D    HW: 4E0 959 760 B
   Component: Sitzmemory BFS H02  0010
   Revision: 00000000    Serial number: 5DS 008 795-03
   Coding: 4071520
Address 07: Control Head        Labels: 4E0-910-7xx-07.lbl
   Part No SW: 4E0 910 732 C    HW: 4E0 035 729 A
   Component: Interfacebox    H43 4140
   Revision: 00000000    Serial number: 348IR077526400
   Coding: 0000003
   VCID: 221EE04668CBE5F71BD-8076
   Subsystem 1 - Part No: 4E0 910 611
   Component: E0380 BedienteilH01 0050
   Subsystem 2 - Serial number: 00000000046653
   Subsystem 3 - Serial number: 0127.09.070000000100010069ÿ
   Subsystem 4 - Serial number: 010069ÿ
02849 - Control Module for Lane Change Assistance (J769)
                    Fault Frequency: 12
                    Reset counter: 142
                    Mileage: 86993 km
                    Date: 2017.04.14
                    Time: 11:57:28
00384 - Optical Databus
                    Fault Status: 00101011
                    Fault Frequency: 18
                    Reset counter: 118
                    Time Indication: 15
   Part No SW: 4E0 910 043 B    HW: 4E0 820 043 G
   Component: KLIMAAUTOMAT    017 0450
   Revision: 00000032    Serial number: 00000000131835
   Coding: 0106961
   VCID: 1C62DEBE4AAFD307D11-8048
Address 09: Cent. Elect.        Labels: 4E0-910-279.lbl
   Part No SW: 4E0 910 279 S    HW: 4E0 907 279 S
   Component: ILM Fahrer      H16 0240
   Coding: 0133123
   VCID: 382A222EDE579F27D59-806C
   Subsystem 1 - Part No: 4E1 910 113 C
   Component: Wischer WWS D3  H60 0420
   Coding: 00000037
   Shop #: WSC 02313
   Component: REGENLICHTSENSORH04 0002
   Coding: 00150573
   Shop #: WSC 02313
Address 0E: Media Player 1 (R192)       Labels: 4E0-035-785.lbl
   Part No SW: 4E0 035 785 B    HW: 4E0 035 785 B
   Component: SG ext.Player H15 0700
   Revision: 00000000
   VCID: 2708F1520FE900DF4C3-8072
Address 0F: Digital Radio        Labels: 4E0-910-593-SIR.lbl
   Part No SW: 4E0 910 593 K    HW: 4E0 035 593 F
   Component: SDAR SIRIUS     H07 0140
   Revision: 00000000    Serial number: AUZ4Z7G0165325
   Coding: 0000100
   VCID: 2F3819722B19589F843-807A
Address 11: Engine II        Labels: Redir Fail!
8 Faults Found:
012322 - Valve for Exhaust Flap 2 (N322)
               P3022 - 002 - Short to Ground - Intermittent
                    Mileage: 88310 km
                    Date: 2017.05.20
                    Time: 16:24:18
                    RPM: 2908 /min
                    Load: 85.1 %
                    Speed: 127.0 km/h
                    Temperature: 99.0°C
                    Temperature: 30.0°C
                    Voltage: 13.208 V
000268 - Mass Air Flow Sensor (G246)
               P010C - 002 - Signal too Low - Intermittent
                    Mileage: 88310 km
                    Date: 2017.05.20
                    Time: 16:24:18
                    RPM: 2772 /min
                    Load: 79.2 %
                    Speed: 127.0 km/h
                    Temperature: 99.0°C
                    Temperature: 30.0°C
                    Voltage: 13.335 V
004764 - Fuel Pressure Regulator Valve; Bank 2 (N276)
               P129C - 002 - Short to Ground - Intermittent
                    Mileage: 88310 km
                    Date: 2017.05.20
                    Time: 16:24:18
                    RPM: 2772 /min
                    Load: 79.2 %
                    Speed: 127.0 km/h
                    Temperature: 99.0°C
                    Temperature: 30.0°C
                    Voltage: 13.335 V
012821 - Oxygen (Lambda) Sensor B3 S2; Heating Circuit
               P3215 - 002 - Short to Ground - Intermittent
                    Mileage: 88311 km
                    Date: 2017.05.20
                    Time: 16:24:19
                    RPM: 2806 /min
                    Load: 72.9 %
                    Speed: 128.0 km/h
                    Temperature: 99.0°C
                    Temperature: 30.0°C
                    Voltage: 13.208 V
012869 - Oxygen (Lambda) Sensor B4 S2; Heating Circuit
               P3245 - 002 - Short to Ground - Intermittent
                    Mileage: 88311 km
                    Date: 2017.05.20
                    Time: 16:24:19
                    RPM: 2806 /min
                    Load: 72.9 %
                    Speed: 128.0 km/h
                    Temperature: 99.0°C
                    Temperature: 30.0°C
                    Voltage: 13.208 V
012800 - Oxygen (Lambda) Sensor B3 S1; Heating Circuit
               P3200 - 002 - Short to Ground - Intermittent
                    Mileage: 88311 km
                    Date: 2017.05.20
                    Time: 16:24:19
                    RPM: 2806 /min
                    Load: 72.9 %
                    Speed: 128.0 km/h
                    Temperature: 99.0°C
                    Temperature: 30.0°C
                    Voltage: 13.208 V
012848 - Oxygen (Lambda) Sensor B4 S1; Heating Circuit
               P3230 - 002 - Short to Ground - Intermittent
                    Mileage: 88311 km
                    Date: 2017.05.20
                    Time: 16:24:19
                    RPM: 2806 /min
                    Load: 72.9 %
                    Speed: 128.0 km/h
                    Temperature: 99.0°C
                    Temperature: 30.0°C
                    Voltage: 13.208 V
005490 - Left Engine Mount Solenoid Valve (N144)
               P1572 - 002 - Short to Ground - Intermittent
                    Mileage: 88323 km
                    Date: 2017.05.20
                    Time: 16:32:12
                    RPM: 681 /min
                    Load: 41.6 %
                    Speed: 5.0 km/h
                    Temperature: 98.0°C
                    Temperature: 30.0°C
                    Absolute Pres.: 860.0 mbar
                    Voltage: 13.716 V
Address 13: Auto Dist. Reg        Labels: None
   Part No SW: 4E0 910 561 F    HW: 4E0 907 561 F
   Component: ABSTANDSREGELUNGH03 0020
   Coding: 0041118
   VCID: 2514FB5A79E512CF7EF-8070
            013 - Check DTC Memory - Intermittent - MIL ON
                    Fault Status: 10111101
                    Reset counter: 149
                    Mileage: 88308 km
                    Date: 2017.05.20
                    Time: 16:24:00
                    Temperature: 28.0°C
                    Voltage: 11.65 V
                    Bin. Bits: 00100000
Address 15: Airbags        Labels: None
   Part No SW: 4E0 910 655 F    HW: 4E0 959 655 L
   Component:    Airbag 9.41  H01 4230
   Revision: 91H01423    Serial number: 003CV0000KD-
   Coding: 0532707
   VCID: 290CF76A15FD36AF5A7-807C
   Subsystem 1 - Part No: 4E0 910 339 C
   Component: BF-Gewichtsens. H02 0040
   Subsystem 2 - Serial number: 00BY7
   Subsystem 3 - Serial number: 0001.01.0000H0200000000000ÿ† 63
   Subsystem 4 - Serial number: 000000ÿ† 63328RB402F2063AGÿ† 63
   Subsystem 5 - Serial number: 2063AGÿ† 63428RB402F1FD47-ÿ† 63
   Subsystem 6 - Serial number: 1FD47-ÿ† 63528RB402F2067BNÿ† 63
   Subsystem 7 - Serial number: 2067BNÿ† 63628RB402F20F2FWÿ† 63
   Subsystem 8 - Serial number: 20F2FWÿ† 63729RB4029F9D3C3ÿ† 63
   Subsystem 9 - Serial number: F9D3C3ÿ† 63829RB4029F9DA0%ÿ
   Subsystem 10 - Serial number: F9DA0%ÿ
Address 16: Steering wheel        Labels: 4E0-910-549.lbl
   Part No SW: 4E0 910 549 A    HW: 4E0 953 549 B
   Revision: 00H03000    Serial number: 90026071740035
   Coding: 0032351
   VCID: 2616FC5604E319D7775-8072
   Component: E0221           H01 0030
Address 17: Instruments        Labels: 4E0-910-xxx-17.lbl
   Part No SW: 4E0 910 981 G    HW: 4E0 920 981 G
   Component: KOMBIINSTR. VDO H83 0620
   Revision: D03         Serial number: AUDID3G8000280
   Coding: 0048283
   Shop #: WSC 49106 001 1048576
   VCID: 2C020E7E1A0F2387A11-8078
Address 19: CAN Gateway        Labels: 4L0-910-468.clb
   Part No SW: 4L0 910 468 A    HW: 4E0 907 468 H
   Component: J533__Gateway   H06 0060
   Revision: 00H06000    Serial number: 0200J079228018
   Coding: F5F5DFFF777A0E00
   VCID: 2D04037A21152A8FB6F-8078
Address 1E: Media Player 2        Labels: 4E0-910-111.lbl
   Part No SW: 4E0 910 110 C    HW: 4E0 035 110 A
   Component: MP3-Changer     H46 0350
   Revision: 00046006    Serial number: AUZ5ZBG3479691
   VCID: 186AC2AEBE97BF27F59-804C
   Part No SW: 4E0 910 158     HW: 4E0 919 158 D
   Component: KLIMA-STG. FOND 017 0230
   Revision: 00000020    Serial number: 00000000059738
   Coding: 0000000
   VCID: 619CAF4A2D4DBEEF427-8034
Address 34: Level Control        Labels: 4E0-910-553.lbl
   Part No SW: 4E0 910 553 L    HW: 4E0 907 553 H
   Component: LUFTFDR.-CDC    H07 6340
   Coding: 0015510
   Component: Sitzmemory FS  H02  0010
   Coding: 4071530
   Part No SW: 4E0 910 888 F    HW: 4E0 919 887 M
   Component: MNS US          H50 0990
   Revision: 00000000    Serial number: 395IW077504416
   Shop #: WSC 26097 444 83501
   VCID: 313C1F0A3D2D4E6F927-8064
Address 38: Roof Electronics        Labels: 4E0-910-135.lbl
   Part No SW: 4E0 910 135 A    HW: 4E0 907 135
   Component: Dachknoten D3   H05 0090
   Serial number: 00000722000006
   Coding: 0003479
   VCID: 1D64D3BA51B5DA0F26F-8048
00213 - Control Circuit for Reading Lights Front Right
                    Reset counter: 65
                    Mileage: 86916 km
                    Date: 2017.04.13
                    Time: 13:26:00
   Part No SW: 4L0 910 566 B    HW: 4L0 907 566 A
   Component: J0769_SWA_MasterH10 0120
   Revision: 00H10000    Serial number: 6PZ 009 014-00
   Coding: 0000009
   Subsystem 1 - Part No: 4L0 910 568 B
   Component: J0770_SWA_Slave_H08 0120
   Subsystem 2 - Serial number: 6PZ 009 014-20
   Subsystem 3 - Serial number: 3F21.09.0700H0800000010211ÿ
   Subsystem 4 - Serial number: 010211ÿ
Address 42: Door Elect, Driver        Labels: 4E1-910-802-42.lbl
   Part No SW: 4E1 910 802 B    HW: 4E1 959 801 F
   Component: Türsteuer.FS BRM005 0180
   Coding: 0028204
   VCID: 201AEA4E66C7F7E70D9-8074
                    Fault Frequency: 0
                    Reset counter: 130
                    Mileage: 87600 km
                    Date: 2017.05.03
                    Time: 18:28:62
Address 46: Central Conv.        Labels: 4E0-910-289.lbl
   Part No SW: 4E0 910 289 E    HW: 4E0 907 289 E
   Component: Komfortgeraet   H10 0010
   Revision: 00100010    Serial number:  W040709270158
   Coding: 0048686
   Component: Heckdeckel   P28H06 0100
Address 47: Sound System        Labels: None
   Part No SW: 4E0 910 466 C    HW: 4E0 035 466
   Component: BO_D3           H06 0310
   Revision: 20S00002    Serial number: 00305070009348
   Coding: 0000026
   Subsystem 1 - Part No: 4E0 910 465 B
   Component: BO_D3_SLAVE     H31 0310
   Subsystem 2 - Serial number: 00407070006860
   Subsystem 3 - Serial number: 0204.07.070000000100030006ÿ
   Subsystem 4 - Serial number: 030006ÿ
                    Reset counter: 140
                    Mileage: 86917 km
                    Date: 2017.04.13
                    Time: 11:56:40
                    Voltage: 14.30 V
                    Temperature: 35.0°C
                    Bin. Bits: 00000011
                    Voltage: 14.00 V
                    Temperature: 31.0°C
Address 4F: Centr. Electr. II        Labels: None
   Part No SW: 4E0 910 280 A    HW: 4E0 907 280 B
   Component: ILM Beifahrer   H11 0070
   Revision:             Serial number: 00000000008429
   Coding: 0010111
   VCID: 1E66D4B65CB3C1173F5-804A
02258 - Door Opener Transmitter
                    Reset counter: 109
                    Mileage: 87240 km
                    Date: 2017.04.21
                    Time: 18:49:00
Address 52: Door Elect, Pass.        Labels: 4E1-910-802-52.lbl
   Part No SW: 4E1 910 802 B    HW: 4E1 959 802 F
   Component: Türsteuer.BF BRM005 0180
   Coding: 0028204
Address 53: Parking Brake        Labels: 4E0-910-801.clb
   Part No SW: 4E0 910 801 D    HW: 4E0 907 801 B
   Component: EPB  A4EC0230   H03 0230
   Revision: --H03---
   Coding: 0000732
   Shop #: WSC 34415 001 1048576
   Coding: 0000018
   Subsystem 1 - Part No: 4F0 941 329 D
   Component: AFS-Modul links H01 0010
   Subsystem 2 - Part No: 4F0 941 329 D
   Component: AFS-Modul rechtsH01 0010
   Part No SW: 4E0 910 541 Q    HW: 4E0 035 541 S
   Revision: 00000000    Serial number: 396IC077579777
   VCID: 2E0604762C1351978F5-807A
Address 5C: Lane Maintain.        Labels: None
   Part No SW: 4E0 910 217 C    HW: 4E0 907 217 C
   Component: J759  LDW       H06 0070
   Revision: 00H06012    Serial number: 4002079130005F
   Coding: 0001102
Address 61: Battery Regul.        Labels: 4E0-910-181.lbl
   Part No SW: 4E0 910 181 C    HW: 4E0 915 181 C
   Component: J0644 BEM       H12 0550
   Revision: 00000000    Serial number: 00000000013563
   Subsystem 1 - Part No: 4E0 915 105 A
   Component: von VA0  0708180189
   Coding: 344530393135313035412056413030373038313830313839
   Shop #: WSC 00000 128 00289
02256 - Quiescent Current
                    Fault Status: 00110001
                    Reset counter: 118
                    Mileage: 87039 km
                    Date: 2017.04.15
                    Time: 01:19:25
Address 62: Door, Rear Left        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802 A    HW: 4E0 959 801 D
   Component: Türsteuer.HL BRM005 0180
   Coding: 0028204
Address 65: Tire Pressure        Labels: 4E0-910-273.lbl
   Part No SW: 4E0 910 273 A    HW: 4F0 907 273 A
   Component: Reifendruck 3   H05
   Revision: 00050340    Serial number: 00000700052887
   Coding: 0232428
   Component: SDS 3501 US     H46 0630
   Revision: 00000000    Serial number: 00000709170399
   Shop #: WSC 12336 024 394758
   VCID: 3432161EC23F7B47F91-8060
Address 6C: Back-up Cam.        Labels: 4E0-910-441.clb
   Part No SW: 4E0 910 441     HW: 4L0 907 441 A
   Component: J772__Rearview      0050
   Revision: --H12---    Serial number: 525PA8-J7810GN
   Coding: 1121402
   VCID: 5CE29EBE0A2F9307111-8008
Address 72: Door, Rear Right        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802 A    HW: 4E0 959 802 D
   Component: Türsteuer.HR BRM005 0180
   Coding: 0028204
Address 76: Park Assist        Labels: 4E0-910-283.lbl
   Part No SW: 4E0 910 283 C    HW: 4E0 919 283 C
   Component: Parkhilfe 8-Kan H12 0040
   Revision: 00H12000    Serial number: 08720725501374
   Coding: 0221208
   VCID: 2310E54277D1ECFF10B-8076
01626 - Sensor for Parking-Aid; Front Right (G252)
                    Reset counter: 118
                    Mileage: 87253 km
                    Date: 2017.04.21
                    Time: 19:38:39
   Part No SW: 4F0 910 336 E    HW: 4E0 862 335
   Component: Handyvorb2      H18 0950
   Revision: 00000000    Serial number: 00000005008476
   Coding: 0010900
02454 - Microphone Unit (in Front Roof Module) (R164)
                    Reset counter: 41
                    Mileage: 86859 km
                    Date: 2017.02.28
                    Time: 10:03:34
End----------(Elapsed Time: 02:35, VBatt start/end: 11.9V/11.8V)-----------
Log-WAUPN94E78N002494-88360km-54904mi-05202017.txt
Open with Google Docs
Displaying Log-WAUPN94E78N002494-88360km-54904mi-05202017.txt.
All those "Short to GND" are likely caused by the missing +12V due to the blown fuse.
Unfortunately it's going to be really tough to find this unless/until the short actually exists while you're looking for it.
I'd place my bests on the OXS heaters and install fuses in all of those directly first ............on controller side and consumer.
You could fuse all consumers individually and when the magic fuse blows that's your part that failed.
I'd also have a look at the brake light switch.
Sandbullet
Utah, USA
C?ID=297733
F word... That's what I thought... :banghead:
I appreciate the review and response though :)
Sandbullet
Utah, USA
C?ID=297733
I really appreciate you taking the time to review my post and then reply. I just wanted to clarify your suggestions.
I assume that you are referring to the heated O2 sensors when you say OXS heaters? I need the dummy version as I'm not as skilled at this stuff as thee...
What do you mean by controller side and consumer side? I can do all of this but just need to understand what you're suggesting.
Are you suggesting that I should look for a short in the brake light switch? Is this a common issue or something you see in the scan? What do you suggest I do with the brake light switch? Test, replace, etc...?
Thank you in advance for your time and assistance! I really appreciate it.
Dustin
