hello all,
i have some problems with coding the BCM and Headlight Regulation.
I have the vin from the donor car of the headlamps and Headlight Regulation.
I have found on Vaglogins.com the Parametrization files, but seems that this is not enought.
i wired all by Elsa online, but still i dont have the side lights, main beam and turn signals.
i can't code the 55, always keeps give Out Of Range.
when the car goes in sleep, the headlights turn on.
i post the scan ....
if anyone has any idea, please let me know, i am super tired with it.
best Regards, Vlad.
later edit i have odis too, i cand send the saved adaptations and coding.
best Regards, Vlad.
Friday,30,September,2022,22:14:16:57416
VCDS Version: 22.9.0.0 (x64) HEX-V2 CB: 0.4623.4
Dealer/Shop Name: Auto Expert Diag
Workshop Code: 210 01369 040505
VIN: WV1ZZZ7HZLH003801 License Plate: LIK
Mileage: 11916km-7404mi Repair Order:
Chassis Type: 7H-VN46 (3Q0)
Scan: 01 03 08 09 15 17 19 44 55 5F D6 D7
VIN: WV1ZZZ7HZLH003801 Mileage: 11916km-7404miles
D6-Light Ctrl Left 2 -- Status: Malfunction 0010
D7-Light Ctrl Right 2 -- Status: Malfunction 0010
Address 01: Engine (J623-CXHC) Labels:. 04L-907-309-V2.clb
Part No SW: 04L 906 056 SC HW: 04L 907 445 M
Component: R4 2.0l TDI H01 9707
Revision: 23301001
Coding: 001140144324010900000000000000000000000000000000
Shop #: WSC 00046 000 00000
ASAM Dataset: EV_ECM20TDI03004L906056SC 004007
ROD: EV_ECM20TDI03004L906056LE_004.rod
VCID: 005A89FEBA8D078BE73-8054
VINID: 9E606AAAA1D8A9C600003200046BB98289
33866 - Mass Air Flow Sensor (G70)
P0101 00 [163] - Implausible Signal
33867 - Mass Air Flow Sensor (G70)
13174 - Mass Air Flow Sensor (G70)
P0103 00 [163] - Signal too High
25110 - Cruise Control Switch (E45)
P0568 00 [035] - Implausible Signal
25130 - Check Coding of ECUs on Powertrain Data Bus
P1647 00 [163] - -
[Checking coding/versions ofcontrol modules in drivetrain]
Readiness: N/A
Address 03: ABS Brakes (J104) Labels: Redir Fail!
Part No SW: 7LB 614 517 HW: 7LB 614 517
Component: ESC_base H01 0650
Serial number: 08500306190812
Coding: 315524524847EE888C5C24A41267770638202078
Shop #: WSC 00012 790 00069
ASAM Dataset: EV_Brake1ESP90iBOSCHVN46X 002010
ROD: EV_Brake1ESP90iBOSCHVN46X_002.rod
VCID: 7DA4F00ACD7F6A638C5-8028
Address 08: Auto HVAC (J301) Labels:* Redir Fail!
Part No SW: 7LA 907 426 B HW: 7LA 907 426 B
Component: AC Manuell H01 0502
Coding: A03010000810000001000800504001050000000000000000800000000000
Shop #: WSC 00012 790 00042
ASAM Dataset: EV_AirCondiBHTCT6PA 001004
ROD: EV_AirCondiBHTCT6PA.rod
VCID: 42DE43F6F401D59BB17-8016
Rear air conditioning block 1:
Part No SW: 2Q5 937 090 HW: 2Q5 937 090
Component: BCM T6PA Std+ H10 0935
Serial number: 01101926000368
ASAM Dataset: EV_BCMA0 205001
ROD: EV_BCMA0_205_VN46.rod
VCID: 74B2D52EFE352B2BF3B-8020
Driver door control module:
Subsystem 1 - Part No SW: 7L2 959 405 HW: 7L2 959 163
Component: FHSG_DRV 001 0002
Serial number: 00000000000032229459
Coding: 130008
Front passenger door control module:
Subsystem 2 - Part No SW: 7L2 959 406 HW: 7L2 959 164
Component: FHSG_PSG 001 0002
Serial number: 00000000000032800890
Coding: 090000
590853 - Window Regulator; Front Drivers Side
B14D1 54 [009] - Missing Calibration / Basic Setting
592133 - Window Regulator; Front Passenger Side
B14D2 54 [009] - Missing Calibration / Basic Setting
Part No SW: 2Q0 959 655 AD HW: 2Q0 959 655 AD
Component: VW22Airbag 013 0506
Revision: --------
Coding: 8800C00000000000400000CF000C00000065
ASAM Dataset: EV_AirbaVW22BPAVW27X 001022
ROD: EV_AirbaVW22BPAVW27X_VW27.rod
VCID: 7F580A02C77378739E9-802A
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI3
Part No SW: 7LA 920 741 HW: 7LA 920 741
Component: KOMBI 204 6750
Coding: 07A0120020000008010828000400000000000000
Shop #: WSC 00012 790 00164
ROD: EV_DashBoardVDDMQBAB_VW27.rod
VCID: 7BA0FE12D36B6453B21-802E
Part No SW: 3Q0 907 530 AC HW: 3Q0 907 530 C
Component: GW MQB High 521 5388
Serial number: 07091911603111
Coding: 030100044F05730000000008000F00010001070000000000000000000000
GVL: 01403C0000000000400010000000480000000000000000000000000000000000
ROD: EV_GatewNF_VW27.rod
VCID: 70BAD93E8A2D170B173-8024
Generator:
Component: 4-00-11-01-04
Subsystem 2 - Part No SW: 3G0 959 442 H HW: 3G0 959 442 H Labels: 3C8-959-537.CLB
Component: E221__MFL-PR6 H06 0110
Serial number: PR6-0440036017204028
Coding: 2F0101
197175 - Control unit for battery monitoring
U1050 00 [009] - No Communication
[BDM (LIN#1) Timeout]
8782085 - Tiptronic Upshift Switch/Paddle in Steering Wheel
B114F 96 [009] - Component Internal Failure
Address 44: Steering Assist (J500) Labels:| 2N0-909-143.clb
Part No SW: 7LA 909 144 F HW: 7LA 909 144 D
Component: EPS_MQB_ZFLS 751 7150
Coding: 0106
ASAM Dataset: EV_SteerAssisMNB 002012
ROD: EV_SteerAssisMNB.rod
VCID: 45D458EAE52FE2A3945-8010
Part No SW: 7P6 907 357 E HW: 7P6 907 357 A
Component: AFS-ECU H07 0070
Coding: 0000000000000000
ASAM Dataset: EV_HeadlRegulAFSMQBMAX 001001
ROD: EV_HeadlRegulAFSMQBMAX_SK25.rod
VCID: 41DC4CFAF107CE83A8D-8014
13705473 - Databus
U1121 00 [137] - Missing Message
[Fahrwerk_01 Datenbus fehlende Botschaft]
5275220 - Headlight
C107E 54 [137] - Missing Calibration / Basic Setting
13636352 - Control module not coded
U1013 00 [137] - -
[Steuergeraet nicht codiert]
Part No SW: 7LA 035 153 A HW: 7LA 035 153 A
Component: MU-N-T-EU 008 0025
Serial number: VWZHZ1W0002077
Coding: 066401002800000000110001000000002F0000040000010000
ASAM Dataset: EV_MUNRUL 001002
ROD: EV_MUNRUL_VN46.rod
VCID: 36362F26A8C9793B0DF-8062
Part No SW: 992 941 571 AE HW: 992 941 571 A
Component: LED1L H08 9202
ASAM Dataset: EV_LLPGen3LKEBODPO68X 001003
ROD: EV_LLPGen3LKEBODPO68X_VW27.rod
VCID: 6594B86A45EFC2A3745-8030
131330 - Databus
U1121 00 [175] - Missing Message
[can message LED_Soll_Fkt0 missing]
131331 - Databus
[CAN message LED_Soll_Fkt1 missing]
131335 - Databus
[can message LCM_Soll_Fkt missing]
Component: LED1R H08 9202
ASAM Dataset: EV_LLPGen3RKEBODPO68X 001003
131330 - Databus
131331 - Databus
131335 - Databus
End----------(Elapsed Time: 01:06, VBatt start/end: 14.4V/14.4V)-----------
