2009 Mk6 Golf DSG intermittent transmittion fault
jay86galway
Ireland
C?ID=305408
Hi Guys,
Complete newbie to VCDS here. Bought it as have been having issues with my DSG gearbox on my golf. It is a LQV code gearbox. Car has 103KW CBAB engine if that's of relevance. Car has been losing drive, will be traveling along as normal in "D" when drive is cut and ESP/ABS lights flash on the dash. "D" is also flashing beside the selector. I have scanned the car and its come back with a long list of codes. Some like the number plate light(LED number plate lights) and air-con pressure are fine but its the transmission control module and incorrect coding of CAN gateway ones I know very little about. I'm guessing, or should I say hoping that the rest are all knock on issues from the CAN gateway and transmission ones. Here is the scan I done the other evening, have cleared them and will re-scan in a day or 2 to see which come back
Wednesday,19,July,2017,19:13:00:56033
VCDS Version: 17.6.0.2  HEX-V2 CB: 0.4341.4
Data version: 20170602 DS274
VIN: WVWZZZ1KZAW______   License Plate:
Mileage: 218550km-135800mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 2E 42 44 46 52 56 62 72
VIN: WVWZZZ1KZAW028658   Mileage: 218550km-135800miles
02-Auto Trans -- Status: Sporadic communication error 1000
Address 01: Engine (CBA)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 LB    HW: 03L 906 022 G
   Component: R4 2,0L EDC G000AG  3894
   Revision: 13H02---    Serial number:
   Coding: 0001078
   Shop #: WSC 00191 264 15243
   VCID: 70BAD9A306AEBD97BF1-8024
008213 - Intake Manifold Flap Position Sensor (Bank 1)
               P2015 - 000 - Implausible Signal - Intermittent
                    Fault Frequency: 7
                    Mileage: 218493 km
                    Date: 2011.11.28
                    Time: 23:11:38
                    Lambda: 11.8 %
                    Lambda: 2.4 %
                    Voltage: 0.380 V
                    Bin. Bits: 00000001
008504 - Accelerator Position Sensors (G79) / (G185)
               P2138 - 000 - Implausible Correlation - Intermittent
                    Mileage: 218242 km
                    Date: 2011.11.15
                    Time: 17:00:13
                    RPM: 1472 /min
                    Speed: 75.0 km/h
                    Voltage: 13.83 V
                    Voltage: 0.912 V
                    Voltage: 0.608 V
                    Bin. Bits:  0 01  0
049409 - No Communication with Transmission Control Module
               U0101 - 000 -  - Intermittent
                    Mileage: 218527 km
                    Date: 2011.12.06
                    Time: 17:09:09
                    RPM: 782 /min
                    Temperature: 14.4°C
                    Voltage: 13.53 V
                    Bin. Bits: 00000000
                    Torque: 0.0 Nm
                    Temperature: 29.7°C
   Part No SW: 02E 300 052     HW: 02E 927 770 AJ
   Component: GSG DSG AG6     440 1913
   Revision: 00044002    Serial number: 00000905150468
   VCID: 51FC7C27ADE4949F90F-8004
   Revision: 00H45001
   Coding: 163B400D09240002681102E9902100823500
   VCID: 005A89633A0EAD174F1-8054
                    Reset counter: 121
                    Mileage: 218259 km
                    Date: 2011.11.15
                    Time: 17:37:45
                    Count: 32782
                    Count: 12800
                    Count: 8195
                    Count: 49408
                    Count: 55040
   Part No SW: 3C8 907 336 H    HW: 3C8 907 336 H
   Component: Climatic      H13 0203
   Revision: 00006001
   Coding: 0000000000
   ASAM Dataset: EV_Climatic A01001
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 323E13ABC4A2CF87895-8066
          B10AB F0 [009] - Too Low
                    Reset counter: 81
                    Mileage: 218547 km
                    Date: 2017.07.18
                    Time: 19:23:21
   Part No SW: 1K0 937 086 C    HW: 1K0 937 086 C
   Component: BCM PQ35  M   103 0537
   Revision: 00103 AC
   Coding: 48180A3A9825F1C044080080140081E443510088536D8160648000200000
   VCID: 303A19A3CA2EFD97FF1-8064
   Component: Wischer 26050  21  0501
   Coding: 009795
   Component: RLS 090609 05  54  0402
   Coding: 0330AD
   Subsystem 4 - Part No: 1K0 951 605 D
   Component: LIN BACKUP HO  H08 9001
            007 - Short to Ground
                    Fault Status: 01100111
                    Fault Frequency: 161
                    Reset counter: 75
                    Mileage: 177440 km
                    Date: 2010.08.25
                    Time: 16:50:53
                        Term 15 Off
                    Voltage: 12.10 V
                        Term 50 Off
                    Reset counter: 121
                    Mileage: 218259 km
                    Date: 2011.11.15
                    Time: 17:37:45
                    Voltage: 13.65 V
                        Term 50 Off
                    Fault Status: 00101110
                    Fault Frequency: 21
                    Reset counter: 106
                    Mileage: 210976 km
                    Date: 2011.07.17
                    Time: 18:18:55
                    Voltage: 11.50 V
                        Term 50 Off
   Part No SW: 5K0 959 655     HW: 5K0 959 655
   Component: AirbagVW10    033 0604
   Serial number: 003C2RA03UHI
   Coding: 00003230
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01009
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 77A8E2BF6F40EAAF7EB-8022
   Component: S.Sens.Fahr.V  U01 ----
   Serial number: 4F741248ZZZZZZZZZZZZ
   Component: S.Sens.Beif.V  U01 ----
   Serial number: 5E343048ZZZZZZZZZZZZ
   Serial number: 262E2864ZZZZZZZZZZZZ
   Serial number: 3A512D3BZZZZZZZZZZZZ
   Part No SW: 1K0 953 549 CD    HW: 1K0 953 549 CD
   Coding: 0001532
   VCID: 76B6EFBB64CA93A765D-8022
   Subsystem 1 - Part No: 3C8 959 537 B  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAP   H4ÿ 0021
   Coding: 00000226
   Part No SW: 5K0 920 970 J    HW: 5K0 920 970 J
   Component: KOMBI         H05 0206
   Coding: 470B00
   VCID: 353428B735CCD8BFAC7-8060
12648704 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 121
                    Mileage: 218259 km
                    Date: 2017.06.24
                    Time: 17:37:43
   Part No SW: 1K0 907 530 AA    HW: 1K0 907 951
   Component: J533  Gateway   H07 0081
   Revision:   H07 01    Serial number: 100609F1000722
   Coding: ED807F06000212000003
   VCID: 6696BFFB346A6327D5D-8032
                    Fault Status: 00110100
                    Reset counter: 121
                    Mileage: 218259 km
                    Date: 2011.11.15
                    Time: 17:37:45
            000 -  -  - Intermittent
                    Mileage: 201000 km
                    Date: 2011.03.23
                    Time: 11:59:48
Address 25: Immobilizer (J334)       Labels:. 5K0-920-xxx-25.clb
   Component: IMMO          H05 0206
   Part No SW: 5N0 035 342 B    HW: 5N0 035 342 B
   Component: SG EXT.PLAYER H13 0090
   Revision: A1001003    Serial number: 7667728859
   VCID: 2616FFFBF8EAA32715D-8072
   Part No SW: 5K0 959 701 C    HW: 5K0 959 701 C
   Component: Tuer-SG         009 2110
   Coding: 0004790
   VCID: 323E13ABC822CF87895-8066
   Part No: 1K0 909 144 H
   Component: EPS_ZFLS Kl. 70     2901
   Revision: 00H15000
   VCID: 2F381ADFDB10E26FE6B-807A
   Part No SW: 5K0 959 702 E    HW: 5K0 959 702 E
   Component: Tuer-SG         009 2124
   Coding: 0005046
   VCID: 353428B7394CD8BFAC7-8060
   Part No SW: 1K0 035 186 AA    HW: 1K0 035 186 AA
   Component: Radio RCD310  013 0036
   Revision: 01000000    Serial number: VWZ1Z2I6172531
   Coding: 0100040004
   VCID: 6594B8F7C56C683FDC7-8030
   Part No SW: 5K0 959 703 C    HW: 5K0 959 703 C
   Coding: 0000144
   Shop #: WSC 01357 011 1012552
   VCID: 343215B33236C1B79B9-8060
   Part No SW: 5K0 959 704 C    HW: 5K0 959 704 C
   Coding: 0000144
End----------(Elapsed Time: 01:04, VBatt start/end: 12.2V/12.2V)-----------
Any help or insight would be greatly appreciated.
Jason
Several other control modules have faults like "Transmission Control Module -- No Signal/Communication -- Intermittent". This is indicative of your TCM itself going off-line, either due to some external cause like a bad electrical connection, or due to an internal fault.
jay86galway
Ireland
C?ID=305408
OK I'm going over to a friend's house later to put the car up on his lift so will check electrical connections. So you reckon that my TCM appears to be the main issue. Guess I'll start there then.
Thanks Uwe
