Hi all;
I own a legitimate VCDS micro can but with MQB chassis, the old vag com doesnt work.
So i bought a new legit Hex V2and register it.
I do some tweaks on the ibiza V MQB (KJ) like cupra display on the virtual cockpit and some basic tweak like desactivation start / stop and so on....
I have a problem because the switch to command glasses up / down and the switch to control side mirrors are not illuminated on the 4 sides (driver, front passenger, rear left passenger and rear right passenger) are not illuminated (no light)
Could you give me any advice please ? Thqnks in advance
Below the history from codinglong
and from adplog
Address 5F,5F0 035 877 ,recoded (Long Coding),from,04720001960A000011110001000808002F0101F401200400CE,to,04720001960A000011110001000808002F0301F401200400CE,(00049/770/00170),Monday,06,February,2023,18:59:08:40727 Address 5F,5F0 035 877 ,recoded (Long Coding),from,04720001960A000011110001000808002F0301F401200400CE,to,04720001960A000011110001000808002F0201F401200400CE,(00049/770/00170),Monday,06,February,2023,19:00:18:40727 Address 5F,5QA 035 846 B,recoded (Long Coding),from,04720001960A000011110001000808002F0100C401200500C6,to,04720001960A000011110001000808002F0106C401200500C6,(00049/770/00113),Tuesday,07,February,2023,19:02:17:40727 Address 17,6F0 920 790 ,recoded (Long Coding-exp),from,04A419142D800008018862011000000080000000,to,04A519142D800008018862011000000080000000,(00049/770/00170),Tuesday,07,February,2023,19:07:45:40727 Address 17,6F0 920 790 ,recoded (Long Coding-exp),from,04A519142D800008018862011000000080000000,to,04A419142D800008018862011000000080000000,(00049/770/00170),Tuesday,07,February,2023,19:23:09:40727
and from adplog
as usual below a full scan
Address 09,2Q0 937 090 A,channel ENG141647-ENG149107-Außenlicht_Front-Tagfahrlicht_nur_in_Schalterstellung_AUTO,adapted from,not active ,to,active ,Monday,06,February,2023,18:40:14:40727 Address 09,2Q0 937 090 A,channel ENG141647-ENG149101-Außenlicht_Front-Tagfahrlicht_Aktivierung_durch_BAP_oder_Bedienfolge_moeglich,adapted from,not active ,to,active ,Monday,06,February,2023,18:41:42:40727 Address 19,3Q0 907 530 AA,channel IDE08348-Start/stop start voltage limit,adapted from,7.8 V,to,12 V,Monday,06,February,2023,18:43:41:40727 Address 17,6F0 920 790 ,channel IDE06588-Ignition active message: actuator,adapted from,Driver door ,to,No display ,Monday,06,February,2023,18:44:56:40727 Address 5F,5F0 035 877 ,channel ENG122227-ENG117566-Car_Function_Adaptations_Gen2-menu_display_compass,adapted from,not activated ,to,activated ,Monday,06,February,2023,18:47:36:40727 Address 5F,5F0 035 877 ,channel ENG122227-ENG122296-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope,adapted from,not activated ,to,activated ,Monday,06,February,2023,18:48:01:40727 Address 5F,5F0 035 877 ,channel ENG122227-ENG122298-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_high,adapted from,not activated ,to,activated ,Monday,06,February,2023,18:48:17:40727 Address 5F,5F0 035 877 ,channel ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high,adapted from,not activated ,to,activated ,Monday,06,February,2023,18:48:32:40727 Address 5F,5F0 035 877 ,channel ENG122229-ENG117732-Car_Function_List_BAP_Gen2-compass_0x15,adapted from,not activated ,to,activated ,Monday,06,February,2023,18:49:05:40727 Address 5F,5F0 035 877 ,channel ENG122229-ENG122334-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24,adapted from,not activated ,to,activated ,Monday,06,February,2023,18:49:43:40727 Address 17,6F0 920 790 ,channel ENG98918-Sport,adapted from,No display ,to,Readout ,Monday,06,February,2023,18:53:55:40727 Address 09,2Q0 937 090 A,channel ENG141651-ENG149179-ZV allgemein-Funk_bei_Klemme_15_ein,adapted from,not active ,to,active ,Tuesday,07,February,2023,19:09:48:40727 Address 09,2Q0 937 090 A,channel ENG141651-ENG149179-ZV allgemein-Funk_bei_Klemme_15_ein,adapted from,not active ,to,active ,Tuesday,07,February,2023,19:10:30:40727 Address 09,2Q0 937 090 A,channel ENG141647-ENG149107-Außenlicht_Front-Tagfahrlicht_nur_in_Schalterstellung_AUTO,adapted from,active ,to,not active ,Tuesday,07,February,2023,19:25:52:40727 Address 09,2Q0 937 090 A,channel ENG141647-ENG149107-Außenlicht_Front-Tagfahrlicht_nur_in_Schalterstellung_AUTO,adapted from,active ,to,not active ,Tuesday,07,February,2023,19:29:26:40727 Address 09,2Q0 937 090 A,channel ENG141647-ENG149107-Außenlicht_Front-Tagfahrlicht_nur_in_Schalterstellung_AUTO,adapted from,active ,to,not active ,Tuesday,07,February,2023,19:29:50:40727 Address 09,2Q0 937 090 A,channel ENG141647-ENG149107-Außenlicht_Front-Tagfahrlicht_nur_in_Schalterstellung_AUTO,adapted from,not active ,to,active ,Tuesday,07,February,2023,19:30:51:40727 Address 09,2Q0 937 090 A,channel ENG141647-ENG149107-Außenlicht_Front-Tagfahrlicht_nur_in_Schalterstellung_AUTO,adapted from,not active ,to,active ,Tuesday,07,February,2023,19:31:14:40727 Address 09,2Q0 937 090 A,channel ENG141651-ENG149179-ZV allgemein-Funk_bei_Klemme_15_ein,adapted from,active ,to,not active ,Tuesday,07,February,2023,19:32:16:40727 Address 09,2Q0 937 090 A,channel ENG141651-ENG149179-ZV allgemein-Funk_bei_Klemme_15_ein,adapted from,active ,to,not active ,Tuesday,07,February,2023,19:32:43:40727 Address 09,2Q0 937 090 A,channel ENG141647-ENG149101-Außenlicht_Front-Tagfahrlicht_Aktivierung_durch_BAP_oder_Bedienfolge_moeglich,adapted from,active ,to,not active ,Tuesday,07,February,2023,19:37:07:40727 Address 09,2Q0 937 090 A,channel ENG141647-ENG149101-Außenlicht_Front-Tagfahrlicht_Aktivierung_durch_BAP_oder_Bedienfolge_moeglich,adapted from,not active ,to,active ,Tuesday,07,February,2023,19:38:32:40727 Address 19,3Q0 907 530 AA,channel IDE08348-Start/stop start voltage limit,adapted from,12.0 V,to,7.8 V,Tuesday,07,February,2023,19:41:40:40727 Address 17,6F0 920 790 ,channel IDE06588-Ignition active message: actuator,adapted from,No display ,to,Driver door ,Tuesday,07,February,2023,19:45:22:40727 Address 17,6F0 920 790 ,channel IDE06588-Ignition active message: actuator,adapted from,Driver door ,to,No display ,Tuesday,07,February,2023,19:45:54:40727 Address 17,6F0 920 790 ,channel ENG98918-Sport,adapted from,Readout ,to,No display ,Tuesday,07,February,2023,19:46:17:40727 Address 17,6F0 920 790 ,channel ENG98918-Sport,adapted from,No display ,to,Readout ,Tuesday,07,February,2023,19:46:53:40727 Address 19,3Q0 907 530 AA,channel IDE08348-Start/stop start voltage limit,adapted from,7.8 V,to,12 V,Tuesday,07,February,2023,19:51:48:40727 Address 09,2Q0 937 090 A,channel ENG141647-ENG149107-Außenlicht_Front-Tagfahrlicht_nur_in_Schalterstellung_AUTO,adapted from,active ,to,not active ,Tuesday,07,February,2023,21:12:43:40727 Address 09,2Q0 937 090 A,channel ENG141647-ENG149101-Außenlicht_Front-Tagfahrlicht_Aktivierung_durch_BAP_oder_Bedienfolge_moeglich,adapted from,active ,to,not active ,Tuesday,07,February,2023,21:13:04:40727
Tuesday,07,February,2023,19:50:51:40727
VCDS Version: 22.10.0.1 (x64) HEX-V2 CB: 0.4623.4
VIN: VSSZZZKJZKR067047 License Plate:
Chassis Type: KJ-SE27 (3Q0)
Scan: 01 03 05 08 09 10 13 15 16 17 19 2B 44 55 5F 69 CA D6 D7
VIN: VSSZZZKJZKR067047 Mileage: 45345km-28176miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DKRF) Labels:. 04E-907-309-V1.clb
Part No SW: 04C 906 025 M HW: 04C 907 309 BB
Component: R3 1.0l TFS H20 6196
Revision: D7H20000 CVN: 69538F0E
Coding: 01190032245405081000
Shop #: WSC 64117 001 1048576
ASAM Dataset: EV_ECM10TFS01104C906025M 002003
ROD: EV_ECM10TFS01104C906025K.rod
VCID: 2A0D0E102C76D82B956-807E
VINID: 9A38EAAAA6DAA9B8801870041C9B603FC0
Part No SW: 2Q0 614 517 AG HW: 2Q0 614 517 N
Component: ESC_base_vFGS H23 0242
Serial number: 08502740181020
Coding: 510D4C5735478AB432FCAC1A24E142A649124D26224A245844541254452442659248B2644452241A222A482AA24AD6437D526BC2BE
ASAM Dataset: EV_Brake1BOSCHESPMQBA0 004036
ROD: EV_Brake1BOSCHESPMQBA0_004.rod
VCID: 73B3D374BB3CD9E3E60-8026
Part No SW: 3Q0 959 435 L HW: 3Q0 959 435 L
Component: VWKESSYMQB 037 1204
Revision: 00037000 Serial number: 0498755539
Coding: 112E0E0603
ASAM Dataset: EV_KessyHellaMQBAB 004046
ROD: EV_KessyHellaMQBAB.rod
VCID: 43D343B4AB1C2963B60-8016
Address 08: Auto HVAC (J255) Labels:* None
Part No SW: 6F0 907 044 B HW: 6F0 907 044 B
Component: Climatronic H03 0502
Coding: 0100000108000100110008000240010D0000000000000000000000000000
Shop #: WSC 00049 770 00138
ASAM Dataset: EV_ACClimaBHBMQBA0 004017
ROD: EV_ACClimaBHBMQBA0_004_SE27.rod
VCID: 2615FA20386EFC4BB1E-8072
Part No SW: 2Q0 937 090 A HW: 2Q0 937 090
Component: BCM A0 Std+ H98 0926
Serial number: 00001831900398
ASAM Dataset: EV_BCMA0 204001
ROD: EV_BCMA0_204_VW27.rod
VCID: 30391C780AAAA2FB5B2-8064
Subsystem 1 - Part No SW: 5Q0 955 559 B HW: 5Q0 955 559 B Labels: 5Q0-955-547.CLB
Component: RLS 050 0105
Serial number: S3Y18M10D25H01M00S52
Coding: 00194D
Driver door control module:
Subsystem 2 - Part No SW: 2Q1 959 881 B HW: 2Q1 959 881 B
Component: FHSG_DRV 001 0001
Serial number: 00000000000025073636
Coding: 13000F
Front passenger door control module:
Subsystem 3 - Part No SW: 2Q1 959 882 D HW: 2Q1 959 882 D
Component: FHSG_PSG 001 0002
Serial number: 00000000000025219583
Coding: 09000F
Subsystem 4 - Part No SW: 5Q0 959 811 D HW: 5Q0 959 811 D
Component: FOND_FHSG_DRV 006 0007
Serial number: 00000000000025285578
Subsystem 5 - Part No SW: 5Q0 959 812 D HW: 5Q0 959 812 D
Component: FOND_FHSG_PSG 006 0007
Serial number: 00000000000025109064
Coding: 190000
919560 - Light Switch
B126A 29 [008] - Signal Implausible
Reset counter: 160
Mileage: 45345 km
Date: 2023.02.07
Time: 19:43:10
Zusaetzliche Umgebungsdaten-Terminal 15 status: OFF
Zusaetzliche Umgebungsdaten-Terminal 50 status: OFF
Zusaetzliche Umgebungsdaten-Low beam: Not operated
Zusaetzliche Umgebungsdaten-OFF: Not operated
Zusaetzliche Umgebungsdaten-Outside temperature: 0
Zusaetzliche Umgebungsdaten-Automatic high beam assist: Not operated
Zusaetzliche Umgebungsdaten-Position lamps: Not operated
Zusaetzliche Umgebungsdaten-Parking light left: Not operated
Zusaetzliche Umgebungsdaten-Parking light right: Not operated
Zusaetzliche Umgebungsdaten-CAN-Bus_aktiv: On
Zusaetzliche Umgebungsdaten-last wakeup: 33
Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (CAN): OFF
Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (HW): OFF
Zusaetzliche Umgebungsdaten-voltage measurement: 12.5 V
Part No SW: 5QA 919 294 C HW: 5QA 919 294
Component: PDC 8 KanalH07 0050
Serial number: 000308418018316
Coding: 0471151901
ASAM Dataset: EV_EPHVA18AU3700000 009039
ROD: EV_EPHVA18AU3700000_AU27.rod
VCID: 4CC168888642E61B47A-8018
Part No SW: 2Q0 907 572 Q HW: 2Q0 907 572 B
Component: ACCCONTIMQB H03 0342
Coding: 2A00608A48FF8728749C814560408700000000000000000000
ASAM Dataset: EV_ACCMRRCONTIVW376 003015
ROD: EV_ACCMRRCONTIVW376_003.rod
VCID: 42DD46B0B406206BBD6-8016
Part No SW: 5QF 959 655 L HW: 5QF 959 655 L
Component: Airbag VW22 006 0520
Revision: -------- Serial number: 003XNPNR1VD7
Coding: 88CCC0C000000000585400CF000C00000065
ASAM Dataset: EV_AirbaVW22TS6VW48X 001028
ROD: EV_AirbaVW22TS6VW48X.rod
VCID: 5F9BAFC427B46D83B28-800A
Subsystem 1 - Part No SW: ----------- HW: 454 003 010 18
Serial number: 3570000000012A85D13F
Subsystem 2 - Part No SW: ----------- HW: 454 003 010 18
Serial number: 35800000000FC20D923T
Subsystem 3 - Part No SW: ----------- HW: 454 802 710 18
Serial number: 351005925BF16000000K
Subsystem 4 - Part No SW: ----------- HW: 454 802 810 18
Serial number: 35200262CBF16000000M
Subsystem 5 - Part No SW: ----------- HW: 454 803 110 18
Component: FrontSensor_D 307 0189
Serial number: 355008F234116000000A
Part No SW: 5Q0 953 521 GE HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0235
Revision: FF035035 Serial number: 20181115500740
Coding: 6404
Shop #: WSC 00049 770 00170
ROD: EV_SMLSVALEOMQB.rod
VCID: 7BA3FB54936C91A3BE0-802E
Address 17: Instruments (J285) Labels:* None-SRI3
Part No SW: 6F0 920 790 HW: 6F0 920 790
Component: KOMBI 614 1701
Coding: 04A419142D800008018862011000000080000000
ASAM Dataset: EV_DashBoardVDDMQBA0 001026
ROD: EV_DashBoardVDDMQBA0_001_VW27.rod
VCID: 678BB724FFE425434A8-8032
Part No SW: 3Q0 907 530 AA HW: 3Q0 907 530 C
Component: GW MQB High 521 5366
Serial number: 04111810521432
Coding: 030100346F085700E9000258080F00010001070000000000000000000000
GVL: 01543C0000000600C00090000000480010000000000000000000000000000000
ROD: EV_GatewNF_VW27.rod
VCID: 6E85C200D01EF40B09E-803A
Generator:
Component: 0-01-02-01-04
Subsystem 2 - Part No SW: 5F0 959 537 E HW: 5F0 959 537 E
Component: E221__MFL-PR6 H04 0130
Serial number: 000000000G0278271018
Coding: 002000
Subsystem 3 - Part No SW: 2Q0 915 181 HW: 2Q0 915 181
Component: J367-BDMBOSCH H02 2011
Serial number: 100B1D3A
131655 - No Communication with Towing System Control Module (J345)
U1003 00 [008] - -
[Timeout Knoten 0x47 / 69 - Steuergerät für Anhängererkennung]
Reset counter: 160
Mileage: 45345 km
Date: 2023.02.07
Time: 19:42:28
Terminal 30 power supply: 13.1 V
Terminal 15: OFF
Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb
Part No SW: 2Q0 905 861 A HW: 2Q0 905 861 A
Component: ELV-MQBB H08 0021
Serial number: 18000364227009
Coding: 0000000000000000
ROD: EV_ELVMarqMQBA0_VW27.rod
VCID: 313F197C01A0ABF354C-8064
Address 44: Steering Assist (J792) Labels:* 2Qx-909-144-V1.clb
Part No SW: 2Q1 909 144 M HW: 2Q1 909 144 F
Component: TRW_G4L_MQBA0 611 6041
Serial number: 0855097CB4J3251
Coding: 010000000000000101010201010001010000010101
ASAM Dataset: EV_SteerAssisTRWG4LMQBA0 011016
ROD: EV_SteerAssisTRWG4LMQBA0.rod
VCID: 3C213848D6E2569BF7A-8068
Part No SW: 7P6 907 357 E HW: 7P6 907 357 A
Component: AFS-ECU H07 0080
Coding: 078A000009200003
ROD: EV_HeadlRegulAFSMQBMAX_VW27.rod
VCID: 41DF49BCB1003B73A4C-8014
Address 5F: Information Electr. (J794) Labels:| 5F0-035-MIB-STD2.clb
Part No SW: 5F0 035 877 HW: 5F0 035 877
Component: MU-S-ND-ER H50 0514
Serial number: SEZAZ2U0861177
Coding: 04720001960A000011110001000808002F0201F401200400CE
ASAM Dataset: EV_MUStd6C1TSAT 001015
ROD: EV_MUStd6C1TSAT_SE27.rod
VCID: 698FB11CE9F013335CC-803C
Subsystem 1 - Part No SW: 6F0 919 605 A HW: 6F0 919 605 A
Component: ABT_Std-2_Nav H53 8130
Serial number: SEZ6ZHV3225285
Subsystem 2 - Part No SW: 6P0 919 866 AF HW: -----------
Component: ECE1 2018/19 --- 1030
Part No SW: 5Q0 907 383 L HW: 5Q0 907 383 L
Component: Anhaenger H27 0260
Revision: 8C001004 Serial number: 0529998034
Coding: 0100000202000000
ROD: EV_TrailFunctGener2Hella_VW27.rod
VCID: 40D94CB8BA0A327BAB2-8014
Part No SW: 4M0 907 594 H HW: 4M0 907 594
Component: SAD_STG_1 014 0005
Coding: 408040527001
ROD: EV_SunRoofCONTIAU736_006.rod
VCID: 3B233B54D3EC51A3FE0-806E
Address D6: Light Ctrl Left 2 (A31) Labels: 7P5-941-591.clb
Part No SW: 7P5 941 591 AD HW: 7P5 941 591 A
Component: LED1L H06 0005
ROD: EV_LED_PLUS_L_KEBODAVW416.rod
VCID: 7EA5F240807E848B99E-802A
Address D7: Light Ctrl Right 2 (A27) Labels: 7P5-941-591.clb
Component: LED1R H06 0005
ROD: EV_LED_PLUS_R_KEBODAVW416_SK38.rod
End----------(Elapsed Time: 01:27, VBatt start/end: 13.0V/13.6V)-----------
