Resolved 2013 JSW TDI ABS Code Lost (MK60EC1)
Resolved
GroovyDP
New Member
Portland, Oregon, USA
UC-2H
I've been a lurker here for a few years and have been able to resolve everything until now. Went to leave and the car was dead. No response from the push button. No power to the instrument cluster. Battery was good. Cleaned connections. Pulled the push button start switch out and cleaned contacts. Nothing. Checked all fuses. Nothing blown. Pulled every relay and found two had switching issues. Replaced relays with number 100 in the engine compartment and 507 under the dash. Instrument cluster came on when I opened the door and the car started easily. ESP, ABS are flashing and has a solid brake light on the cluster.
Codes are: 01042 Control not coded, 01435 Brake Pressure Sensor, 00778 Steering angle sensor, 01423, Transverse acceleration sensor. Tested all sensors including wheel speed. Everything works and showing correct values but the control module. It is all zeros.
I scanned this yesterday:
Monday,25,March,2024,17:26:44:29277
VCDS Version: 23.11.0.0 (x64)
Data version: 20240322 DS351.0
VIN: 3VWPL7AJ3DM684192   License Plate:
Mileage: 183690km-114139mi   Repair Order:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 37 42 44 46 4F 52 56
          62 72
VIN: 3VWPL7AJ3DM684192   Mileage: 183690km-114139miles
Address 01: Engine (CJA)       Labels: 03L-906-022-CBE.clb
   Part No SW: 03L 997 030 E    HW: 03L 907 309 AA
   Component: R4 2.0l TDI G000AG  9983
   Revision: 12H15---    Serial number:
   Coding: 0050078
   Shop #: WSC 42028 005 1048576
   VCID: 3041C49FA3510E1173-8064
   VINID: 0E69E070745A0D474620404908A8CB79B8
   Part No SW: 02E 300 062 B    HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 9430
   Revision: 05651213    Serial number: 00001302051560
   Shop #: WSC 00066 000 00000
   VCID: 1409680F3709D23177-8040
   Revision: 00H31001
   VCID: 7DDF2DABE4833379A8-8028
                    Reset counter: 94
                    Date: 2018.08.16
                    Time: 17:17:29
                    Count: 3
                    Count: 12
                    Count: 20992
                    Count: 195
                    Count: 50176
   Part No SW: 5K0 959 434 B    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 086 1101
   Revision: 00086000    Serial number: 0202186223 Dataset Number: 5K0116v____ 1K07
   Coding: 030C0C
   VCID: 3449C88F9F49323117-8060
   Part No SW: 7N0 907 426 BH    HW: 7N0 907 426 BH
   Component: AC Manuell    H20 0505
   Revision: 00001018
   Coding: 0010002002
   Shop #: WSC 00066 000 00119
   VCID: 7BDB23B3F2973D4996-802E
   Part No SW: 5K0 937 084 J    HW: 5K0 937 084 J
   Component: BCM PQ35 B    021 3068
   Revision: BG021001
   Coding: 6F380E1F802F3EC4008800C17000004449000086575D05F064802020A040
   Shop #: WSC 57444 001 1048576
   VCID: 3957F9BBB02BCF59C4-806C
   Component: Wischer 27041  26  0512
   Coding: 009795
   Part No SW: 5C0 959 655 M    HW: 5C0 959 655 M
   Component: AirbagVW10G   014 0726
   Serial number: 003L4R01MYUD   Dataset Number: 1KM003v__B_ 0047
   Coding: 00004E42
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3C59E0AFB719FA71DF-8068
   Subsystem 1 - Part No SW: 1KM 959 339 B    HW: 1KM 959 339 B
   Component: BF-Gewichtss.  006 0001
   Serial number: ---0000R--00007M5400
   Subsystem 2 - Part No SW: 1KM 955 557     HW: 1KM 955 557
   Serial number: 3572MSME0E4F6175ZZZ2
   Subsystem 3 - Part No SW: 1KM 955 557     HW: 1KM 955 557
   Serial number: 3582MSME560F5676ZZZ1
   Serial number: 3511HSME4C63212FZZZQ
   Serial number: 3521HSME386B212FZZZU
   Serial number: 35527SME0547192FZZZJ
   Serial number: 35627SME5E5F072FZZZ/
   Part No SW: 5K0 953 521 BR    HW: 5K0 953 569 E
   Revision: FF010041    Serial number: 20130226100612
   Coding: 100A140000
   Shop #: WSC 00066 000 00185
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 7DDF2DABEC833379A8-8028
   Subsystem 1 - Part No SW: 5K0 959 542 C    HW: 5K0 959 542 C  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H31 0037
   Coding: 820000
   Part No SW: 5K0 920 973 C    HW: 5K0 920 973 C
   Component: KOMBI         H05 0705
   Coding: 270F01
   VCID: 3147C19B605B07197C-8064
   Part No SW: 7N0 907 530 AH    HW: 7N0 907 530 AH
   Component: J533  Gateway H50 1634
   Revision:   H50       Serial number: 10041303290676
   Coding: 352002
   VCID: 76CD3287C1B56021E9-8022
   Component: IMMO          H05 0705
   Coding: 000007
   VCID: 6AF516F78D0DB4C17D-803E
   Revision: 00000000    Serial number: 13000022147002
   Coding: 4900000000000000
   Shop #: WSC 00066 790 50316
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 3041C49F6B510E1173-8064
   Part No SW: 5N0 035 342 F    HW: 5N0 035 342 F
   Component: SG EXT.PLAYER H19 0550
   Revision: A1001003    Serial number: 7664398478
   Coding: 020100
   VCID: 2A75D6F7458D74C1BD-807E
   Part No SW: 1K0 035 274 D    HW: 1K0 035 274 D
   Component: RNS315-NAR    H58 0319
   Serial number: VWZAZ2N0092116
   Coding: 04000401040007000000100A
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_RNS315NARV2UDS 001705
   ROD: EV_RNS315NARV2UDS.rod
   VCID: 256F25CB24935BB990-8070
   Data carrier:
   Subsystem 1 - Part No: 3AA 919 866 B
   Component: NAR_V3_(0037)  0037
1048669 - Tuner for Satellite Radio
          B11CF 53 [00001001] - Deactivated
                    Reset counter: 93
                    Mileage: 183683 km
                    Date: 2024.03.24
                    Time: 15:04:23
   Part No SW: 561 959 701     HW: 3C0 959 793 B
   Component: TUER-SG FT    002 0501
   Revision: 13110009    Serial number: 0006590104
   Coding: 0004B5
   VCID: 5B9B43335257DD49F6-800E
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 703 C    HW: 3C0 959 795 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  008 1509
   Serial number: 00000007721729
   Coding: 000490
131072 - Rear Door Control Module
          B11ED 04 [00001001] - Internal System Fault
                    Mileage: 17576 km
                    Date: 2014.07.23
                    Time: 18:20:12
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 70     3305
   Revision: 00H22000
   Shop #: WSC 02069 000 90108
   VCID: 3753FF83463FD92932-8062
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AH
   Component: EZE_2         H50 1634
   Coding: 050B0500
   VCID: 6FC307E3BEEF51E92A-803A
   Subsystem 1 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
   Component: J245EE20SKB13  H05 0220
   Component: J394EE20SKB13  H05 0220
   Part No SW: 561 959 702     HW: 3C0 959 792 B
   Component: TUER-SG BT    002 0501
   Revision: 15110009    Serial number: 0006586348
   Coding: 0004B4
   VCID: 5C99402F5759DA71FF-8008
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 704 C    HW: 3C0 959 794 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  008 1509
   Serial number: 00000007674331
   Coding: 000490
End-------------------------(Elapsed Time: 02:50)--------------------------
Dana
Western PA, USA
Thanks for the history with the full scan! I'm confident one of us can build this lost 03-ABS coding from scratch if needed however if you have owned this JSW in addition to VCDS for a while you may already have saved scan(s) from happier times. Please check this folder to see if a scan prior to the event is saved:
C:\Ross-Tech\VCDS\Scans
If you have a saved scan from this VIN with non-zero ABS all should be well. If not, bump this back up and one of us will dig into it.
GroovyDP
New Member
UC-2H
Unfortunately, I do not have the same laptop that I did with my last scan. I did check the folder though and confirmed it's not there.
GroovyDP
New Member
UC-2H
You can try: B14B400C492A00FE8D0C02ED921B0042A71800
I tried it and it works. It does say error "Hill Hold Assist". I did not realize I had that. Is that a code in the ABS module or should I look to change the value in something?
Boki Ar
Arandjelovac, Serbia
C?ID=57300
Byte 16, bit 0: B14B400C492A00FE8D0C02ED921B0042A61800
Boki Ar
C?ID=57300
You're welcome. Post a new Auto Scan, please. :thumbs:
Dana
Western PA, USA
Hi guys,
I came up with a significantly different coding string:
114B600C492A00FE880C06ED921B0042B70000
I'll bounce this off of the team to make sure I'm not way off track on that.
GroovyDP
New Member
UC-2H
Wednesday,27,March,2024,08:57:53:29277
          62 72
   Coding: 0050078
   Revision: 00H31001
   Coding: B14B400C492A00FE8D0C02ED921B0042A61800
   Shop #: WSC 00066 123 12345
   Coding: 030C0C
   Revision: 00001018
   Coding: 0010002002
   Revision: BG021001
   Coding: 009795
   Coding: 00004E42
   Coding: 100A140000
   Coding: 820000
   Coding: 270F01
   Coding: 352002
   Coding: 000007
   Coding: 020100
   Data carrier:
                    Reset counter: 93
                    Mileage: 183683 km
                    Date: 2024.03.24
                    Time: 15:04:23
   Coding: 0004B5
   Slave Driver:
   Coding: 000490
                    Mileage: 17576 km
                    Date: 2014.07.23
                    Time: 18:20:12
   Revision: 00H22000
   Coding: 050B0500
   Coding: 0004B4
   Slave Passenger:
   Coding: 000490
End-------------------------(Elapsed Time: 03:15)--------------------------
Dana
Western PA, USA
@GroovyDP , thanks for the new scan. After bouncing this off of the team we are confident that the correct factory coding string is the one I posted above. I don't think the car is going to be dangerous to drive but I woudl change it to this string:
Boki Ar
C?ID=57300
@GroovyDP pay attention to the post #9 by Dana.
I'm calculate on a lightweight rear axle as I saw in the title MY 2013.
I don't have the data for the NAR and you may need to change the coding.
GroovyDP
New Member
UC-2H
I have changed to this coding. Thank you so much.
