Thursday,28,March,2024,18:00:09:26772
VCDS Version: 23.3.1.0 (x64)
VIN: WVWZZZ1KZBM674809 License Plate:
Mileage: 327500km-203499mi Repair Order:
Chassis Type: 1K-VW36 (7N0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 61 62 69 72
VIN: WVWZZZ1KZBM674809 Mileage: 327500km-203499miles
Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 997 557 T HW: 03L 907 425 C
Component: R4 1.6l TDI H43 9982
Revision: --H43--- Serial number: 00000000000000 CVN: 90AB929A
Coding: 10114014032401080000
Shop #: WSC 05881 003 1048576
ASAM Dataset: EV_ECM16TDI02103L997557T 003003
ROD: EV_ECM16TDI02103L997557T.rod
VCID: 4D90ED551CB98AFB70-8018
VINID: 9E69EAAAA05BA927461C420024FBBF6719
7338 - Leak in Air Intake System
P2279 00 [104] - -
Fault Frequency: 11
Mileage: 327429 km
Date: 2024.03.28
Time: 15:44:46
Engine RPM: 2100.75 /min
Normed load value: 42.7 %
Vehicle speed: 83 km/h
Coolant temperature: 99 °C
Intake air temperature: 43 °C
Voltage terminal 30: 14.908 V
Air mass: actual value (mg/stroke)-MAF_MES: 940.54 mg/stroke
Air mass proportion filtered-FAC_MAF_CYL_KGH_RATIO_FIL: 0.64404
EGR Solen.val.: actual value-ANG_EGRV[0]: 99.997 %
Throttle valve adapter: actual value-ANG_THR[0]: 95.996 %
Charge air pressure: specified value-MAP_SP_MMV: 1517.47 hPa
Charge air pressure: actual value-MAP_MMV: 1440.53 hPa
Engine torque-TQI_SP: 114.00 Nm
7609 - Control Module 1 for Coolant Fan
P1946 00 [109] - Defective
Fault Frequency: 17
Mileage: 299890 km
Date: 2023.09.04
Time: 19:15:51
Engine RPM: 1532.50 /min
Normed load value: 18.0 %
Vehicle speed: 61 km/h
Coolant temperature: 86 °C
Intake air temperature: 17 °C
Voltage terminal 30: 14.344 V
Vehicle speed: 79 km/h
Sensor for temp after charge air cooler: raw value-TBA_MES: 10 °C
Sensor for engine block temperature: raw value-Coolant temperature: 91 °C
Coolant temperature at radiator outlet: actual value-TCO_2: 17 °C
Outside temperature-Ambient temperature: 6.75 °C
Ambient air pressure-Ambient pressure: 980.09 hPa
Coolant fan 1: activation-Radiator fan 1: activation: 9.8 %
10116 - Fuel Rail/System Pressure
P0087 00 [096] - Too Low
Mileage: 327421 km
Date: 2024.03.28
Time: 15:38:02
Engine RPM: 2065.25 /min
Vehicle speed: 56 km/h
Coolant temperature: 96 °C
Intake air temperature: 48 °C
Voltage terminal 30: 15.360 V
Fuel high-pressure: actual value-FUP_FIL: 121.057 MPa
Fuel pressure regulator valve: specified value rail pressure-LV_PCV_CTL: 00000001
Fuel level-FTL_CAN: 36 l
Fuel temperature-TFU: 30 °C
Fuel Metering Valve-VCV: 18.661 %
Fuel Pressure Regulator Valve-PCV: 46.910 %
Fuel high pressure commanded value_1-FUP_SP_KPA_ENVD: 129931.641 kPa
Readiness: 0 1 0 0 0
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 113B200D092900FE881304E490220051310000
Shop #: WSC 00066 000 00000
VCID: 7BF4738DFA8DF44B9E-802E
Part No SW: 7N0 907 426 L HW: 7N0 907 426 L
Component: AC Manuell H17 0202
Revision: 00012001
Coding: 0000000003
Shop #: WSC 00066 000 00148
ROD: EV_ClimaBasis_VW36.rod
VCID: 3D70BD95AC193A7BE0-8068
Part No SW: 5K0 937 084 F HW: 5K0 937 084 F
Component: BCM PQ35 B 011 0046
Revision: BA011001
Coding: 00180E3A902D02C040000080500000E443000288625D0562648087200041
Shop #: WSC 00066 123 12345
VCID: 3560A5B59C29E23B28-8060
Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 12021 26 0512
Coding: 009795
Fault Status: 00101010
Reset counter: 26
Mileage: 327463 km
Date: 2018.08.19
Time: 16:30:27
Voltage: 14.60 V
Part No SW: 5C0 959 655 C HW: 5C0 959 655 C
Component: AirbagVW10 013 0613
Serial number: 003G6R0181EX Dataset Number: 1KM003v____ 0038
Coding: 00003536
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 326A9EA96547F5030D-8066
Subsystem 1 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Serial number: 3572MSME3D28545AZZZ0
Subsystem 2 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Serial number: 3582MSME142F555AZZZ+
Serial number: 3511HSME3F570425ZZZM
Serial number: 3521HSME10110A25ZZZ2
Part No SW: 5K0 953 507 BA HW: 5K0 953 549 C
Revision: -------- Serial number: 90422JLK001J6 Dataset Number: 5K0953507BA D005
Coding: 5080140000
Shop #: WSC 00066 000 00186
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 70EE54A1ABCB87133B-8024
Part No SW: 5K0 920 861 AX HW: 5K0 920 861 AX
Component: KOMBI H03 0406
Coding: 170F00
Shop #: WSC 68500 205 00000
VCID: 03040B6D8A7D8C8BD6-8056
Part No SW: 7N0 907 530 D HW: 1K0 907 951
Component: J533 Gateway H35 0614
Revision: H35 Serial number: 11021101200162
Coding: 352002
VCID: 316891A56841CE1B74-8064
Component: IMMO H03 0406
VCID: 6ADA46C98D177DC375-803E
Component: TUER-SG FT 002 0501
Revision: 13110009 Serial number: 0001968545
Coding: 0200B4
Shop #: WSC 01383 790 50316
VCID: 5BB4130D524D144BFE-800E
Slave Driver:
Subsystem 1 - Part No SW: 1K0 959 703 AG HW: 1K0 959 795 R Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 006 1401
Serial number: 00000005479586
Coding: 000090
132610 - Motors for Rear Central Locking
B122C 01 [008] - Electrical Failure
Fault Frequency: 13
Reset counter: 6
132866 - Switch for Rear Central Locking
B122E 29 [008] - Signal Implausible
Fault Frequency: 60
Reset counter: 6
Mileage: 315833 km
Date: 2023.12.31
Time: 15:49:36
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 69 3201
Revision: 00H20000
Shop #: WSC 02069 000 90108
VCID: 346698B15753FB331F-8060
Component: TUER-SG BT 002 0501
Revision: 15110009 Serial number: 0001943553
Coding: 0200B4
VCID: 5CB6101157431373F7-8008
Slave Passenger:
Subsystem 1 - Part No SW: 1K0 959 704 AG HW: 1K0 959 794 R Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 006 1401
Serial number: 00000005517994
Coding: 000090
67589 - Turn Signal in Exterior Mirror
B11FD 01 [008] - Electrical Failure
Fault Frequency: 119
Reset counter: 25
Mileage: 325666 km
Date: 2024.03.13
Time: 13:27:18
Reset counter: 3
Fault Frequency: 21
Reset counter: 3
Mileage: 320939 km
Date: 2024.02.06
Time: 11:30:56
Part No SW: 1K0 035 186 AA HW: 1K0 035 186 AA
Component: Radio RCD310 016 0049
Revision: 00000000 Serial number: VWZ1Z2L9107197
Coding: 0500040004
VCID: 65C035F56C0952BB58-8030
Part No SW: 7N0 907 534 HW: 1K0 907 951
Component: Batt.regelung H35 0614
Coding: 030B185A
VCID: 71E851A5A8C18E1B34-8024
Subsystem 1 - Part No SW: 1K0 915 181 C HW: 1K0 915 181 A
Component: J367-BDM H07 0125
Serial number: 00000000002790385688
Address 69: Trailer Labels: RETROFIT69.lbl
Part No SW: 5F0 05V 010 1 HW: 5F0 05V 010 1
Component: TOWBARMODULE ECS 0010
Coding: 0000001
VCID: 285E7CC19B9B8FD3A3-807C
End-------------------------(Elapsed Time: 02:43)--------------------------
P2279 00 [104] - -
Fault Frequency: 11
Mileage: 327429 km
Date: 2024.03.28
Time: 15:44:46
Fault Frequency: 17
Mileage: 299890 km
Date: 2023.09.04
Time: 19:15:51
Mileage: 327421 km
Date: 2024.03.28
Time: 15:38:02
Revision: 00H31001
Revision: 00012001
Coding: 0000000003
Revision: BA011001
Coding: 009795
Reset counter: 26
Mileage: 327463 km
Date: 2018.08.19
Time: 16:30:27
Voltage: 14.60 V
Coding: 00003536
Coding: 5080140000
Coding: 170F00
Coding: 352002
Coding: 0200B4
Slave Driver:
Coding: 000090
Fault Frequency: 13
Reset counter: 6
Fault Frequency: 60
Reset counter: 6
Mileage: 315833 km
Date: 2023.12.31
Time: 15:49:36
Revision: 00H20000
Coding: 0200B4
Slave Passenger:
Coding: 000090
Reset counter: 25
Mileage: 325666 km
Date: 2024.03.13
Time: 13:27:18
Reset counter: 3
Fault Frequency: 21
Reset counter: 3
Mileage: 320939 km
Date: 2024.02.06
Time: 11:30:56
Coding: 0500040004
Coding: 030B185A
Coding: 0000001
End-------------------------(Elapsed Time: 02:40)--------------------------
Address 01: DTCs cleared
