Friday,03,January,2020,13:38:43:45262
VIN: WV1ZZZ2KZDX1xxxxx License Plate:
Chassis Type: 2K-VN35 (7N0)
Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 52 56 61 77
VIN: WV1ZZZ2KZDX1xxxxx Mileage: 108260km-67269miles
Address 01: Engine (J623-CAYD) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 TH HW: 03L 907 425 C
Component: R4 1.6l TDI H43 9978
Revision: --H43--- Serial number: 00000000000000
Coding: 00114014032401080000
Shop #: WSC 35110 790 50316
ASAM Dataset: EV_ECM16TDI02103L906023TH 003002
ROD: EV_ECM16TDI02103L997557R.rod
VCID: 7F5B04DD1776701FB0D-802A
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Revision: 00H31001
Coding: 423C400D092503FA420C02E79021C051310000
Shop #: WSC 35110 377 08192
VCID: 7DA7FED51DFA620FA21-8028
Part No SW: 7N0 907 426 BK HW: 7N0 907 426 BK
Component: AC Manuell H20 0505
Revision: 00001018
Coding: 0010004003
VCID: 7EA5F9D9107C7917BBB-802A
9473905 - Motor for Temperature Flap
B108F 71 [008] - Actuator stuck
Reset counter: 213
Mileage: 106704 km
Date: 2019.11.27
Time: 14:32:55
Part No SW: 5K0 937 085 R HW: 5K0 937 085 R
Component: BCM PQ35 B+ 021 0068
Revision: BB021001
Coding: 411A583A8025F369088800829000006403017288424FAD60648087000041
VCID: 42DD4D292484DDF79F3-8016
Subsystem 1 - Part No: 1T1 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer 09041 26 0512
Coding: 009795
Subsystem 2 - Part No: 7N0 951 171 A
Component: DWA-Sensor 00 002 0206
Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
Component: VW10Airbag029 H07 0013
Revision: -------- Serial number: 003HL00H4NBA
Coding: 000000000000000000000000000000003239
VCID: 353726F565CA7A4F2A1-8060
Part No SW: 5K0 953 507 BA HW: 5K0 953 549 C
Component: Lenks.Modul 008 0090
Revision: -------- Serial number: 90440MDB000I6
Coding: 5080160000
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 70B9D7E15A281F67397-8024
Part No SW: 2K0 920 875 L HW: 2K0 920 875 L
Component: KOMBI H06 0705
Coding: 181A01
VCID: 38292FC172D88727317-806C
Address 18: Aux. Heat Labels: 1K0-815-007.clb
Part No: 7N0 963 272 C
Component: Standheizer 044 4840
Revision: 00044000 Serial number: 09024302000000
Coding: 0031032
Shop #: WSC 48487 002 1048576
VCID: 353726F5694A7A4F2A1-8060
Part No SW: 7N0 907 530 AG HW: 7N0 907 530 AG
Component: J533 Gateway H53 1634
Revision: H53 Serial number: 070413F2000997
Coding: 357400
VCID: 75B7E6F525CA3A4FEA1-8020
Component: IMMO H06 0705
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6A8DC5897CF4E5B7773-803E
Part No SW: 1T0 959 701 T HW: 1T0 959 701 T
Component: Tuer-SG 009 2109
Coding: 0131120
VCID: 48C95F010EB8F7A7417-801C
00912 - Window Regulator Switch; Front Left (E40)
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 140 3305
Revision: 00H22000
VCID: 372B2CFD7346885F38D-8062
Part No SW: 1T0 959 702 R HW: 1T0 959 702 R
Coding: 0131120
VCID: 47CB5C3D03A6F8DF48D-8012
Address 56: Radio (J0503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 3C8 035 195 G HW: 3C8 035 195 G
Component: Radio RCD510 050 0207
Revision: 00000001 Serial number: VWZ1Z3L1549898
Coding: 0100040004000C
Shop #: WSC 01324 020 00200
VCID: 2C010391B6003B8745F-8078
Reset counter: 88
Mileage: 89322 km
Date: 2018.03.13
Time: 08:17:46
Reset counter: 88
Mileage: 89322 km
Date: 2018.03.13
Time: 08:17:46
Reset counter: 88
Mileage: 89322 km
Date: 2018.03.13
Time: 08:17:49
00877 - Treble Speaker Rear Right (R16)
Reset counter: 88
Mileage: 89322 km
Date: 2018.03.13
Time: 08:17:49
00856 - Radio Antenna
Reset counter: 88
Mileage: 89322 km
Date: 2018.03.13
Time: 08:18:02
02877 - Digital Radio Antenna (R183)
Reset counter: 88
Mileage: 89322 km
Date: 2018.03.13
Time: 08:18:02
Part No SW: 7N0 907 534 HW: 7N0 907 530 AG
Component: Batt.regelung H53 1634
Coding: 030F1859
VCID: 71BFD2E551A2166F369-8024
Component: J367-BDM H07 0180
Serial number: 30093L42271491177559
Part No SW: 7P6 035 730 J HW: 7P6 035 730 J
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007664566874
Coding: 0A01010001010110
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002.rod
VCID: 392F2AC549D29E2FCE9-806C
End----------(Elapsed Time: 01:13, VBatt start/end: 14.8V/14.7V)-----------
