Monday,22,May,2023,16:26:36:42016
VCDS Version: 23.3.1.0 (x64) HEX-NET2 CB: 0.4631.5
VIN: WUAZZZFX0H7903602 License Plate:
Chassis Type: FX-AU72 (4S0)
Scan: 01 02 03 05 06 08 09 11 31 14 15 16 17 19 1B 22 30 36 3B 42
44 46 52 53 55 5F 65 6C 81 A6 C2
VIN: WUAZZZFX0H7903602 Mileage: 45539km-28296miles
A6-Microphone -- Status: Malfunction 0010
C2-Auto Trans 2 -- Status: OK 0000
Address 01: Engine (------CSPB) Labels:. 07L-907-552-V1.clb
Part No SW: 4S0 907 552 L HW: 4T0 907 552 A
Component: 5.2l V10HDZ / H56 0003
Revision: NHH56--- CVN: C453C0C5
Coding: 1A2500320526010B3000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM52FSI1114S0907552L 001003
ROD: EV_ECM52FSI1114S0907552L.rod
VCID: 3FD029FA47F7FEF2361-806A
VINID: 9E546AAAA5A80181C9003180085303D4E9
Readiness: 1110 1001
Address 02: Auto Trans (J217) Labels:. 0BH-927-711.clb
Part No SW: 4S0 927 155 F HW: 0BH 927 711 F
Component: AU 6E SB RdW H10 3913
Revision: 00H10V01 CVN: BD8BCAC5
ASAM Dataset: EV_TCMDL800041 001013
ROD: EV_TCMDL800041_AU72.rod
VCID: 3A2658EE5CD5DBDA01F-806E
Address 03: ABS Brakes (J104) Labels: 4H0-907-379.clb
Part No SW: 4S0 907 379 D HW: 4S0 907 379 D
Component: ESP PREMIUM H09 0300
Coding: 01A9C10B809583D04B00
ASAM Dataset: EV_ESPPremiAU57X 004048
ROD: EV_ESPPremiAU57X_AU72.rod
VCID: 3E2E54FE40FDF7FA3D7-806A
0668 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[ComScl_PDU_HSP_01_Timeout]
Reset counter: 123
Mileage: 45539 km
Date: 2023.05.22
Time: 15:11:17
VzRef: 00
Bit Info 1: 00
Bit Info 2: 00
Bit Info 3: 02
Bit Info 4: 1F
F-Path: 00
F-Type: E4
Uz: 9F
Part No SW: 4H0 907 064 HB HW: 4H0 907 064 HB
Component: BCM2 2.0 H61 0825
Coding: 05B06F06000000000000
VCID: 70B2BAC64AA9518AFFB-8024
Serial number: 3216000040778011
Part No SW: 4S0 959 760 HW: 4S0 959 760
Component: MEM-BFS 001 0020
Revision: AA001003 Serial number: 00000180757321
Coding: 00201000000460F1000001210101210000000000000000
VCID: 7BA89DEA13EF22D25A9-802E
Address 08: Auto HVAC (E87) Labels:* None
Part No SW: 4S0 820 043 K HW: 4S0 820 043 K
Component: AC Automat H08 0040
Revision: 20012000 Serial number: 96800000005048
Coding: 4100A00000100010
ASAM Dataset: EV_AirCondiVAPrehAU72x 003005
ROD: EV_AirCondiVAPrehAU72x.rod
VCID: 333875CA7BBF2A92C29-8066
Rear A/C Control Head 2:
Subsystem 1 - Part No SW: 8S0 820 359 A HW: 8S0 820 359 A
Component: E775 BuA_2 H07 0020
Serial number: 00000000000000006386
Rear A/C Control Head 3:
Subsystem 2 - Part No SW: 8S0 820 359 HW: 8S0 820 359
Component: E776 BuA_3 H07 0020
Rear A/C Control Head 4:
Subsystem 3 - Part No SW: 8S0 820 359 B HW: 8S0 820 359 B
Component: E777 BuA_4 H07 0020
Part No SW: 4H0 907 063 HK HW: 4H0 907 063 EK
Component: BCM1 2.0 H21 0725
Revision: 2502102S Serial number: 00001497808901
Coding: 010DC01410349FF07D0140C380001800C59DC28A2708320100040814E1101100004000340B0000
VCID: 78A282E622D909CA37B-802C
Subsystem 1 - Part No SW: 4S2 955 119 B HW: 8V2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS624 161012 043 0081
Serial number: 90248163161025134931
Coding: 3247FD
Component: G397_RLFS H06 0004
Serial number: 62359283
Coding: 02005D
Subsystem 3 - Part No SW: 4S0 941 531 HW: 4S0 941 531
Component: E1 - LDS H01 0044
Serial number: 09 11 2016 00001185
Subsystem 4 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H01 0005
Serial number: 0B988E4800PAG0MUFU03
Address 11: Engine II (-----) Labels:. 07L-907-552-V1.clb
ASAM Dataset: EV_ECM52FSI2114S0907552L 001003
ROD: EV_ECM52FSI2114S0907552K.rod
Address 14: Susp. Elect. (J250) Labels: 8V0-907-376.clb
Part No SW: 4S0 907 376 D HW: 4S0 907 376 C
Component: DAEMPFUNGS-SG H06 0064
Serial number: 161016011 Dataset Number: 4S0909554D 0009
ASAM Dataset: EV_AudiMagneRide 002008
ROD: EV_AudiMagneRide.rod
VCID: 3B285DEA53EFE2D21A9-806E
Part No SW: 4S0 959 655 HW: 4S0 959 655
Component: Airbag10.43 H62 0204
Revision: -------- Serial number: 003NJ0014SRJ Dataset Number: 4S0909602C 0019
Coding: 30333845303430303639554A305234533053
ASAM Dataset: EV_AirbaAU10BPAAU64X 001036
VCID: 7EAE94FE007D37FA7D7-802A
Serial number: 3575HRB4067492D698U1
Serial number: 3585HRB405F492DA508M
Serial number: 3515JRB401I57AREII0L
Serial number: 3525JRB401I57AREI99M
Serial number: 3554VRB401657HS2E8CI
Serial number: 3564VRB400G57FBCO1R.
Part No SW: 4S0 907 129 J HW: 4S0 907 129 J
Component: Lenks.Modul H06 0007
Revision: C0071527 Serial number: 91335PK801139-
Coding: 000034
VCID: 3D2C53F24D7BECE224D-8068
Address 17: Instruments (J285) Labels:* None-SRI2
Part No SW: 4S0 920 790 A HW: 4S0 920 790 A
Component: FBenRDW H14 0251
Coding: 242D30C0BA8206000130ECC41000801000000000
ASAM Dataset: EV_DashBoardBOSCHAU724 001022
ROD: EV_DashBoardBOSCHAU724.rod
U1014 00 [008] - -
[ECU incorrectly coded]
Reset counter: 123
Mileage: 45539 km
Date: 2023.05.22
Time: 15:35:04
16777088 - Databus
[HSP_01 communication error can_error_timeout]
Reset counter: 123
Mileage: 45539 km
Date: 2023.05.22
Time: 15:47:39
Address 19: CAN Gateway (J533) Labels:| 4H0-907-468.clb
Part No SW: 4S0 907 468 B HW: 4S0 907 468 A
Component: J533--Gateway H15 0074
Revision: -------- Serial number: 00000002431593 Dataset Number: 4S0909515B 0029
Coding: C02D03161C
GVL: FF91CC98DC08200180740800
Subsystem 1 - Part No SW: 4S0 915 181 HW: 4S0 915 181
Component: J367-BDM H08 0270
Serial number: 53294713112871788226
Address 1B: Active Steering (J792) Labels: None
Part No SW: 8K0 907 144 N HW: 8K0 907 144 N
Component: DYNAMIKLENK. H06 0740
Revision: 52001005 Serial number: --------------
Coding: 0D0100
VCID: 3A2658EE5C55DBDA01F-806E
Address 22: AWD (J492) Labels: 4T0-907-160.clb
Part No SW: 4S0 907 160 HW: 4S0 907 160
Component: 4 Wheel Drive H07 0207
Revision: 00001002 Serial number: BBPEDYK Dataset Number: 4S0909104C 0001
ASAM Dataset: EV_AllWheelContrBORGLB724 006012
ROD: EV_AllWheelContrBORGLB724.rod
VCID: 6E8EA4BE501D477AED7-803A
Address 30: Special Function II (J843) Labels: 8K0-907-440.clb
Part No SW: 4H0 907 440 HW: 4H0 907 440
Component: STS H06 0030
Revision: S0H06000 Serial number: 00000000098778
Coding: 01010101000000000001000102
VCID: 649AC6968E51FD2A8B3-8030
Component: MEM-FS 001 0020
Revision: AA001003 Serial number: 00000180755156
Coding: 00381900000460F1C00001210101210000000000000000
Part No SW: 4G0 907 637 L HW: 4G0 907 637 G
Component: SARA 6D red H04 0056
Revision: -------- Serial number: EJ1BPA7E02H3YS Dataset Number: 4S0909573A 0002
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 372041DA6FC7C6B2FE1-8062
Part No SW: 4G8 959 793 J HW: 4G8 959 793 G
Component: TSG FA H03 0511
Coding: 011C52425021000300080402
VCID: 47C0311A1FA7B6328E1-8012
Address 44: Steering Assist (J500) Labels:| 4S0-909-144.clb
Part No SW: 4S0 909 144 H HW: 4S0 909 144 B
Component: EPS H13 0905
Revision: 00000000 Serial number: L00173076
Coding: 0903
ASAM Dataset: EV_EPSZFAU72X 003010
ROD: EV_EPSZFAU72X_003.rod
Revision: 00002001 Serial number: 0422376494
Coding: 011B0E8000B18881E330CA04000580470000000000000000000000000000
Subsystem 1 - Part No: 4S0 951 177
Component: Sensor, DWA 005 0002
Subsystem 3 - Part No SW: 4G8 959 252 A HW: 4G8 959 252
Component: HSP-SG H11 0031
Serial number: WA125827000026784350
Component: TSG BF H03 0511
Coding: 011C52425E21000300080400
VCID: 46DE3C1E18ADAF3A757-8012
Part No SW: 4S0 907 801 HW: 8K0 907 801 J
Component: EPB-4 H03 0001
Revision: -------- Serial number: 20000000002837
ROD: EV_ParkiBrake_AU72.rod
VCID: 70B2BAC64A29518AFFB-8024
Part No SW: 4H4 907 357 G HW: 7P6 907 357 B
Component: MxB-ECU 001 0115
Revision: -------- Serial number: -------------- Dataset Number: 4S0909865C 0012
Coding: 07FE081022230200
ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005011
VCID: 363E4CDE68CD3FBAE57-8062
Subsystem 1 - Part No SW: 7PP 941 572 AC HW: 7PP 941 572 A Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H09 0008
Coding: E02200
Subsystem 2 - Part No SW: 7PP 941 572 AC HW: 7PP 941 572 A Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H09 0008
Coding: E02200
Address 5F: Information Electr. (J794) Labels:* 8W0-035-MIB-HGH2.clb
Part No SW: 4S0 035 021 C HW: 4S0 035 021 B
Component: MU-H-LND-EU 053 0909
Serial number: A725K0GB000618 Dataset Number: 4S0909545F 0030
Coding: 012704010000000013111102000A00102F0000E300700000DE
ASAM Dataset: EV_MUHig6C8Gen2HBAS 001182
ROD: EV_MUHig6C8Gen2HBAS.rod
VCID: 251C9B92C56B44225CD-8070
Subsystem 1 - Part No SW: V03 959 801 FC HW: -----------
Component: ECE 2017 --- 0157
Subsystem 2 - Part No SW: 4S2 919 614 D HW: 4S2 919 614 D
Component: ControlUnit_H H30 0206
Serial number: APVAK120101600010004
Compact disc data bank:
Component: Gracenote2--- --- 1015
Address 65: Tire Pressure (-----) Labels: 3Y0-907-273.clb
Part No SW: 4H0 907 273 D HW: 4H0 907 273 B
Component: RDKBERU25 H10 0900
Serial number: 10000000033944 Dataset Number: 4S0909850A 0006
ASAM Dataset: EV_RDKBERU25 003014
ROD: EV_RDKBERU25_AU57.rod
VCID: 2C0A6EB6A681756A833-8078
Address 6C: Back-up Cam. (J772) Labels:| 4S0-980-556.clb
Part No SW: 4S0 980 556 A HW: 95B 980 551 L
Component: RVC Compact H12 0201
Dataset Number: 4S0909460B 0010
Coding: 027504010A000001000040
ASAM Dataset: EV_CamSysRVRVCPANAAU57X 002003
ROD: EV_CamSysRVRVCPANAAU57X_002.rod
VCID: 392447E259D3D0C2085-806C
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 4S2 713 041 C HW: 4M2 713 041 F
Component: GSM-LL H09 0073
Revision: 0L0D5012 Serial number: 20161018000110
ASAM Dataset: EV_GSMWaehlZFAU736 001016
ROD: EV_GSMWaehlZFAU736_AU72.rod
Address A6: Microphone (J886) Labels:. 420-907-394.clb
Part No SW: 420 907 394 B HW: 420 907 394
Component: BELTMICBOX H10 0820
Coding: 0101030202
ASAM Dataset: EV_BeltMicPARAGAU335 003011
ROD: EV_BeltMicPARAGAU335.rod
VCID: 1862A2660219E9CAD7B-804C
0080 - Microphone 1 for Drivers Side
B1203 13 [009] - Open Circuit
Reset counter: 83
Mileage: 45539 km
Date: 2023.05.22
Time: 16:18:31
0096 - Microphone 2 for Drivers Side
B1204 13 [009] - Open Circuit
Reset counter: 83
Mileage: 45539 km
Date: 2023.05.22
Time: 16:18:31
0112 - Microphone 3 for Drivers Side
B1205 13 [009] - Open Circuit
Reset counter: 83
Mileage: 45539 km
Date: 2023.05.22
Time: 16:18:31
Address C2: Auto Trans 2 (J217) Labels:. 0BH-927-711-C2.clb
Part No SW: 4S0 927 109 HW: 4S0 927 109
Component: DL800 ZSG H11 0002
Revision: --H11--- Serial number: 0000000066 CVN: 0000CB9C
ASAM Dataset: EV_TCMDL800421 001024
ROD: EV_TCMDL800.rod
VCID: 73B8B5CA3B3F6A92029-8026
End----------(Elapsed Time: 02:09, VBatt start/end: 12.0V/12.0V)-----------
