hi guys i seem to have issues with some of the moduals in my car with some having malfunctions and some communication errors , this is something i have never done before can someone shed some light it would be appreciated !
Friday,11,November,2016,11:23:02:63393
VCDS Version: 16.8.3.1
VIN: WUAZZZ4F58N900328 License Plate: OYO8UPF
Mileage: 141720km-88060mi Repair Order:
Chassis Type: 4F (4L0)
Scan: 01 02 03 05 07 08 09 0E 0F 11 31 14 15 16 17 19 1E 36 37 42
46 47 4F 52 53 55 56 57 61 62 65 67 6C 6D 72 76 77
VIN: WUAZZZ4F58N900328 Mileage: 141720km-88060miles
01-Engine -- Status: Sporadic communication error 1000
02-Auto Trans -- Status: Malfunction 1010
11-Engine II -- Status: Sporadic communication error 1000
31-Engine other -- Status: Sporadic communication error 1000
Address 01: Engine (BUH) Labels: 07L-910-552-BUH1.clb
Part No SW: 4F1 910 552 D HW: 4F1 907 552 A
Component: 5.0L V10/4V TFSI ™0080
Revision: F1H05--- Serial number:
Coding: 010D0003190F01B0
Shop #: WSC 66565 257 00032
VCID: 2540717EEC16A76AEF-8070
Readiness: 0110 1100
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4F5 910 156 P HW: 09E 927 156 D
Component: MRC 09E 5,0TFSI 280 0050
Revision: --H04--- Serial number: 0000391
Coding: 0000001
VCID: 3560A13E5CB6D7EA5F-8060
006273 - Powertrain Data Bus: Missing Message
P1881 - 000 - Acceleration Request - Intermittent
Mileage: 141136 km
Date: 2016.11.02
Time: 08:57:05
049408 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 - 000 - - Intermittent
Mileage: 141136 km
Date: 2016.11.02
Time: 08:57:05
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 AJ HW: 4F0 614 517 AR
Component: ESP8 quattro H01 0120
Coding: 0020931
Shop #: WSC 02152 785 00200
VCID: 6CD6445A4F7C562270-8038
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 A HW: 4F0 905 852 C
Component: FBSAUDIC6 ELVSG H01 0040
Revision: 09010701 Serial number: 10601601019888
Coding: 0000147
VCID: 24466C7AE72C5E62F8-8070
Subsystem 1 - Part No: 4F0 910 131 E
Component: FBSAUDIC6 EZS H46 0080
Subsystem 2 - Part No: 4F0 910 220 D
Component: FBSAUDIC6 IDG H01 0040
00263 - Transmission
Reset counter: 203
Mileage: 141136 km
Date: 2016.11.02
Time: 08:51:09
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F0 910 732 K HW: 4E0 035 729 A
Component: Interfacebox H43 5140
Revision: 00000000 Serial number: 351CV087559418
Coding: 0031002
Shop #: WSC 02556 785 00200
VCID: 2B5487468AF2911A39-807E
Component: Bedienteil MMIC6H01 0060
Subsystem 2 - Serial number: 00000000999963
Subsystem 3 - Serial number: 0119.02.080000000100010327ˇ
Subsystem 4 - Serial number: 010327ˇ
01310 - Level Control System Control Module (J197)
Reset counter: 251
Mileage: 126174 km
Date: 2015.06.22
Time: 17:22:36
01964 - Control Module for Seat & Steering Column Memory (J136)
Reset counter: 198
Mileage: 140399 km
Date: 2016.10.23
Time: 14:50:05
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 A HW: 4F2 820 043 Q
Component: KLIMABETAETIGUNGH30 0020
Revision: 00000052 Serial number: 00000000501797
Coding: 0525578
VCID: 1C36549ADF5C66A240-8048
00657 - Positioning Motor for Central Vents (V102)
003 - Mechanical Failure
Fault Status: 01100011
Reset counter: 184
Mileage: 126173 km
Date: 2007.07.31
Time: 18:53:04
Voltage: 13.80 V
Temperature: 23.0∞C
(no units): 31.0
(no units): 103.0
Temperature: 24.0∞C
01273 - Fresh Air Blower (V2)
Fault Status: 00101001
Fault Frequency: 153
Reset counter: 224
Mileage: 137825 km
Date: 2016.07.19
Time: 18:15:45
Temperature: 43.0∞C
Speed: 19.0 km/h
(no units): 25.0
(no units): 218.0
Reset counter: 204
Mileage: 141136 km
Date: 2016.11.02
Time: 08:57:09
Part No SW: 4F0 910 279 J HW: 4F0 907 279 A
Component: ILM Fahrer H18 0250
Coding: 0115121
VCID: 306E902AA3D4F2C20C-8064
Subsystem 1 - Part No: 4F2 910 113 B Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H04 0190
Coding: 00064784
Shop #: WSC 02556
Subsystem 2 - Part No: 4E0 910 557 B Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0100
Coding: 00146221
Shop #: WSC 02556
Address 0E: Media Player 1 (R199) Labels: 4E0-035-785.lbl
Part No SW: 4E0 035 785 D HW: 4E0 035 785
Component: SG ext.Player H15 0830
Revision: 00000000
Shop #: WSC 02399 823 56573
VCID: 29587D4E400E830ACB-807C
Address 0F: Digital Radio Labels: None
Part No SW: 4E0 910 563 C HW: 4E0 035 563
Component: DAB-Tuner H41 0830
Revision: 00000001 Serial number: KE1276V8100236
Coding: 0000001
Address 11: Engine II Labels: 07L-910-552-BUH2.clb
Address 14: Susp. Elect. Labels: None
Part No SW: 4F0 910 376 HW: 4F0 907 376
Component: J250 DRC FahrwerH02 0010
Serial number: 00870000037200
Coding: 0000000
VCID: 64C62C7AA7AC1E6238-8030
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
Component: 4F AIRBAG AUDI8RH30 0280
Revision: 09H30000 Serial number: 0037LD0X3DBI
Coding: 0013382
Shop #: WSC 02325 785 00200
VCID: 29587D4E800E830ACB-807C
Subsystem 1 - Serial number: 6332CSME2E3078296
Subsystem 2 - Serial number: 6342CSME2E351102X
Subsystem 3 - Serial number: 6352QSME50123405/
Subsystem 4 - Serial number: 6362QSME597B0D7B+
Subsystem 5 - Serial number: 63734SME57012D0B/
Subsystem 6 - Serial number: 63834SME585479513
Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
Component: J0527 0410
Revision: 00H03000 Serial number: 90026080600011
Coding: 0112142
VCID: 275C7B76961AB57ADD-8072
Component: E0221 H06 0030
Part No SW: 4F0 910 930 D HW: 4F0 920 981 T
Component: KOMBIINSTR. M73 H22 0010
Revision: 00100000 Serial number: 73A33YC28
Coding: 3153458
Shop #: WSC 15849 067 57207
Address 19: CAN Gateway Labels: 4L0-910-468.clb
Part No SW: 4L0 910 468 A HW: 4L0 907 468 B
Component: J533__Gateway H06 0060
Revision: 00H06000 Serial number: 1100B08305822D
Coding: F5D5FEF7707E0602
VCID: 2D50895EB4E69F2A27-8078
007 - Short to Ground
Fault Status: 01100111
Reset counter: 235
Mileage: 131881 km
Date: 2015.12.09
Time: 19:48:50
Reset counter: 203
Mileage: 141136 km
Date: 2016.11.02
Time: 08:51:09
Reset counter: 204
Mileage: 141136 km
Date: 2016.11.02
Time: 08:57:05
01342 - Engine Control Module 2 (Slave 1)
Reset counter: 204
Mileage: 141136 km
Date: 2016.11.02
Time: 09:07:00
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 E HW: 4E0 035 110 A
Component: MP3-Changer H46 0390
Revision: 00046002 Serial number: AUZ5ZBH8334826
VCID: 1A3A5282D568189252-804E
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory FS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0091138
VCID: 61C8256EB8BE0B4AD3-8034
Part No SW: 4E0 910 888 E HW: 4E0 919 887 M
Component: MNS ECE H51 1050
Revision: 00000000 Serial number: 364C.087768166
Shop #: WSC 00976 210 83269
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 N HW: 4F0 959 793 N
Component: TSG FA H05 0240
Revision: 00000000 Serial number: Å!S
Coding: 0012026
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 K HW: 4F0 907 289 K
Component: Komfortgeraet H27 0220
Revision: 02200027 Serial number: 01100625850000
Coding: 3285755
VCID: 326A9A22ADD8C0D27A-8066
Subsystem 1 - Component: Sounder No Answer
Subsystem 2 - Part No: 4F0 910 177
Component: Innenraumueberw.H01 0020
Reset counter: 184
Mileage: 139692 km
02071 - Local Databus
Fault Status: 00101100
Fault Frequency: 17
Reset counter: 223
Mileage: 139750 km
Fault Frequency: 16
Reset counter: 223
Mileage: 139750 km
Date: 2016.09.23
Time: 16:35:26
Reset counter: 204
Mileage: 141136 km
Date: 2016.11.02
Time: 08:57:05
Address 47: Sound System Labels: 4F0-910-223-BO.lbl
Part No SW: 4F0 910 223 J HW: 4F0 035 223 G
Component: DSP-High C6 H10 0240
Revision: PROD_01 Serial number: 00000000076534
Coding: 0000127
Part No SW: 4F0 910 280 HW: 4F0 907 280 G
Component: ILM Beifahrer H12 0100
Revision: Serial number: 00000000002791
Coding: 0011101
VCID: 5EB21E9289C034B2EE-800A
Reset counter: 204
Mileage: 141136 km
Date: 2016.11.02
Time: 08:57:00
Voltage: 11.800 V
Temperature: 14.0∞C
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 N HW: 4F0 959 792 N
Component: TSG BF H05 0240
Revision: 00000000 Serial number: &
Coding: 0012026
Part No SW: 4F0 910 801 C HW: 4F0 907 801 A
Component: EPB CDEC0080 H04 0080
Revision: --H04---
Coding: 0008021
Shop #: WSC 02197 785 00200
VCID: 204E606AF33442429C-8074
Reset counter: 204
Mileage: 141136 km
Date: 2016.11.02
Time: 08:57:05
Voltage: 10.97 V
Count: 241
Reset counter: 203
Mileage: 141136 km
Date: 2016.11.02
Time: 08:51:09
Voltage: 11.18 V
Count: 243
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Coding: 0000016
Shop #: WSC 00016 210 91098
Subsystem 1 - Part No: 4F0 941 329 D
Component: AFS-Modul links H01 0010
Subsystem 2 - Part No: 4F0 941 329 D
Component: AFS-Modul rechtsH01 0010
Mileage: 141144 km
Date: 2016.11.02
Time: 08:57:05
Part No SW: 4E0 910 541 Q HW: 4F0 035 541 L
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 394C%087876636
Coding: 0000001
VCID: 2E528E52B9E0E4321E-807A
Address 57: TV Tuner Labels: None
Part No SW: 4E0 910 148 D HW: 4E0 919 148
Component: R78 TVHybridDVB 0440
Revision: R0H06000 Serial number: 76300801256602
Coding: 0000303
Part No SW: 4F0 910 181 F HW: 4F0 915 181 B
Component: J0644 BEM H12 0760
Revision: 00000000 Serial number: 00000000046725
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 350313D0HB
Coding: 344630393135313035442056413033353033313344304842
Shop #: WSC 59530 001 104857
02255 - Voltage Measuring Lead from Vbat
Fault Status: 01101001
Reset counter: 184
Mileage: 141727 km
Date: 2007.07.31
Time: 12:19:31
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 G HW: 4F0 959 795 G
Component: TSG HL H04 0220
Coding: 0011306
Address 65: Tire Pressure Labels: 4F0-910-273-HI.lbl
Part No SW: 4F0 910 273 C HW: 4F0 907 273 A
Component: Reifendruck 3 H05 0100
Revision: 00050100 Serial number: 00000700028275
Coding: 0222625
Shop #: WSC 00477 128 73980
VCID: 23446F66E222595A81-8076
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 S HW: 4E0 035 753 A
Component: SDS 3502 UK H46 0630
Revision: 00000000 Serial number: 00000802150218
Shop #: WSC 12336 024 394758
VCID: 3662A63241B0DCF256-8062
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4F0 910 441 A HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J8230XC
Coding: 1020505
Shop #: WSC 00000 785 00200
VCID: 1E325E92C94074B2AE-804A
Address 6D: Trunk Elect. Labels: Redir Fail!
Part No SW: 4F9 910 591 HW: 4F9 827 851 F
Component: ValeoHeckdeckel H25 0290
Revision: --H25001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
Subsystem 1 - Part No: 4F9 910 592
Subsystem 3 - Serial number: RD28.02.08--H25001001B0034ˇ
Subsystem 4 - Serial number: 1B0034ˇ
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 G HW: 4F0 959 794 G
Component: TSG HR H04 0220
Coding: 0011306
Part No SW: 4F1 910 283 A HW: 4F1 919 283 A
Component: Parkhilfe 8-Kan H12 0110
Revision: 00H12000 Serial number: 64340806300009
Coding: 0221116
Reset counter: 203
Mileage: 141136 km
Date: 2016.11.02
Time: 08:51:09
Address 77: Telephone Labels: 4F1-910-336.lbl
Part No SW: 4F1 910 336 C HW: 4F1 862 335
Component: BTA H10 0960
Revision: 00H10000 Serial number: 00000007565461
Coding: 0050001
End-------------------------(Elapsed Time: 03:33)--------------------------
