Hi all.
Just received my new car, and this is my first post - so I hope it´s placed the right place.
My car is a 2016 Skoda Superb 3V, that comes with a lot of kit as standard. I.e. it has the A5 camera, ACC and so on. I would like
to activate Lane Assist, which I read on Stemei.de is possible on the Passat B8 - a car that is technically quite identical to the Superb.
Road Sign Recognition would be nice to activate as well, but by reading posts on Briskoda.co.uk it seems like the system will throw an error, if you activate this without having a navigation system installed.
Another nice feature would be the possibility to close the tailgate using the remote and/or the button inside the car, but I don´t believe there is any solution for this yet?
Since some of the modules are still lacking label files, I would like to ask for help to activate Lane Assist. Which modules should be coded etc.
Just by "playing around" and taking a look, I can see that LA is mentioned in many of the modules. Steering, camera etc.
Thanks in advance - any help is appreciated.
Below is an autoscan:
Saturday,09,April,2016,20:17:11:21896
VCDS Version: 15.7.4.1
Data version: 20160216
VIN: TMBJB7NP5G7066963 License Plate:
Mileage: 128km-79mi Repair Order:
Chassis Type: NP (5Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 36 42 44 52 55 5F 6D A5
VIN: TMBJB7NP5G7066963 Mileage: 128km-79miles
Address 01: Engine (J623-CZEA) Labels: 04E-907-309-V1.clb
Part No SW: 04E 906 027 BT HW: 04E 907 309 AB
Component: R4 1.4l TFS H23 9042
Revision: R6H23---
Coding: 01250032236419086000
Shop #: WSC 33361 790 00063
ASAM Dataset: EV_ECM14TFS01104E906027BT 001010
ROD: EV_ECM14TFS01104E906027BT.rod
VCID: 77D31055CE98CC864F-8022
Address 02: Auto Trans (J743) Labels: 0CW-927-769.clb
Part No SW: 0CW 300 040 J HW: 0AM 927 769 E
Component: GSG DQ200G2_M H05 0605
Revision: 00005005 Serial number: CU501602126249
ROD: EV_TCMDQ200021_SK25.rod
VCID: 3B5BCC65B23028E66B-806E
Part No SW: 3Q0 907 379 AB HW: 3Q0 907 379 G
Component: ESC H42 0723
Revision: 00000000 Serial number: 60476000002068
Coding: 1E076A9C342613720780060641C64978562CC8E0608292F51821F078C202
ROD: EV_Brake1UDSContiMK100IPB_SK37.rod
VCID: 7AD50961FD8AD1EE30-802E
Address 08: Auto HVAC (E87) Labels: None
Part No SW: 3V0 907 044 AG HW: 3V0 907 044 AG
Component: AC Automat H32 3701
Revision: 20K05000 Serial number: 00000B00070329
Coding: 12010004000100011005100000101002
Shop #: WSC 73430 790 00063
ASAM Dataset: EV_ACClimaPrehVW37X 002012
ROD: EV_ACClimaPrehVW37X_SK48.rod
VCID: 79D7166DF88CDAF639-802C
Slave 1:
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5Q0 937 084 CL HW: 5Q0 937 084 AN
Component: BCM MQBAB H H24 0175
Serial number: 01061605302155
Coding: 0C001B46C2C722FB57C44004001C57280000000000000000000000000000
ROD: EV_BCMBOSCH_SK48.rod
VCID: 042977998F4E971E5A-8050
Slave 1:
Subsystem 1 - Part No SW: 3V1 955 119 HW: 3V1 955 119 Labels: 5QX-955-119-V1.CLB
Component: 48x LL 160217 032 0121
Serial number: 00000001602120308271
Coding: 165DDD
Slave 2:
Component: RLHS 037 0059
Serial number: S4Y16M02D24H17M13S00
Coding: 00084D
Address 10: Park/Steer Assist (J446) Labels: 5Q0-919-294.clb
Part No SW: 5Q0 919 294 L HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0056
Revision: -------- Serial number: 39391605101238
Coding: 0071051851
ROD: EV_EPHVA18AU3700000_SK48.rod
VCID: 44A9B799CFCE571E1A-8010
Address 13: Auto Dist. Reg (J428) Labels: 3Q0-907-572.clb
Part No SW: 3Q0 907 572 B HW: 3Q0 907 572 B
Coding: 320067C211FFC428949C804D
ROD: EV_ACCBOSCHVW48X.rod
VCID: 3449E7599F6EE79EAA-8060
Part No SW: 5Q0 959 655 AK HW: 5Q0 959 655 AK
Component: AirbagVW21 005 0130
Serial number: 003Q5R1GMMLE
Coding: 98CCC0C0000000005C5400CF004800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002146
ROD: EV_AirbaVW20SMEVW37X_SK48.rod
VCID: 093766ADA86CCA7629-805C
Subsystem 1 - Part No SW: ----------- HW: 480 002 002 16
Serial number: 35700000000B4969691R
Subsystem 2 - Part No SW: ----------- HW: 480 002 002 16
Serial number: 3580000000069099D91T
Subsystem 3 - Part No SW: ----------- HW: 480 402 302 16
Serial number: 3510002A51F93A31C374
Subsystem 4 - Part No SW: ----------- HW: 480 402 302 16
Serial number: 3520002A51F93A31733$
Subsystem 5 - Part No SW: ----------- HW: 480 402 302 16
Serial number: 3550002B31F93A35C1AC
Address 16: Steering wheel (J524) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 521 GB HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0195
Revision: FF033033 Serial number: 20160220400177
Coding: 6410
ROD: EV_SMLSVALEOMQB.rod
VCID: 78D11369C386C3FE46-802C
Part No SW: 3V0 920 750 HW: 3V0 920 750
Component: KOMBI 313 6422
Coding: 07A5090A2F80000801883A011000000000000000
Shop #: WSC 73430 031 00063
ROD: EV_DashBoardVDDMQBAB_SK25.rod
VCID: 70C12B49ABF69BBE8E-8024
Part No SW: 5Q0 907 530 AJ HW: 5Q0 907 530 M
Component: GW MQB High 212 2246
Revision: -------- Serial number: 19021610802558
Coding: 030100047F085700FB00025A1C0F00010001070000000000000000000000
ROD: EV_GatewConti.rod
Subsystem 2 - Part No SW: 3V0 919 719 A HW: 3V0 919 719 A
Component: E221__MFL-PR6 H02 0150
Serial number: 000000000B0503150216
Subsystem 3 - Part No SW: 5Q0 915 181 G HW: 5Q0 915 181 G
Component: J367-BDMHella H04 8050
Serial number: 4589149303
Address 36: Seat Mem. Drvr (J810) Labels: None
Part No SW: 5Q0 959 760 A HW: 5Q0 959 760 A
Component: Sitzmemory H06 0009
Serial number: Y0006PB110055
Coding: 001000000000010001A080808080000000008181000000D4
ASAM Dataset: EV_SeatMemorDriveSide 001015
ROD: EV_SeatMemorDriveSide_SK37.rod
Component: TSG FS 020 0041
Serial number: 180116EAG11272
Coding: 001D0920DE00040000001100
ROD: EV_DCUDriveSideEWMAXCONT_SK37.rod
VCID: 43ABB485CAC0502623-8016
Address 44: Steering Assist (J500) Labels: 5Q0-909-143.clb
Part No SW: 5Q0 909 143 M HW: 5Q0 909 143 E
Component: MQB_PP_APA 204 2041
Revision: 00000000 Serial number: 0000625324
Coding: 01000010005001
ASAM Dataset: EV_SteerAssisVWBSMQBA 008028
ROD: EV_SteerAssisVWBSMQBA_SK48.rod
VCID: 3D5FC27DAC2426D655-8068
Component: TSG BFS 020 0041
Serial number: 150116EAE11088
Coding: 001D0320DE00040000001100
ROD: EV_DCUPasseSideEWMAXCONT_SK37.rod
VCID: 42A5B181D5DA592E28-8016
Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Coding: 06DA00003F000000
ROD: EV_HeadlRegulVWAFS_SE26.rod
VCID: 40A1BB89DBD64B3E3E-8014
Subsystem 1 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0006
Coding: B20000
Subsystem 2 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0006
Coding: B20000
Address 5F: Information Electr. (J794) Labels: 3V0-035-MIB-STD2.clb
Part No SW: 5Q0 035 842 A HW: 5Q0 035 842 A
Component: MU-S-D-ER H24 0245
Serial number: SKZAZ2S8233209
Coding: 03840200FF0000001111120100880A002F0200C40120010002
ROD: EV_MUStd4CTSAT_SE25.rod
VCID: 2D7FF23D7C44B656E5-8078
Media Player Position 1:
Subsystem 1 - Part No SW: 3V0 919 605 HW: 3V0 919 605
Component: ABT_Std-2 H46 1031
Serial number: SKZ8Z9SFD002CW
Address 6D: Trunk Elect. (J605) Labels: None
Part No SW: 5Q0 959 107 J HW: 5Q0 959 107 J
Component: HDSG-Modul H13 0253
Revision: -------- Serial number: 30535386500000
Coding: 0D00
ASAM Dataset: EV_DeckLidCONTIAU736 001012
ROD: EV_DeckLidCONTIAU736_SK48.rod
VCID: 3FA3B875A62834C647-806A
Address A5: Frt Sens. Drv. Assist (R242) Labels: None
Part No SW: 3Q0 980 654 D HW: 3Q0 980 654
Component: MQB_B_MFK H04 0024
Serial number: 16021611K11208
Coding: 0204080200000401002200448040A00000000E100020
ROD: EV_MFKBoschMQBB_SK48.rod
VCID: 3851D369830603FE86-806C
End-------------------------(Elapsed Time: 04:13)--------------------------
