TT-RS Kessy retrofit
David_GTi_700
C?ID=426963
Hi guys, wondering if anybody has any success in retrofitting kessy (advanced key) to a 2015+ audi TT.
my car is a 2018 TT-RS 8s FL, it came equipped with keyless go but not entry, we have installed a new Kessy module with all the pins populated, both driver and passenger door handle sensors and the 3 wireless antennas.
The new kessy module has been adapted online and has the relevant TT dataset installed and keys matched. this all works however the keyless entry/lock does not
I get 2 fault codes on the handle sensors saying short to ground, although i suspect this is incorrect.
when using measuring blocks in vcds
door handle version information
door handle software version
door handle EEPROM
I get FF for all data
however when looking at the proximity count, i can see it counting as i touch the handles.
any tips advise or a admap from a factory car would be great.
David_GTi_700
C?ID=426963
Please post an Auto-Scan so we see how this TT-RS is now equipped and configured.
sorry not currently possible, car has gone in for body repair. just trying to get some ideas together of how to resolve it and what parts I need to order for when it comes back at the end ion the month.
David_GTi_700
C?ID=426963
;SW:3Q0-959-435-F   HW:3Q0-959-435-F ---  Acc/Start Auth.
;Component:VWKESSYMQB    027 0907, Coding:000F0F1720
;EV_KessyHellaMQBAB,004041,EV_KessyHellaMQBAB.rod
;Sunday,24,April,2022,19:27:08:56476
;VCDS Version: Release 22.3.1 (x64)  Data version: 20220407 DS337.0
;VCID: 3D2732881DFC6723E49-8068
IDE00001-MAS12708-Production mode-Deactivation of automatic shutdowns of terminal 15,not active ,3
IDE00001-MAS12709-Production mode-Deactivation of automatic rear lid opening,not active ,3
IDE00001-MAS12710-Production mode-Deactivation of terminal 50 request,not active ,3
IDE10844-Control module rear lid opening: duration status query,4960 ms,1
IDE10845-Control module rear lid opening: vehicle type,FE ,1
ENG153713-ENG129122-Byte12_diverse-environment_scan_step1,not activated ,1
ENG153713-ENG126978-Byte12_diverse-environment_scan_step2,not activated ,1
ENG153713-ENG154598-Byte12_diverse-exeption_drivers_doors_interior_scan,activated ,1
ENG153713-ENG154691-Byte12_diverse-interior_scan_clamp_15_new_concept,activated ,1
ENG153713-ENG154710-Byte12_diverse-open_cabrio_canopy_interior_scan,not activated ,1
ENG153713-ENG154787-Byte12_diverse-suppression_access_detection_for_remotestart,not activated ,1
ENG244871-ENG245027-Byte13_vit_lf-lock_via_toggle_by_closed_vehicle_skin,not activated ,1
ENG244871-ENG245033-Byte13_vit_lf-toggle_active,not activated ,1
ENG244871-ENG245019-Byte13_vit_lf-toggle_at _open_door,not activated ,1
ENG244871-ENG297724-Byte13_vit_lf-toggleVariante,China ,1
ENG244871-ENG129126-Byte13_vit_lf-vit_evaluate_inversbit,not activated ,1
ENG244871-ENG129125-Byte13_vit_lf-vit_exit,not activated ,1
ENG126956-ENG126976-Byte9_VIP-active_vip,not activated ,1
ENG126956-ENG154580-Byte9_VIP-Coding_easyclose_locking,not activated ,1
ENG126956-ENG154581-Byte9_VIP-Coding_kick and_close_function,not activated ,1
ENG126956-ENG248655-Byte9_VIP-ECL_Start_ueber_ViP,not activated ,1
ENG126956-ENG129121-Byte9_VIP-Hitch_trailer_installation,not activated ,1
ENG126956-ENG142121-Byte9_VIP-vip_activation_on_clamp15,not activated ,1
ENG126956-ENG126977-Byte9_VIP-vip_deactivation_on_running_engine,not activated ,1
ENG129011-CAN_signal_transmitting_delay_of_car_roll _away_warning,1.00 s,1
ENG126957-CAN_signal_transmitting_duration_of_automatic_Terminal_15_shutoff,1.00 s,1
ENG129010-CAN_signal_transmitting_duration_of_comfort_switch_off,1.00 s,1
ENG105462-CAN-timeout service-key message,260 ms,1
ENG105634-Correction value LED dimming,1.0 ,1
ENG114301-Cycletime for voltage monitoring during sleepmode,100 ms,1
ENG120046-Cyclic interior scan during clamp 15 on,10 s,1
ENG126961-deactivation_time_vip_slidingdoor,15 s,1
ENG126960-Debounce_time_detection,500 ms,2
ENG126959-Debounce_time_driver_presence,200 ms,1
ENG126948-delay_time_Terminal_15_S_Shut_down_after_leaving_vehicle,300 ms,1
ENG129004-delay_time_Terminal_15_S_Shut_down_by_BEM,30.00 s,1
ENG105791-Delta value LED dimming curve first point 40 percent dimming,30.0 %,1
ENG105792-Delta value LED dimming curve forth point 100 percent dimming,5.0 %,1
ENG105793-Delta value LED dimming curve second point 60 percent dimming,15.0 %,1
ENG105794-Delta value LED dimming curve third point 80 percent dimming,10.0 %,1
ENG105809-ENG100524-DeveloperCoding: Passiv Go-GO only via antenna IN1 if sliding door open,not activated ,1
ENG105809-ENG102049-DeveloperCoding: Passiv Go-GO only via antenna IN1 if tailgate open,not activated ,1
ENG105809-ENG121990-DeveloperCoding: Passiv Go-Impairment go on a low key battery,not activated ,1
ENG105809-ENG102152-DeveloperCoding: Passiv Go-Passive Go,activated ,1
ENG105809-ENG99072-DeveloperCoding: Passiv Go-Passive Go: tailgate authorized to start,activated ,1
ENG123038-ENG104126-DeveloperCoding: Proximity Sensor-AUDI doorknobs mounted,not activated ,1
ENG123038-ENG102457-DeveloperCoding: Proximity Sensor-Detection of an repeated failed doorknob actuation,activated ,1
ENG123038-ENG129119-DeveloperCoding: Proximity Sensor-energized_doorhandles_at_stateKL15on_when_opening_door,not activated ,1
ENG123038-ENG102353-DeveloperCoding: Proximity Sensor-No turn off for driver doorknob while passive,activated ,1
ENG123038-ENG99826-DeveloperCoding: Proximity Sensor-Proximity Sensor: sensor stays active after fault detection,not activated ,1
ENG123038-ENG102252-DeveloperCoding: Proximity Sensor-Suppress fault manager entry "Falschverbau aktiv",not activated ,1
ENG123036-ENG102436-DeveloperCoding: Search lights-Standardisation of ZAT,activated ,1
ENG123036-ENG99363-DeveloperCoding: Search lights-ZAT active during clamp 58t on,activated ,1
ENG123036-ENG120038-DeveloperCoding: Search lights-ZAT detecting open load,not activated ,1
ENG123036-ENG154826-DeveloperCoding: Search lights-ZAT_illumination_concept_mybeat_clamp58xt,not activated ,1
ENG123036-ENG154827-DeveloperCoding: Search lights-ZAT_illumination_modus_mybeat_clamp58xt,not activated ,1
ENG123037-ENG98487-DeveloperCoding: vehicle environment-Convertible,not activated ,1
ENG123037-ENG100924-DeveloperCoding: vehicle environment-Pre Catch for Trunk,not activated ,1
ENG123037-ENG129114-DeveloperCoding: vehicle environment-reactivate_all_doorhandles,not activated ,1
ENG123037-ENG103200-DeveloperCoding: vehicle environment-Steering wheel,Right hand steering ,1
ENG105825-Diagnostic: wait time after power on,500 ms,1
ENG126943-Display_duration_emergency_off,3000 ms,1
ENG126944-Display_duration_error_mode_2_SPN,10 s,1
ENG126941-Display_duration_please_engage_P,10 s,1
ENG105898-Doorknob contact sensor disconnecting time,5400 min,1
ENG244875-duration_A-CAN_wake_up_for_Engine_ECU_wake_up,2000 ms,1
ENG126955-duration_to_ZAT_continuous_actuation_detection,1000 ms,1
ENG129005-duration_to_ZAT_multi_actuation_detection,3000 ms,1
ENG126950-duration_ZAT_debounce,50 ms,1
ENG129029-ENG142128-Easy_close_alignment-max_threashold_reopen_EasyClose,30 %,9
ENG129029-ENG142127-Easy_close_alignment-Max_time_IDGeber_rear,2.00 s,9
ENG129029-ENG142129-Easy_close_alignment-max_time_reentry_EasyClose,5.00 s,9
ENG129029-ENG142130-Easy_close_alignment-min_rssi_values_hysteresis_EasyClose,150 ,9
ENG129029-ENG142126-Easy_close_alignment-Min_threashold_trunk,70 %,9
ENG129029-ENG129138-Easy_close_alignment-RSSI_ sample_rate,500 ms,9
ENG129029-ENG129139-Easy_close_alignment-Timeframe_scan_active,20.00 s,9
ENG129028-ENG142124-Easy_close_detection_areas-Easy_close_antenna_current_step,0E ,5
ENG129028-ENG142125-Easy_close_detection_areas-Easy_close_open_door_antenna_current_step,05 ,5
ENG129028-ENG142032-Easy_close_detection_areas-Value_area_4,70 mV/m,5
ENG129028-ENG142033-Easy_close_detection_areas-Value_area_leaving_area,65 mV/m,5
ENG126966-environment_scan_cyclic_step1,700 ms,1
ENG126967-environment_scan_cyclic_step2,2000 ms,1
ENG126965-environment_scan_duration_step1,300 min,1
ENG126971-environment_scan_duration_step2,24 H,1
ENG126969-environment_scan_level_bem,2 ,1
ENG126968-environment_scan_responselevel_reduction,500 ,1
ENG126970-environment_scan_startdelay_time,5 s,1
ENG126958-Ignition_For_Immobilizer,Default ,1
ENG107050-Interior scan: deceleration after comfort closing,3200 ms,1
ENG107051-Interior scan: max. engine speed for standing engine,10 km/h,1
ENG107052-Interior scan: opening threshold sliding roof,1 %,1
ENG107053-Interior scan: opening threshold window lifter,5.0 %,1
ENG107054-Interior scan: Speed - threshold,20 km/h,1
ENG153724-Interior_scans_clamp15_break_at_active_message,5000 ms,1
ENG153725-Interior_scans_clamp15_retry_at_active_message,5 ,1
ENG98656-internal,0 B,1
ENG129022-ENG142120-internal_keyminder_byte1-aktivate_function_trigger_access_leaving_elv,not activated ,1
ENG129022-ENG129115-internal_keyminder_byte1-allowa_remotestart_to_disable_keys,not activated ,1
ENG129022-ENG120037-internal_keyminder_byte1-Cyclic interior scan during active warning message "Key not found",not activated ,1
ENG129022-ENG100928-internal_keyminder_byte1-Seat Memory: scan after driver door opening,not activated ,1
ENG129022-ENG99649-internal_keyminder_byte1-Seat Memory: scan after driver door opening no KESSY unlocking,not activated ,1
ENG129022-ENG99417-internal_keyminder_byte1-Softtouch mounted,installed ,1
ENG129023-ENG99123-internal_keyminder_byte2-Inhibit ID-transmitter for passive go,activated ,1
ENG129023-ENG102581-internal_keyminder_byte2-Lock prevention tailgate,not activated ,1
ENG129023-ENG101018-internal_keyminder_byte2-No locking with ID-transmitter last used interior,not activated ,1
ENG129023-ENG103451-internal_keyminder_byte2-Re-open after passive comfort closing,not activated ,1
ENG129023-ENG99711-internal_keyminder_byte2-Re-open last handling,not activated ,1
ENG129023-ENG103237-internal_keyminder_byte2-Re-open tailgate,not activated ,1
ENG129020-ENG121989-internal_passive_entry_exit_byte1-Impairment Entry / Exit key on low battery,not activated ,1
ENG129020-ENG125240-internal_passive_entry_exit_byte1-lf_crc,not activated ,1
ENG129020-ENG99763-internal_passive_entry_exit_byte1-Passive Exit: access door not open,not activated ,1
ENG129020-ENG103722-internal_passive_entry_exit_byte1-Passive Exit: all doors not open,not activated ,1
ENG129020-ENG126975-internal_passive_entry_exit_byte1-passive_exit_door_slam_lock,not activated ,1
ENG129021-ENG155267-internal_passive_entry_exit_byte2-lf_shutdown,activated ,1
ENG129021-ENG155268-internal_passive_entry_exit_byte2-lf_shutdown_gotrigger,activated ,1
ENG129021-ENG100246-internal_passive_entry_exit_byte2-Passive Entry bei Tuer verriegelt/gesafed ODER ZV ist gesafed,activated ,1
ENG129021-ENG123039-internal_passive_entry_exit_byte2-Passive Entry Exit,not activated ,1
ENG129021-ENG103289-internal_passive_entry_exit_byte2-Passive Entry Exit: control by pulling door handle during active DSL,activated ,1
ENG129021-ENG103620-internal_passive_entry_exit_byte2-Passive Entry Exit: retry with antennastep 1,not activated ,1
ENG129021-ENG103529-internal_passive_entry_exit_byte2-Passive Entry: second control concept,not activated ,1
ENG107211-Key Minder: delay reunlocking tailgate,500 ms,1
ENG107212-Key Minder: p_keyless_eventsearch_holding_time,10 s,1
ENG107213-Key Minder: p_keyless_eventsearch_retries,2 ,1
ENG107363-LED dimming curve first point 20 percent dimming,40.0 %,1
ENG153886-lf_shutdown_timeout_2nd_operation,5 s,1
ENG107592-MCTX Pause,1 B,1
ENG107593-MCTX pause for Go / Key Minder,20 ms,1
ENG107594-MCTX pause for Go authentification,14 B,1
ENG107595-MCTX settling phase,10 B,1
ENG129013-min_receptiontime_vit,0 ms,1
ENG126945-min_time_for_Terminal_50_request,850 ms,1
ENG129003-Number_of_Multiple_ZAT_activations_to_emergency_shutoff,2 ,1
ENG126940-Number_of_ZAT_activations_to_DTC,10 ,1
ENG129015-Passive Entry Exit: control by pulling the door handle during active DSL_timeout,2.00 s,1
ENG108166-Passive Entry Exit: entry request e-sliding door active time,500 ms,1
ENG108167-Passive Entry Exit: minimum activity time locking sensor,140 ms,1
ENG108168-Passive Entry Exit: PARA_T_TIMOUT_PROXIMITY_ENTRY,210 ms,1
ENG108169-Passive Entry Exit: T_ACT_OP_2,5000 ms,1
ENG108297-Proximity Sensor: Comfort Exit-Enlargement,200 ms,1
ENG108298-Proximity Sensor: duration of proximity Signal,10 s,1
ENG108299-Proximity Sensor: lower limit Impuls,2000 µs,1
ENG108300-Proximity Sensor: lower limit proximity-Impuls,12200 µs,1
ENG108301-Proximity Sensor: max Vehiclespeed for a standing vehicle,10.0 km/h,1
ENG108302-Proximity Sensor: max. Impulslength,75 ms,1
ENG108303-Proximity Sensor: max. Impulslength of proximity-Impuls,20400 µs,1
ENG108304-Proximity Sensor: max. intermission-length Diagnostic,14 ms,1
ENG108305-Proximity Sensor: max. length of Diagnosticimpuls,71 ms,1
ENG108306-Proximity Sensor: max. length of Entryimpuls,10400 µs,1
ENG108307-Proximity Sensor: max. length of Exitimpuls,40400 µs,1
ENG108308-Proximity sensor: max. length of signal hall sensor,100 s,1
ENG108309-Proximity Sensor: max. signal-length,120 s,1
ENG108310-Proximity sensor: max. tolerance data bit length,200 µs,1
ENG108311-Proximity Sensor: min Vehiclespeed for a driving vehicle,20.0 km/h,1
ENG108312-Proximity Sensor: min. enginespeed for a running engine,300 /min,1
ENG108313-Proximity Sensor: min. length of Diagnosticimpuls,42 ms,1
ENG108314-Proximity Sensor: min. length of Entryimpuls,6200 µs,1
ENG108315-Proximity Sensor: min. length of Exitimpuls,24200 µs,1
ENG108316-Proximity sensor: min. tolerance data bit length,120 µs,1
ENG108317-Proximity Sensor: SP_X2,10 min,1
ENG108318-Proximity Sensor: SP_X3,1 ,1
ENG108319-Proximity Sensor: SP_X4,80 ,1
ENG108320-Proximity Sensor: SP_X5,1 ,1
ENG108321-Proximity Sensor: SP_X6,30 min,1
ENG108322-Proximity Sensor: SP_X7,1 ,1
ENG108323-Proximity Sensor: Time Power On,1960 ms,1
ENG123035-Proximity Sensor: Timervalue for ExitReverseOption,0 ms,1
ENG108325-Proximity sensor: turn-off limit from battery-manager,2 ,1
ENG108326-Proximity Sensor: upper limit intermission-length,10 ms,1
ENG120045-Reduced current for transponder-ID request,0 Step,1
ENG126939-rpm_threshold_engine_runnning,100 /min,1
ENG108575-Scan Procedure: current limiting on undervoltage at Go-protocol,5 Step,1
ENG108576-Scan Procedure: cycle convenience coverage limiting,65 ms,1
ENG108577-Scan Procedure: Number of Repeats,1 ,1
ENG108578-Scan Procedure: p_keyless_eventsuche_retries_pause,100 ms,1
ENG108579-Scan Procedure: Timeout Authentification Result,150 ms,1
ENG129017-Scan Procedure: timeout ID-transmitter ready-to-receive after LF-error Go,190 ms,1
ENG129018-Scan Procedure: timeout ID-transmitter ready-to-receive after LF-error Kombi,700 ms,1
ENG108582-Scan Procedure: Timeout LF Repetition,100 ms,1
ENG108585-ScanProcedure: Timeout Entry Response,260 ms,1
ENG108586-ScanProcedure: Timeout Response,100 ms,1
ENG126963-settime_trigger_entry_vehicle,500 ms,1
ENG126962-settime_trigger_exit_vehicle,500 ms,1
ENG129024-ENG120039-Sonstiges_byte1-Backdoor TSG,not activated ,1
ENG129024-ENG103075-Sonstiges_byte1-Battery manager mounted,activated ,1
ENG129024-ENG102728-Sonstiges_byte1-Diagnostic: service 86 - response on event,not activated ,1
ENG129024-ENG98656-Sonstiges_byte1-internal,not activated ,1
ENG129024-ENG102591-Sonstiges_byte1-Response extension for scan procedure,not activated ,1
ENG129024-ENG99430-Sonstiges_byte1-Scan Procedure: Timeoutcontrol active,activated ,1
ENG129024-ENG104010-Sonstiges_byte1-Use default antenna data,not activated ,1
ENG129025-ENG129137-sonstiges_byte2-interiorscan_clamp15_reach_trashhold,not activated ,1
ENG129025-ENG142122-sonstiges_byte2-sad_existing,not activated ,1
ENG129025-ENG142123-sonstiges_byte2-trunk_ecu_existing,not activated ,1
ENG129007-Speed_threshold_for_driving_cycle_detection,3.0 km/h,1
ENG129006-Speed_threshold_for_moving_vehicle_detection,1.0 km/h,1
ENG129008-Speed_threshold_for_terminal_15_emergency_shutoff,7.0 km/h,1
ENG109053-Standard dimming value ZAT,80 %,1
ENG126946-Terminal_S_Timeout,30 min,1
ENG102207-Time Sensor Power Off Group 2,3600 min,1
ENG129027-Time_frame_VIP_kick_forecast,5 ,1
ENG126942-time_to_drive_cycle_detection,1.00 s,1
ENG126947-time_to_ignore_ignition_trigger,35 s,1
ENG126954-time_to_ZAT_Open_circuit_detection,1000 ms,1
ENG126951-time_to_ZAT_Short_circuit_fault_detection,60 s,1
ENG126949-time_ZAT_actuation_detection,3000 ms,1
ENG126952-time_ZAT_lock_after emergency_shutoff,1000 ms,1
ENG126953-time_ZAT_lock_after_normal_shutoff,500 ms,1
ENG129009-Timeframe_request_immobilizer_terminal_approval,20000 ms,1
ENG129019-timeout_convenience_coverage_limiting,75 s,1
ENG129014-Timeout_trigger_terminal_deactivation_central_locking,1.00 s,1
ENG109974-Voltage monitoring: overvoltage Delta,500 mV,1
ENG109975-Voltage monitoring: overvoltage for KESSY ECU,16000 mV,1
ENG109976-Voltage monitoring: overvoltage for Keyless Go,27000 mV,1
ENG109977-Voltage monitoring: overvoltage Jumpstart 2 Delta,0 mV,1
ENG109978-Voltage monitoring: undervoltage Delta,500 mV,1
ENG109979-Voltage monitoring: undervoltage for KESSY ECU,9000 mV,1
ENG109980-Voltage monitoring: undervoltage for Keyless Go,6000 mV,1
ENG109981-Voltage monitoring: undervoltage Jumpstart 1 Delta,0 mV,1
ENG120047-ZAT init value,0 %,1
ENG110364-ZAT nominal voltage,13.0 V,1
ENG110365-ZAT post-carridge during clamp 15 off,10 min,1
ENG153750-ZAT_clamp58xt_signal_factor,0.200 ,1
ENG153751-ZAT_clamp58xt_signal_offset,3.0 ,1
ENG153752-ZAT_first_fall_time_high_low_state,900 ms,1
ENG153753-ZAT_first_rise_time_low_high_state,100 ms,1
ENG153754-ZAT_motor_signal_timer_1,3000 ms,1
ENG153755-ZAT_motor_signal_timer_2,3000 ms,1
ENG153756-ZAT_pwm_offset_1_lower_limit,5 %,1
ENG153757-ZAT_pwm_offset_2_lower_limit,10 %,1
ENG153758-ZAT_pwm_peak1_upper_limit,90 %,1
ENG153759-ZAT_pwm_peak2_upper_limit,100 %,1
ENG153760-ZAT_second_fall_time_high_low_state,2000 ms,1
Elapsed Time: 00:52
here is the original Adpmap from when i first got the car, will do a updated scan when i get the car back
David_GTi_700
C?ID=426963
;SW:3Q0-959-435-E   HW:3Q0-959-435-G ---  Acc/Start Auth.
;Component:VWKESSYMQB    037 0811, Coding:132C2C0723
;EV_KessyHellaMQBAB,004039,EV_KessyHellaMQBAB.rod
;Sunday,10,July,2022,18:00:35:56476
;VCID: 3C213F8C06E66E2BD37-8068
IDE10845-Control module rear lid opening: vehicle type,22 ,1
ENG129010-CAN_signal_transmitting_duration_of_comfort_switch_off,10.00 s,1
ENG129004-delay_time_Terminal_15_S_Shut_down_by_BEM,60.00 s,1
ENG123038-ENG129119-DeveloperCoding: Proximity Sensor-energized_doorhandles_at_stateKL15on_when_opening_door,activated ,1
ENG123038-ENG102252-DeveloperCoding: Proximity Sensor-Suppress fault manager entry "Falschverbau aktiv",activated ,1
ENG129029-ENG142128-Easy_close_alignment-max_threashold_reopen_EasyClose,10 %,9
ENG129029-ENG142129-Easy_close_alignment-max_time_reentry_EasyClose,7.00 s,9
ENG129029-ENG142130-Easy_close_alignment-min_rssi_values_hysteresis_EasyClose,20 ,9
ENG129029-ENG142126-Easy_close_alignment-Min_threashold_trunk,50 %,9
ENG129029-ENG129138-Easy_close_alignment-RSSI_ sample_rate,400 ms,9
ENG129028-ENG142124-Easy_close_detection_areas-Easy_close_antenna_current_step,04 ,5
ENG129028-ENG142125-Easy_close_detection_areas-Easy_close_open_door_antenna_current_step,02 ,5
ENG129028-ENG142032-Easy_close_detection_areas-Value_area_4,220 mV/m,5
ENG129028-ENG142033-Easy_close_detection_areas-Value_area_leaving_area,40 mV/m,5
ENG129023-ENG102581-internal_keyminder_byte2-Lock prevention tailgate,activated ,1
ENG129023-ENG101018-internal_keyminder_byte2-No locking with ID-transmitter last used interior,activated ,1
ENG129023-ENG103451-internal_keyminder_byte2-Re-open after passive comfort closing,activated ,1
ENG129023-ENG103237-internal_keyminder_byte2-Re-open tailgate,activated ,1
ENG129020-ENG99763-internal_passive_entry_exit_byte1-Passive Exit: access door not open,activated ,1
ENG129021-ENG155268-internal_passive_entry_exit_byte2-lf_shutdown_gotrigger,not activated ,1
ENG129021-ENG123039-internal_passive_entry_exit_byte2-Passive Entry Exit,activated ,1
ENG129021-ENG103620-internal_passive_entry_exit_byte2-Passive Entry Exit: retry with antennastep 1,activated ,1
ENG107595-MCTX settling phase,7 B,1
ENG126945-min_time_for_Terminal_50_request,200 ms,1
ENG108168-Passive Entry Exit: PARA_T_TIMOUT_PROXIMITY_ENTRY,220 ms,1
ENG129009-Timeframe_request_immobilizer_terminal_approval,10000 ms,1
Elapsed Time: 00:51
Finally got the car back, here is the requested Autoscan with the updated module
Spacewalker
Poland
C?ID=159607
Cuzoe
C?ID=279487
I didn't say I could help with this. My car has no keyless anything. In fact my remote fobs aren't even working right now 😂. My statement was just a general, from when it was stated that an auto-scan was not available.
And for what it's worth, these are not auto-scans... although they should be useful for anyone that is able to help.
Ad-map of the BCM would be helpful, lots of lock configuration channels there. Finally, why do you think the "short to ground" faults are incorrect?
Spacewalker
Poland
C?ID=159607
I did many kessy
full retrofit
and add just door handle
door handle is not a Space X technology , is just 4 wires
but can be lqdamage
if you see error = wrong connectionm, or faulty door handle
of course if you code proper door handle = front left / front right and you connect them to proper socket
because we dont know if error is just from one door handle , or from both, you can simple swap them
if all is good , - last chance is kessy module
David_GTi_700
C?ID=426963
Useful? - yes. But not enough to know how the TT-RS that @David_GTi_700 is asking about is equipped and configured, so we STILL need him to post an Auto-Scan.
Monday,11,July,2022,09:58:58:56476
VIN: WUAZZZFV7J1903538   License Plate: GV18DLO
Mileage: 22355km-13890mi   Repair Order:
Chassis Type: FV-AU37 (8S0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 22 2B 42 44 52 55 5F 65 6C
          A5
VIN: WUAZZZFV7J1903538   Mileage: 22355km-13890miles
Address 01: Engine (------DAZA)       Labels:. 07K-907-309-V1.clb
   Part No SW: 8S0 907 404 E    HW: 07K 907 309 E
   Component: R5 2.5l TFSI  X22 0005
   Revision: 53X22000    CVN: 09725145
   Coding: 1A250032242605032600
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM25TFS0118S0907404E 001005
   ROD: EV_ECM25TFS0118S0907404A.rod
   VCID: 3829239C32DE420B37F-806C
   VINID: 9E546AAAA5A61DA04900314320B8B549AD
Readiness: 1110 0000
   Part No SW: 0DL 300 043 T    HW: 0GC 927 711 G
   Component: TVS DQ500     H06 9999
   Revision: 00H06V07    CVN: 1B640D67
   Coding: 0018
   VCID: 3E25358410FA7C3BFD3-806A
   Part No SW: 8S0 907 379 J    HW: 8S0 907 379 J
   Component: ESC           H42 0050
   Revision: 00000000    Serial number: 61098000000281
   Coding: 99AAF08D7A9915AC409600670399960EB5990F5EA80200C06970AD
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 061007
   ROD: EV_Brake1UDSContiMK100IPB_061.rod
   VCID: 48C9535C423E328B47F-801C
   Part No SW: 3Q0 959 435 E    HW: 3Q0 959 435 G
   Component: VWKESSYMQB    037 0811
   Revision: 00037000    Serial number: 0473934032
   Coding: 132C2C0723
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_KessyHellaMQBAB 004039
   ROD: EV_KessyHellaMQBAB.rod
   Part No SW: 8S0 820 043     HW: 8S0 820 043
   Component: AC Automat    H05 0040
   Revision: 20010000    Serial number: 18200000009000
   Coding: 410050000011001100
   ASAM Dataset: EV_AirCondiVAPrehAU33x 003011
   ROD: EV_AirCondiVAPrehAU33x.rod
   VCID: 6C81CFCC36063EAB037-8038
   Humidity sensor: exterior:
   Rear A/C Control Head 1:
   Subsystem 2 - Part No SW: 8S0 820 373 A    HW: 8S0 820 373 A
   Component: E774 BuA_1  H07 0020
   Serial number: 00000000000000049647
   Rear A/C Control Head 2:
   Subsystem 3 - Part No SW: 8S0 820 359 A    HW: 8S0 820 359 A
   Component: E775 BuA_2  H07 0020
   Rear A/C Control Head 3:
   Subsystem 4 - Part No SW: 8S0 820 359     HW: 8S0 820 359
   Component: E776 BuA_3  H07 0020
   Rear A/C Control Head 4:
   Subsystem 5 - Part No SW: 8S0 820 359 B    HW: 8S0 820 359 B
   Component: E777 BuA_4  H07 0020
   Rear A/C Control Head 5:
   Subsystem 6 - Part No SW: 8S0 820 373 B    HW: 8S0 820 373 B
   Component: E778 BuA_5  H07 0020
   Part No SW: 5Q0 937 084 CP    HW: 5Q0 937 084 CF
   Component: BCM MQBAB M+  H36 0253
   Serial number: 01001814402460
   ROD: EV_BCMBOSCH_018.rod
   VCID: 0849935C02BEF28B87F-805C
   Subsystem 1 - Part No SW: 8S2 955 119 B    HW: 8S2 955 119 A  Labels: 5QX-955-119-V1.CLB
   Component: 43x RL 220218  038 0371
   Serial number: 00000001802190304633
   Coding: 1BC7F7
   Serial number: 63315380
   Coding: 00005D
   Serial number: 08 02 2018  00000369
   Subsystem 4 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY181032QES
   Serial number: 00000000000030145678
   Revision: --------    Serial number: 39361811702463
   Coding: 0070141051
   VCID: 43D344707B1811D392D-8016
   Part No SW: 5Q0 959 655 P    HW: 5Q0 959 655 P
   Component: AirbagVW20    010 0870
   Serial number: 003M7R02HYK3
   Coding: 88CCF0C00C8000005C5000CFC0C800000065
   VCID: 4DC76248AD5CD7A3749-8018
   Subsystem 1 - Part No SW: -----------    HW: 480 002 605 18
   Serial number: 35700000000DD261003A
   Subsystem 2 - Part No SW: -----------    HW: 480 002 605 18
   Serial number: 35800000000FC261003C
   Subsystem 3 - Part No SW: -----------    HW: 480 010 705 18
   Component: SideSensor_Dr  005 0108
   Serial number: 351001A0D8014D728FFK
   Subsystem 4 - Part No SW: -----------    HW: 480 400 604 18
   Serial number: 3550002BF252D861C037
   Subsystem 5 - Part No SW: -----------    HW: 480 401 603 18
   Serial number: 3560002C925325B4509/
   Subsystem 6 - Part No SW: -----------    HW: 480 402 505 18
   Component: PedP_Sensor_C  004 6149
   Serial number: 23000010C2AE74C25592
   Subsystem 7 - Part No SW: -----------    HW: 480 001 805 18
   Serial number: I0M0000000003614AF2
   Subsystem 8 - Part No SW: -----------    HW: 480 001 805 18
   Serial number: I0N0000000062614AF21
   Part No SW: 8S0 907 129 BJ    HW: 8S0 907 129 BJ
   Component: Lenks. Modul  H07 0150
   Revision: --------    Serial number: 91335REF00141
   Coding: 281C
   ASAM Dataset: EV_SMLSKLOMQB 050001
   ROD: EV_SMLSKLOMQB_050.rod
   VCID: 035384703B98D1D3D2D-8056
   Part No SW: 8S0 920 790 C    HW: 8S0 920 790 C
   Component: FBenRDW       H42 0326
   Coding: 202D10D068868E000122EEC49000801000000000
   ASAM Dataset: EV_DashBoardBOSCHAU33X 001027
   ROD: EV_DashBoardBOSCHAU33X.rod
   VCID: 392F269809D45B03C81-806C
9456128 - Engine Control Module (ECM) not authorized
          B104A 00 [008] - -
                    Mileage: 22355 km
                    Date: 2022.07.11
                    Time: 09:55:39
   Part No SW: 8S0 907 468 G    HW: 8S0 907 468 E
   Component: GW MQB TT3    022 0323
   Serial number: 26041810802787
   Coding: 030100042F025D004B008068380B00000000000000000000000000000001
   GVL: 01DC3C0000000600408C10000002C80000000000000000000000000000000000
   ASAM Dataset: EV_GatewContiAU33X 013005
   ROD: EV_GatewContiAU33X_013.rod
   VCID: 44D1476C7E1616EBAB7-8010
   Generator:
   Subsystem 2 - Part No SW: 8S0 951 523 K    HW: 8S0 951 523 K
   Component: J453 MFL  H01 0002
   Serial number: 20180515072244 00560
   Subsystem 3 - Part No SW: 8W0 915 181     HW: 8W0 915 181
   Serial number: 9179107204
   Part No SW: 0CQ 907 554 K    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7762
   Serial number: HA1-00009.04.18
   Coding: 0701
   Serial number: 18000124700017
   Coding: 0900000000000000
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 333314B02BB8A15302D-8066
   Serial number: 160518EEG08041
   Coding: 001E42224001040100001402
   Part No SW: 3Q0 909 144 L    HW: 3Q0 909 144 L
   Component: EPS_MQB_ZFLS  507 5081
   Coding: 91170000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 3B233C9003E86913DAD-806E
   Serial number: 280518EER03324
   Coding: 001E42224C01040100001402
   Shop #: WSC 12345 123 61029
   VCID: 42DD4174640218DB99B-8016
   Part No SW: 4H4 907 357 G    HW: 7P6 907 357 B
   Component: MxB-ECU       001 0115
   Coding: 03EE00102B230200
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005012
   VCID: 36352DA438CAB47B253-8062
   Coding: E01800
   Coding: E01800
   Subsystem 3 - Part No SW: 8S0 941 329     HW: 8S0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H02 S002
   Coding: E01800
   Subsystem 4 - Part No SW: 8S0 941 329     HW: 8S0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H02 S002
   Coding: E01800
   Part No SW: 8S0 035 021 M    HW: 8S0 035 021 E
   Component: MU-H-LND-EU   054 1339
   Serial number: A710E0JS007786
   Coding: 01336401FF08000011111101000A00102F0000E300700000DE
   Shop #: WSC 40627 005 1048576
   Subsystem 1 - Part No SW: V03 959 802 TP    HW: -----------
   Component: ECE 2022/2023  --- 0197
   Subsystem 2 - Part No SW: 8S0 919 614 M    HW: 8S0 919 614 M
   Component: ControlUnit_H  H30 0206
   Serial number: APVAK120031800010025
   Compact disc data bank:
   Component: Gracenote2  --- 1016
   Serial number: 40000000368227
   ROD: EV_RDKBERU30_005.rod
   VCID: 343117AC2EB6A66B1B7-8060
8398082 - Tire Pressure Sensor(s)
          C111A 31 [009] - No Signal
                    Reset counter: 61
                    Mileage: 22160 km
                    Date: 2022.05.30
                    Time: 19:58:19
                    Vehicle speed: 120 km/h
                    Outside temperature: 10.5 °C
                    Reception level antenna 1: 470 mV
                    Offset level antenna 1: 270 mV
   Coding: 0237060100002001000040
10489856 - No Basic Setting
          B2010 00 [009] - -
                    Reset counter: 82
                    Mileage: 22355 km
                    Date: 2022.07.11
                    Time: 09:55:27
                    passive
   Part No SW: 5Q0 980 653 G    HW: 5Q0 980 653
   Component: MQB_MFK       H07 0060
   Serial number: 10000643958
   Coding: 0101010001010305000501000000010100
   ROD: EV_MFKBoschAU370.rod
End----------(Elapsed Time: 01:29, VBatt start/end: 12.0V/12.0V)-----------
David_GTi_700
C?ID=426963
The short to ground faults, in my mind, would indicate either a faulty sensor or broken wire/shorted cable. However when logging the touch proxy sensors in the door handle i can see the count increasing.
this tells me that at least the wiring is ok, it may however be a fault in the door handle still.
Cuzoe
C?ID=279487
If I had a short to ground fault I could not conclude that the wiring was okay. But I did have a look at the KESSY handle wiring (for an Mk7 Golf, but probably quite similar) and there are 4 wires to the handle...
Two for the touch sensor, and two for the antenna in the handle.
Since the touch count increases you could reasonably conclude those two wires are good. That leaves the other two wires to be checked (for resistance, proper termination/pin location, and for shorts). Whether it's the wiring or handle(s) causing the faults... I would suspect the problem is with the antenna portion and it needs to be solved.
All that said, the scan you posted doesn't have short to ground faults. Where are you seeing those? Or have they been resolved? Or are the faults intermittent and this scan taken right after clearing all faults?
Adaptation map of 09-Cemtral Electronics (BCM) is still needed.
David_GTi_700
C?ID=426963
The TT/A3 use a 2 pin door handle instead of 4. This is what confuses me considering its 1 signaland 1 GND it cant be a cable short.
David_GTi_700
C?ID=426963
BCM Admap
;SW:5Q0-937-084-CP   HW:5Q0-937-084-CF ---  Cent. Elect.
;Component:BCM MQBAB M+  H36 0253, Coding:000000000000000000000000000000000000000000000000000000000000
;EV_BCMMQB,018001,EV_BCMBOSCH_018.rod
;Sunday,24,April,2022,19:28:22:56476
;VCID: 0849935C02BEF28B87F-805C
IDE01550-Service position,163.999837 °,2
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,DELAY ,10
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,normal ,10
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,not active ,10
IDE02488-Anti-theft system interior monitoring,100 %,1
IDE02711-ENG112304-Rear wiper-Heckwischer,not installed ,8
IDE02711-ENG116695-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,3 s,8
IDE02711-ENG116696-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,1 s,8
IDE02711-ENG116694-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,5 s,8
IDE02711-ENG116693-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,5 s,8
IDE02711-ENG116689-Rear wiper-Menuesteuerung Komfortwischen HW,not active ,8
IDE02711-ENG116691-Rear wiper-Traenenwischen Heck,not active ,8
IDE02711-ENG154831-Rear wiper-Zeit_wasch_min_heck,0 ms,8
IDE03638-IDE04231-Stationary cornering lamp-Steering wheel angle: offset,-0.3 °,16
IDE03638-ENG116677-Stationary cornering lamp-Abdimmgeschwindigkeit,50.0 %/s,16
IDE03638-ENG116673-Stationary cornering lamp-bei Rueckwaertsfahrt,OFF ,16
IDE03638-ENG116675-Stationary cornering lamp-Lower speed threshold,0.0 km/h,16
IDE03638-ENG116682-Stationary cornering lamp-Maximaltemperatur,100.0 °C,16
IDE03638-ENG116679-Stationary cornering lamp-obere Grenztemperatur,95.0 °C,16
IDE03638-ENG116681-Stationary cornering lamp-Oberer Lenkradwinkel,90 °,16
IDE03638-ENG116680-Stationary cornering lamp-untere Grenztemperatur,80.0 °C,16
IDE03638-ENG116678-Stationary cornering lamp-Unterer Lenkradwinkel,30 °,16
IDE03638-ENG116676-Stationary cornering lamp-Upper speed threshold,32.0 km/h,16
IDE03638-ENG116674-Stationary cornering lamp-Vorschrift,OFF ,16
IDE03638-ENG115830-Stationary cornering lamp-Zeitwert Einschaltzeit Abbiegelicht,15 min,16
IDE03787-Activate left/right hand drive switch-over,No_Menue ,1
IDE04927-IDE01446-Window heater-Running time of heated front window,600 s,11
IDE04927-ENG126845-Window heater-FSH Automatik,not active ,11
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,not active ,11
IDE04928-MAS01577-Anti-theft protection-Parking heater,not installed ,8
IDE04928-ENG115867-Anti-theft protection-Akustischer Alarm Signalhorn,not active ,8
IDE04928-ENG115864-Anti-theft protection-Alarmsignal,frequency modulated ,8
IDE04928-ENG141960-Anti-theft protection-Anti-theft alarm system,active ,8
IDE04928-ENG154588-Anti-theft protection-Deaktivierung DWA-Sensoren via Doppelklick,not_active ,8
IDE04928-ENG154589-Anti-theft protection-Deaktivierung_DWA_Sensoren_HMI,not_active ,8
IDE04928-ENG115865-Anti-theft protection-DWA Alarmverzoegerung,not active ,8
IDE04928-ENG115812-Anti-theft protection-DWA Camper Modus,not active ,8
IDE04928-ENG142007-Anti-theft protection-DWA_Einfachhorn_oder_Sounder,Sounder_verbaut ,8
IDE04928-ENG141961-Anti-theft protection-Heckscheibenbruchsensor,installed ,8
IDE04928-ENG142006-Anti-theft protection-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet,No ,8
IDE04928-ENG142249-Anti-theft protection-OBD Alarm,activ ,8
IDE04928-ENG154722-Anti-theft protection-RHF_Panikalarm,not_active ,8
IDE04928-ENG142009-Anti-theft protection-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv),No ,8
IDE04928-ENG142010-Anti-theft protection-Sensor_fuer_Innenraumueberwachung,Yes ,8
IDE04928-ENG115866-Anti-theft protection-Sirenen Alarmzahl,10 Alarme ,8
IDE04928-ENG142008-Anti-theft protection-tilt_sensor,Yes ,8
IDE04928-ENG126842-Anti-theft protection-Ueberwachung Innenentriegelungshebel,active ,8
IDE04928-ENG115868-Anti-theft protection-Verzoegerung Panikalarm,keine verzoegerung ,8
IDE05145-Light configuration,21 34 00 14 02 00 7F 03 00 00 00 00 00 00 00 00 21 3E 00 15 04 00 7F 05 00 00 00 00 00 00 00 00 04 48 00 4A 08 09 1C 1E 00 1C 14 00 64 06 00 80 04 4C 00 4C 08 0A 1C 1E 00 1C 14 00 64 07 00 80 01 48 00 49 14 08 7F 1E 09 7F 00 00 00 06 00 80 01 4C 00 4B 14 08 7F 1E 0A 7F 00 00 00 07 00 80 05 36 00 1A 0B 00 7F 1E 00 7F 00 00 00 00 00 00 05 40 00 1B 0C 00 7F 1E 00 7F 00 00 00 00 00 00 05 36 00 5D 28 00 7F 1E 00 7F 00 00 00 00 00 00 05 40 00 5E 28 00 7F 1E 00 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 00 00 62 3F 00 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,224
IDE05822-Anti-theft alarm system vehicle inclination sensor,100 %,1
IDE05823-DWA Interior monitoring parameter set,01 0A 08 00 43 63 0A C8 01 14 0A 03 81 33 0C 00 00 00 01 CD 46 26 00 0F 1D 00 85 0F 39 F7 24 19 45 31 57 9B 25 44 3F 3A 69 35 95 18 09 A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 29 0F E3 31 87 9B 05 34 3F 3A 69 58 03 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 29 19 45 31 77 9B 05 24 3F 3A 69 47 03 08 09 A3 04 23 15 4A 16 0A 16 1F 88 0B 28 51 32 0C 61 31 5A 94 05 24 8F FD 57 45 02 14 05 A2 05 64 26 26 15 0C 12 18 86 09 30 33 27 19 45 31 57 9B 25 24 0C FA 0A 34 95 18 09 A3 21 03 00 02 02 02 02 02 02 91 20 61 26 41 ,172
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s,30
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,20.00 °C,30
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,18.00 °C,30
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,20.00 °C,30
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,18.00 °C,30
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,32.00 °C,30
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,30.00 °C,30
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,32.00 °C,30
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,30.00 °C,30
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,45.00 °C,30
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,43.00 °C,30
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,45.00 °C,30
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,43.00 °C,30
IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI,Sollspannungsanforderung 14.7 ,30
IDE06089-ENG154785-Seat heater level current consumption allocation-Spannungsoffset SIH_75,15.7 V,30
IDE06507-MAS13129-Button in center console-Function of button 2,Offroad ,8
IDE06507-MAS13132-Button in center console-Function of button 3,NOT-DEFINED ,8
IDE06507-ENG140243-Button in center console-Zusatzcodierung Fahrprofiltaster hat keine LED,LED not installed ,8
IDE07007-ENG142253-Air conditioning/heating function via remote control-Abbruch_d_Warnblinker_moeglich,active ,8
IDE07007-ENG142252-Air conditioning/heating function via remote control-Abbruch_Hupen_RSt,not active ,8
IDE07007-ENG142255-Air conditioning/heating function via remote control-Aktivierung_Drehzahlanzeige,active ,8
IDE07007-ENG142254-Air conditioning/heating function via remote control-Kombi_Fahrerhinweis_m_Akustik,active ,8
IDE07356-Position during interval mode,41.494464 °,2
IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Ein,not active ,6
IDE08786-ENG124476-Assistance light functions-Sunlight photo sensor,not installed ,9
IDE09731-ENG154511-Int. light: 2nd generation-Ambiente_Fahrprofil_Individual,2 ,19
IDE09731-ENG154512-Int. light: 2nd generation-Ambiente_Farbliste_HMI_mit_Farbtransformation,not active ,19
IDE09731-ENG154513-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung,not active ,19
IDE09731-ENG154514-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung_Status_hmi_default,not active ,19
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit,0.00 s,19
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,0 ,19
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2,0 ,19
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,0 ,19
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,0 %,19
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,0 ,19
IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum,0 %,19
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole,0 %,19
IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer,0 %,19
IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn,0 %,19
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,active ,19
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen,not active ,19
IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschalten,not active ,19
IDE09731-ENG98648-Int. light: 2nd generation-Interior lighting,Keine_Spannungsanforderung ,19
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig,not active ,19
IDE09732-ENG154509-Interior light: light configuration-Ambience_light_colorlist_default,0 ,5
IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI,not active ,5
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus,not active ,5
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung,installed ,5
IDE09732-ENG114629-Interior light: light configuration-Footwell lighting,installed ,5
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,25 %,17
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,25 %,17
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,58 %,17
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,53 %,17
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,58 %,17
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,53 %,17
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,85 %,17
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,80 %,17
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,85 %,17
IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbar,not installed ,17
IDE10298-Alternating park position 1,29.999970 °,2
IDE10299-Alternating park position 2,33.494472 °,2
IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach,1.00 ,256
IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel,1.00 ,256
IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer,1.00 ,256
IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI,00000000  ,256
IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2,00000000  ,256
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2,00000000  ,256
IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach,100 %,256
IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel,100 %,256
IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach,100 %,256
IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel,100 %,256
IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach,100 %,256
IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel,100 %,256
IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach,100 %,256
IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum,100 %,256
IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel,100 %,256
IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren,100 %,256
IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach,100 %,256
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum,100 %,256
IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel,100 %,256
IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren,100 %,256
IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach,100 %,256
IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum,100 %,256
IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel,100 %,256
IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren,100 %,256
IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach,126 %,256
IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum,100 %,256
IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren,100 %,256
IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach,100 %,256
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum,100 %,256
IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel,100 %,256
IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren,100 %,256
IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach,100 %,256
IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel,100 %,256
IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum,100 %,256
IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren,100 %,256
IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach,100 %,256
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum,100 %,256
IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel,100 %,256
IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren,100 %,256
IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach,100 %,256
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum,100 %,256
IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel,100 %,256
IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren,100 %,256
IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum,0.0 s,256
IDE11714-ENG126827-Ambient light color list-Blauwert Farbe 1,0 ,30
IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10,0 ,30
IDE11714-ENG126830-Ambient light color list-Blauwert Farbe 2,0 ,30
IDE11714-ENG126833-Ambient light color list-Blauwert Farbe 3,0 ,30
IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4,0 ,30
IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5,0 ,30
IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6,0 ,30
IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8,0 ,30
IDE11714-ENG126826-Ambient light color list-Gruenwert Farbe 1,0 ,30
IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10,0 ,30
IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe 2,0 ,30
IDE11714-ENG126832-Ambient light color list-Gruenwert Farbe 3,0 ,30
IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5,0 ,30
IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6,0 ,30
IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7,0 ,30
IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8,0 ,30
IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9,0 ,30
IDE11714-ENG126825-Ambient light color list-Rotwert Farbe 1,0 ,30
IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10,0 ,30
IDE11714-ENG126828-Ambient light color list-Rotwert Farbe 2,0 ,30
IDE11714-ENG126831-Ambient light color list-Rotwert Farbe 3,0 ,30
IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4,0 ,30
IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5,0 ,30
IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6,0 ,30
IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8,0 ,30
IDE11944-ENG116655-Keyless access and start authorization-Kessy Komfortbedienung Reichweitenbegrenzung,active ,3
IDE11944-ENG116626-Keyless access and start authorization-Oeffnung Heckdeckel bei Wiederentriegelung,active ,3
IDE12412-ENG154557-LIN Ambient light color list-Blauwert_Farbe_3_lin,0 ,30
IDE12412-ENG154560-LIN Ambient light color list-Blauwert_Farbe_4_lin,0 ,30
IDE12412-ENG154561-LIN Ambient light color list-Blauwert_Farbe_5_lin,0 ,30
IDE12412-ENG154562-LIN Ambient light color list-Blauwert_Farbe_6_lin,0 ,30
IDE12412-ENG154656-LIN Ambient light color list-Gruenwert_Farbe_2_lin,0 ,30
IDE12412-ENG154676-LIN Ambient light color list-Gruenwert_Farbe_3_lin,0 ,30
IDE12412-ENG154679-LIN Ambient light color list-Gruenwert_Farbe_4_lin,0 ,30
IDE12412-ENG154680-LIN Ambient light color list-Gruenwert_Farbe_5_lin,0 ,30
IDE12412-ENG154681-LIN Ambient light color list-Gruenwert_Farbe_6_lin,0 ,30
IDE12412-ENG154682-LIN Ambient light color list-Gruenwert_Farbe_7_lin,0 ,30
IDE12412-ENG154683-LIN Ambient light color list-Gruenwert_Farbe_8_lin,0 ,30
IDE12412-ENG154733-LIN Ambient light color list-Rotwert_Farbe_1_lin,0 ,30
IDE12412-ENG154744-LIN Ambient light color list-Rotwert_Farbe_2_lin,0 ,30
IDE12412-ENG154767-LIN Ambient light color list-Rotwert_Farbe_4_lin,0 ,30
IDE12412-ENG154768-LIN Ambient light color list-Rotwert_Farbe_5_lin,0 ,30
IDE12412-ENG154769-LIN Ambient light color list-Rotwert_Farbe_6_lin,0 ,30
IDE12412-ENG154771-LIN Ambient light color list-Rotwert_Farbe_8_lin,0 ,30
MAS05055-lower turn position,42.494463 °,2
MAS05056-upper turn position,171.494335 °,2
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle,1000 lx,24
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell,4000 lx,24
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung,4500 mV,24
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung,2000 mV,24
ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,not active ,4
ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,not active ,4
ENG141683-ENG141975-Allwetterlicht_Spoiler-tt_spoiler,feststehender Spoiler ,4
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1,0.00 ,30
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10,0.00 ,30
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11,0.00 ,30
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12,0.00 ,30
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13,0.00 ,30
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14,0.00 ,30
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15,0.00 ,30
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2,0.00 ,30
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3,0.00 ,30
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4,0.00 ,30
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5,0.00 ,30
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6,0.00 ,30
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7,0.00 ,30
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8,0.00 ,30
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9,0.00 ,30
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1,NOT-DEFINED ,30
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10,NOT-DEFINED ,30
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11,NOT-DEFINED ,30
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12,NOT-DEFINED ,30
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13,NOT-DEFINED ,30
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14,NOT-DEFINED ,30
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15,NOT-DEFINED ,30
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2,NOT-DEFINED ,30
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3,NOT-DEFINED ,30
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4,NOT-DEFINED ,30
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5,NOT-DEFINED ,30
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6,NOT-DEFINED ,30
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7,NOT-DEFINED ,30
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8,NOT-DEFINED ,30
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9,NOT-DEFINED ,30
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1,00 ,60
ENG153712-ENG154510-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Ambiente,Sollspannungsanforderung 13.5 ,23
ENG153712-ENG154603-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_1,1 ,23
ENG153712-ENG154604-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_10,1 ,23
ENG153712-ENG154611-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_3,1 ,23
ENG153712-ENG154612-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_4,1 ,23
ENG153712-ENG154613-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_5,1 ,23
ENG141649-ENG122212-Außenlicht_Blinker-ABBA_Blinken,active ,10
ENG141649-ENG133379-Außenlicht_Blinker-Abbruch Komfortblinken,not active ,10
ENG141649-ENG122207-Außenlicht_Blinker-DWA_Alarm_Blinken,active ,10
ENG141649-ENG122206-Außenlicht_Blinker-DWA_Schaerfungsquittung,active ,10
ENG141649-ENG121967-Außenlicht_Blinker-Panic flashing,active ,10
ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links,active ,10
ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts,active ,10
ENG141649-ENG122201-Außenlicht_Blinker-Schluessel_Anlern_Blinken,active ,10
ENG141649-ENG121968-Außenlicht_Blinker-Taxi alarm flashing,active ,10
ENG141649-ENG126629-Außenlicht_Blinker-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken,active ,10
ENG141649-ENG122202-Außenlicht_Blinker-UGDO_ Anlern_Blinken,active ,10
ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS,active ,10
ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN,active ,10
ENG141649-ENG122204-Außenlicht_Blinker-ZV_Blinken_auf,active ,10
ENG141649-ENG122203-Außenlicht_Blinker-ZV_Blinken_zu,active ,10
ENG141647-ENG115833-Außenlicht_Front-Fahrlicht bei Tag,Daytime running lamps ,9
ENG141647-ENG142193-Außenlicht_Front-Geschwindigkeitsabhaengiges TFL,4 km/h,9
ENG141647-ENG115832-Außenlicht_Front-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,active ,9
ENG141647-ENG116593-Außenlicht_Front-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,active ,9
ENG141648-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit,60 km/h,5
ENG141648-ENG115831-Aussenlicht_Heck-Schlusslicht mit Bremslichtfunktion,active ,5
ENG141656-ENG142020-Außenlicht_uebergreifend-All-weather light,installed ,18
ENG141656-ENG142188-Außenlicht_uebergreifend-bewusstes Standlicht,bewusste Aktivierung Fahrer Dauerhaft ,18
ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach,not active ,18
ENG141656-ENG137034-Außenlicht_uebergreifend-Faktor fuer Verfuegbarkeitstimer,Faktor fuer x1 Stunden ,18
ENG141656-ENG154177-Außenlicht_uebergreifend-Fog lamp,Keine_Spannungsanforderung ,18
ENG141656-ENG116608-Außenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung,6400 lx,18
ENG141656-ENG115858-Außenlicht_uebergreifend-Kontrollleuchte fuer Begrenzungslicht,separate ,18
ENG141656-ENG141989-Außenlicht_uebergreifend-Lichtdrehschalter (LDS),LIN ,18
ENG141656-ENG142034-Außenlicht_uebergreifend-Light_Control_Module,not installed ,18
ENG141656-ENG115863-Außenlicht_uebergreifend-Menueeinstellung CHO LHO,Menuesteuerung aktivieren ,18
ENG141656-ENG116603-Außenlicht_uebergreifend-Menueeinstellung Cominghome,20 seconds ,18
ENG141656-ENG116607-Außenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP,60 seconds ,18
ENG141656-ENG133383-Außenlicht_uebergreifend-Standlicht-Verfügbarkeit,8 s,18
ENG141656-ENG154174-Außenlicht_uebergreifend-Turn signal lamp,Keine_Spannungsanforderung ,18
ENG122925-DWA_Interior_Monitoring_Data_Set_Development,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,150
ENG122934-erase_error_table,00 00 00 ,3
ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung,AFS: Fernlicht ueber AFS ,6
ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent,not installed ,6
ENG141650-ENG116641-Fernlicht_assistent-Menuesteuerung Fernlichtassistent Werkseinstellung,not installed ,6
ENG141682-ENG115835-Front_wiper-Adaptives Nachwischen bei SRA,active ,6
ENG141682-ENG142250-Front_wiper-Anfahrzeit_servicestellung,500 ms,6
ENG141682-ENG116614-Front_wiper-Frontwischer Referenzlauf,not active ,6
ENG141682-ENG154706-Front_wiper-Mindestwaschzeit_Frontwischer,2000 ms,6
ENG141682-ENG116618-Front_wiper-Traenenwischen Front Status,active ,6
ENG141682-ENG115770-Front_wiper-Variable Regensensoraktivierung,not active ,6
ENG99457-ENG117394-Head area heater-blower_speed,0 ,2
ENG99457-ENG98971-Head area heater-Temperature,-3 ,2
ENG141660-ENG115658-Kennlinie_sLWR_Soll-x0,-0.00 %,30
ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1,-0.50 %,30
ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2,-1.00 %,30
ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3,-1.50 %,30
ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4,-2.00 %,30
ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5,-2.50 %,30
ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6,-3.00 %,30
ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7,-3.50 ,30
ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8,-4.00 %,30
ENG141660-ENG115663-Kennlinie_sLWR_Soll-x9,-4.50 %,30
ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0,100.0 %,30
ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1,90.0 %,30
ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2,80.0 %,30
ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3,70.0 %,30
ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4,60.0 %,30
ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5,50.0 %,30
ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6,40.0 %,30
ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7,30.0 %,30
ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8,15.0 %,30
ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9,0.0 %,30
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0,127 ,16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0,14 ,16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0,34 ,16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0,33 - LED-Modul Blinkleuchten ,16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0,Blinken links Hellphase ,16
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0,Blinken links Dunkelphase ,16
ENG141657-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15,63 ,16
ENG141657-ENG116160-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 15,Unknown (76),16
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11,127 ,16
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11,62 ,16
ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11,2 - Shutter: Diagnosesensierung für 'LED low' ,16
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11,Aktive Blinkfunktion hat ein auf 1 gesetztes zugeordnetes Bit in pa_dynamisch_blinken ,16
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12,0 ,16
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12,00 ,16
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12,00 ,16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,not active ,16
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12,not active ,16
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13,0 ,16
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13,00 ,16
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13,00 ,16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,not active ,16
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13,not active ,16
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16,minimize ,16
ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16,127 ,16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,0B ,16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,00 ,16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,36 - LED Kleinleistung ,16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,Klemme 30G ,16
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16,Heckdeckel geschlossen ,16
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16,Klemme 15 mit Nachlauf bis Fahrzeugstillstand ,16
ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16,Luggage compartment light ,16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,100 ,16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,04 ,16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,00 ,16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,46 - LED Kleinleistung ,16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,Ambientelicht 2 ,16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,127 ,16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,33 - LED-Modul Blinkleuchten ,16
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18,Blinken links Dunkelphase ,16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,127 ,16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,33 - LED-Modul Blinkleuchten ,16
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19,Blinken rechts Dunkelphase ,16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,127 ,16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,15 ,16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1,3E ,16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,33 - LED-Modul Blinkleuchten ,16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,Blinken rechts Hellphase ,16
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1,Blinken rechts Dunkelphase ,16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,127 ,16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,34 - LED Bremsleuchten ,16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20,Brake lamp ,16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,127 ,16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,34 - LED Bremsleuchten ,16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21,Brake lamp ,16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,100 ,16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,100 ,16
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23,100 ,16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,40 - allgemeine LED ,16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,Coming Home oder Leaving Home aktiv ,16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23,Daytime running lamps ,16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24,100 ,16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,100 ,16
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24,100 ,16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,40 - allgemeine LED ,16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,Coming Home oder Leaving Home aktiv ,16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,Parking light right ,16
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24,Daytime running lamps ,16
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25,100 ,16
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25,100 ,16
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25,Daytime running lamps ,16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,60 ,16
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26,100 ,16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,43 - allgemeine LED ,16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Brake lamp ,16
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26,Nebelschlusslicht wenn kein Anhaenger gesteckt ,16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,60 ,16
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27,100 ,16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,2F ,16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,1C ,16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,43 - allgemeine LED ,16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,Brake lamp ,16
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27,Nebelschlusslicht wenn kein Anhaenger gesteckt ,16
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28,100 ,16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,40 - allgemeine LED ,16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,40 - allgemeine LED ,16
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2,minimize ,16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,28 ,16
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2,28 ,16
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2,100 ,16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2,4A ,16
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2,48 ,16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,4 - LED Tagfahrlichtmodul Signal ,16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2,Coming Home oder Leaving Home aktiv ,16
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2,Daytime running lamps ,16
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2,Blinken links aktiv (beide Phasen) ,16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,46 - LED Kleinleistung ,16
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31,100 ,16
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32,100 ,16
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32,Ambientelicht 2 ,16
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33,100 ,16
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33,Ambientelicht 3 ,16
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34,100 ,16
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34,Ambientelicht 4 ,16
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3,minimize ,16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,28 ,16
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3,28 ,16
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3,100 ,16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3,4C ,16
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3,4C ,16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,4 - LED Tagfahrlichtmodul Signal ,16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3,Parking light right ,16
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3,Coming Home oder Leaving Home aktiv ,16
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3,Daytime running lamps ,16
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3,Blinken rechts aktiv (beide Phasen) ,16
ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4,minimize ,16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,127 ,16
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4,127 ,16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4,49 ,16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4,48 ,16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,1 - LED Tagfahrlichtmodul Versorgung ,16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,Daytime running lamps ,16
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4,Coming Home oder Leaving Home aktiv ,16
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4,Blinken links aktiv (beide Phasen) ,16
ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5,minimize ,16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,127 ,16
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5,127 ,16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5,4B ,16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5,4C ,16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,1 - LED Tagfahrlichtmodul Versorgung ,16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,Daytime running lamps ,16
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5,Coming Home oder Leaving Home aktiv ,16
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5,Parking light right ,16
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5,Blinken rechts aktiv (beide Phasen) ,16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,5D ,16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,36 ,16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,5 - LED Abblendlicht ,16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8,Klemme 15 mit Nachlauf bis Fahrzeugstillstand ,16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,Coming Home oder Leaving Home aktiv ,16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,5E ,16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,40 ,16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,5 - LED Abblendlicht ,16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9,Klemme 15 mit Nachlauf bis Fahrzeugstillstand ,16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,Coming Home oder Leaving Home aktiv ,16
ENG141661-Leuchtenkonfiguration_Aussenlich_Heck,21 08 00 16 02 00 7F 03 00 00 00 00 00 00 00 00 21 18 00 18 04 00 7F 05 00 00 00 00 00 00 00 00 22 09 00 2B 18 00 7F 00 00 00 00 00 00 00 00 00 22 19 00 2D 18 00 7F 00 00 00 00 00 00 00 00 00 2A 29 00 2C 18 00 64 00 00 00 00 00 00 00 00 00 28 0A 00 29 08 1E 64 09 00 64 14 00 64 00 00 00 28 1A 00 2A 08 1E 64 0A 00 64 14 00 64 00 00 00 2B 28 00 30 08 1E 64 14 00 64 00 00 00 00 00 00 2B 0C 00 2E 18 00 3C 00 00 00 1A 00 64 00 00 00 2B 1C 00 2F 18 00 3C 00 00 00 1A 00 64 00 00 00 28 0B 00 31 19 00 64 00 00 00 00 00 00 00 00 00 28 1B 00 32 19 00 64 00 00 00 00 00 00 00 00 00 ,192
ENG141662-Leuchtenkonfiguration_Sonstiges,24 00 00 0B 25 00 7F 22 28 80 00 00 00 2A 00 7F 2E 00 00 04 2E 00 64 00 00 00 00 00 00 00 00 00 2E 00 00 02 2B 00 64 00 00 00 00 00 00 00 00 00 00 00 00 03 2D 00 64 00 00 00 00 00 00 00 00 00 00 00 00 04 2E 00 64 00 00 00 00 00 00 00 00 00 00 00 00 05 2F 00 64 00 00 00 00 00 00 00 00 00 00 00 00 06 30 00 64 00 00 00 00 00 00 00 00 00 29 00 00 63 4C 00 64 00 00 00 00 00 00 00 00 00 ,128
ENG141658-ENG142219-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges,2700 mm,62
ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze,90.0 %,62
ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze,10.0 %,62
ENG141658-ENG154591-Leuchtweitenregulierung-Delay_DC_Motor_Versorgung,-127.0 ms,62
ENG141658-ENG142214-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1,5.00 mm/%,62
ENG141658-ENG142216-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2,5.00 mm/%,62
ENG141658-ENG154599-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_3,5.00 mm/%,62
ENG141658-ENG142213-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1,3.00 mm/%,62
ENG141658-ENG142215-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2,3.00 mm/%,62
ENG141658-ENG154600-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_3,3.00 mm/%,62
ENG141658-ENG142204-Leuchtweitenregulierung-Fail_Safe_sLWR,100.0 %,62
ENG141658-ENG142223-Leuchtweitenregulierung-fFiltEinf,0.03 Hz,62
ENG141658-ENG142212-Leuchtweitenregulierung-Lineare_Abbildung,normal ,62
ENG141658-ENG142226-Leuchtweitenregulierung-lwr_pwm_obere_schwelle,47.5 %,62
ENG141658-ENG142225-Leuchtweitenregulierung-lwr_pwm_untere_schwelle,12.5 %,62
ENG141658-ENG142227-Leuchtweitenregulierung-max_v_slwr,0 km/h,62
ENG141658-ENG142224-Leuchtweitenregulierung-pa_fFiltSwNeigung,0.03 Hz,62
ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed,not installed ,62
ENG141658-ENG142199-Leuchtweitenregulierung-sLWR_bei_Abblendlicht,not active ,62
ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese,20.0 %,62
ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad,5.0 %/s,62
ENG141658-ENG142206-Leuchtweitenregulierung-sLWR_Touristenlicht,-100.0 %,62
ENG141658-ENG142205-Leuchtweitenregulierung-Zyklus_sLWR,10.00 s,62
ENG141659-ENG115658-lwr_ofs_RSw_Ah1S-x0,-3.71 %,20
ENG141659-ENG101574-lwr_ofs_RSw_Ah1S-X1,-2.96 %,20
ENG141659-ENG99557-lwr_ofs_RSw_Ah1S-X2,-2.04 %,20
ENG141659-ENG102140-lwr_ofs_RSw_Ah1S-X3,-1.48 %,20
ENG141659-ENG102936-lwr_ofs_RSw_Ah1S-X4,-0.37 %,20
ENG141659-ENG115659-lwr_ofs_RSw_Ah1S-y0,-0.20 ,20
ENG141659-ENG99777-lwr_ofs_RSw_Ah1S-Y1,-0.10 ,20
ENG141659-ENG100480-lwr_ofs_RSw_Ah1S-Y2,-0.05 ,20
ENG141659-ENG100773-lwr_ofs_RSw_Ah1S-Y3,-0.01 ,20
ENG141659-ENG100631-lwr_ofs_RSw_Ah1S-Y4,-0.00 ,20
ENG124714-ENG142261-OCU-Remote HuF Abbruch,0 km/h,8
ENG124714-ENG142262-OCU-Remote HuF Hupfrequenz,0 Hz,8
ENG124714-ENG133391-OCU-Remote Lock Unlock Timer s1,0 s,8
ENG124714-ENG133392-OCU-Remote Lock Unlock Timer s3,0 ms,8
ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten,0 ,16
ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkion,profiles_inactive ,16
ENG98831-ENG142030-Personalization-Profil_Variante,Schluessel ,16
ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1,not active ,16
ENG141646-MAS01065-Querschnitts_funktionen-Brand,Audi ,5
ENG141646-ENG116624-Querschnitts_funktionen-CAN Wecken bei Softtouchbetaetigung,not active ,5
ENG141646-ENG154685-Querschnitts_funktionen-Hupe,Sollspannungsanforderung 13.5 ,5
ENG141646-ENG142015-Querschnitts_funktionen-Personalisierungsuebernahme,installed ,5
ENG141646-ENG141964-Querschnitts_funktionen-Steering alignment,Right ,5
ENG141646-ENG141965-Querschnitts_funktionen-Traffic side,Left ,5
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn,100 lx,1
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day,200 lx,1
ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,8 ,10
ENG115729-ENG141949-Scheinwerferreinigung-Headlamp washer system,not installed ,10
ENG115729-ENG115769-Scheinwerferreinigung-SRA bei Waschwassermangel,active ,10
ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit,1000 ms,10
ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit,1200 ms,10
ENG115729-ENG116611-Scheinwerferreinigung-SRA Pausenzeit,1000 ms,10
ENG115729-ENG116610-Scheinwerferreinigung-SRA Verzoegerungszeit,1000 ms,10
ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit,1200 ms,10
ENG115729-ENG154424-Scheinwerferreinigung-Waschen,Sollspannungsanforderung 13.5 ,10
ENG141684-SFT271873-Slave_systems_identification-Wiper motor control module,Not available ,6
ENG141684-SFT271874-Slave_systems_identification-Rain/Light Recognition Sensor,Not available ,6
ENG141684-SFT271877-Slave_systems_identification-Garage door opener control head,Not available ,6
ENG141684-SFT271894-Slave_systems_identification-Anti-theft alarm system sensor,Not available ,6
ENG141684-SFT271904-Slave_systems_identification-Sunroof control module,Not available ,6
ENG141684-SFT271910-Slave_systems_identification-Roof electronics control module,Not available ,6
ENG141684-SFT271928-Slave_systems_identification-Roof shade control module,Not available ,6
ENG141684-SFT271947-Slave_systems_identification-Humidity sensor: interior,Not available ,6
ENG141684-SFT271966-Slave_systems_identification-Left head area heater,Not available ,6
ENG141684-SFT271967-Slave_systems_identification-Right head area heater,Not available ,6
ENG141684-SFT272065-Slave_systems_identification-Blower 1 for left front backrest,Not available ,6
ENG141684-SFT272067-Slave_systems_identification-Blower 1 for left front seat cushion,Not available ,6
ENG141684-SFT272069-Slave_systems_identification-Blower 1 for right front backrest,Not available ,6
ENG141684-SFT272071-Slave_systems_identification-Blower 1 for right front seat cushion,Not available ,6
ENG141635-ENG116658-Spiegelverstellung-Funk Spiegelanklappen,not active ,5
ENG141635-ENG116660-Spiegelverstellung-Menuesteuerung Funk Spiegel anklappen,not active ,5
ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung,not active ,5
ENG141635-ENG133411-Spiegelverstellung-Spiegelanklappen_bei_Wiederverriegelung,not active ,5
ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron,not active ,5
ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter,CAN ,10
ENG153700-ENG154828-Steering Column Switch-Zeit_erkennung_fahrt_für_P_plausibel,10.0 min,10
ENG141663-ENG141988-Suchbeleuchtung_allgemein-Eingabemedium_Suchbeleuchtung,Potentiometer ,21
ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen,0.0 s,21
ENG141663-ENG116599-Suchbeleuchtung_allgemein-KL58 Verriegelungsausschalten,active ,21
ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS,5 ,21
ENG141663-ENG115631-Suchbeleuchtung_allgemein-Suchbeleuchtung Festwert,50 %,21
ENG141663-ENG115821-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Faktor,0.248 ,21
ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert,1.0 %,21
ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0,6.0 %,12
ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1,6.0 %,12
ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2,16.0 %,12
ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3,30.0 %,12
ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4,60.0 %,12
ENG141632-ENG116647-Sunroof-SAD Komfort oeffnen,active ,4
ENG141632-ENG116646-Sunroof-SAD Komfort schliessen,active ,4
ENG141634-ENG116716-Verdecksteuergeraet-Doppelpuls nur Verdeck,not active ,9
ENG141634-ENG125654-Verdecksteuergeraet-Nachsaven_nach_Verdecklauf,active ,9
ENG141634-ENG126838-Verdecksteuergeraet-Softtouch-Betaetigung senden,nur wenn freigegeben ,9
ENG141634-ENG122191-Verdecksteuergeraet-Verdeck oeffnen via Funkfernbedienung,not active ,9
ENG141634-ENG122192-Verdecksteuergeraet-Verdeck oeffnen via Kessy,not active ,9
ENG141634-ENG116714-Verdecksteuergeraet-Verdeck schließen via Funkfernbedienung,not active ,9
ENG141634-ENG142258-Verdecksteuergeraet-Virtuelles_Pedal_HMI_einstellba,not active ,9
ENG124901-Wischer_Fehlermaske_Mitsuba_Entw,0 bit,4
ENG116832-ENG126852-Wischgeschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute,42 ,3
ENG116832-ENG126853-Wischgeschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute,62 ,3
ENG141651-ENG115755-ZV allgemein-Notschließfunktion,not active ,7
ENG141651-ENG141996-ZV allgemein-ZV_ohne_Safe_Funktion,not installed ,7
ENG141655-ENG116661-ZV Crash-SAD PreCrash Konturschliessen,active ,4
ENG141655-ENG116635-ZV Crash-ZV-Entriegelung nach Seitencrash,active ,4
ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster,via_CAN ,7
ENG141653-ENG141995-ZV Heck-Heckschloss_Steuerung,Pulse control ,7
ENG141653-ENG115761-ZV Heck-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,active ,7
ENG141681-IDE02022-ZV Komfort-Comfort opening,not active ,8
ENG141681-ENG141984-ZV Komfort-elektrischer_Fensterheber_hinten,No ,8
ENG141681-ENG116663-ZV Komfort-Fahrertuerbedienung Fensterheber oeffnen,not active ,8
ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen,not active ,8
ENG141652-ENG141999-ZV Türkonfiguration-Fond_Schloss,Tuersteuergeraet im Fond verbaut oder keine Fondtuer ,5
ENG141652-ENG142000-ZV Türkonfiguration-Schlosstyp_NAR,No ,5
ENG141652-ENG141959-ZV Türkonfiguration-Viertuerer,No ,5
Elapsed Time: 01:59
David_GTi_700
C?ID=426963
Here are the faults
Thursday,14,July,2022,15:01:56:56476
VIN: WUAZZZFV7J1903538   License Plate: GV18DLO
                Address 05: Acc/Start Auth.       Labels: 5Q0-959-435.clb
Control Module Part Number: 3Q0 959 435 E    HW: 3Q0 959 435 G
  Component and/or Version: VWKESSYMQB    037 0811
           Software Coding: 132C2C0723
            Work Shop Code: WSC 01383 790 50316
              ASAM Dataset: EV_KessyHellaMQBAB 004039 (AU37)
                       ROD: EV_KessyHellaMQBAB.rod
                      VCID: 3C213F8C06E66E2BD37-8068
1052939 - Touch Sensor on Exterior Door Grip; Driver Side
          B116B 13 [137] - Open Circuit
                    Reset counter: 89
                    Mileage: 22416 km
                    Date: 2022.07.14
                    Time: 15:00:16
                    Terminal_15_Kessy_specified_value: On
                    Terminal_15_Kessy_actual_value: On
                    Terminal_15_central electric_actual_value: On
                    Terminal_15red_Kessy_specified_value: On
                    Terminal_15red_Kessy_actual_value: On
                    Terminal_S_Kessy_specified_value: On
                    Terminal_S_Kessy_actual_value: On
                    Terminal_S_central electric_actual_value: On
                    Terminal_50_Kessy_specified_value: OFF
                    Terminal_50_Kessy_actual_value: OFF
                    ZAT_pressed: OFF
                    Request active: Condition not met
                    Enabling Steering Column Lock: Condition not met
                    Enabling immobilizer: Condition not met
                    Control Module Voltage: 12.233 V
                    Vehicle speed: 0.0 km/h
                    Engine RPM: 0.0 /min
                    Status of vehicle locking: Vehicle unlocked
                    Coding information: coded
                    Coding information: Not coded
                    Driver door: closed
                    Front Passenger Door: closed
                    Left rear door: closed
                    Right rear door: closed
                    Active_LF_scans: Init
                    ID-sensor 1 authentication: status: No response
                    ID-sensor 2 authentication: status: No response
                    ID-sensor 3 authentication: status: No response
                    ID-sensor 4 authentication: status: No response
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
1053195 - Touch Sensor on Exterior Door Grip; Passenger Side
          B116C 13 [137] - Open Circuit
                    Reset counter: 89
                    Mileage: 22416 km
                    Date: 2022.07.14
                    Time: 15:00:16
                    ZAT_pressed: OFF
                    Driver door: closed
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
Cuzoe
C?ID=279487
These show the handles are both broken (less likely I would think) or both have wiring issues... broken, mis-pinned, connectors loose, something.
  • Agree
Spacewalker
Poland
C?ID=159607
...or kessy module is faulty
David_GTi_700
C?ID=426963
These are the bits that have me baffled, if I touch either handle it registers in vcds as "last handle touched" and the proximity count increases.
This what leads me to believe my wiring is ok.
