- May 1, 2024
- 4
- 3
- Butler, PA, USA
- C?ID=162050
Installing a VW trailer wiring harness and need help with the programing. I've looked up some threads and made some slight changes to the codes. Here is what the codes look like so far:
Wednesday,01,May,2024,10:06:23:44010
VCDS Version: 23.11.0.0 (x64) HEX-V2 CB: 0.4643.4
VIN: 3VVCB7AX1PM114562 License Plate:
Chassis Type: AX-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 3C 42 44 52 5F 69 6C 75 A5
BB BC CA
VIN: 3VVCB7AX1PM114562 Mileage: 23671km-14708miles
BB-Door Rear Drv -- Status: Cannot be reached 0100
BC-Door Rear Pass -- Status: Cannot be reached 0100
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DTEA) Labels: None
Part No SW: 83A 907 115 K HW: 06L 907 309 B
Component: R4 2.0l TFSI H31 0002
Revision: 1DH31000 CVN: 556E26D5
Coding: 012A00122464012FB4000000000000000000000000000000
Shop #: WSC 00066 790 00143
ASAM Dataset: EV_ECM20TFS01183A907115K 001003
ROD: EV_ECM20TFS01183A907115J.rod
VCID: 2E050277F09DFBDA8DF-807A
VINID: 0E699348746806074104414608EFBA2956
17156 - Databus
U1123 00 [00101111] - Received Error Message
Fault Frequency: 28
Mileage: 23486 km
Date: 2024.04.29
Time: 11:05:27
Engine RPM: 1208.50 /min
Normed load value: 14.9 %
Coolant temperature: 20 °C
Intake air temperature: 23 °C
Voltage terminal 30: 11.480 V
Drivetrain coordinator: brake fault status-Bits 0-7: 0
Acceleration: 0.000 m/s²
23765 - Control unit for information electronics 1
U1054 00 [00100000] - No Communication
[Information electronics control module 1No Communication]
Mileage: 15366 km
Date: 2024.01.08
Time: 15:55:49
Engine RPM: 1119.00 /min
Normed load value: 26.3 %
Coolant temperature: 66 °C
Intake air temperature: 59 °C
Voltage terminal 30: 11.920 V
Unlearning counter according OBD: 36
Com st X Set2 Val1-Bits 0-7: 0
Com st X Set2 Val2-Bits 0-7: 0
Com st X Set2 Val3-Bits 0-7: 0
Com st X Set2 Val4-Bits 0-7: 0
Com st X Set2 Val4-Bits 0-7: 32
Com st X Set2 Val5-Bits 0-7: 0
Com st X Set2 Val6-Bits 0-7: 0
Com st X Set2 Val7-Bits 0-7: 0
Com st X Set2 Val7-Bits 0-7: 1
Address 02: Auto Trans (J217) Labels: None
Part No SW: 09G 927 158 GM HW: 09G 927 158
Component: AISIN AQ8 206 3936
CVN: F1FCAF00
Coding: 0000000100000000000000000000000000000000
Shop #: WSC 00066 790 00454
ROD: EV_TCMAQ450031_VW37.rod
VCID: 045180DF0E91A18A0BB-8050
Part No SW: 5Q0 614 517 GB HW: 5Q0 614 517 BP
Component: ESC H36 0114
Revision: 00000000 Serial number: 51103000001216 Dataset Number: V03935346AW 0001
Coding: 0BFA6BA450211B70C57C0206A2C549D0D60AD8A34045927038415558D2A24A0B00002E64121A03102F35351919323200
ASAM Dataset: EV_Brake1UDSContiMK100IPB 049015
ROD: EV_Brake1UDSContiMK100IPB_049.rod
VCID: 77ABE7134F47FA121E9-8022
Part No SW: 3Q0 959 435 Q HW: 3Q0 959 435 Q
Component: VWKESSYMQB 037 1400
Revision: 00037000 Serial number: 0617608976 Dataset Number: V03935340QJ 0001
Coding: 132C0C0723
Shop #: WSC 00066 790 00441
ASAM Dataset: EV_KessyHellaMQBAB 004055
ROD: EV_KessyHellaMQBAB.rod
VCID: 48C954EF723945EAA73-801C
Address 08: Auto HVAC (E87) Labels:| 5G0-907-044.clb
Part No SW: 5NA 907 044 AP HW: 5NA 907 044 AP
Component: AC Automat H60 1501
Revision: 20K03000 Serial number: 00000A00620666 Dataset Number: V03935361EE 0000
Coding: 0002002420011C0C1104010012111416
ASAM Dataset: EV_ACTouchPrehVW37X 001010
ROD: EV_ACTouchPrehVW37X_VW37.rod
VCID: 0D47A5FB5DDBE0C2545-8058
Part No SW: 5Q0 937 085 CK HW: 5Q0 937 085 CK
Component: BCM MQBAB HNA H44 0511
Serial number: 3152014501ÿÿÿÿ Dataset Number: V03935387SY 0001
ASAM Dataset: EV_BCMMQB 022001
ROD: EV_BCMBOSCH_022_VW27.rod
Subsystem 1 - Part No SW: 5NN 955 119 B HW: 5NN 955 119 Labels: 1KX-955-119.CLB
Component: 326 LL 230412 041 0374
Serial number: 23040621044830
Coding: 064DDD
Subsystem 2 - Part No SW: 81D 955 555 A HW: 81D 955 555
Component: G397_RLFSS H06 0004
Serial number: 40855059X81D955555A0
Coding: 0000DE
Steering Column Switch:
Subsystem 3 - Part No SW: 5Q1 953 521 KK HW: 5Q1 953 569 H
Component: Lenks.Modul H04 0190
Serial number: 0300240520230C201126
15626 - Bulb for Left Brake Lamp / Turn Signal
B1333 15 [00001000] - Open or Short to Plus
Reset counter: 4
Mileage: 20279 km
Date: 2024.04.06
Time: 10:39:01
Terminal 15 status: OFF
Terminal 50 status: OFF
CAN-Bus_aktiv: On
OFF: Not operated
Position lamps: Not operated
Low beam: Not operated
Voltage: 12.3 V
Outside temperature: 16.5 °C
18186 - Bulb for Rear Left Side Marker Lamp
B12BC 15 [00001000] - Open or Short to Plus
Reset counter: 4
Mileage: 20279 km
Date: 2024.04.06
Time: 10:39:01
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 12.3 V
Part No SW: 5QA 919 294 J HW: 5QA 919 294
Component: PDC 8 Kanal H08 0073
Serial number: 000460608223130 Dataset Number: V03935375UJ 0001
Coding: 8471155911
ASAM Dataset: EV_EPHVA18AU3700000 009053
VCID: 53F37383BB7FF632C21-8006
13688835 - Databus
[Steuergerät für Rear Cross Traffic Alert - RCTA_01.RCTA_Status - Fehlerspeicher auslesen]
Reset counter: 43
Mileage: 23637 km
Date: 2024.04.30
Time: 19:09:19
Part No SW: 2Q0 907 572 AA HW: 2Q0 907 572 D
Component: ACCCONTIMQB H09 0396
Dataset Number: V03935389RR 0001
Coding: 3200075218FF8728749C810580409700000000000000000034
ASAM Dataset: EV_ACCMRRCONTIVW376 003018
ROD: EV_ACCMRRCONTIVW376_003.rod
VCID: 73B3D3035B3F9632221-8026
0803 - Databus
[FAULT_BV1_FEHLER]
Reset counter: 254
Mileage: 23486 km
Date: 2024.04.29
Time: 11:05:34
Voltage terminal 15: 11.6 V
Control Module temperature: 29 °C
Vehicle speed: 0.00 m/s
Longitudinal acceleration: 0.00 m/s²
Adaptive distance regulation: status: ACC_irreversible error
196740 - Sensor for Automatic Distance Control
C110B F0 [00001000] - Limited Visibility
[FAULT_SENSOR_BLOCKAGE]
Reset counter: 4
Mileage: 19042 km
Date: 2024.01.28
Time: 15:04:45
Voltage terminal 15: 14.7 V
Control Module temperature: 19 °C
Vehicle speed: 35.22 m/s
Longitudinal acceleration: -0.44 m/s²
Adaptive distance regulation: status: ACC_switch-off_reaction
1229 - Control Module Incorrectly Coded
U1014 00 [00001001] - -
[FAULT_CODING_AAG]
Reset counter: 254
Mileage: 23486 km
Date: 2024.04.29
Time: 11:05:27
Control Module temperature: 28 °C
Adaptive distance regulation: status: ACC_Off_MainSwitch_Off
Part No SW: 5Q0 959 655 CB HW: 5Q0 959 655 CB
Component: AirbagVW21 010 0421
Serial number: 003J4M0F3R7E Dataset Number: V03935355MG 0001
ASAM Dataset: EV_AirbaVW20SMEVW37X 002166
VCID: 025D86C71485AFBA397-8056
Component: BF-Gewichtss. H17 0022
Serial number: IBH00000000000KHGSDB
Coding: 303553
Subsystem 2 - Part No SW: ----------- HW: 480 000 903 23
Serial number: 35700000000417A0766D
Subsystem 3 - Part No SW: ----------- HW: 480 000 803 23
Serial number: 358000000008F228856R
Subsystem 4 - Part No SW: ----------- HW: 480 403 003 23
Component: SideSensor_Dr 005 6149
Serial number: 3510001C8A05A1159881
Subsystem 5 - Part No SW: ----------- HW: 480 403 003 23
Component: SideSensor_Pr 003 6149
Serial number: 3520001A70E6CA4201C3
Subsystem 6 - Part No SW: ----------- HW: 480 402 804 23
Component: FrontSensor_D 003 6149
Serial number: 3550001C50E8EFA327BT
Subsystem 7 - Part No SW: ----------- HW: 480 402 804 23
Component: FrontSensor_P 003 6149
Serial number: 3560001A50E8EFA1841J
Part No SW: 5NA 920 410 B HW: 5NA 920 410 B
Component: KOMBI 060 4848
Coding: 08A400086788CF050288620B10010000A0200D02
Shop #: WSC 00066 790 00277
ASAM Dataset: EV_DashBoardJCIMQBAB 010007
ROD: EV_DashBoardJCIMQBAB_010_VW27.rod
VCID: 36352A1708CDC31AC5F-8062
16777018 - Function Restricted due to Interrupted Communications
U1110 00 [00001000] - -
[BAP_Audio_0x31 keine Kommunikation]
Reset counter: 35
Mileage: 23446 km
Date: 2024.04.28
Time: 15:23:46
[BAP_TEL_0x28 keine Kommunikation]
Reset counter: 16
Mileage: 22534 km
Date: 2024.04.20
Time: 15:17:02
16777022 - Function Restricted due to Interrupted Communications
[BAP_NAV SD_0x32 keine Kommunikation]
Reset counter: 35
Mileage: 22534 km
Date: 2024.04.20
Time: 15:17:01
16777056 - Function Restricted due to Interrupted Communications
[BAP_SDS_0x46 keine Kommunikation]
Reset counter: 7
Mileage: 21164 km
Date: 2024.04.12
Time: 09:42:29
Part No SW: 3Q0 907 530 AR HW: 3Q0 907 530 E
Component: GW MQB High 524 5502
Serial number: 12052300841700 Dataset Number: V03935370EU 0001
Coding: 030900347F085B00FA0002D8180F00010001070000000000000000000000
GVL: 01443C0000000400C0CC80008002C80010000000000000000000000000000000
ROD: EV_GatewNF_VW37.rod
VCID: 7F5B0F336777C252569-802A
Generator:
Component: 5-01-14-01-04
Subsystem 2 - Part No SW: 1EA 959 442 E HW: 1EA 959 442 E
Component: MFL H03 0219
Serial number: 17036218130752300832
Coding: 2C2B00
Subsystem 3 - Part No SW: 5QA 915 181 D HW: 5QA 915 181 D
Component: J367-BDMHella H11 9070
Serial number: 1484069800
131699 - Control unit for information electronics 1
U1054 00 [00001000] - No Communication
[Timeout Knoten 0x73 / 5F - Steuergerät für Informationselektronik 1]
Reset counter: 38
Mileage: 15366 km
Date: 2024.01.08
Time: 15:55:51
Terminal 30 power supply: 12.1 V
Terminal 15: On
66304 - Databus
U1124 00 [00001000] - Additional Installations Detected
[Mehrverbau CAN]
Fault Frequency: 46
Reset counter: 41
Mileage: 23486 km
Date: 2024.04.28
Time: 18:48:01
Terminal 30 power supply: 12.5 V
Terminal 15: OFF
197149 - Generator
U1052 00 [00001000] - No Communication
[Generator (LIN#1) Timeout]
Reset counter: 41
Address 3C: Lane Change (J1086) Labels:* None
Part No SW: 2Q0 907 686 B HW: 2Q0 907 686 B
Component: HRE3_Kl15_Mst H07 0150
Serial number: 11230058691846 Dataset Number: V03935352AH 0001
Coding: 52954640
ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
ROD: EV_HREntryHellaGen3Kl15.rod
VCID: 392F212B39D32C6228D-806C
Subsystem 1 - Part No SW: 2Q0 907 685 B HW: 2Q0 907 685 B
Component: HRE3_Kl15_Slv H07 0150
Serial number: 11230058996831
2240530 - Databus
[databus error value received - Parkhilfe_01 - PH_Tongeber_H_verfuegbar]
Mileage: 23657 km
Date: 2024.05.01
Time: 08:55:58
2240558 - Databus
[databus error value received - ESP_33 - ESC_Verz_Reg_nicht_verfuegbar]
Reset counter: 38
Mileage: 23637 km
Date: 2024.04.30
Time: 19:09:19
Part No SW: 5Q4 959 393 P HW: 5Q4 959 393 P
Component: TSG FS 009 0911
Serial number: 85018310500283 Dataset Number: V03935381RR 0001
Coding: 003E13200000048008000000
VCID: 50F97C8F8A698D2AFF3-8004
Subsystem 1 - Part No SW: 5Q6 959 811 B HW: 5Q6 959 811 B
Component: Fond FHSG DRV 001 0006
Serial number: 00000000000016288292
Coding: 011000
Address 44: Steering Assist (J500) Labels:| 5WA-907-14X-V1.clb
Part No SW: 5QM 907 144 D HW: 5QM 907 144
Component: BASGEN1MQB37 102 1063
Serial number: 01957534 Dataset Number: V03935378EA 0001
Coding: 01000000010000000001020101000100000001010100
ASAM Dataset: EV_SteerAssisBASGEN1MQB37 010058
ROD: EV_SteerAssisBASGEN1MQB37_010_VW27.rod
Part No SW: 5Q4 959 392 P HW: 5Q4 959 392 P
Component: TSG BFS 009 0911
Serial number: 86018309501815 Dataset Number: V03935381RS 0001
Coding: 003E13200000048000000000
VCID: 4FFB7FF3975792D2E69-801A
Subsystem 1 - Part No SW: 5Q6 959 812 B HW: 5Q6 959 812 B
Component: Fond FHSG PSG 001 0006
Serial number: 00000000000016287067
Coding: 091000
Address 5F: Information Electr. (J794) Labels:| 3G5-035-MIB-HGH3.clb
Part No SW: 3G5 035 842 G HW: 3G5 035 842
Component: MU-O-NS-US H59 0835
Serial number: WG8LGM110523000 Dataset Number: V03935382LZ 0001
Coding: 23260000002020000000000000000000000000000000000000
ASAM Dataset: EV_MUOIMQB 001002
ROD: EV_MUOIMQB_001_VW27.rod
VCID: 2C01087FC68189CAA3B-8078
Subsystem 1 - Part No SW: 5NN 919 605 C HW: 5NN 919 605 C
Component: ABT_Std-2 285 8304
Serial number: VWZ6ZMB1345590
Subsystem 2 - Part No SW: V03 959 817 SQ HW: -----------
Component: NAR 2023 --- 8073
Address 69: Trailer (J345) Labels:| 5H0-907-383.clb
Part No SW: 5H2 907 383 C HW: 5H2 907 383
Component: Anhaenger H12 0058
Serial number: 000000000006275
Coding: 0200000202001400
ASAM Dataset: EV_TrailFunctGener3Hella 001012
ROD: EV_TrailFunctGener3Hella_VW27.rod
VCID: 30391C0FEAA9ED2A9F3-8064
7 Faults Found:
660234 - Bulb for Left Brake Light on Trailer
C10FA 15 [01101000] - Open or Short to Plus
Fault Frequency: 12
Mileage: 23657 km
Date: 2024.05.01
Time: 08:55:38
660490 - Bulb for Right Brake Light on Trailer
C10FB 15 [01101000] - Open or Short to Plus
Fault Frequency: 11
Mileage: 23657 km
Date: 2024.05.01
Time: 08:55:38
649998 - Voltage Supply for Pin 9 in Socket
C10EA 01 [00100000] - Electrical Failure
85770 - Tail Lamp on Trailer
C10DB 15 [01101100] - Open or Short to Plus
Fault Frequency: 16
Mileage: 23657 km
Date: 2024.05.01
Time: 08:55:58
342020 - Comfort System CAN Bus (SAE Medium Speed Bus)
U0011 00 [00101000] - Performance
[Convenience data bus - no signal/communication]
Reset counter: 35
Mileage: 948128 km
136197 - Voltage Supply Terminal 30
B1996 F0 [00100000] - Switched; Open Circuit
136198 - Voltage Supply Terminal 30
B1996 F1 [00101111] - Charging Cable Open Circuit
Fault Frequency: 65
Mileage: 616734 km
Component: RVC Compact H18 0231
Dataset Number: V03935347PY 0001
Coding: 0123060122002017300040
Part No SW: 5WA 035 285 C HW: 5WA 035 285
Component: OCUGen3High H12 0322
Serial number: 0000000212VIBB1 Dataset Number: V03935357PG 0001
Coding: 023260201968AC209005460160102607
ASAM Dataset: EV_OCUGen3High 003007
ROD: EV_OCUGen3High_003_VW27.rod
VCID: 47CB57D37F274A92AE9-8012
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 2Q0-980-653.clb
Part No SW: 2Q0 980 653 D HW: 2Q0 980 653
Component: MQB MFK 3.0 H16 1401
Serial number: EA1567404230950 Dataset Number: V03935374AH 0001
Coding: 00000A88116E4020089F10000020000000418000000000000000000000000000
ASAM Dataset: EV_MFK3ValeoMQB 007042
1123187 - Local Data Bus
U116B 00 [00001001] - Received Malfunction Value
[RDR1_Header_FGN_Status]
Mileage: 23486 km
Date: 2024.04.29
Time: 11:05:30
1122664 - Databus
[TIMEOUT_PSD_04]
Reset counter: 35
Mileage: 15366 km
Date: 2024.01.08
Time: 15:55:51
Address BB: Door Rear Drv
Address BC: Door Rear Pass
Part No SW: 4K0 907 594 AC HW: 4K0 907 594
Component: SAD_STG_1 006 0002
Dataset Number: V03935361DS 0001
Coding: 00804073260C
ROD: EV_SunRoofCONTIAU736_009_VW37.rod
VCID: 75B7ED1B554B88020C5-8020
End----------(Elapsed Time: 01:30, VBatt start/end: 12.4V/12.4V)-----------
