Help Error 11 - VCDS: Login Invalid
sjc123456789
C?ID=285385
Hi, sorry to bother you, but i'm having trouble trying to do a regen on my 2011 VW Phaeton (UK car).
I believe the vcds is working and reading / cancelling down codes etc, but when trying to use the 27971 (security) and 10016 code for regen im getting the message below (both the security 27921 and 10016 codes appeared to be accepted) but then i got the following error that stopped me continuing with regen -
message in pop up windown is -
VCDS: Login Invalid
X Login Code Not Accepted by Controller!
You will have to turn the igntion OFF
for a while before trying again.
Error 11: Service not supported.
what am i doing wrong please?
MartinsX
Riga, Latvia
C?ID=268515
First of all full autoscan of Your car could be useful to see complete information.
Second - You do not need security login to start regeneration. Try to enter regeneration login only.
sjc123456789
C?ID=285385
Hi MartinS, thanks for the reply - please see below
Friday,23,September,2016,12:56:24:26315
VCDS Version: 16.8.1.3 (x64)
Data version: 20160902 DS256
Dealer/Shop Name: SJC123456789
Workshop Code: 678 12345 000009
VIN: WVWZZZ3DZB8006637   License Plate:
Chassis Type: 3D (6N0)
Scan: 01 02 03 05 06 07 08 09 15 16 17 18 19 34 36 37 38 42 46 47
          52 55 56 62 68 71 72 76
VIN: WVWZZZ3DZB8006637   Mileage: 154960km-96287miles
38-Roof Electronics -- Status: OK 0000
68-Wiper Electr. -- Status: OK 0000
71-Battery Charger -- Status: OK 0000
Address 01: Engine (CEX)       Labels: None
   Part No SW: 3D0 907 401 H    HW: 3D0 907 401 D
   Component: 3.0TDI EDC17G000AG  0010
   Revision: --H05---    Serial number: VWX3Z0K1930317
   Coding: 0406002C191F0160
   Shop #: WSC 01065 000 00000
   VCID: 24466C3CE4BD3462EA-5106
   Part No SW: 09L 927 760 R    HW: GS1 9.1 1.4
   Component: AG6 09L 3,0 TDI RdW 3606
   Revision: --H05---    Serial number:        4606283
   Coding: 0000001
   VCID: 4682D6B432C12672D4-5140
Address 03: ABS Brakes        Labels: 3D0-614-517.lbl
   Part No: 3D0 614 517 AK
   Component: ESP 5.7 allrad  H35 0047
   Coding: 0008356
   VCID: 6BD4470049E33B1A6B-5122
   Part No SW: 3D0 909 139 D    HW: 3D0 909 139 D
   Component:    Kessy            6850
   Revision: 00H23072    Serial number: VWX3Z0K1930317
   Coding: 0004328
   VCID: 2A5A82048199E212D0-807E
Address 06: Seat Mem. Pass        Labels: 3D0-959-759.lbl
   Part No: 3D0 959 759 CA
   Component: Sitzmemory D1 BF    1722
   Coding: 0000001
   VCID: 77FC6B7002AB8FFA9F-8022
Address 07: Control Head        Labels: 3D0-907-048.clb
   Part No SW: 3D0 907 048     HW: 3D0 907 048
   Component: J127 KBT vorn       0035
   Revision: ABH34001    Serial number: VWZ6Z7L0033035
   VCID: 63C42F20A633735AD3-8036
Address 08: Auto HVAC        Labels: 3D0-907-040.lbl
   Part No: 3D0 907 040 M
   Component: Climatronic D1      2039
   Coding: 0000001
   Shop #: WSC 16575 000 1048576
   VCID: 285E780C9F95D002C6-807C
Address 09: Cent. Elect.        Labels: 3D0-937-049-V2.clb
   Part No SW: 3D0 937 049 P    HW: 3D0 937 049 P
   Component: J519                7600
   Revision: -4006---    Serial number: --------------
   Coding: 618C0000AB2115825502770000000000
   VCID: 377CAB70422B4FFA5F-8062
   Part No: 3D0 909 601 F
   Component: 0S Airbag 8.4E+ H13 1155
   Coding: 0012371
   VCID: 264276349581C672F4-8072
Address 16: Steering wheel        Labels: 7L6-953-549.lbl
   Part No: 7L6 953 549 K
   Component: J527                3601
   Coding: 0000012
   VCID: 479CDBB032CB3F7A2F-8012
Address 17: Instruments        Labels: 3D0-920-xxx-17.lbl
   Part No SW: 3D0 920 983 G    HW: 3D0 920 983 G
   Component: J285 KOMBI-INST.    1421
   Revision: KPH06V04
   Coding: 0039401
   Shop #: WSC 37359 001 1048576
   VCID: 2D508918B477F52A35-8078
Address 18: Aux. Heat        Labels: None
   Part No: 3D0 815 005 AP
   Component: J737__Standheizung  4405
   Revision: 00084000    Serial number: 09020869A00000
   Shop #: WSC 12345 678 00009
   VCID: 6BD447004AE33B1A6B-803E
Address 19: CAN Gateway        Labels: 6N0-909-901-7L.clb
   Part No SW: 6N0 909 901     HW: 3D0 920 983 G
   Component: J533  GW-K-CAN TP20 1421
   Coding: 7FF2F7AE33011003
   VCID: 70EE506C63C5D8C25E-8024
Address 34: Level Control        Labels: 3D0-907-553-V2.clb
   Part No: 3D0 907 553 C
   Component: LUFTFDR.-CDC- 3C3V0 1122
   Coding: 0005521
   Shop #: WSC 03726 002 1048576
   VCID: 275C7B30928BDF7ACF-8072
Address 36: Seat Mem. Drvr        Labels: 3D0-959-760.lbl
   Part No: 3D0 959 760 CA
   Component: Sitzmemory D1 F     1722
   Coding: 0000004
   VCID: 6FEC53107AFBC73A47-803A
Address 37: Navigation (J0506)       Labels: None
   Part No SW: 3D0 035 680 B    HW: 3D0 035 680 B
   Component: RNS-MID       H34 1230
   Revision: AB001001    Serial number: VWZ6Z7L0033035
   Coding: 020100020000002000
   VCID: 1F4C63D00EDB17BAB7-804A
Address 38: Roof Electronics        Labels: 3D0-907-135.lbl
   Part No: 3D0 907 135 F
   Component: Dachmodul           0903
   Coding: 0012351
Address 46: Central Conv.        Labels: 3D0-959-933.lbl
   Part No: 3D0 959 933 M
   Component: 6Z HSG              8133
   Coding: 0000040
   VCID: 3A7AB24476395292A0-4AE8
   Subsystem 1 - Part No: 3D2 959 701 H
   Component: Tuersteuergeraet FS 0202
   Subsystem 2 - Part No: 3D2 959 702 H
   Component: Tuersteuergeraet BF 0202
   Subsystem 3 - Part No: 3D0 959 703 G
   Component: Tuersteuergeraet HL 0202
   Subsystem 4 - Part No: 3D0 959 704 G
   Component: Tuersteuergeraet HR 0202
   Subsystem 5 - Part No: 3D0 909 610 F
   Component: 3P HDSG             2630
   Subsystem 6 - Part No: 7L0 907 719 A
   Part No SW: 3D0 035 465 C    HW: 3D0 035 465 C
   Component: 08K Audioverst.     0120
   Revision: 00005000    Serial number: 00000000238844
   VCID: 21486528F8AF214A81-8074
Address 55: Headlight Range (J745)       Labels: 5M0-907-357-V3.clb
   Part No SW: 5M0 907 357 E    HW: 7L6 907 357 C
   Component: AFS-ECU       H04 0080
   Coding: 012E00000B000200
   Shop #: WSC 01065 000 00022
   ASAM Dataset: EV_HeadlRegulVWAFSPt 002006
   VCID: 3662A6748921B6F244-8062
   Subsystem 1 - Part No SW: 3D0 941 329 A    HW: 3D0 941 329 A  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H03 X008
   Coding: 210000
   Subsystem 2 - Part No SW: 3D0 941 329 A    HW: 3D0 941 329 A  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H03 X008
   Coding: 210000
Address 56: Radio (J0506)       Labels: None
Address 68: Wiper Electr.        Labels: 3Dx-955-1xx-V2.clb
   Part No: 3D2 955 120 B
   Component: Front Wiper         3501
   Coding: 0015733
   Shop #: WSC 01065 000 376832
   VCID: 21486528FCAF214A81-8074
Address 71: Battery Charger        Labels: 3D0-915-181.lbl
   Part No: 3D0 915 181 E
   Component: Batteriemanagement  2800
   VCID: 25407138E887CD6AFD-8070
Address 76: Park Assist        Labels: None
   Part No: 3D0 919 283 E
   Component: 10 Einparkhilfe     1107
   VCID: 2C56841C8B6DFC2222-8078
End-------------------------(Elapsed Time: 04:10)--------------------------
is this ok?
MartinsX
Riga, Latvia
C?ID=268515
Autoscan looks nice. I guess Uwe will correct Code tags soon :D
Why You want to run regeneration if You have no faults for restricted or overloaded DPF?
sjc123456789
C?ID=285385
Sorry, what tags do i need to change?
I had a code saying that it needed a regen - as below,
Thursday,15,September,2016,11:41:20:26315
VIN: WVWZZZ3DZB8006637   License Plate: ML61FFX
Mileage: 95702   Repair Order: 10
                Address 01: Engine       Labels: None
Control Module Part Number: 3D0 907 401 H    HW: 3D0 907 401 D
  Component and/or Version: 3.0TDI EDC17G000AG  0010
           Software Coding: 0406002C191F0160
            Work Shop Code: WSC 01065 000 00000
                      VCID: 24466C3CE4BD3462EA-5122
009263 - Diesel Particulate Filter (Bank 1)
               P242F - 001 - Restricted/Clogged - Intermittent
                    Fault Status: 00100001
                    Mileage: 153922 km
                    Date: 2016.09.14
                    Time: 22:02:55
                    RPM: 693 /min
                    (no units): 41.0
                    (no units): 23.0
                    (no units): 42.3
                    (no units): 1.0
008194 - Particulate Trap Bank 1
               P2002 - 008 - Efficiency Below Threshold - Intermittent
                    Mileage: 153922 km
                    Date: 2016.09.14
                    Time: 22:02:55
                    RPM: 693 /min
                    (no units): 41.0
                    (no units): 23.0
                    (no units): 42.3
                    (no units): 1.0
Was trying to do one just in case
MartinsX
Riga, Latvia
C?ID=268515
By "code tags" I mean way how to post autoscan printout. Like this:
Mileage: 153922 km
Date: 2016.09.14
Time: 22:02:55
RPM: 693 /min
(no units): 41.0
(no units): 23.0
(no units): 42.3
(no units): 1.0
Mileage: 153922 km
Date: 2016.09.14
Time: 22:02:55
RPM: 693 /min
(no units): 41.0
(no units): 23.0
(no units): 42.3
(no units): 1.0
Try just 10016 for regeneration.
sjc123456789
C?ID=285385
Thanks, will try again a little later, as said before i couldnt and was getting this message -
VCDS: Login Invalid
I wasnt sure if my shop name etc was wrong, i just typed something meaningful for me as -
Workshop Identification
Shop Name
SJC123456789
Code(WSC)
12345
VZ/Importer
678
Equipment Number
00009
sorry, not very original.
