Krisz77
- Jan 17, 2023
- 10
- 0
- Hungary
- C?ID=136909 (NRRT)
I have a 2002 VW 1.4 petrol (BBY engine code), the carbon monoxide emission is too high.
The lambda probe before the catalist is new. When I started the readiness test, it stoped at catalitic converter test.
The temperature was above 400 C, but the test didn't start. What is the problem?
Best regards: Krisztian Vegh
Monday,29,April,2024,15:00:35:32863
VCDS Version: 23.11.0.0 (x64)
Data version: 20240322 DS351.0
VIN: WVWZZZ9NZ3D040744 License Plate: LPG928
Mileage: 287510km-178650mi Repair Order:
Chassis Type: 9N (9N - VW Polo (2002 > 2010))
Scan: 01 02 03 08 09 15 17 19 25 37 44 45 46 56 76
VIN: WVWZZZ9NZ3D040744 Mileage: 287510km-178650miles
Address 01: Engine Labels: 036-906-034-APE.lbl
Part No: 036 906 034 DD
Component: MARELLI 4MV 4828
Coding: 00071
VCID: 57B82942B58D3B29D2-4B00
WVWZZZ9NZ3D040744 VWZ7Z0B5387427
18049 - Please check DTC Memory of A/C Controller
P1641 - 35-00 -
17584 - Bank1: O2 (Lambda) Correction Behind Catalyst
P1176 - 35-00 - Control Limit Reached
Readiness: 0000 0001
Address 03: ABS Brakes Labels: 6Q0-907-37x-ABS2.lbl
Part No: 6Q0 907 379 L
Component: ABS FRONT MK60 0101
Coding: 0001097
Shop #: WSC 31414 000 00000
VCID: 4686F4063227B2A1B9-5120
Address 08: Auto HVAC Labels: 6Q0-820-045-V1.clb
Part No: 6Q0 820 045
Component: Klimaanlage X0840
VCID: 6ADE60B616FFB6C17D-5102
01271 - Positioning Motor for Temperature Flap (V68)
01596 - Motor for Outside/Recirculated Air Flap (V154)
30-00 - Open or Short to Plus
55-00 - Adaptation Not Successful
07-00 - Signal too Low
00898 - Control Circuit A/C compressor
Address 09: Cent. Elect. Labels:. 6Qx-937-049-C.lbl
Part No: 6Q1 937 049 C
Component: 00 BN-SG. 1S33
Coding: 09358
Shop #: WSC 31414
VCID: 3B7095F229E5FF49D6-5102
7 Faults Found:
00975 - Heated Rear Window (Z1)
28-10 - Short to Plus - Intermittent
37-10 - Faulty - Intermittent
80-00 - Single-Wire Operation
01598 - Drive Battery Voltage
00906 - Horn (H1)
Part No: 1C0 909 605 K
Component: 0L AIRBAG VW51 0P 0004
Coding: 12364
Shop #: WSC 31414
VCID: 2C52A6AEDC8B68F14F-5120
Address 17: Instruments Labels: 6Q0-920-xxx-17.lbl
Part No: 6Q0 920 800
Component: KOMBI+WEGFAHRSP VDO V13
Coding: 01141
VCID: 6ADE60B616FFB6C17D-5120
Address 19: CAN Gateway Labels: 6N0-909-901-19.clb
Part No: 6N0 909 901
Component: 02 GATEWAY CAN 1S33
Coding: 00014
Shop #: WSC 31414
VCID: 70EA72DE30234C1133-5102
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6Q0 423 156 L
Component: LenkhilfeKYO V910
Coding: 00140
Shop #: WSC 31414
VCID: 387A8AFE18D3D4513B-5102
Address 46: Central Conv. Labels:. 6Q0-959-433.clb
Part No: 6Q0 959 433 H
Component: 1G Komfortgerát 0001
Coding: 00067
Shop #: WSC 31414
VCID: 408AE21E40039C9183-4AE6
Subsystem 1 - Part No: 6Q2959802A
Component: 1G Tőrsteuer.FS TFK 0003
Subsystem 2 - Part No: 6Q2959801A
Component: 1G Tőrsteuer.BF TFK 0003
7 Faults Found:
00914 - Window Regulator Switch; Rear Left; Driver (E53)
00915 - Window Regulator Switch; Rear Right; Driver (E55)
00939 - Mirror Adjust Motor; Drivers Side (V149)
08-10 - Control Limit Surpassed - Intermittent
End-------------------------(Elapsed Time: 03:23)--------------------------
