Hi All,
My first post in the forum, although it has been a big help to me over the years.
I have a fault with my 2021 VW California. I let the battery system go completely flat (doh) while it was standing unused on the driveway for several weeks. The starter battery was toast after that, and I had a whole load of low voltage trouble codes to clear once I changed it. This was no problem thanks to VCDS, I even managed to clear the parking heater interlock. However, one fault keeps coming back immediately when I try to clear it - 73217 - Energy Management Parallel Warning Triggered.
Does anyone know what this is? I am wondering if it is something to do with the split charge system. I am also wondering if it is a symptom of the low battery, or maybe it caused the batteries to fully discharge in the first place. I have left the van for that length of time before without any problem. Searches of the internet and this forum have not shed any light.
Thanks in advance for any help.
Here is the full scan output
Thursday,04,April,2024,18:30:57:01844
VCDS Version: 23.11.0.0 (x64) HEX-V2 CB: 0.4643.4
VIN: WV2ZZZ7HZMH131770 License Plate:
Mileage: 13937km-8660mi Repair Order:
Chassis Type: 7H-VN46 (3Q0)
Scan: 01 02 03 08 09 10 13 15 17 18 19 3C 3D 44 55 5F 65 75 D6 D7
800B
VIN: WV2ZZZ7HZMH131770 Mileage: 13937km-8660miles
3D-Special Function -- Status: Malfunction 0010
800B-Aux air heater 2 -- Status: OK 0000
Address 01: Engine (J623-DMZA) Labels:. 05L-907-309-V1.clb
Part No SW: 05L 906 023 HW: 05L 907 309 F
Component: R4 2.0l BTD H80 1160
Revision: N1H80--- CVN: FACD043BF3218A0EA3C795CF64CF85E9A3C795CF43FB2DAA
Coding: 0025003C0364050800000000000000000000000000000000
Shop #: WSC 00012 790 00049
ASAM Dataset: EV_ECM20BTD01105L906023 006005
ROD: EV_ECM20BTD01105L906023.rod
VCID: 6596478605E1B562BC5-8030
VINID: 9E60AAAAA1D8A9D6010C11C700351EDB7B
Readiness: 1110 1011
Part No SW: 0DV 300 046 B HW: 0GC 927 711 H
Component: GSG DQ500 H06 3702
Revision: 00H06V13 CVN: 5EB78E29
ROD: EV_TCMDQ500021.rod
VCID: 392EDBF6D9D9E18228D-806C
Part No SW: 7LA 614 517 B HW: 7LA 614 517
Component: ESC_high H01 0800
Serial number: 08512986210607
Coding: 10552752C84AEE86085BE4AB13667766392724B8
ASAM Dataset: EV_Brake1ESP90iBOSCHVN46X 003012
ROD: EV_Brake1ESP90iBOSCHVN46X_003.rod
VCID: 3E24C8EAC0F7C6BA1DF-806A
Address 08: Auto HVAC (J255) Labels:* Redir Fail!
Part No SW: 7LA 907 040 G HW: 7LA 907 040 G
Component: Climatronic H01 0602
Coding: 9031100008102300010009005040010500000000000A1501A04000000000
ASAM Dataset: EV_AirCondiBHTCVN54XT6PA 001002
ROD: EV_AirCondiBHTCVN54XT6PA.rod
VCID: 3FDAB5EEC7FDCFB2169-806A
Rear A/C Control Head 1:
Subsystem 1 - Part No SW: 7LA 906 453 A HW: 7LA 906 453 A
Component: E857 H01 0206
Serial number: 00002140521120343101
Subsystem 2 - Part No SW: 7LA 907 049 F HW: 7LA 907 049 F
Component: E857 H02 0301
Serial number: 00001069311311220812
Part No SW: 2Q5 937 090 A HW: 2Q5 937 090 A
Component: BCM T6PA Std+ H11 0943
Serial number: 01102115800153 Dataset Number: V03935338JL 0001
ASAM Dataset: EV_BCMA0 206001
ROD: EV_BCMA0_206_VW27.rod
VCID: 3536D7C6F5C105E2CC5-8060
Subsystem 1 - Part No SW: 5Q0 955 559 C HW: 5Q0 955 559 C Labels: 5Q0-955-547.CLB
Component: RLS 054 0206
Serial number: S5Y21M05D31H07M28S34
Coding: 0018EE
Driver door control module:
Subsystem 2 - Part No SW: 7L1 959 405 B HW: 7L1 959 163 B
Component: FHSG_DRV 001 0002
Serial number: 00000000000051441017
Coding: 1F0007
Front passenger door control module:
Subsystem 3 - Part No SW: 7L1 959 406 B HW: 7L1 959 164 B
Component: FHSG_PSG 001 0002
Serial number: 00000000000049145068
Coding: 050007
Subsystem 4 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Serial number: 000000000ZY211001E0V
Serial number: 00000000000049615541
Part No SW: 5QA 919 298 K HW: 5QA 919 298 A
Component: PLA 3.0 12K H08 0073
Serial number: 000150057321148 Dataset Number: V03935331VA 0001
Coding: 8371165851
ASAM Dataset: EV_EPHVA2CAU3700000 009055
ROD: EV_EPHVA2CAU3700000_010_AU37.rod
VCID: 58E87E724293188A373-800C
Part No SW: 2Q0 907 572 R HW: 2Q0 907 572 B
Component: ACCCONTIMQB H03 0372
Dataset Number: V03935335RG 0001
Coding: 3204670349FF8748949C815580508700000000000000000004
Shop #: WSC 00012 790 00024
ROD: EV_ACCMRRCONTIVW376_003.rod
VCID: 43D2B91EAB15AB52721-8016
Part No SW: 2Q0 959 655 AE HW: 2Q0 959 655 AE
Component: VW22Airbag 016 0506
Revision: -------- Dataset Number: V03935330EJ 0001
Coding: 88CCC00000000000800000CF008C40000065
ASAM Dataset: EV_AirbaVW22BPAVW27X 001022
ROD: EV_AirbaVW22BPAVW27X.rod
VCID: 00587612FA83704A2F3-8054
Subsystem 1 - Part No SW: ----------- HW: 442 062 205 21
Serial number: 3577Y50A903F7E222084
Subsystem 2 - Part No SW: ----------- HW: 442 062 205 21
Serial number: 3587Y50A903F7E2232EE
Address 17: Instruments (J285) Labels:| 7LA-920-XXX-V1.clb-SRI3
Part No SW: 7LA 920 320 A HW: 7LA 920 320 A
Component: KOMBI 502 5175
Coding: 24A40088248826000188624D1001000080601E02
ASAM Dataset: EV_DashBoardVDDMQBA0 001044
ROD: EV_DashBoardVDDMQBA0_001_VW27.rod
Address 18: Aux. Heat (J364) Labels:* Redir Fail!
Part No SW: 5WA 963 271 C HW: 5WA 963 271 C
Component: STH-VW37x 006 0012
Serial number: 000000000000119
Coding: 3143221854121512DCE519
ASAM Dataset: EV_AuxilHeateWOSVW38X 002009
ROD: EV_AuxilHeateWOSVW38X_002.rod
VCID: 4CC09222864B642A83B-8018
Part No SW: 3Q0 907 530 AG HW: 3Q0 907 530 C
Component: GW MQB High 443 4424
Revision: -------- Serial number: 0001753562 Dataset Number: V03935338TK 0001
Coding: 030100544F05730401100258100F00010001070000000000000000000000
GVL: 014C3C0000100000404090008004C80000000000100000000000000000000000
ROD: EV_GatewNF_VW27.rod
VCID: 74B02AC2BE3B5CEA3BB-8020
Generator:
Component: 5-00-11-00-04
Subsystem 2 - Part No SW: 3G0 959 442 N HW: 3G0 959 442 N Labels: 3C8-959-537.CLB
Component: E221__MFL-PR6 H07 0110
Serial number: PR6-0440036154210421
Coding: 2C0D00
Subsystem 3 - Part No SW: 7E0 915 181 L HW: 7E0 915 181 L
Component: J367-BDMConti H03 1051
Serial number: 771972000021050504C0
Address 3C: Lane Change (J1086) Labels:* None
Part No SW: 2Q0 907 686 B HW: 2Q0 907 686 B
Component: HRE3_Kl15_Mst H06 0150
Serial number: 14520009459974 Dataset Number: V03935303MB 0001
Coding: 92954640
ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
ROD: EV_HREntryHellaGen3Kl15.rod
Subsystem 1 - Part No SW: 2Q0 907 685 B HW: 2Q0 907 685 B
Component: HRE3_Kl15_Slv H06 0150
Serial number: 14520009302270
Address 3D: Special Function (J608) Labels:* Redir Fail!
Part No SW: 2N0 907 427 R HW: 2N0 907 427 H
Component: KFG H24 0408
Serial number: GB24212220474 Dataset Number: V03935349WS 0001
Coding: 04002000000000200200000860B8135EB8000000
ASAM Dataset: EV_SpeciFunctFlextVN54X 008036
ROD: EV_SpeciFunctFlextVN54X.rod
Subsystem 5 - Part No SW: 7C0 907 155 HW: 7C0 907 155
Component: U13DCAC H05 0870
Serial number: A078385
Subsystem 6 - Part No SW: 7E0 915 181 M HW: 7E0 915 181 M
Serial number: 77194501002105120063
B1A50 00 [00001001] - -
Reset counter: 185
Mileage: 13937 km
Date: 2024.04.04
Time: 18:19:19
Address 44: Steering Assist (J500) Labels:| 2N0-909-143.clb
Part No SW: 7LA 909 144 G HW: 7LA 909 144 D
Component: EPS_MQB_ZFLS 751 7160
Dataset Number: V03935340DA 0001
Coding: 0306
ASAM Dataset: EV_SteerAssisMNB 002015
ROD: EV_SteerAssisMNB.rod
VCID: 46D4A00A98279E7A55F-8012
Part No SW: 7P6 907 357 E HW: 7P6 907 357 A
Component: AFS-ECU H07 0080
Revision: -------- Serial number: -------------- Dataset Number: V03935338PG 0001
Coding: 0C8E020009210003
ROD: EV_HeadlRegulAFSMQBMAX_VN46.rod
VCID: 41DEB316B109B94260D-8014
Address 5F: Information Electr. (J794) Labels:| 3G5-035-MIB-HGH3.clb
Part No SW: 3G5 035 816 D HW: 3G5 035 816
Component: MU-O-ND-EU H57 0809
Serial number: WG8LGM140621000 Dataset Number: V03935346KS 0001
Coding: 64600008000020000000000000000000000000000000000000
ASAM Dataset: EV_MUOIMQB 001002
ROD: EV_MUOIMQB_VW49.rod
VCID: 2A0CF4BA2C7F5A1A517-807E
Subsystem 1 - Part No SW: 5G6 919 606 B HW: 5G6 919 606 B
Component: ABT_High-2 H61 9216
Serial number: VWZ6ZJY1481092
Subsystem 2 - Part No SW: V03 959 809 CP HW: -----------
Component: EU 2021 --- 4031
Part No SW: 5Q0 907 273 D HW: 5Q0 907 273
Component: RDKBERU30 H06 0010
Serial number: 30000000556223 Dataset Number: V03935349DE 0001
ROD: EV_RDKBERU30_VW41.rod
VCID: 3634D0CAE8C70EFAC5F-8062
Part No SW: 5WA 035 284 E HW: 5WA 035 284 B
Component: OCUGen3High H20 0141
Serial number: 0000000105VIRG9 Dataset Number: V03935344UB 0001
Coding: 06462000196898209005460160502607
ASAM Dataset: EV_OCUGen3High 003007
ROD: EV_OCUGen3High_003_VW41.rod
VCID: 48C8AE329233880AA73-801C
Part No SW: 992 941 571 AE HW: 992 941 571 A
Component: LED1L H08 9202
ROD: EV_LLPGen3LKEBODPO68X_001_VW27.rod
Component: LED1R H08 9202
Address 800B: Aux air heater 2 (J604) Labels:* None
Part No SW: 7C0 963 273 C HW: 7C0 963 273 C
Component: LSH_DIESEL 008 0026
Dataset Number: 0026 0026
Coding: 3200
ASAM Dataset: EV_LSHECCSMNB 002018
ROD: EV_LSHECCSMNB.rod
VCID: 2B02F1BE23854312AA1-807E
Auxiliary heating remote control:
Subsystem 1 - Part No SW: 3Q0 963 513 A HW: 3Q0 963 513 A
Component: R64 D208L 004 0402
Serial number: 00000000000001271905
End----(Elapsed Time: 01:36, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
