2012 Audi A3 TDI abs module replacement and coding issues
Bozwhizzle
C?ID=389205
Hi there, I am new to this forum. I have read several post about this issue and looking for some help or direction of where to go?
I had a local shop diagnose my troubles and verified it was the abs module that went bad. I recently purchased one from ecs tuning.
I did the auto scan and saved the file to my desktop. Then I opened up the abs system and retrieved the long coding and other numbers perhaps needed.
Installed the new abs module, connected to VCDS and have tried to enter new long coding and get this message..
"VCDS has detected a change in coding length. Are you sure you want to continue?"
Believing that I have the correct coding information from the previous abs module I select "Yes".
Then this message pop up - "This appears to be an uninitialized control module, valid WSC/Importer/Equipment data may be required. Click Yes for VCDS to use defalt values of 12345/123/12345. Click No for VCDS to try the values currently in the module. Click cancel to manually edit the values."
What I have read on this forum and researched seems like I am at the point where I could use some direction? Any help would be greatly appreciated!
Eddie
Please post both auto-scans; the one from before the ABS module swap, and the one with the new module installed.
Bozwhizzle
C?ID=389205
Hi there, thank you so much for your quick response!
I don't believe I have a scan from before the swap... I realized from several other posts that I jumped the gun and should have performed an auto scan before moving forward!
I have the scan from when I was trying to add the new coding to the new abs module. Let me know what you think?
Monday,23,December,2019,17:31:19:19969
VIN: WAUKJAFM5CA067047   License Plate:
Mileage: 127440km-79187mi   Repair Order:
Chassis Type: FM-AU35 (7N0)
Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 47 4C 52 55 56 62
          72 77
VIN: WAUKJAFM5CA067047   Mileage: 127440km-79187miles
4C-Tire Pressure II -- Status: Cannot be reached 1100
Address 01: Engine (CBE)       Labels: 03L-906-022-CBE.clb
   Part No SW: 03L 997 030 A    HW: 03L 906 019 EJ
   Component: R4 2.0l TDI G000AG  9983
   Revision: 12H14---    Serial number: AUX7Z0K8FNT0IN
   Coding: 0050078
   Shop #: WSC 03377 002 1048576
   VCID: 2C010314DA0FD77745F-8078
               U1017 - 000 -  - Intermittent
                    Fault Frequency: 255
                    Mileage: 113554 km
                    Date: 2019.06.29
                    Time: 15:15:21
                    RPM: 1196 /min
                    Speed: 15.0 km/h
                    Load: 29.0 %
                    Voltage: 13.15 V
                    Torque: 96.0 Nm
                    Hex Value: 0xFF02
                    Bin. Bits: 00101100
   Part No SW: 02E 300 057 A    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 9334
   Revision: 05351113    Serial number: 00001109200366
   Shop #: WSC 06314 000 00000
   VCID: 176BCCF8738944AF18D-8042
18255 - Please check DTC Memory of ABS Controller
            P1847 - 000 -  - Intermittent
                    Reset counter: 1
                    Mileage: 127428 km
                    Date: 2019.12.22
                    Time: 23:57:06
18261 - Powertrain Data Bus
            P1853 - 000 - Implausible Message from ABS Controller
                    Reset counter: 40
                    Mileage: 127442 km
                    Date: 2019.12.23
                    Time: 03:48:49
   Revision: 00H45001
   VCID: 005987A40A07E317C97-8054
6 Faults Found:
00003 - Control Module
                    Fault Status: 01100101
                    Reset counter: 0
                    Mileage: 127442 km
                    Count: 3
                    Count: 4096
                    Count: 143
                    Count: 44544
                    Count: 256
                    Reset counter: 0
                    Mileage: 127442 km
                    Count: 3
                    Count: 4096
                    Count: 279
                    Count: 44544
                    Count: 256
                    Reset counter: 0
                    Mileage: 127442 km
                    Count: 3
                    Count: 4096
                    Count: 295
                    Count: 44544
                    Count: 256
                    Reset counter: 0
                    Mileage: 127442 km
                    Count: 3
                    Count: 4096
                    Count: 270
                    Count: 44544
                    Count: 256
                    Reset counter: 0
                    Mileage: 127442 km
                    Count: 3
                    Count: 4096
                    Count: 195
                    Count: 44544
                    Count: 256
                    Reset counter: 0
                    Mileage: 127442 km
                    Count: 3
                    Count: 4096
                    Count: 212
                    Count: 44544
                    Count: 256
   Part No SW: 8P0 820 043 BM    HW: 8P0 820 043 BM
   Component: KlimavollautomatH09 0180
   Revision: 000046      Serial number: 8P0820043BM
   VCID: 78A9EF445ED7ABD7F17-802C
Address 09: Cent. Elect. (J519)       Labels:. 8P0-907-063.clb
   Part No SW: 8P0 907 063 Q    HW: 8P0 907 063 Q
   Component: BCM PQ35  M   110 0719
   Revision: 00110 AF
   Coding: 6E000A0FA01336E4287241E000100D4D401E62AA104DD128E40008840040
   Shop #: WSC 09550 758 180955
   VCID: 42DD4DAC448B31079F3-8016
   Subsystem 1 - Part No SW: 8P1 955 119 F    HW: 8P1 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer AU350  H11 0050
   Coding: 00DD13
01134 - Alarm Horn (H12)
                    Reset counter: 89
                    Mileage: 126101 km
                    Date: 2019.12.05
                    Time: 04:46:50
                        Term 15 Off
                    Voltage: 13.10 V
                        Term 50 Off
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Fault Frequency: 169
                    Reset counter: 89
                    Mileage: 126101 km
                    Date: 2019.12.05
                    Time: 04:54:55
                        Term 15 Off
                    Voltage: 12.65 V
                        Term 50 Off
                    Reset counter: 129
                    Mileage: 127442 km
                    Date: 2019.12.23
                    Time: 05:27:59
                    Voltage: 11.60 V
                        Term 50 Off
   Part No SW: 8E0 035 593 P    HW: 8E0 035 593 P
   Component: SDAR SIRIUS     H07 0160
   Revision: 00000000    Serial number: AUZ4Z7L0603354
   Coding: 0000100
   VCID: 3635217C14439DA723B-8062
Address 15: Airbags (J234)       Labels:* 8P0-959-655-10.clb
   Part No SW: 8P0 959 655 Q    HW: 8P0 959 655 Q
   Component: Airbag AU1042 H09 0250
   Revision: --------    Serial number: 003FC001JVA5
   Coding: 303142393041303030374A55304C38503053
   ROD: EV_Airba10AURB4.rod
   VCID: 50F977E49A67D397197-8004
   Subsystem 1 - Part No SW: 8P0 959 339 D    HW: 8P0 959 339 D
   Component: BF-Gewichtss.  H03 0040
   Serial number: 5850000R1190600QZV
   Serial number: 3572DRB40000E005315E
   Serial number: 3582DRB40000E0087A4U
   Serial number: 35128RB400006601E0DF
   Serial number: 35228RB40000660A93CM
   Serial number: 35547RB4000066D588B.
   Serial number: 35647RB4000066D5877X
   Part No SW: 8P0 953 549 K    HW: 8P0 953 549 K
   Coding: 0014142
   VCID: 46D551BC64A30D27B3B-8012
   Component: E0221           H02 0100
Address 17: Instruments        Labels: 8P0-920-xxx-17-MY8.clb
   Part No SW: 8P0 920 983 D    HW: 8P0 920 983 D
   Component: KOMBIINSTR. VDO H02 0150
   Revision: D0H02002    Serial number: 2248K002001786
   Coding: 0272288
   Shop #: WSC 12345 067 57207
   VCID: 3B2330482F6140CFDC5-806E
                    Mileage: 104614 km
                    Date: 2019.03.26
                    Time: 01:39:04
   Revision:   H42       Serial number: 210911F2002401
   Coding: 352102
   VCID: 35372670054596BF2A1-8060
03109 - Tire Pressure Monitoring Control Module 2 (J793)
                    Reset counter: 89
                    Mileage: 127442 km
                    Date: 2019.12.23
                    Time: 03:48:52
   Revision: D0H02002    Serial number: AUX7Z0K8FNT0IN
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN3.lbl
   Part No SW: 8P0 959 801 Q    HW: 8P0 959 801 Q
   Component: Tuer-SG         H04 0101
   Coding: 0001181
   VCID: 49CF5A8075BDE25F5E9-801C
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 233    3201
   Revision: 00H20000
   VCID: 34311B74023F8FB71DF-8060
                    Fault Status: 00101101
                    Reset counter: 129
                    Mileage: 127429 km
                    Date: 2019.12.22
                    Time: 23:57:45
                    Voltage: 13.50 V
                        DU
                    Temperature: 21.0°C
                    RPM: 1651 /min
                    Speed: 22.0 km/h
                    Speed: 22.0 km/h
   Part No SW: 8P4 035 382 E    HW: 8P4 035 382 E
   Component: AB2 SUBWOOFERBOXH07 0180
   Revision: 00006       Serial number: 92158124266503
   Part No SW: 8P0 959 802 Q    HW: 8P0 959 802 Q
   Coding: 0001181
   VCID: 4ACD658C70BBE947573-801E
   Part No: 8P3 907 357 B
   Coding: 0000013
   VCID: 3C2133542A6F47F7D5F-8068
                    Fault Frequency: 173
                    Reset counter: 129
                    Mileage: 111384 km
                    Date: 2019.06.10
                    Time: 18:58:31
   Part No SW: 8P0 035 186 AC    HW: 8P0 035 186 AC
   Component: R Concert2+     H05 0293
   Revision: 00H05000    Serial number: AUZ1Z3L2599809
   Coding: 0750112
   VCID: 73B3D86847B1C88FC45-8026
Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
   Part No SW: 8P4 959 801 F    HW: 8P4 959 801 F
   Component: Tuer-SG         H04 0050
   Coding: 0001176
   Shop #: WSC 06314 000 1012544
   VCID: 42DD4DAC488B31079F3-8016
Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
   Part No SW: 8P4 959 802 F    HW: 8P4 959 802 F
   Coding: 0001176
   VCID: 43D348A85791380F945-8016
   Part No SW: 8P1 862 336 A    HW: 8P1 862 336
   Component: FSE_256x BT     H44 0660
   Revision: 00000000    Serial number: 00000005158070
   Coding: 0001277
End----------(Elapsed Time: 01:35, VBatt start/end: 12.1V/12.1V)-----------
Gateway Installation List:  7N0 907 530 H
VCDS Release 19.6.2:  SRI Reset
Control Module Part Number: 8P0 920 983 D       Labels:  8P0-920-xxx-17-MY8.clb
Component:KOMBIINSTR. VDO H02 0150, Coding:0272288
Channel  	Description                                       	Unit      	Current val.  	New val.
02       	Service Reminder Status                           	          	1             	---
40       	Distance since Service                            	km x100   	49            	---
41       	Time since Service                                	Days      	70            	---
42       	Minimum Distance to Service                       	km x100   	150           	---
43       	Maximum Distance to Service                       	km x100   	150           	---
44       	Maximum Time to Service                           	Days      	365           	---
45       	Oil Quality                                       	          	1             	---
47       	Soot Quantity                                     	km x100   	0             	---
48       	Thermal Load                                      	km x100   	0             	---
49       	Minimum Time to Service                           	Days      	365           	---
50       	Basic Distance Value for Oil Change               	km x100   	160           	---
51       	Basic Time Value for Oil Change                   	Days      	365           	---
52       	Basic Distance Value for Inspection               	km x100   	160           	---
53       	Distance since Inspection                         	km x100   	286           	---
54       	Basic Time Value for Inspection                   	Days      	365           	---
55       	Time since Inspection                             	Days      	346           	---
56       	Day Counter                                       	Days      	2472          	---
Tuesday,24,December,2019,15:46:30:19969
          72 77
   Coding: 0050078
                    Mileage: 113554 km
                    Date: 2019.06.29
                    Time: 15:15:21
                    RPM: 1196 /min
                    Speed: 15.0 km/h
                    Load: 29.0 %
                    Voltage: 13.15 V
                    Torque: 96.0 Nm
                    Hex Value: 0xFF02
                    Bin. Bits: 00101100
                    Reset counter: 40
                    Mileage: 127442 km
                    Date: 2019.12.23
                    Time: 05:31:14
                    Reset counter: 1
                    Mileage: 127442 km
                    Date: 2019.12.24
                    Time: 03:26:13
   Revision: 00H45001
7 Faults Found:
                    Fault Status: 00101100
                    Reset counter: 89
                    Mileage: 127442 km
                    Date: 2019.12.24
                    Time: 03:26:13
                    Count: 3
                    Count: 12800
                    Count: 64
                    Count: 49674
                    Count: 7680
                    Reset counter: 89
                    Mileage: 127442 km
                    Date: 2019.12.23
                    Time: 05:31:15
                    Count: 7
                    Count: 12
                    Count: 4096
                    Count: 143
                    Count: 42752
                    Reset counter: 89
                    Mileage: 127442 km
                    Date: 2019.12.23
                    Time: 05:31:15
                    Count: 7
                    Count: 12
                    Count: 4096
                    Count: 279
                    Count: 42752
                    Reset counter: 89
                    Mileage: 127442 km
                    Date: 2019.12.23
                    Time: 05:31:15
                    Count: 7
                    Count: 12
                    Count: 4096
                    Count: 295
                    Count: 42752
                    Reset counter: 89
                    Mileage: 127442 km
                    Date: 2019.12.23
                    Time: 05:31:15
                    Count: 7
                    Count: 12
                    Count: 4096
                    Count: 270
                    Count: 42752
                    Reset counter: 89
                    Mileage: 127442 km
                    Date: 2019.12.23
                    Time: 05:31:15
                    Count: 7
                    Count: 12
                    Count: 4096
                    Count: 195
                    Count: 42752
                    Reset counter: 89
                    Mileage: 127442 km
                    Date: 2019.12.23
                    Time: 05:31:15
                    Count: 7
                    Count: 12
                    Count: 4096
                    Count: 212
                    Count: 42752
   Revision: 00110 AF
   Coding: 00DD13
                    Reset counter: 89
                    Mileage: 127442 km
                    Date: 2019.12.23
                    Time: 05:32:32
                        Term 15 Off
                    Voltage: 12.05 V
                        Term 50 Off
                    Reset counter: 89
                    Mileage: 127442 km
                    Date: 2019.12.23
                    Time: 05:34:31
                        Term 15 Off
                    Voltage: 13.60 V
                        Term 50 Off
   Coding: 0000100
   Coding: 0014142
   Coding: 0272288
   Coding: 352102
                    Reset counter: 89
                    Mileage: 127442 km
                    Date: 2019.12.23
                    Time: 05:31:19
   Coding: 0001181
   Revision: 00H20000
                    Reset counter: 129
                    Mileage: 127443 km
                    Date: 2019.12.24
                    Time: 03:36:27
                    Voltage: 11.88 V
                        DD
                    Temperature: 11.0°C
   Coding: 0001181
   Coding: 0000013
                    Reset counter: 129
                    Mileage: 127448 km
                    Date: 2019.12.24
                    Time: 03:26:17
   Coding: 0750112
   Coding: 0001176
   Coding: 0001176
   Coding: 0001277
End----(Elapsed Time: 01:33, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
Address 03,1K0 907 379 AP,recoded (Long Coding),from,000000000000000000000000000000000000,to,1150400F49280001880B02E892200042BF0C00,(00000/000/00000),
alfa
Kiev, Ukraine
1142401209280001880B02E890200042xxxx
to complete two bytes to add
Или
1142401209280001880B02E8902000423800
Bozwhizzle
C?ID=389205
I really appreciate the help!
Just so I am sure...
Enter the first code...what do you mean to “complete two bytes to add”?
Do I just enter the long coding and see if it takes?
The second coding would be if the first didn’t work?
Sorry for the questions, this is my first time going through this.
Have you looked in your Scans sub-folder?
So you're saying you don't have the original coding?
alfa
Kiev, Ukraine
Do not think, but do it when a specialist advises. I need information, pleasant coding or rejected, and then we’ll compose it according to the configuration.
Вместо ххх вставьте ноли 0000.
Последние байты ручками составим, главное что бы блок скушал кодинг.
Bozwhizzle
C?ID=389205
Yes I do not have an auto scan from before the swap.
The original long code for the abs module before swap is the following:
When I enter the first long code that you provided I get Error 22 “coding rejected, conditions not correct or request sequence error”
Also, Error 31: request out of range.
I will run another auto scan and attach it.
Thanks again!!!
Bozwhizzle
C?ID=389205
Latest s
auto scan after I tried the code you sent me.
Friday,27,December,2019,18:20:42:19969
Mileage: 127440km-79187mi   Repair Order: 12.27.19
          72 77
   Coding: 0050078
                    Mileage: 113554 km
                    Date: 2019.06.29
                    Time: 15:15:21
                    RPM: 1196 /min
                    Speed: 15.0 km/h
                    Load: 29.0 %
                    Voltage: 13.15 V
                    Torque: 96.0 Nm
                    Hex Value: 0xFF02
                    Bin. Bits: 00101100
                    Reset counter: 40
                    Mileage: 127443 km
                    Date: 2019.12.25
                    Time: 03:39:30
   Revision: 00H45001
9 Faults Found:
                    Fault Status: 00100011
                    Reset counter: 89
                    Mileage: 127443 km
                    Date: 2019.12.25
                    Time: 03:13:27
                    Count: 3
                    Count: 4608
                    Count: 67
                    Count: 49677
                    Count: 5120
                    Reset counter: 89
                    Mileage: 127442 km
                    Date: 2019.12.24
                    Time: 03:26:13
                    Count: 3
                    Count: 12800
                    Count: 64
                    Count: 49674
                    Count: 7680
03306 - Coding Not Valid
                    Reset counter: 89
                    Mileage: 264453 km
                    Date: 2001.12.04
                    Time: 00:08:07
                    Count: 768
                    Count: 159
                    Count: 22784
                    Count: 4161
                    Count: 256
                    Count: 36609
                    Count: 212
                    Count: 22785
                    Reset counter: 89
                    Mileage: 127442 km
                    Date: 2019.12.23
                    Time: 05:31:15
                    Count: 7
                    Count: 12
                    Count: 4096
                    Count: 143
                    Count: 42752
                    Reset counter: 89
                    Mileage: 127442 km
                    Date: 2019.12.23
                    Time: 05:31:15
                    Count: 7
                    Count: 12
                    Count: 4096
                    Count: 279
                    Count: 42752
                    Reset counter: 89
                    Mileage: 127442 km
                    Date: 2019.12.23
                    Time: 05:31:15
                    Count: 7
                    Count: 12
                    Count: 4096
                    Count: 295
                    Count: 42752
                    Reset counter: 89
                    Mileage: 127442 km
                    Date: 2019.12.23
                    Time: 05:31:15
                    Count: 7
                    Count: 12
                    Count: 4096
                    Count: 270
                    Count: 42752
                    Reset counter: 89
                    Mileage: 127442 km
                    Date: 2019.12.23
                    Time: 05:31:15
                    Count: 7
                    Count: 12
                    Count: 4096
                    Count: 195
                    Count: 42752
                    Reset counter: 89
                    Mileage: 127442 km
                    Date: 2019.12.23
                    Time: 05:31:15
                    Count: 7
                    Count: 12
                    Count: 4096
                    Count: 212
                    Count: 42752
   Revision: 00110 AF
   Coding: 00DD13
                    Reset counter: 89
                    Mileage: 127443 km
                    Date: 2019.12.25
                    Time: 03:33:03
                    Voltage: 11.70 V
                        Term 50 Off
                    Reset counter: 89
                    Mileage: 127443 km
                    Date: 2019.12.25
                    Time: 03:34:28
                        Term 15 Off
                    Voltage: 12.00 V
                        Term 50 Off
   Coding: 0000100
   Coding: 0014142
   Coding: 0272288
   Coding: 352102
                    Reset counter: 89
                    Mileage: 127443 km
                    Date: 2019.12.25
                    Time: 03:39:34
   Coding: 0001181
   Revision: 00H20000
   Coding: 0001181
   Coding: 0000013
   Coding: 0750112
   Coding: 0001176
   Coding: 0001176
   Coding: 0001277
End----(Elapsed Time: 01:33, VBatt start/end: 11.6V/11.6V. VIgn 11.6V)-----
Old coding:
Current module:
Old coding is one byte too long for current module!
Try:
alfa
Kiev, Ukraine
Так.
1442401209280001280B02E8902000423F04
Bozwhizzle
C?ID=389205
Unfortunately the last two codes that you sent were rejected.
Here is the latest auto scan after my attempts...
Sunday,29,December,2019,09:17:28:19969
Mileage: 127440km-79187mi   Repair Order: 12.29.19
          72 77
   Coding: 0050078
                    Mileage: 113554 km
                    Date: 2019.06.29
                    Time: 15:15:21
                    RPM: 1196 /min
                    Speed: 15.0 km/h
                    Load: 29.0 %
                    Voltage: 13.15 V
                    Torque: 96.0 Nm
                    Hex Value: 0xFF02
                    Bin. Bits: 00101100
                    Reset counter: 40
                    Mileage: 127443 km
                    Date: 2019.12.25
                    Time: 03:39:30
                    Reset counter: 1
                    Mileage: 127443 km
                    Date: 2019.12.27
                    Time: 06:25:04
   Revision: 00H45001
9 Faults Found:
                    Reset counter: 89
                    Mileage: 127442 km
                    Date: 2019.12.24
                    Time: 03:26:13
                    Count: 3
                    Count: 12800
                    Count: 64
                    Count: 49674
                    Count: 7680
                    Reset counter: 89
                    Mileage: 127443 km
                    Date: 2019.12.25
                    Time: 03:13:27
                    Count: 3
                    Count: 4608
                    Count: 67
                    Count: 49677
                    Count: 5120
                    Reset counter: 89
                    Mileage: 264453 km
                    Date: 2001.12.04
                    Time: 00:04:08
                    Count: 768
                    Count: 159
                    Count: 22784
                    Count: 4161
                    Count: 256
                    Count: 36609
                    Count: 212
                    Count: 22785
                    Reset counter: 89
                    Mileage: 127442 km
                    Date: 2019.12.23
                    Time: 05:31:15
                    Count: 7
                    Count: 12
                    Count: 4096
                    Count: 143
                    Count: 42752
                    Reset counter: 89
                    Mileage: 127442 km
                    Date: 2019.12.23
                    Time: 05:31:15
                    Count: 7
                    Count: 12
                    Count: 4096
                    Count: 279
                    Count: 42752
                    Reset counter: 89
                    Mileage: 127442 km
                    Date: 2019.12.23
                    Time: 05:31:15
                    Count: 7
                    Count: 12
                    Count: 4096
                    Count: 295
                    Count: 42752
                    Reset counter: 89
                    Mileage: 127442 km
                    Date: 2019.12.23
                    Time: 05:31:15
                    Count: 7
                    Count: 12
                    Count: 4096
                    Count: 270
                    Count: 42752
                    Reset counter: 89
                    Mileage: 127442 km
                    Date: 2019.12.23
                    Time: 05:31:15
                    Count: 7
                    Count: 12
                    Count: 4096
                    Count: 195
                    Count: 42752
                    Reset counter: 89
                    Mileage: 127442 km
                    Date: 2019.12.23
                    Time: 05:31:15
                    Count: 7
                    Count: 12
                    Count: 4096
                    Count: 212
                    Count: 42752
   Revision: 00110 AF
   Coding: 00DD13
                    Fault Frequency: 7
                    Reset counter: 89
                    Mileage: 127443 km
                    Date: 2019.12.25
                    Time: 03:33:03
                    Voltage: 11.70 V
                        Term 50 Off
                    Reset counter: 89
                    Mileage: 127443 km
                    Date: 2019.12.25
                    Time: 03:34:28
                        Term 15 Off
                    Voltage: 12.00 V
                        Term 50 Off
   Coding: 0000100
   Coding: 0014142
   Coding: 0272288
   Coding: 352102
                    Reset counter: 89
                    Mileage: 127443 km
                    Date: 2019.12.25
                    Time: 03:39:34
   Coding: 0001181
   Revision: 00H20000
                    Reset counter: 129
                    Mileage: 127443 km
                    Date: 2019.12.27
                    Time: 06:25:04
                    Voltage: 13.63 V
                        DU
                    Temperature: 18.0°C
                    RPM: 992 /min
                    Speed: 1.0 km/h
                    Speed: 1.0 km/h
   Coding: 0001181
   Coding: 0000013
   Coding: 0750112
   Coding: 0001176
   Coding: 0001176
   Coding: 0001277
End----(Elapsed Time: 01:38, VBatt start/end: 11.6V/11.6V. VIgn 11.6V)-----
alfa
Kiev, Ukraine
1142401209280001880B02E8902000513808
Пробуй.
Bozwhizzle
C?ID=389205
The last one did not work either.
Just to make sure I am doing this correctly...
Open VCDS, go to Select Control Module - 03 - ABS Brakes - Coding 07 - New Coding then enter new code in space below? Click Do It!
Below that section has Workshop# , Importer # and Equipment # Do I need to enter anything for those values?
On my previous abs module for the Workshop # it had 06314
Thanks again!
alfa
Kiev, Ukraine
Yes need. The coding may not be accepted if there are 00000
sorry
00 - 14
01 - 50 USA ?????
02 - 40
14424012хх280001280B02E8xx200051B900
1442401209280001280B02E890200051B900
1442401249280001280B02E892200051B900
14424012хх280001280B02E8xx200051????
Bozwhizzle
C?ID=389205
So I went back and tried to enter each code again also adding the work shop # 06314 they are all rejected. Still not coding properly.
Do you need an updated auto scan?
Bozwhizzle
C?ID=389205
here is the updated scan.
Monday,30,December,2019,17:20:16:19969
Mileage: 127440km-79187mi   Repair Order: 12.30.19
          72 77
   Coding: 0050078
                    Mileage: 113554 km
                    Date: 2019.06.29
                    Time: 15:15:21
                    RPM: 1196 /min
                    Speed: 15.0 km/h
                    Load: 29.0 %
                    Voltage: 13.15 V
                    Torque: 96.0 Nm
                    Hex Value: 0xFF02
                    Bin. Bits: 00101100
                    Reset counter: 40
                    Mileage: 127443 km
                    Date: 2019.12.25
                    Time: 03:39:30
                    Reset counter: 1
                    Mileage: 127443 km
                    Date: 2019.12.27
                    Time: 06:25:04
   Revision: 00H45001
8 Faults Found:
                    Reset counter: 89
                    Mileage: 127442 km
                    Date: 2019.12.24
                    Time: 03:26:13
                    Count: 3
                    Count: 12800
                    Count: 64
                    Count: 49674
                    Count: 7680
                    Reset counter: 89
                    Mileage: 127443 km
                    Date: 2019.12.25
                    Time: 03:13:27
                    Count: 3
                    Count: 4608
                    Count: 67
                    Count: 49677
                    Count: 5120
                    Reset counter: 89
                    Mileage: 127442 km
                    Date: 2019.12.23
                    Time: 05:31:15
                    Count: 7
                    Count: 12
                    Count: 4096
                    Count: 143
                    Count: 42752
                    Reset counter: 89
                    Mileage: 127442 km
                    Date: 2019.12.23
                    Time: 05:31:15
                    Count: 7
                    Count: 12
                    Count: 4096
                    Count: 279
                    Count: 42752
                    Reset counter: 89
                    Mileage: 127442 km
                    Date: 2019.12.23
                    Time: 05:31:15
                    Count: 7
                    Count: 12
                    Count: 4096
                    Count: 295
                    Count: 42752
                    Reset counter: 89
                    Mileage: 127442 km
                    Date: 2019.12.23
                    Time: 05:31:15
                    Count: 7
                    Count: 12
                    Count: 4096
                    Count: 270
                    Count: 42752
                    Reset counter: 89
                    Mileage: 127442 km
                    Date: 2019.12.23
                    Time: 05:31:15
                    Count: 7
                    Count: 12
                    Count: 4096
                    Count: 195
                    Count: 42752
                    Reset counter: 89
                    Mileage: 127442 km
                    Date: 2019.12.23
                    Time: 05:31:15
                    Count: 7
                    Count: 12
                    Count: 4096
                    Count: 212
                    Count: 42752
   Revision: 00110 AF
   Coding: 00DD13
                    Fault Frequency: 9
                    Reset counter: 129
                    Mileage: 127443 km
                    Date: 2019.12.25
                    Time: 03:33:03
                    Voltage: 11.70 V
                        Term 50 Off
                    Reset counter: 89
                    Mileage: 127443 km
                    Date: 2019.12.25
                    Time: 03:34:28
                        Term 15 Off
                    Voltage: 12.00 V
                        Term 50 Off
   Coding: 0000100
   Coding: 0014142
   Coding: 0272288
   Coding: 352102
                    Reset counter: 89
                    Mileage: 127443 km
                    Date: 2019.12.25
                    Time: 03:39:34
   Coding: 0001181
   Revision: 00H20000
                    Reset counter: 129
                    Mileage: 127443 km
                    Date: 2019.12.28
                    Time: 23:11:37
                    Voltage: 13.88 V
                        DU
                    Temperature: 13.0°C
                    RPM: 922 /min
   Coding: 0001181
   Coding: 0000013
                    Reset counter: 129
                    Mileage: 127448 km
                    Date: 2019.12.28
                    Time: 21:26:28
   Coding: 0750112
   Coding: 0001176
   Coding: 0001176
   Coding: 0001277
End----(Elapsed Time: 01:38, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
Did you also try non-zero values for Importer and Equipment Number?
Try with WSC = 07221, Importer = 444, and Equipment Number = 09104.
Bozwhizzle
C?ID=389205
I went back through and tried all the codes provided adding the WCS, Importer and Equipment #'s... still a no go? Any ideas?
Do you need any info from either the old abs module or the new one?
alfa
Kiev, Ukraine
Блок HW: 1K0 907 379 AP не ставился на эту модель автомобиля.
Был случай когда после аварии из двух авто делали один, тоже были похожие проблеммы. Блок вприлюбых правильных кодировках выдавал код 31
Block HW: 1K0 907 379 AP was not placed on this model of car.
There was a case when after an accident they made one of two cars, there were similar problems too. The block in any correct encoding gave code 31
