- Mar 9, 2015
- 476
- 336
- Australia
- C?ID=241363
This seemingly simple retrofit has turned out to be one of the most problematic in terms of compatibility.
Just posting to get some feedback and other experience if possible.
There are 2 possible scenarios:
1. Retrofit to a car that already has 'max/highline' controllers 5Q0 959 593/592 - this is a plug and play install, just need to update door controller coding and central electrics adaptation to get mirrors to auto fold and unfold with car locking. Have seen this in Golf Rs, R Wagon Wolfburg edition, GTIs.
2. Car has 'min/lowline' controllers 5Q0 959 393/392. These need highline door controllers retrofitted. This is where the problems begin...
Problem:
I had a 2016 ED40 GTI that had lowline controllers in it, with SW 041. I installed highline x593B with software 025. All folding functions worked as did all other expected functions eg turn signal, side assist etc EXCEPT for puddle light, and could not run basic adaptation for window regulator. Therefor window autorun will not work.
Solution: replaced with 5Q0 959 593B controller with SW 041.
Problem:
2014 Golf TSI. Replaced lowline controllers with 5Q4 959 593B with SW 031. All functions work, window regulator adaptation works. However on unlock, the mirrors fold out, then immediately fold back in. When the car is started, mirrors fold out again. There is a fault being recorded against central locking having an open circuit. This would appear to be bogus, as this fault is not evident either with the factory door controllers nor with the abovementioned x593B controller with SW 025 (which has the problem of not being able to run regulator adaptation). Central locking basic settings test passes, and all doors lock and unlock with the keyfob.
Awaiting arrival of some sw 041 593B controllers to hopefully resolve this...
It appears to me that only controllers with SW 041 are able to support the retrofit but the supplier of the 5Q4 modules insists that sw 031 should work.
The only remaining problem I have is with the locking switch on the driver's door. When the head lights are on, this button is illuminated by a white LED. When the door is locked, this changes to an orange LED. When new door controllers are fitted, this no longer changes to orange. Output test confirms that the orange LED works, but it seems there is a coding/adaptation change which is required. I have heard that online ODIS is required for this, is anyone able to confirm?
Here is an autoscan of the Golf TSI with the 5Q4 controllers installed, which has the central locking fault which causes the mirrors to fold after opening:
Problem:
Problem:
Tuesday,01,November,2016,12:54:59:02396
VCDS Version: 16.8.2.3
Data version: 20160926 DS261.0
Workshop Code: 123 12345 000000
VIN: WVWZZZAUZEP0 License Plate: SANG
Mileage: 14538km-9033mi Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZEP01 Mileage: 14538km-9033miles
Address 01: Engine (J623-CXSA) Labels: 04E-907-309-V1.clb
Part No SW: 04E 906 016 DF HW: 04E 907 309 A
Component: 1.4l R4 TSI H08 5673
Revision: WAH08---
Coding: 01250032242405082000
Shop #: WSC 00028 028 00209
ASAM Dataset: EV_ECM14TFS01104E906016DF 002002
ROD: EV_ECM14TFS01104E906016DF_VW37.rod
VCID: 69D24F078870BE0A03-803C
Address 02: Auto Trans (J743) Labels: 0CW-927-769.clb
Part No SW: 0CW 300 044 T HW: 0AM 927 769 G
Component: GSG DQ200-MQB H43 4506
Revision: 00043014 Serial number: CU501305315456
ROD: EV_TCMDQ200021.rod
VCID: 4992AF87E8B05E0A23-801C
Part No SW: 5Q0 907 379 AA HW: 5Q0 907 379 G
Component: ESC H31 0457
Revision: 00000000 Serial number: 61693000000341
Coding: 01FA8AA124211171037E060641C92980512488C0608294F300220038C102
VCID: 7BFE054FF2EC3C9AE1-802E
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5G0 907 044 T HW: 5G0 907 044 T
Component: Climatronic H02 0705
Revision: 00001K06
Coding: 00120004200100001005000012101800
VCID: 3874DA43835AD7824C-806C
Air quality sensor:
459020 - Databus
Reset counter: 146
Mileage: 14492 km
Date: 2016.10.14
Time: 11:33:59
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5Q0 937 084 R HW: 5Q0 937 084 R
Component: BCM MQBAB B H14 0112
Serial number: 00011316301497
Coding: 03001842C24102F34BE44000000403081000000000000000000000000000
ROD: EV_BCMBOSCH_011_VW37.rod
VCID: 4796A9BFFEA4A87A35-8012
Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 130605 042 0551
Serial number: 130608153557
Subsystem 2 - Part No SW: 5Q0 955 547 HW: 5Q0 955 547 Labels: 5Q0-955-547.CLB
Component: RLFS 024 0042
Serial number: Y13M06D30H23M35S17S1
Coding: 00A8DD
549141 - Databus
Reset counter: 146
Mileage: 14492 km
Date: 2016.10.14
Time: 11:33:58
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-294.clb
Part No SW: 5Q0 919 294 C HW: 5Q0 919 294 A
Component: PARKHILFE 8K H02 0033
Revision: -------- Serial number: 94231316902283
Coding: 0031151011
ASAM Dataset: EV_EPHVA18AU3700000 002019
ROD: EV_EPHVA18AU3700000_VW37.rod
VCID: 3B7EC54FB26CFC9AA1-806E
Part No SW: 5Q0 959 655 C HW: 5Q0 959 655 C
Component: AirbagVW20 011 0361
Serial number: 003F5R05P9UX
Coding: 98CCC000000000005C00000000C800000065
Shop #: WSC 00028 028 00054
VCID: 4084B2A3DB8A9F42F4-8014
Subsystem 1 - Part No SW: ----------- HW: 480 001 506 13
Serial number: 35767000000EC6756D05
Subsystem 2 - Part No SW: ----------- HW: 480 001 506 13
Serial number: 35867000000F47756D00
Subsystem 3 - Part No SW: ----------- HW: 480 401 806 13
Serial number: 3516502A9107446343A/
Subsystem 4 - Part No SW: ----------- HW: 480 401 806 13
Serial number: 3526502AB1074462D151
Subsystem 5 - Part No SW: ----------- HW: 480 401 506 13
Serial number: 3556502AB106FA230367
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 507 AE HW: 5Q0 953 549 A
Revision: -------- Serial number: 25061304221465
Coding: 0500
Shop #: WSC 40195 333 37120
ROD: EV_SMLSKLOMQB_VW37.rod
VCID: 79F21F47F8D00E8AF3-802C
Part No SW: 5G0 920 861 HW: 5G0 920 861
Component: KOMBI 252 2210
Coding: 27A419082380000800082A00040000
VCID: 66C8443B996E91722E-8032
Part No SW: 5Q0 907 530 L HW: 5Q0 907 530 L
Component: GW MQB Mid 211 2147
Revision: -------- Serial number: 18061310800876
Coding: 030100342B086400EF0002481C0F00010001000000000000000000000000
ASAM Dataset: EV_GatewConti 009011
ROD: EV_GatewConti_009.rod
VCID: 3A70C04BBD56C592BA-806E
Subsystem 2 - Part No SW: 5G0 959 442 J HW: 5G0 959 442 J
H14 0035
Serial number: 27130000646290123202
Coding: 280000
Subsystem 3 - Part No SW: 5Q0 915 181 C HW: 5Q0 915 181 C
Component: J367-BDMHella H03 8042
Serial number: 7376150803
131659 - Door Control Module - Passenger's Door
U0200 00 [008] - No Communications
Reset counter: 146
Mileage: 14492 km
Date: 2016.10.14
Time: 11:34:00
Supply voltage: Terminal 30: 11.8 V
Terminal 15: On
Part No SW: 5Q4 959 593 E HW: 5Q4 959 593 B
Component: TSG FS 010 0031
Serial number: 9601161270110
Coding: 001102205C01020000001000
Shop #: WSC 12345 123 00000
Subsystem 1 - Part No SW: 5Q4 959 812 A HW: 5Q4 959 812 A
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000001739122
Coding: 0D0000
Reset counter: 106
Mileage: 14538 km
Date: 2016.11.01
Time: 12:47:23
65593 - Switch for Central Locking
B122D 29 [008] - Signal Implausible
Reset counter: 146
Mileage: 14538 km
Date: 2016.11.01
Time: 12:47:32
65652 - Motors for Central Locking
B122B 13 [009] - Open Circuit
Reset counter: 106
Mileage: 14538 km
Date: 2016.11.01
Time: 12:48:55
Part No SW: 5Q0 909 144 L HW: 5Q0 909 144 L
Component: EPS_MQB_ZFLS 119 1021
Coding: 01
ROD: EV_SteerAssisMQB_008.rod
VCID: 3D7ACB57AC78F2AA9F-8068
Part No SW: 5Q4 959 592 E HW: 5Q4 959 592 B
Component: TSG BFS 010 0031
Serial number: 9901161160510
Coding: 001100205C01020000001000
VCID: 4688A4BBF9AEB172CE-8012
Subsystem 1 - Part No SW: 5Q4 959 811 A HW: 5Q4 959 811 A
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000001752601
Coding: 050000
Reset counter: 146
Mileage: 14538 km
Date: 2016.11.01
Time: 12:44:15
Reset counter: 106
Mileage: 14538 km
Date: 2016.11.01
Time: 12:45:33
Address 5F: Information Electr. (J794) Labels: 5G0-035-MIB-STD1.clb
Part No SW: 5G0 035 824 A HW: 5G0 035 824 A
Component: MU-S--ER 040 0421
Serial number: V1E02006131654
Coding: 02730000FF00000011510001000900001F0100960100010001
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 234E1D2F2ADCA45A89-8076
Subsystem 1 - Part No SW: 5G0 919 605 HW: 5G0 919 605
Component: ABT_Std_Radio H44 0020
Serial number: VWZ8Z9N2403ANT
End-------------------------(Elapsed Time: 02:59)--------------------------
