I have a VW Passat Alltrack B8 2016. Im living in Sweden and wanted the tail lights on as DRL. After I some monthes ago managed to program the tail lights (Not that easy to find sadly) I got a diffrent issue. Now the headlights in the function Comming home/Leaving home only lights up when I unlock the car. When I have driven and turn off the car the headlights doesnt stay on for the 20-30 sec as they should but shuts off imidiatlly.
If I can´t get the headlights to work with DRL maybe someone can help me how to get things back to the Comming home/Leaving home working again and then I skip the tail lights as DRL.
Sadly all my photos of the instructions was lost when I changed phone and all the Autoscans I have from before are in Swedish.
Thankfull for all help I can get!
Saturday,20,April,2024,12:54:46:29720
VCDS Version: 23.11.0.0 (x64) HEX-V2 CB: 0.4643.4
VIN: WVWZZZ3CZGE206942 License Plate:
Chassis Type: 3C-VW48 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 22 2B 42 44 52 55 5F
69 6C 6D BB BC
VIN: WVWZZZ3CZGE206942 Mileage: 239139km-148594miles
Address 01: Engine (J623-DFCA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 GA HW: 04L 907 309 M
Component: R4 2.0l TDI H23 2013
Revision: B4H23--- CVN: 570F665F38D3FF82
Coding: 011D003A04761D083000
Shop #: WSC 05311 115 00304
ASAM Dataset: EV_ECM20TDI01104L906026GA 004002
ROD: EV_ECM20TDI01104L906026FM_004_VW48.rod
VCID: 6FBBC06A071A4DF2C69-803A
VINID: 9E69EAAAA0D3A9754200624408E276B933
5158 - Particulate Filter; Differential Pressure Sensor
P2456 00 [01100000] - Intermittent
5262 - Particulate Filter; Differential Pressure Sensor
P2454 00 [00100000] - Short to GND
Part No SW: 0D9 300 012 A HW: 02E 927 770 AQ
Component: DQ250-6A MQB H53 4902
Revision: 06253104 Serial number: TFK01602110064 CVN: 000012EE
Shop #: WSC 05311 115 00063
ROD: EV_TCMDQ250021.rod
VCID: 1471AF864EFCCE2A9BB-8040
Part No SW: 3Q0 907 379 AB HW: 3Q0 907 379 G
Component: ESC H42 0723
Revision: 00000000 Serial number: 60786000000493
Coding: 40EC6A8F34204B720780070441C54902562CD2E0E08292F9B8625078E209
Shop #: WSC 00015 115 00001
VCID: 7AADE13E4C58185A617-802E
16401 - Tire Pressure Warning
C102D 00 [00001000] - -
Reset counter: 198
Mileage: 227913 km
Date: 2023.11.02
Time: 13:56:54
Part No SW: 3Q0 959 435 B HW: 3Q0 959 435 B
Component: VWKESSYMQB 026 0710
Revision: 00026000 Serial number: 0398275354 Dataset Number: V03935228XM 0001
Coding: 000F0F0F03
ROD: EV_KessyHellaMQBAB.rod
VCID: 392F3E3209DED34228D-806C
Part No SW: 5G1 907 044 J HW: 5G1 907 044 J
Component: Climatronic H04 1202
Revision: 00001K10
Coding: 12020104204101011015500C0010190A
Shop #: WSC 00015 115 08193
ASAM Dataset: EV_ACClimaBHBVW37X 005137
VCID: 2F3B006AC79A0DF2869-807A
Air quality sensor:
Humidity sensor: exterior:
328199 - Position Sensor for Right Temperature Flap Motor
B1095 15 [00001000] - Open or Short to Plus
Reset counter: 224
Mileage: 238574 km
Date: 2024.04.14
Time: 20:07:03
Voltage terminal 30: 14.4 V
Outside temperature: 9.5 C
Inside temperature: 15.0 C
Right temperature flap: actual value: 233
Right temperature flap: actual value: 100.0 %
Temperature door right - Specified value: 233
263425 - Air Quality Sensor
B10AF 04 [00001000] - Internal System Fault
Fault Frequency: 113
Reset counter: 236
Mileage: 227014 km
Date: 2023.10.16
Time: 17:19:34
Voltage terminal 30: 14.6 V
Outside temperature: 14.5 C
System run time-Engine running time: 34 s
System run time-Terminal 15 on: 34 s
Part No SW: 5Q0 937 086 AK HW: 5Q0 937 086 AK
Component: BCM PQ37BOSCH 028 0163
Revision: -------- Serial number: 865813031600YA Dataset Number: V03935235HB 0001
Coding: 00031C46C2C102FF17844094B11C57281C80000000000000000000000000
ASAM Dataset: EV_BodyContrModul1UDSBosc 015001
ROD: EV_BCMBOSCH_015.rod
VCID: 03539CDA3B925992321-8056
Subsystem 1 - Part No SW: 3G1 955 119 A HW: 3G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 160224 042 0607
Serial number: 160229063829
Subsystem 2 - Part No SW: 8UD 955 559 B HW: 8UD 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0004
Serial number: 30046982
Coding: 00006E
Subsystem 3 - Part No SW: 3G0 941 633 H HW: 3G0 941 633 H
Component: E1 - LDS MQB H01 0032
Serial number: 04 12 2015 10000354
Subsystem 4 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Serial number: 000000000ZY110390J0B
Serial number: 00000000000034917815
Humidity sensor: interior:
U1400 00 [00001000] - -
204290 - Remote key 1
B1479 18 [00001000] - Current Too Low
Mileage: 232349 km
Date: 2024.01.17
Time: 12:39:02
Terminal 15 status: OFF
Terminal 50 status: OFF
CAN-Bus_aktiv: On
OFF: Not operated
Position lamps: Not operated
Low beam: Not operated
Voltage: 12.2 V
Outside temperature: 5.0 C
Part No SW: 5QA 919 298 HW: 5Q0 919 298 C
Component: PLA 3.0 12KH08 0161
Serial number: 000305183616059 Dataset Number: V03935223VR 0001
Coding: 0A71161951
ASAM Dataset: EV_EPHVA2CAU3700000 009017
VCID: 0D47BAE26DD61FE2545-8058
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 3Q0 907 572 B HW: 3Q0 907 572 B
Dataset Number: V03935229RW 0001
Coding: 3200678B11FFC428949C804D
ROD: EV_ACCBOSCHVW48X.rod
VCID: 34310F062EBC2E2AFBB-8060
1538 - Sensor for Automatic Distance Control
C110B F0 [00001000] - Limited Visibility
[FAULT_SENSOR_BLIND]
Reset counter: 207
Mileage: 237662 km
Date: 2024.04.03
Time: 06:07:58
Control Module temperature: 10 C
Voltage terminal 15: 14.2 V
Velocity_vehicle_reference: 9.82 m/s
Longitudinal_acceleration_vehicle_reference: 0.23 m/s
1396 - Sensor for Automatic Distance Control
[FAULT_SENSOR_NO_FREE_SIGHT]
Reset counter: 207
Mileage: 237715 km
Control Module temperature: 5 C
Voltage terminal 15: 12.1 V
Longitudinal_acceleration_vehicle_reference: 0.00 m/s
Status_ACC_System: ACC_Init
1542 - Sensor for Automatic Distance Control
[FAULT_SYSTEM_BLIND]
Reset counter: 207
Mileage: 237662 km
Date: 2024.04.03
Time: 06:07:58
1397 - Sensor for Automatic Distance Control
[FAULT_SYSTEM_NO_FREE_SIGHT]
Reset counter: 207
Mileage: 237715 km
Part No SW: 3Q0 959 655 BA HW: 3Q0 959 655 BA
Component: Airbag VW20 013 0195
Revision: -------- Serial number: 003SSP5VZL15 Dataset Number: 3G0003V____ 0036
Coding: 88CCC000008000005C5400CC000800000065
Shop #: WSC 05314 000 00001
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 7EA5ED2E5070347A5DF-802A
Left seat belt tensioner:
Serial number: 3G1857705G0069Q01201
Coding: 80000D
Right seat belt tensioner:
Serial number: 3G1857706G0063Q00322
Coding: 80000D
Subsystem 3 - Part No SW: ----------- HW: 454 001 103 16
Serial number: 3576U000000624C4B91E
Subsystem 4 - Part No SW: ----------- HW: 454 001 103 16
Serial number: 3586U00000005485B919
Subsystem 5 - Part No SW: ----------- HW: 454 802 802 16
Serial number: 3516R62433E0A000000+
Subsystem 6 - Part No SW: ----------- HW: 454 802 802 16
Serial number: 3526R5C413E0A0000006
Subsystem 7 - Part No SW: ----------- HW: 454 801 302 16
Serial number: 3556V8E861A0A000000L
Part No SW: 3Q0 953 521 EJ HW: 5Q0 953 569 B
Component: Lenks.Modul 100 0205
Revision: FF035035 Serial number: 20160306500307 Dataset Number: 3G0094V____ 0001
Coding: 0410
ASAM Dataset: EV_SMLSVALEOMQBLRH 001005
ROD: EV_SMLSVALEOMQBLRH.rod
VCID: 7CA1E726466C266A73B-8028
Part No SW: 3G0 920 751 A HW: 3G0 920 751 A
Component: KOMBI 301 6421
Coding: 07A5081BAF80000801882B013001000000000000
VCID: 2313FC5A9B52B992121-8076
Address 18: Aux. Heat (J364) Labels:| 5Q0-963-272.clb
Part No SW: 5Q0 963 272 E HW: 5Q0 963 272 E
Component: STH-MQB 007 0072
Coding: 9309
VCID: 38293B3632D4CA4AD73-806C
Auxiliary heating remote control:
Subsystem 1 - Part No SW: 5Q0 963 513 A HW: 5Q0 963 513 A
Component: R149 T91-LIN 003 0301
Serial number: 00000000000001348351
Part No SW: 5Q0 907 530 AJ HW: 5Q0 907 530 M
Component: GW MQB High 212 2246
Revision: -------- Serial number: 12031610802244 Dataset Number: 3G0067V____ 2404
Coding: 030300345F017300FB00225E1E0F00010001070000000000000000000000
GVL: 01D43C0008000600C00C90000006C80000000000000000000000000000000000
ROD: EV_GatewConti_013.rod
VCID: 79AFFE32495E134268D-802C
Generator:
Subsystem 2 - Part No SW: 5G0 959 442 K HW: 5G0 959 442 K Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H17 0040
Serial number: 29160000417230076083
Coding: 2FFFFF
Subsystem 3 - Part No SW: 3Q0 915 181 A HW: 3Q0 915 181 A
Component: J367-BDMHella H04 8050
Serial number: 6561819103
Analog clock:
Subsystem 4 - Part No SW: 3G0 919 204 C HW: 3G0 919 204 C
Component: Analoguhr 209 2002
Serial number: HA1-00018.02.16 Dataset Number: v1260x015G0 0000
Coding: 0301
VCID: 4ACD71FE5C3848DAB17-801E
Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0032
Serial number: 16000046465001
Coding: 0800000000000000
ROD: EV_ELVMarquMQBB_VW37.rod
VCID: 71BFC612112E5B02D0D-8024
Component: TSG FS 020 0041
Serial number: 010216EAU12379 Dataset Number: V03935234RN 0001
Coding: 003F0A20D000028000001000
VCID: 43D35CDA7B129992721-8016
Address 44: Steering Assist (J500) Labels:| 5Q0-909-143.clb
Part No SW: 5Q0 909 143 M HW: 5Q0 909 143 E
Component: MQB_PP_APA 204 2041
Revision: 00000000 Serial number: 0000678173 Dataset Number: 3G0074V____ 0241
Coding: 01010010005001
Shop #: WSC 00015 115 00304
ASAM Dataset: EV_SteerAssisVWBSMQBA 008028
ROD: EV_SteerAssisVWBSMQBA_008.rod
VCID: 3D272A221DF6EF62045-8068
Component: TSG BFS 020 0041
Serial number: 220116EAL04097 Dataset Number: V03935234TC 0001
Coding: 003F0020D000028000001000
VCID: 42DD59DE6408909A797-8016
Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
Component: AFS-ECU H01 0120
Coding: 03AA00000F200200
Shop #: WSC 05311 000 08193
ROD: EV_HeadlRegulAFSMQBMLB_VW48.rod
VCID: 3FDB502A17FAFD72169-806A
Subsystem 1 - Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H09 0003
Coding: E02400
Subsystem 2 - Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H09 0003
Coding: E02400
Subsystem 3 - Part No SW: 3G0 941 329 _ HW: 3G0 941 329 _ Labels: 3D0-941-329.CLB
Component: LeiMo links H02 0003
Coding: E02400
Subsystem 4 - Part No SW: 3G0 941 329 _ HW: 3G0 941 329 _ Labels: 3D0-941-329.CLB
Component: LeiMo rechts H02 0003
Coding: E02400
Part No SW: 3Q0 035 824 A HW: 3Q0 035 824 A
Component: MU-S--ER 620 0633
Serial number: Dataset Number: V03935233XZ 0001
Coding: 02840200FF00000051110001000808001F0108C40120010003
Shop #: WSC 40526 003 1048576
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 2B03147AF38271D2AA1-807E
Subsystem 1 - Part No SW: 3G0 919 605 B HW: 3G0 919 605 B
Component: ABT_Std-2 H43 4064
Serial number: VWZ6Z9S0790970
Part No SW: 5Q0 907 383 G HW: 5Q0 907 383 D
Component: Anhaenger H21 0203
Revision: 8A001003 Serial number: 0398755817 Dataset Number: 0G0124v____ 0016
Coding: 0100000202000000
VCID: 3B23243A03E2E1523A1-806E
Part No SW: 5Q0 980 568 HW: 5Q0 980 568
Component: RVC Compact+ H05 0100
Dataset Number: V03935222WP 0001
Coding: 0184020163002017000048
ASAM Dataset: EV_CamSysRVRVCARPANAMQBAB 006008
ROD: EV_CamSysRVRVCARPANAMQBAB_006_VW37.rod
9591827 - Video Signal Line
B125C 13 [00001000] - Open Circuit
Fault Frequency: 14
Reset counter: 236
Mileage: 233663 km
Date: 2024.02.06
Time: 17:57:16
ARA_error_bits: 0
ARA_function_operating_time: 0.0000 s
Reason: Freeze frame conditions
current likeliness: 0.0000
Camera_System_Operating_Condition: passive
Part No SW: 5Q0 959 107 J HW: 5Q0 959 107 J
Component: HDSG-Modul H13 0253
Revision: -------- Serial number: 30561999200000 Dataset Number: V03935230GZ 0001
Coding: 0280
ASAM Dataset: EV_DeckLidCONTIAU736 001012
Component: TSG HFS 020 0041
Serial number: 260216BB902303 Dataset Number: V03935234UT 0001
Coding: 000E00200100028000001000
VCID: 45D742C27526A7A25C5-8010
Component: TSG HBFS 020 0041
Serial number: 260216BB902309 Dataset Number: V03935234TU 0001
End----(Elapsed Time: 02:24, VBatt start/end: 12.0V/11.9V. VIgn 11.9V)-----
