I just retrofitted the wireless charging module in my Q5 2022. cars equipped with the new MMI MIB3 communicate with the wireless charger using Can bus.
I am unable to register the module, i have tried everything single bit in Can Gateway [19] & 5F.
I also changed the following in 5F
ENG248434-ENG248718-function_configuration_phone-interlink_box_wireless_charging ---> Installed
Here is a complete scan of my car
Does anyone know what additional adaptation /coding is required ?
thank you very much!
Friday,18,March,2022,15:16:46:24009
VCDS Version: 22.3.0.1 (x64) HEX-NET CB: 0.4613.4
Data version: 20220225 DS336.1
VIN: WA16AAFY7N2054914 License Plate:
Chassis Type: FY-AU49 (80C)
Scan: 01 02 03 08 09 13 15 16 17 19 22 36 3C 42 44 46 52 5F 65 6C
6D 75 80 81 8B A5 BB BC CA CF D6 D7 DE
VIN: WA16AAFY7N2054914 Mileage: 911km-566miles
80-Batt. reg. aux. accum. -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
DE-Charger 1 for mobile dev -- Status: Not registered 0001
Address 01: Engine (J623-DPVA) Labels: None
Part No SW: 80A 906 259 AB HW: 06L 907 425 E
Component: R4 2.0l TFSI H08 0002
CVN: ED8A53BF
Coding: 2A6500322566012E74382000000000000000000000000000
ASAM Dataset: EV_ECM20TFS02080A906259AB 001002
ROD: EV_ECM20TFS02080A906259AB.rod
VCID: 6B9627ED82D839D707-803E
VINID: 9D10464515A91DE0801442411035C9671F
Radiator shutter:
Subsystem 1 - Part No SW: 95B 965 501 AA HW: 95B 965 501 AA
Component: V544KJS1 H13 0110
Serial number: 20211106060103051453
Readiness: 1010 0101
Address 02: Auto Trans (J217) Labels:| 0CJ-927-156.clb
Part No SW: 80A 927 155 DQ HW: 0HK 927 156 B
Component: 0JC 20TFSINAR H01 0002
Revision: --H01--- Serial number: 0000000900 CVN: FAF0469F
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_TCMDL382021 002038
ROD: EV_TCMDL382021_AU49.rod
VCID: 7BB617ADF2B8A95797-802E
MTF pump:
Subsystem 1 - Part No SW: 0CK 927 152 AA HW: 0CK 321 281 M
Component: V553 MTFP 003 0582
Serial number: 75290041210215002815
Address 03: ABS Brakes (J104) Labels: 8W0-907-379-PRE-V1.clb
Part No SW: 80A 907 379 AF HW: 80A 907 379 H
Component: ESP9 Premium H17 0871
CVN: C2732B8A
Coding: 4CAA40BE2CA70A9A93A75892228112A2F535DA32023450C91A444845AFAC5B
ROD: EV_ESP9BOSCHCMP_002_AU49.rod
VCID: 73A63F8DDAE8E117CF-8026
Address 08: Auto HVAC (E87) Labels:* None
Part No SW: 80A 820 043 AJ HW: 80A 820 043 AJ
Component: Klima Zone 3 H60 0291
Coding: 640909895548000D10000100080000000000000000000000000000000000
ASAM Dataset: EV_AirCondiBHTCAU491 001029
ROD: EV_AirCondiBHTCAU491.rod
VCID: 658251D5643C0FA751-8030
Subsystem 1 - Part No SW: 4M1 820 021 C HW: 4M1 820 021 C
Component: J126 FLuftV H09 0004
Serial number: 00000000000006653954
Humidity sensor: exterior:
Subsystem 2 - Part No SW: 4H0 907 658 C HW: 4H0 907 658 C
Component: G935 MuFu H05 0010
Serial number: ABD5115900PAG0MUFU04
Rear A/C control head:
Subsystem 3 - Part No SW: 80A 919 158 A HW: 80A 919 158 A
Component: E265 Kli Fond H40 0080
Address 09: Cent. Elect. (J519) Labels:* None
Part No SW: 8W1 907 063 BG HW: 8W1 907 063 G
Component: BCM1 MLBevo H10 0728
Coding: 07000760C13910DD050757899CAF9CF9130B75490000009801010A0060001C01086302BB22B70A0000000000000000000000000000000000000000000000000000
ASAM Dataset: EV_BCM1BOSCHAU651 018005
ROD: EV_BCM1BOSCHAU651_018_AU49.rod
VCID: 02486A499552D89FD4-8056
Subsystem 1 - Part No SW: 80B 955 119 B HW: 80B 955 119
Component: 426 LL 211109 041 0590
Serial number: 00000002111062106383
Coding: FFC7F7
Subsystem 2 - Part No SW: 81A 955 555 B HW: 81A 955 555
Component: G397_RLFSS H06 0004
Serial number: 42140276X81A955555B0
Coding: 02006E
Subsystem 3 - Part No SW: 4M0 941 531 AN HW: 4M0 941 531 AN
Component: E1 - LDS H07 0008
Serial number: 15 12 2021 13490202
Subsystem 4 - Part No SW: 4N0 907 410 C HW: 4M0 907 410 A
Component: USHL5 GX1 H12 0300
Serial number: 0000009600373Z009W02
Coding: 250000
Subsystem 5 - Part No SW: 4KE 857 511 C HW: 4KE 857 511
Component: Y7_Innenspieg H05 0003
Serial number: GX1NR123112123310057
Interior Light Module:
Subsystem 6 - Part No SW: 80A 947 135 BQ HW: 80A 947 135
Component: Dachmodul H42 0415
Serial number: Q00040100
Coding: 0D0104
Subsystem 7 - Part No SW: 80A 907 705 A HW: 80A 907 705
Component: J866-EVLS-SG H09 0210
Serial number: WA151839000110830973
Coding: 0A0700
Cup holder with heating and cooling element:
Subsystem 8 - Part No SW: 80A 864 981 B HW: 80A 864 981 B
Component: Q5 THERMO CUP H07 0020
Serial number: 0018465739
Subsystem 9 - Part No SW: 4N0 963 575 B HW: 4N0 963 575 B
Component: V512 LLR1SLvL H01 0012
Serial number: X02AM32779565
Subsystem 10 - Part No SW: 4N0 963 575 B HW: 4N0 963 575 B
Component: V514 LLR1SKvL H01 0012
Serial number: X02AM30673920
Subsystem 11 - Part No SW: 4N0 963 575 B HW: 4N0 963 575 B
Component: V516 LLR1SLvR H01 0012
Serial number: X02AM32780225
Subsystem 12 - Part No SW: 4N0 963 575 B HW: 4N0 963 575 B
Component: V518 LLR1SKvR H01 0012
Serial number: X02AM30673847
Address 13: Auto Dist. Reg (J428) Labels:* None
Part No SW: 80A 907 561 C HW: 8W0 907 561
Component: LRR4 H12 0451
Coding: D5779FF358FFEC0A959B83E1
ASAM Dataset: EV_ACCBOSCHAU49X 003024
ROD: EV_ACCBOSCHAU49X_003_AU49.rod
VCID: 281C18E153AED2CFAA-807C
Address 15: Airbags (J234) Labels:| 80A-959-655.clb
Part No SW: 80A 959 655 R HW: 80A 959 655 R
Component: AirbagVW30 009 0703
Serial number: 0032QM039VW%
Coding: AECCFCC000A00000A000003FF20C400000C5
ASAM Dataset: EV_AirbaVW31SMEAU65x 001044
VCID: 42C8AA49D5D2189F94-8016
Left seat belt tensioner:
Subsystem 1 - Part No SW: 4M0 980 945 B HW: 4M0 980 945 B
Component: BeltPretRevFL 306 2044
Serial number: 80A857705P0217V01016
Coding: 882007
Right seat belt tensioner:
Subsystem 2 - Part No SW: 4M0 980 946 B HW: 4M0 980 946 B
Component: BeltPretRevFR 306 2044
Serial number: 80A857706P0256V00141
Coding: 882007
Subsystem 3 - Part No SW: 4M0 959 339 HW: 4M0 959 339
Component: BF-Gewichtss. H14 0022
Serial number: IBH0000D21000H88730J
Coding: 303239
Subsystem 4 - Part No SW: ----------- HW: 480 002 008 21
Serial number: 35700000000C1C3D475T
Subsystem 5 - Part No SW: ----------- HW: 480 002 008 21
Serial number: 35800000000E908C475W
Subsystem 6 - Part No SW: ----------- HW: 480 033 008 21
Component: SideSensor_Dr 002 0149
Serial number: 351002C20F9DC97149BT
Subsystem 7 - Part No SW: ----------- HW: 480 033 008 21
Component: SideSensor_Pr 002 0149
Serial number: 352002C20C7C0080B842
Subsystem 8 - Part No SW: ----------- HW: 480 030 609 21
Component: FrontSensor_D 002 0149
Serial number: 355002C20B045C908D6B
Subsystem 9 - Part No SW: ----------- HW: 480 030 609 21
Component: FrontSensor_P 002 0149
Serial number: 356002C20B0450908F1/
Central crash sensor X/Y:
Subsystem 10 - Part No SW: ----------- HW: 480 020 208 21
Component: CentrSensorXY 005 0108
Serial number: I0O0001A8C4FA98375FK
Part No SW: 80A 907 129 EM HW: 80A 907 129 EM
Component: Lenks.Modul H03 0009
VCID: 77BE0B9DCE908D37F3-8022
Address 17: Instruments (J285) Labels:* None-SRI2
Part No SW: 80A 920 790 K HW: 80A 920 790 J
Component: FBenRDW------ H11 0215
Coding: 81CF3EC4EE980008028063641800480008003000
ASAM Dataset: EV_DashBoardAU65X 002027
ROD: EV_DashBoardAU65X_002_AU49.rod
VCID: 2F2EF3FD764085F76B-807A
Part No SW: 80C 907 468 E HW: 80B 907 468 B
Component: Gateway H08 0612
Serial number: 12F04275973101
Coding: 02030001002006402987000000590032DC3A0001100000000100008E02000000
GVL: 01D83C000800000040DCC8008002C800100C0000004000000000000000006500
ASAM Dataset: EV_Gatew31xAU65x 003250
ROD: EV_Gatew31xAU65x_AU49.rod
VCID: 3228FA896572A81F04-8066
Subsystem 1 - Part No SW: 80A 951 523 M HW: 80A 951 523 M
Component: J453 MFL H08 0005
Serial number: 20211124154157 00944
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Component: J367-BDMHella H11 9070
Serial number: 4350678400
Subsystem 3 - Part No SW: 80A 419 508 B HW: 80A 419 508 B
Component: J1158 KLR H03 0007
Serial number: 21258032503S0007H034
Address 22: AWD (J492) Labels:* Redir Fail!
Part No SW: 80A 927 755 HW: 0CJ 927 749 A
Component: Q5_DL3_N_SD2H02 0012
Serial number: 2131424943
Coding: 110F0000
ASAM Dataset: EV_AWDCQUOD31 001048
ROD: EV_AWDCQUOD31.rod
VCID: 6C9424F187D63EEF0E-8038
Part No SW: 4M6 959 760 HW: 4M4 959 760
Component: MEM-FS 009 0064
Serial number: 12A14127601041
Coding: 015C1A400000B4010003010101010000000000000000000000000000004000
ROD: EV_SCMDriveSideCONTIAU736_006.rod
Address 3C: Lane Change (J769) Labels:* None
Part No SW: 80A 907 566 B HW: 80A 907 566
Component: MRR1Rear H23 0441
Revision: --------
Coding: 0EC002
ASAM Dataset: EV_RearRadarS1BoschAU736 001022
VCID: 2C14E4F14756FEEF4E-8078
Part No SW: 4M1 959 793 J HW: 4M1 959 793 D
Component: TSG FS003 0430
Serial number: Y0016UKC026O9
Coding: 005D8B005E00148000010032
VCID: 46C0B659F9FA24BFB8-8012
Part No SW: 4N0 909 144 E HW: 4N0 909 144 C
Coding: B0112101010001
ROD: EV_EPSVWBSAU426_010.rod
Part No SW: 4N0 907 064 FP HW: 4N0 907 064 P
Component: BCM2 MLBevo H16 0242
Coding: 013400004FB100C0650BA0006C019802030340008104A6502F0000000F04803F001E0681000A31
ASAM Dataset: EV_BCM2CONTIAU651 012009
ROD: EV_BCM2CONTIAU651_012.rod
ID - sensor:
Subsystem 2 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY211750MN5
Subsystem 3 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000050089160
Subsystem 4 - Part No SW: 3G0 962 243 D HW: 3G0 962 243 D
Component: GEB.F.Heckoef H17 0908
Serial number: 38889629
Rear spoiler control module:
left tail lamp 2:
Subsystem 6 - Part No SW: 80A 945 429 E HW: 80A 945 429 E
Component: T2 LH SAE H10 0503
Serial number: 0F8
Right rear tail lamp 2:
Subsystem 7 - Part No SW: 80A 945 430 E HW: 80A 945 430 E
Component: T2 RH SAE H10 0503
Serial number: 18X
Part No SW: 4M2 959 792 J HW: 4M2 959 792 J
Component: TSG BFS001 0430
Serial number: Y0016UKU03WE9
Coding: 005D8B005E00148000010030
Part No SW: 80A 035 050 E HW: 80A 035 050 A
Component: MU-TH-NS-US 044 3620
Serial number: 8VV-DDM16.12.21
Coding: 14261010802020000000000000000000000000000000000000
ASAM Dataset: EV_MUTI 001010
ROD: EV_MUTI_AU27.rod
VCID: 1B76372D12F8095737-804E
Multimedia System 1:
Subsystem 1 - Part No SW: 80B 919 620 HW: 80B 919 620
Component: CenterDisplay H41 0160
Serial number: AUZ8Z9M6H02YXS
Subsystem 2 - Part No: V03 959 808 LN
Component: MIB3_NA_2022. 0696
Compact disc data bank:
Component: Gracenote2 3006
Volume Control 1:
Subsystem 4 - Part No SW: 80B 919 616 A HW: 80B 919 616 A
Component: LSR-Q5PA H20 0103
Serial number: ALJAL228072100050444
Media socket:
Subsystem 5 - Part No: 8W0 035 708 A
009 0007
Digital Sound System Control Module 2:
Subsystem 6 - Part No SW: 8Y0 035 465 A HW: 8Y0 035 465 A
Component: B_A_3_P_0_AU H11 0100
Serial number: C5B-26029.12.2166610
Address 65: Tire Pressure (J502) Labels: 4M0-907-273.clb
Part No SW: 4M0 907 273 B HW: 4M0 907 273 B
Component: RDKHUFAU736 H04 0010
Serial number: 40000000005092
ROD: EV_RDKHUFAU736_AU37.rod
Part No SW: 8W0 907 428 C HW: 4M0 907 428
Component: Areaview 2 H18 0108
Serial number: C854611JJ019011
Coding: 02240602BE0FA10038004004
ASAM Dataset: EV_CamSysRVAV2CE2MLBPA 002001
ROD: EV_CamSysRVAV2CE2MLBPA_002.rod
VCID: 40CCA041DBDE0A8F82-8014
Part No SW: 4KE 959 107 HW: 4KE 959 107
Component: HDSG-Modul H04 0330
Revision: -------- Serial number: A2-C772-8040-3
Coding: 0720
ASAM Dataset: EV_DeckLidCONTIAU536 001001
ROD: EV_DeckLidCONTIAU536_AU38.rod
VCID: 03466F4D8A48D197DF-8056
Part No SW: 4K2 035 284 C HW: 4K2 035 284 B
Component: CB_H_CAN 042 0360
Serial number: A983G0MS028473
Coding: 01E0E0F8C04080F6E0
ASAM Dataset: EV_ConBoxHighAU49X 001004
ROD: EV_ConBoxHighAU49X.rod
VCID: 2A18E2E94DA2E0DFBC-807E
Address 80: Batt. reg. aux. accum. (A1) Labels: None
Part No SW: 8W0 915 101 A HW: 8W0 915 101 A
Component: MQ-BMS H20 0127
Serial number: 21000301652004
ASAM Dataset: EV_BMS12VLiIonSDIAU49X 001001
ROD: EV_BMS12VLiIonSDIAU49X.rod
VCID: 312AF585607493077D-8064
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 80B 713 041 AD HW: 80B 713 041 N
Component: GSM-LL H10 0077
Revision: 0L0D5012 Serial number: 20211111000104
ROD: EV_GSMWaehlZFAU736.rod
VCID: 5F8E433D466055779B-800A
Address 8B: Adaptive Cruise 2 (J850) Labels: 4M0-907-541.clb
Part No SW: 80A 907 541 C HW: 8W0 907 541
ASAM Dataset: EV_ACC2BOSCHAU49X 003024
ROD: EV_ACC2BOSCHAU49X_003_AU49.rod
VCID: 260016D959BAC4BF98-8072
Address A5: Frt Sens. Drv. Assist (R242) Labels:* Redir Fail!
Part No SW: 80A 907 217 F HW: 80A 907 217 D
Component: BVS H28 0070
Coding: 0404020600000201022023AEC50000FEB0F0C020E280
ASAM Dataset: EV_BVSMLBevKOSTAAU736 002028
ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
VCID: 291A1DE548A4EBC7B5-807C
Part No SW: 4M2 959 795 J HW: 4M2 959 795 J
Component: TSG HFS001 0430
Serial number: Y0016ULB00933
Coding: 000D89000000148040000020
VCID: 49DABD65E8E4CBC755-801C
Component: TSG HBFS001 0430
Serial number: Y0016ULB00938
Part No SW: 4K0 907 594 AC HW: 4K0 907 594
Component: SAD_STG_1 006 0002
Coding: 22804004261C
ROD: EV_SunRoofCONTIAU736_009_AU37.rod
VCID: 75A20195D49CFF27E1-8020
Address CF: Lane Chge Asst 2 (J770) Labels: None
Part No SW: 80A 907 590 B HW: 80A 907 590
Revision: --------
Coding: 0EC002
ASAM Dataset: EV_RearRadarS2BoschAU736 001022
Part No SW: 4K0 941 591 BD HW: 4K0 941 591 B
Component: LMS_MLBevo H11 0040
ASAM Dataset: EV_LMSLeftHELLAAU58X 001015
ROD: EV_LMSLeftHELLAAU58X.rod
VCID: 72A83A89A5F2E81FC4-8026
ASAM Dataset: EV_LMSRightHELLAAU58X 001015
Address DE: Charger 1 for mobile dev (J1146) Labels:* None
Part No SW: 80A 035 502 B HW: 80A 035 502 B
Component: WLC Front H14 0061
Coding: 400000
VCID: 1A7832291DC2705F2C-804E
End----------(Elapsed Time: 02:16, VBatt start/end: 13.3V/13.3V)-----------
