Good afternoon all. The gauges on my wife's A3 have just stopped working and I'm after some pointers on how to rectify it so we can sell it please.
The speedo, tacho, fuel gauge and temp gauge, along with the multifunction display have stopped working. All the warning lights still work, as do the heaters etc and the car runs and drives fine.
I'm aware that the scan has thrown up a fuel sensor fault, but was wondering if that would cause this issue. The fuel gauge worked fine until all gauges died.
I have checked power to both sides of all fuses under the bonnet and in the RH end of the dash panel, and removed/refitted all relays from the BCM, swapping like for like where possible.
If anyone has any pointers to resolve this, it'd be very much appreciated
Friday,11,November,2022,10:01:28:11279
VCDS Version: 22.3.1.4 (x64)
Chassis Type: 8P (1K0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 26 42 44 46 47 52 55 56 62
72
VIN: TRUZZZ8P091010625 Mileage: 202000km-125516miles
25-Immobilizer -- Status: Malfunction 1010
Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 MA HW: 03L 906 022 BQ
Component: R4 2,0L EDC 0000AG 3611
Revision: 13H01--- Serial number: AUX7Z0H9FND05T
Coding: 0000078
Shop #: WSC 01236 785 00200
VCID: 70E802F2638F1C0F3F-8024
VINID: 92296AAAA22000904004018214A47B436D
Part No SW: 02E 300 052 HW: 02E 927 770 AJ
Component: GSG DSG AG6 431 1956
Revision: 04843012 Serial number: 00000809201063
VCID: 51AEA776C8C5350710-8004
Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AE HW: 1K0 907 379 AE
Component: ESP MK60EC1 H35 0106
Revision: 00H35001
Coding: 13424012092300FAC81102E6901E0082B900
Shop #: WSC 01236 758 00200
VCID: 75E633E6DCED3927EC-8020
Part No SW: 8P0 820 043 BD HW: 8P0 820 043 BD
Component: KlimavollautomatH03 0110
Revision: 160177 Serial number: 8P0820043BD
VCID: 6FEA018E7EB103F726-803A
003 - Mechanical Failure
Fault Status: 01100011
Reset counter: 147
Mileage: 188839 km
Date: 2020.09.30
Time: 06:44:06
Voltage: 13.80 V
Temperature: 21.5°C
(no units): 175.0
(no units): 163.0
Temperature: 9.0°C
Address 09: Cent. Elect. Labels:. 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 N HW: 8P0 907 279 N
Component: Bordnetz-SG H54 2801
Revision: 00H54000 Serial number: 00000008984154
Coding: F1021F01B0141080EF00000A0000000000084E0164060003002000000000
VCID: 48988A123B9FF4CF47-801C
Subsystem 1 - Part No: 8P2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H10 0040
Coding: 00056595
Shop #: WSC 01236
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Coding: 00150573
Shop #: WSC 01236
00906 - Horn (H1)
Fault Status: 00101001
Reset counter: 187
Mileage: 202003 km
Date: 2022.11.09
Time: 15:11:00
Voltage: 12.45 V
00924 - Relay for Headlamp Cleaning System (J39)
Reset counter: 187
Mileage: 202003 km
Date: 2022.11.09
Time: 15:11:00
Voltage: 12.45 V
01516 - Terminal 30; Left
Fault Status: 00101011
Reset counter: 187
Mileage: 202003 km
Date: 2022.11.09
Time: 15:11:00
Voltage: 12.45 V
Address 10: Park/Steer Assist (J446) Labels:. 8P0-919-475-7X1.clb
Part No SW: 8P0 919 475 F HW: 8P0 919 475
Component: PARKHILFE 4K H06 0102
Revision: 11001001 Serial number: 52330827613949
Coding: 000103
VCID: 418E9736D8A5C58780-8014
Address 15: Airbags Labels: 8P7-959-655.clb
Part No SW: 8P7 959 655 HW: 8P7 959 655
Component: SR Airbag 9.43 H01 0020
Revision: 93H01002 Serial number: 003BS000HFA+
Coding: 0021330
VCID: 0604442A710B22BFF5-8052
Subsystem 1 - Serial number: 6332DRB407D60C32Q
Subsystem 2 - Serial number: 6342DRB407D5CD360
Subsystem 3 - Serial number: 63747RB4046403E4I
Subsystem 4 - Serial number: 63847RB404640BAEX
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0012111
VCID: 418E973618A5C58780-8014
Component: E0221 H02 0030
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 982 C HW: 8P0 920 982 C
Component: KOMBIINSTR. VDO H18 0830
Revision: D0H18006 Serial number: 2249H006007849
Coding: 0000428
Shop #: WSC 12345 067 57207
VCID: 397EFFD670759D47C8-806C
00771 - Fuel Level Sensor (G)
Fault Status: 00101010
Reset counter: 185
Mileage: 201975 km
Date: 2022.11.05
Time: 02:35:13
Fault Status: 00101110
Reset counter: 185
Mileage: 201975 km
Date: 2022.11.05
Time: 16:47:40
Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533__Gateway H16 0202
Revision: H16 Serial number: 2700K089228322
Coding: EDA17F261002029101
VCID: 3566F3E65C6D79272C-8060
Reset counter: 185
Revision: D0H18006 Serial number: AUX7Z0H9FND05T
16346 - Control Module - ROM Error
014 - Defective
Address 26: Auto Roof Labels: Redir Fail!
Part No: 8P7 959 255
Component: VSG AUDI A3 H14 0100
VCID: 020C583A5D231E9FD9-8056
Address 42: Door Elect, Driver Labels: None
Part No SW: 8P7 959 801 B HW: 8P7 959 801 B
Component: Tuer-SG H02 0020
Coding: 0000692
01552 - Motor for Central Locking; Drivers Door (V56); Lock
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 233 2301
Revision: 00H15000
VCID: 2A5CD09A85D326DFB1-807E
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 J
Component: KSG H11 0080
Coding: 1990200042386D0985254C9ED633
VCID: 43829D3E02B9D79792-8016
Subsystem 2 - Part No: 8P7 951 177
Component: DWA-Sensor H03 0030
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P7 035 382 HW: 8P7 035 382
Component: AB2 SUBWOOFERBOXH06 0160
Revision: 00005 Serial number: 30703841036436
VCID: 74E00EE21797202FDB-8020
Address 52: Door Elect, Pass. Labels: None
Part No SW: 8P7 959 802 B HW: 8P7 959 802 B
Coding: 0000692
VCID: 428C983A1DA3DE9F99-8016
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 J
Component: Dynamische LWR H01 0020
Coding: 0000013
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8P0 035 195 M HW: 8P0 035 195 M
Component: R Symphony2+ H05 0270
Revision: 00H05000 Serial number: AUZ1Z4H7177691
Coding: 0330211
VCID: 3C70E6C27F47A86FD3-8068
Reset counter: 145
Mileage: 201975 km
Date: 2022.11.05
Time: 02:35:19
00857 - CD Changer Unit (R41)
Reset counter: 145
Mileage: 201975 km
Date: 2022.11.05
Time: 02:38:45
Part No SW: 8P7 959 811 A HW: 8P7 959 811 A
Component: Tuer-SG H01 0030
Coding: 0000144
Shop #: WSC 01236 785 1012552
Part No SW: 8P7 959 812 A HW: 8P7 959 812 A
Coding: 0000144
End-------------------------(Elapsed Time: 02:41)--------------------------
