I accidentally erased my abs long code. Can anyone help me generate a new code? Here is the auto scan I know there are many problem to be addressed this car been sitting for awhile and went through alot i also took alot of the bulbs for my other vws hence all the light codes
This is the sticker from the trunk with all the codes for the car.
the car is a 2009 rhd gti 2 door
https://photos.app.goo.gl/ySC7ddVv3Y7eZJ2KA
https://photos.app.goo.gl/ySC7ddVv3Y7eZJ2KACode:Wednesday,24,April,2024,14:52:52:02756 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 arm64(arm64 CPU) VCDS Version: 23.11.0.0 (arm64) HEX-V2 CB: 0.4643.4 Data version: 20231027 DS351.0 www.Ross-Tech.com VIN: WVWED71K19W092894 License Plate: Chassis Type: 1K (1K0) Scan: 01 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 55 56 65 VIN: WVWED71K19W092894 Mileage: 361920km-224886miles 01-Engine -- Status: Malfunction 0010 03-ABS Brakes -- Status: Malfunction 0010 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 0F-Digital Radio -- Status: Malfunction 0010 15-Airbags -- Status: Malfunction 0010 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: Malfunction 0010 19-CAN Gateway -- Status: Malfunction 0010 1C-Position Sensing -- Status: OK 0000 25-Immobilizer -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: Malfunction 0010 44-Steering Assist -- Status: Malfunction 0010 46-Central Conv. -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: Malfunction 0010 55-Headlight Range -- Status: Malfunction 0010 56-Radio -- Status: Malfunction 0010 65-Tire Pressure -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (CBF) Labels:. 06J-907-115-CBF.clb Part No SW: 1K0 907 115 AF HW: 1K0 907 115 AD Component: 2.0l R4/4V TFSI 0010 Revision: E3H12--- Serial number: VWX7Z0H73NB8WO Coding: 0403010818070160 Shop #: WSC 01357 011 00200 VCID: 6A8DD261A07F451A917-803E VINID: 9E69D550705B0499C024220910F8640DDD 3 Faults Found: 000256 - Mass Air Flow Sensor (G70) P0100 - 000 - Supply Voltage - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 361927 km Time Indication: 0 Date: 2000.00.00 Time: 00:05:02 Freeze Frame: RPM: 762 /min Load: 21.6 % Speed: 0.0 km/h Temperature: 102.0 C Temperature: 46.0 C Absolute Pres.: 1000.0 mbar Voltage: 13.716 V 000257 - Mass Air Flow Sensor (G70) P0101 - 000 - Implausible Signal - MIL ON Freeze Frame: Fault Status: 11100000 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 361927 km Time Indication: 0 Date: 2000.00.00 Time: 00:05:40 Freeze Frame: RPM: 1109 /min Load: 18.4 % Speed: 0.0 km/h Temperature: 98.0 C Temperature: 44.0 C Absolute Pres.: 1000.0 mbar Voltage: 13.843 V 006481 - Radiator Fan 2 (V177) P1951 - 000 - Movement Restricted / Jammed Freeze Frame: Fault Status: 01100000 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 361927 km Time Indication: 0 Date: 2000.00.00 Time: 01:31:20 Freeze Frame: RPM: 760 /min Load: 22.3 % Speed: 0.0 km/h Temperature: 86.0 C Temperature: 57.0 C Absolute Pres.: 1000.0 mbar Voltage: 13.335 V Readiness: 0110 1101 ------------------------------------------------------------------------------- Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb Part No SW: 1K0 907 379 AN HW: 1K0 907 379 AN Component: ESP MK60EC1 H45 0107 Revision: 00H45001 Coding: 000000000000000000000000000000000000 Shop #: WSC 52507 001 1048576 VCID: 7EA5EE31C0F7D9BA5DF-802A 4 Faults Found: 01435 - Brake Pressure Sensor 1 (G201) 005 - No or Incorrect Basic Setting / Adaptation Freeze Frame: Fault Status: 01100101 Fault Priority: 2 Fault Frequency: 1 Reset counter: 23 Mileage: 361915 km Time Indication: 0 Freeze Frame: Count: 16391 Count: 0 Count: 8192 Count: 279 Count: 45312 Count: 0 Count: 0 Count: 0 00778 - Steering Angle Sensor (G85) 005 - No or Incorrect Basic Setting / Adaptation Freeze Frame: Fault Status: 01100101 Fault Priority: 2 Fault Frequency: 1 Reset counter: 23 Mileage: 361915 km Time Indication: 0 Freeze Frame: Count: 16391 Count: 0 Count: 8192 Count: 295 Count: 45312 Count: 0 Count: 0 Count: 0 01423 - Lateral Acceleration Sensor (G200) 005 - No or Incorrect Basic Setting / Adaptation Freeze Frame: Fault Status: 01100101 Fault Priority: 2 Fault Frequency: 1 Reset counter: 23 Mileage: 361915 km Time Indication: 0 Freeze Frame: Count: 16391 Count: 0 Count: 8192 Count: 270 Count: 45312 Count: 0 Count: 0 Count: 0 01042 - Control Module; Not Coded 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 23 Mileage: 361915 km Time Indication: 0 Freeze Frame: Count: 16391 Count: 0 Count: 8192 Count: 195 Count: 45312 Count: 0 Count: 0 Count: 0 ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 1K0-820-047.lbl Part No SW: 1K0 820 047 JM HW: 1K0 820 047 JM Component: Climatic PQ35 142 1212 Revision: 00142032 Serial number: 00000000000000 Shop #: WSC 00000 000 00000 VCID: 78A9F829EED3E78A173-802C 2 Faults Found: 00229 - Refrigerant Pressure 002 - Lower Limit Exceeded 01271 - Positioning Motor for Temperature Flap (V68) 000 - - - Intermittent ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl Part No SW: 3C8 937 049 E HW: 3C8 937 049 E Component: Bordnetz-SG H54 2602 Revision: 00H54000 Serial number: 00000008749961 Coding: 178D8F214004150047140000001400000028770B5C000100000000000000 Shop #: WSC 00000 785 00200 VCID: 33330F05B735C4D2E21-8066 Subsystem 1 - Part No: 1K1 955 119 E Labels: 1KX-955-119.CLB Component: Wischer 060808 021 0501 Coding: 00038805 Shop #: WSC 00000 10 Faults Found: 01497 - Bulb for Blinkers; Front Right (M7) 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 2 Fault Frequency: 2 Reset counter: 77 Mileage: 361923 km Time Indication: 0 Freeze Frame: OFF Voltage: 12.05 V OFF ON OFF OFF OFF 01501 - Bulb for Blinkers; Rear Left (M6) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 2 Fault Frequency: 2 Reset counter: 37 Mileage: 361927 km Time Indication: 0 Freeze Frame: ON Voltage: 14.30 V ON ON ON OFF OFF 01505 - Bulb for Blinkers; Rear Right (M8) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 37 Mileage: 361923 km Time Indication: 0 Freeze Frame: OFF Voltage: 12.05 V OFF ON OFF OFF OFF 02394 - Parking Light Left Front (M1) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 37 Mileage: 361923 km Time Indication: 0 Freeze Frame: ON Voltage: 11.70 V ON ON ON OFF OFF 02395 - Parking Light Front Right (M3) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 2 Fault Frequency: 5 Reset counter: 37 Mileage: 361915 km Time Indication: 0 Freeze Frame: ON Voltage: 13.65 V ON ON ON OFF OFF 01518 - Bulb for Back-Up Lights; Left (M16) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 2 Fault Frequency: 3 Reset counter: 37 Mileage: 361923 km Time Indication: 0 Freeze Frame: ON Voltage: 11.70 V ON ON ON OFF OFF 01519 - Bulb for Back-Up Lights; Right (M17) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 37 Mileage: 361923 km Time Indication: 0 Freeze Frame: ON Voltage: 11.70 V ON ON ON OFF OFF 01516 - Terminal 30; Left 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 1 Fault Frequency: 2 Reset counter: 70 Mileage: 361925 km Time Indication: 0 Freeze Frame: OFF Voltage: 12.90 V OFF ON OFF OFF OFF 00978 - Lamp for Low Beam; Left (M29) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 1 Fault Frequency: 3 Reset counter: 74 Mileage: 361923 km Time Indication: 0 Freeze Frame: ON Voltage: 14.35 V ON ON ON OFF OFF 00979 - Lamp for Low Beam; Right (M31) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 1 Fault Frequency: 2 Reset counter: 77 Mileage: 361923 km Time Indication: 0 Freeze Frame: ON Voltage: 14.30 V ON ON ON OFF OFF ------------------------------------------------------------------------------- Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl Part No SW: 8E0 035 593 M HW: 8E0 035 593 M Component: SDAR SIRIUS H07 0150 Revision: 00000000 Serial number: AUZ4Z7H0395748 Coding: 0000100 Shop #: WSC 01357 011 00200 VCID: 33330F05B735C4D2E21-8066 4 Faults Found: 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 7 Fault Frequency: 3 Reset counter: 73 Mileage: 361927 km Time Indication: 0 Freeze Frame: Voltage: 5.90 V 00446 - Function Limitation due to Under-Voltage 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 7 Fault Frequency: 3 Reset counter: 73 Mileage: 361927 km Time Indication: 0 Freeze Frame: Voltage: 5.90 V 02617 - Satellite Antenna (R170) 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 66 Mileage: 361923 km Time Indication: 0 Date: 2000.00.00 Time: 17:35:58 02635 - Tuner Not Enabled/Activated 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 7 Fault Frequency: 11 Reset counter: 18 Mileage: 361869 km Time Indication: 0 Date: 2000.00.00 Time: 18:40:03 ------------------------------------------------------------------------------- Address 15: Airbags Labels: 1K0-909-605.lbl Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB Component: 6K AIRBAG VW8R 034 8000 Revision: 05034000 Serial number: 003B6D0BS27 Coding: 0013899 Shop #: WSC 01357 011 00200 VCID: 6C81D479AA8B5B2AE3B-8038 Subsystem 1 - Part No: 1K0 959 339 G Component: BF-Gewichtsens. 007 0007 Subsystem 2 - Serial number: 6332MSME375341150 Subsystem 3 - Serial number: 6342MSME3E66336BO Subsystem 4 - Serial number: 6352QSME1C031E30B Subsystem 5 - Serial number: 6362QSME7E0D1321J Subsystem 6 - Serial number: 63727SME1758450C2 Subsystem 7 - Serial number: 63827SME175842480 9 Faults Found: 02511 - Control Module for Seat Occupied Recognition (J706) 005 - No or Incorrect Basic Setting / Adaptation - Intermittent - MIL ON 00591 - Seat Belt Switch; Driver (E24) 010 - Open or Short to Plus - MIL ON 01217 - Side Airbag Igniter; Driver Side (N199) 001 - Upper Limit Exceeded - Intermittent - MIL ON 00592 - Seat Belt Switch; Passenger (E25) 010 - Open or Short to Plus - Intermittent - MIL ON 02756 - Redundant signal path of Airbag cut-off switch - front passenger side (E224) 010 - Open or Short to Plus - Intermittent - MIL ON 01218 - Side Airbag Igniter; Passenger Side (N200) 001 - Upper Limit Exceeded - Intermittent - MIL ON 02511 - Control Module for Seat Occupied Recognition (J706) 004 - No Signal/Communication - Intermittent - MIL ON 01738 - Crash Sensor for Front Airbag; Drivers Side (G283) 010 - Open or Short to Plus - Intermittent - MIL ON 01739 - Crash Sensor for Front Airbag; Pass. Side (G284) 010 - Open or Short to Plus - Intermittent - MIL ON ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl Part No SW: 1K0 953 549 AG HW: 1K0 953 549 AG Component: J0527 036 0070 Coding: 0003022 Shop #: WSC 01279 785 00200 VCID: 77ABFB15E3CDE8F21E9-8022 Subsystem 1 - Part No: XXXXXXXXXXX Component: E0221 002 0010 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 1K0-920-xxx-17.lbl Part No SW: 1K6 920 974 H HW: 1K6 920 974 H Component: KOMBIINSTRUMENT VDD 2416 Revision: V0003000 Serial number: VWX7Z0H73NB8WO Coding: 0007203 Shop #: WSC 00000 067 57207 VCID: 392F3D2D95593E8228D-806C 3 Faults Found: 00446 - Function Limitation due to Under-Voltage 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 25 Reset counter: 73 Mileage: 361915 km Time Indication: 0 Date: 2000.00.00 Time: 23:46:51 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 5 Reset counter: 73 Mileage: 361915 km Time Indication: 0 Date: 2000.00.00 Time: 19:26:49 00779 - Outside Air Temp Sensor (G17) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 2 Fault Frequency: 6 Reset counter: 73 Mileage: 361927 km Time Indication: 0 Date: 2000.00.00 Time: 22:08:38 ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb Part No SW: 1K0 907 530 Q HW: 1K0 907 951 Component: J533 Gateway H07 0062 Revision: H07 01 Serial number: 210708F1001391 Coding: E9811F070013020000 Shop #: WSC 01357 011 00200 VCID: 3537311DB941DAE2CC5-8060 1 Fault Found: 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 3 Fault Frequency: 3 Reset counter: 73 Mileage: 361915 km Time Indication: 0 Date: 2000.00.00 Time: 10:21:33 ------------------------------------------------------------------------------- Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl Part No SW: 1K6 919 879 HW: 1K6 919 879 Component: Kompass 001 0003 Revision: 00001000 Serial number: 1225223T3NFS03 Shop #: WSC 00000 000 00000 VCID: 7DA7E93DC1F1C2A2445-8028 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb Part No SW: 1K6 920 974 H HW: 1K6 920 974 H Component: IMMO VDD 2416 Revision: V0003000 Serial number: VWX7Z0H73NB8WO Shop #: WSC 00000 000 00000 VCID: 392F3D2D95593E8228D-806C 1 Fault Found: 01176 - Key 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 255 Mileage: 361915 km Time Indication: 0 Date: 2000.00.00 Time: 00:00:27 ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb Part No SW: 1K0 959 701 M HW: 1K0 959 701 M Component: Tuer-SG 006 1207 Coding: 0001077 Shop #: WSC 01357 011 00200 VCID: 38293829AE53278AD73-806C 3 Faults Found: 01811 - Supply Voltage for Door Controller; Drivers Side (J386) 002 - Lower Limit Exceeded - Intermittent 00943 - Heated Exterior Mirror; Driver Side (Z4) 012 - Electrical Fault in Circuit 00109 - Left Mirror Turn Signal Lamp (L131) 012 - Electrical Fault in Circuit - Intermittent ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb Part No: 1K1 909 144 M Component: EPS_ZFLS Kl.074 H08 1901 Shop #: WSC 00000 028 00001 VCID: 3537311DB941DAE2CC5-8060 2 Faults Found: 02546 - Steering Limit Stop 005 - No or Incorrect Basic Setting / Adaptation Freeze Frame: Mileage: 361920 km Temperature: 74.0 C Voltage: 13.60 V Voltage: 13.40 V 00778 - Steering Angle Sensor (G85) 005 - No or Incorrect Basic Setting / Adaptation Freeze Frame: ------------------------------------------------------------------------------- Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb Part No SW: 1K0 959 433 CT HW: 1K0 959 433 CT Component: KSG PQ35 RDK 052 0221 Revision: 00052000 Serial number: 00000000000000 Coding: 139006885103281B0904058FB0080A04889C00 Shop #: WSC 00000 785 00200 VCID: 04519CD9A21BB36A0BB-8050 Subsystem 1 - Component: Sounder n.mounted Subsystem 2 - Component: NGS n.mounted Subsystem 3 - Component: IRUE n.mounted 1 Fault Found: 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 4 Fault Frequency: 8 Reset counter: 73 Time Indication: 0 ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb Part No SW: 1K0 959 702 M HW: 1K0 959 702 M Component: Tuer-SG 006 1207 Coding: 0001076 Shop #: WSC 01357 011 00200 VCID: 392F3D2D95593E8228D-806C 2 Faults Found: 01812 - Supply Voltage for Door Controller; Pass. Side (J387) 002 - Lower Limit Exceeded - Intermittent 00110 - Right Mirror Turn Signal Lamp (L132) 012 - Electrical Fault in Circuit ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 1T0-907-357.lbl Part No: 1T0 907 357 Component: Dynamische LWR 0003 Coding: 0000003 Shop #: WSC 01357 011 00200 VCID: 74B1CC19F2BB83EA3BB-8020 5 Faults Found: 01539 - Headlights Not Adjusted 005 - No or Incorrect Basic Setting / Adaptation 00496 - Sensor for Vehicle Leveling; Front 010 - Open or Short to Plus 01535 - Control Circuit for Right Headlight Range Adjusting Motor (V49) 010 - Open or Short to Plus - Intermittent 01533 - Terminal 56 (High Beams) 011 - Open Circuit - Intermittent 01317 - Control Module in Instrument Cluster (J285) 004 - No Signal/Communication - Intermittent ------------------------------------------------------------------------------- Address 56: Radio Labels: 1K0-035-1xx-56.clb Part No SW: 1K0 035 180 L HW: 1K0 035 180 L Component: Radio PM6 019 0037 Revision: 00019000 Serial number: VWZ5Z7H2251291 Coding: 0040401 Shop #: WSC 01357 011 00200 VCID: 290FED6D65F98E0258D-807C 2 Faults Found: 00668 - Supply Voltage Terminal 30 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 3 Fault Frequency: 9 Reset counter: 74 Mileage: 361915 km Time Indication: 0 Date: 2000.00.00 Time: 23:46:36 00874 - Treble Speaker Front Left (R20) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 3 Fault Frequency: 1 Reset counter: 37 Mileage: 361927 km Time Indication: 0 Date: 2000.00.00 Time: 01:39:51 ------------------------------------------------------------------------------- Address 65: Tire Pressure Labels: 3C0-959-433-65.lbl Part No SW: 1K0 959 433 CT HW: 1K0 959 433 CT Component: RDK 0450 Revision: 00052000 Serial number: 00000000000000 Coding: 0100101 Shop #: WSC 131071 1023 2097151 VCID: 04519CD9A21BB36A0BB-8050 No fault code found. End----------(Elapsed Time: 01:17, VBatt start/end: 13.8V/13.6V)-----------
OkSince it was a GTI, I went for a bigger TMC, 23,8. Based on one AS from my base:
WVWZZZ1KZAW182575
03: ABS Brakes (-----) Labels:. User\1K0-907-379-60EC1F.lbl
Part No SW: 1K0 907 379 AP HW: 1K0 907 379 AP
Revision: 00H45001
Coding: 143B600D092A00FC281006EB901E00423100 - @Scottarossjr do not use this coding, not for your VIN number.
Keep it here, any information is useful.
I didn’t yet. I won’t be back to the car until tomorrow. I will post if it’s resolved first thing tomorrow. Thank youCan we consider the case resolved? Did you use the encoding that @NEtech recommended?
Sorry, I'm a little confused. Here you wrote RHD, and the car is (after all) LHD, for NAR, am I right?the car is a 2009 rhd gti 2 door
Thank you for all your helpNo problem, everything is fine. We understood each other.
Hopefully I can learn how to figure it out on my own so I can help people alsoYou're welcome, the forum is for that.
In contrast to RoW models, NAR Golf 6 GTI models always have the small TMC.Since it was a GTI, I went for a bigger TMC, 23,8. Based on one AS from my base:
It says this code is wrong lenghtFrom other models, I would try this:
113B600D492B00FC881306ED921D00413000
143B600D092B00FC281306ED901D00413000
