We replaced front and rear brakes and rotors, he did open the bleeders to push the piston fluid out. After he put it together it has low brake pedal. We bled the brakes and it appears right front and left rear have less fluid flow than other wheels. I have to try to gravity bleed but ran out of time. I did try repair bleed and bleed but asks for a code or number, any ideas? I tried blocking each wheel and no change. Thanks Mario
Thursday,04,August,2016,19:04:06:15785
VCDS Version: 16.8.0.1
Data version: 20160801 DS254
VIN: WAUFGCFC2CN088384 License Plate: 2012 A6
Mileage: 80709km-50150mi Repair Order:
Chassis Type: FC (4G0)
Scan: 01 02 03 05 08 09 0E 10 15 16 17 19 36 3B 42 44 46 52 53 55
56 5F 62 72
VIN: WAUFGCFC2CN088384 Mileage: 80709km-50150miles
Address 01: Engine (J623-CGXB) Labels: 06E-907-551-CGW.clb
Part No SW: 4G0 907 551 A HW: 4G0 907 551 A
Component: 3.0l V6 TFSIH07 0008
Revision: --H07---
Coding: 0A2A0032052600060000
Shop #: WSC 02311 785 00200
ASAM Dataset: EV_ECM30TFS0214G0907551A 003009
ROD: EV_ECM30TFS0214G0907551A.rod
VCID: 275646065ED0BD7AC3-8072
Address 02: Auto Trans (J217) Labels: 0BK-927-156.clb
Part No SW: 4G0 927 158 P HW: 0BK 927 156 R
Component: 0BK 30TFSIUSA H08 1006
Revision: --H08---
Coding: 000002
ASAM Dataset: EV_TCMAL551211 002018
ROD: EV_TCMAL551211_AU48.rod
VCID: 3B7E8A76B258099AB7-806E
Address 03: ABS Brakes (J104) Labels: 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 H HW: 4G0 907 379 H
Component: ESP PREMIUM H09 0361
Coding: 44A70F0122E5F0805B00
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ESPPremiAU57X 004028
ROD: EV_ESPPremiAU57X_AU57.rod
VCID: 36689B42897AD4F248-8062
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 4H0 907 064 BC HW: 4H0 907 064 BC
Component: BCM2 2.0 H31 0333
Coding: 09883006000000000000
VCID: 6BDE7A368AB8591A67-803E
Component: J764 ELV MLB H39 0046
Serial number: 2311000244813010
Address 08: Auto HVAC (J255) Labels: 4G0-820-043-2Z.clb
Part No SW: 4G0 820 043 H HW: 4G0 820 043 H
Component: KLIMA 2 ZONEN H10 0063
Serial number: 21111100040447
Coding: 6681201808
ASAM Dataset: EV_AirCondiBasisUDS 002039
ROD: EV_AirCondiBasisUDS.rod
VCID: 244C510A2FE65662E6-8070
0019 - Motor for Fresh Air / Recirculated Air Flap
B11AF 07 [008] - Mechanical Failure
Reset counter: 12
Mileage: 79492 km
Date: 2016.07.12
Time: 15:39:28
Voltage terminal 30: 13.71 V
Outside air temperature: 35.0 °C
Interior temperature: 46.57 °C
Fresh air door motor-Act.value: 11421
Fresh air door motor-Specified value: 10211
Fresh air door motor-Stop open: 11412
Fresh air door motor-Stop closed: 10000
Fresh air door motor-Last active operating mode: 0
Fresh air door motor-Active operating mode before last: 0
Address 09: Cent. Elect. (J519) Labels: 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 BG HW: 4H0 907 063
Component: BCM1 2.0 H12 0100
Revision: 11012002 Serial number: 00000001299147
Coding: 06002096063C9FE00100088780003908CF9CD308A2090121800004402000
VCID: 6ED87322B9AAAC3240-803A
Component: WWS57X 111013 H35 0051
Serial number: 111021190926
Coding: 0045F7
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 11777797
Coding: 02512B
Subsystem 3 - Part No SW: 4G0 941 531 D HW: 4G0 941 531 D
Component: E1 - LDS H07 0044
Serial number: 08 11 2011 00001160
Component: USHL4.2 H30 0030
Serial number: 0000002274555R0TS502
Subsystem 5 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA103381000000590161
Coding: 020300
Subsystem 6 - Part No SW: 4G0 907 658 A HW: 4G0 907 658 A
Component: Humidity_Sens H02 0002
Serial number: BD184AD5000000000001
Address 0E: Media Player 1 (R41) Labels: Redir Fail!
Part No SW: 8X0 035 110 B HW: 8X0 035 110
Component: CDC-MP3-Pana H41 0480
Revision: 00000007
VCID: 2C5CB92A4F369E222E-8078
Address 10: Park/Steer Assist (J446) Labels: 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 L HW: 4H0 919 475 C
Component: PARKHILFE ACC H07 0043
Revision: 11001001 Serial number: 55901131901314
Coding: 080105
ASAM Dataset: EV_EPHVA18AU57X0000 002005
ROD: EV_EPHVA18AU57X0000.rod
Address 15: Airbags (J234) Labels: 4H0-959-655.clb
Part No SW: 4G0 959 655 A HW: 4G0 959 655 A
Component: Airbag10.43 H31 0032
Revision: -------- Serial number: 003D8001KT5-
Coding: 30323437313130303035554A304C34473053
ROD: EV_AirbaAU10BPAAU64X_AU57.rod
VCID: 336EA2569A08C1DA6F-8066
Serial number: 3575HRB40510UJCIF9CS
Serial number: 3585HRB40530UJCI6PSB
Serial number: 3515JRB405D0OSD4FP8
Serial number: 3525JRB40650R8AAFPCM
Serial number: 3554VRB404T0PMKOLP35
Serial number: 3564VRB404T0PMKOK15Q
Address 16: Steering wheel (J527) Labels: 4H0-953-568.clb
Part No SW: 4H0 953 568 H HW: 4H0 953 568 H
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90372KK4001C3
Coding: 000414
VCID: 3874957A8B6E22825A-806C
Subsystem 1 - Part No SW: 4G0 951 528 F HW: 4G0 951 528 F
Component: E221 - MFL H09 0009
Serial number: 27 10 2011 33154614
Address 17: Instruments (J285) Labels: 4H0-920-xxx-17.clb
Part No SW: 4G8 920 931 L HW: 4G8 920 931 L
Component: TBenRdw H79 0416
Revision: 25460175 Serial number: 658141111592006
Coding: 0BA609040B010008020000
ASAM Dataset: EV_RBD4K 004045
ROD: EV_RBD4K.rod
VCID: 377696468E702DFA53-8062
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 4G0 907 468 G HW: 4G0 907 468 A
Component: J533--Gateway H08 0214
Revision: -------- Serial number: 00000000307939
Coding: 00C1033000
ROD: EV_GatewUDS_AU57.rod
VCID: 346CA14A9F06C6E276-8060
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0141
Serial number: 00000000003790118679
Component: MEM-FS H03 0154
Revision: AA000000 Serial number: 00000018197452
Coding: 0058130000002001000001010101102030303232203232
VCID: 77F65646C6F0EDFA93-8022
Part No SW: 4G0 907 637 HW: 4G0 907 637
Component: SARA 3D H02 0004
Revision: -------- Serial number: EJ1BPA3200X5XR0
ASAM Dataset: EV_SARA 006014
ROD: EV_SARA.rod
VCID: 6BDE7A3682B8591A67-803E
Address 42: Door Elect, Driver (J386) Labels: None
Part No SW: 4G8 959 793 E HW: 4G8 959 793 A
Component: TSG FA H05 0212
Coding: 011F17204E00620002000002
Shop #: WSC 02312 785 00200
VCID: 4280F792DDB27852F4-8016
Address 44: Steering Assist (J500) Labels: None
Part No SW: 4G0 909 144 L HW: 4G0 909 144 G
Component: RCEPS H35 0010
Revision: 00001000 Serial number: 0003219202
Coding: 101000010000
Shop #: WSC 29088 001 1048576
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_AU57.rod
VCID: 3260A7526512C8D264-8066
Address 46: Central Conv. (J393) Labels: 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0163382600
Coding: 0106023A00FA440480B00800000500000000000000000000000000000000
Subsystem 1 - Part No SW: 4G0 959 719 HW: 4G0 959 719
Component: GTO BF H01 0070
Serial number: 00000000000000059089
Subsystem 3 - Part No SW: 7P5 959 591 HW: 4H0 959 591
Component: J245 PS40.033 H07 0006
Serial number: WOO1413850$
Coding: 101E00
Address 52: Door Elect, Pass. (J387) Labels: None
Part No SW: 4G8 959 792 E HW: 4G8 959 792 A
Component: TSG BF H05 0212
VCID: 4182F89ED8B4634AED-8014
Part No SW: 4H0 907 801 E HW: 4H0 907 801 A
Component: EPB-4 H03 0012
Revision: -------- Serial number: 00000000185700
ROD: EV_ParkiBrake_AU57.rod
VCID: 2A50BF324DC28012DC-807E
Address 55: Headlight Range (J431) Labels: 8X0-907-357.clb
Part No SW: 4H0 907 357 A HW: 4H0 907 357 A
Component: ....LWR12.... H02 0013
Serial number: 111115-0004-116
Coding: 1221A6101002A200
ROD: EV_HeadlRegulBasic.rod
VCID: 2C5CB92A47369E222E-8078
Part No SW: 4G0 035 082 B HW: 4G0 035 082
Component: Radio U SIRIU H53 0076
Revision: AB001007 Serial number: 156KA0B7574398
Coding: 020007020100000001
VCID: 1F465EE60E8075BABB-804A
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 4G0 035 664 C HW: 4G0 035 664
Component: H-BN-NA H48 0423
Revision: -------- Serial number: 434K20B7506676
Coding: 050200000003E0ED45028B0E00000003F00001020000000000
VCID: 26484B0251DAA472F8-8072
Component: NAR 2011 0505
Subsystem 2 - Part No SW: 4G0 919 605 A HW: 4G0 919 605 A
Component: DU8 C7 SV H42 0021
Serial number: AUZ8ZDB1301RBGT
Subsystem 3 - Part No SW: 4G1 919 610 C HW: 4G1 919 610 C
Component: E380 BDT C7 H11 0204
Serial number: 90349KKE000F5
Component: CD-Database 3371
Address 62: Door, Rear Left (J388) Labels: None
Part No SW: 4G8 959 795 E HW: 4G8 959 795 A
Component: TSG HL H04 0212
Coding: 010F17204000620002000002
VCID: 448CF18AC7A67662C6-8010
Address 72: Door, Rear Right (J389) Labels: None
Component: TSG HR H04 0212
End-------------------------(Elapsed Time: 05:07)--------------------------
