Transmission fluid leaking where bellhousing and transmission meet up underneath the car. As of today i took out my engine to see whats going on, torque coverter i feel like is the issue. The seal and bearing look fine to me but wanted some advice to see what needs replacement exactly to eliminate the problem, transmission works great so its not my transmission and looked at the front transmission pump looks fine also . For reference i drove the car for 1000k miles after i installed used engine and didnt have a problem with the leak it was small, one day i noticed i was leaking too much from transmission lines going to radiator . Fixed that with o rings but bout the time i did that it occured to me i was running the transmission on low fluid the whole time , then the whine came. Question is , does torque converter,bearing, or seal need replacement? Will follow up with photos.
