2020 A3 MMI Navigation Plus Upgrade
hro0250
Washington, USA
C?ID=409496
Hello I have a 2020 Audi A3 that I upgraded to have the virtual cockpit (mostly done, still have a check engine light as seen in the attached autoscans). The next step is upgrading the glove box mounted MMI to include factory navigation. I bought a nav enabled MMI on eBay from an A3 with virtual cockpit so I have all the necessary connections. I’m still pretty new to VCDS, I was hoping someone could help me interpret my errors and help me configure this to my car. I know it still has component protection enabled; what is the best way to unlock it? Any help is greatly appreciated, original MMI auotscan and new MMI Nav Plus autoscans attached. Thank you!
Factory MMI:
Saturday,28,November,2020,11:22:24:03229
VCDS Version: 20.4.2.0 (x64)  HEX-V2 CB: 0.4513.4
VIN: WAUJEGFF4LA039731   License Plate:
Chassis Type: FF-AU37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 22 29 2B 39 3C 42 44 47 4B
          52 5F 6C A5 BB BC CF D6 D7
VIN: WAUJEGFF4LA039731   Mileage: 14482km-8998miles
Address 01: Engine (J623-DHHA)       Labels: None
   Part No SW: 5G0 906 259 Q    HW: 06K 907 425 J
   Component: 2.0l R4 TFSI  H13 0002
   Revision: --H13---
   Coding: 0A2500324466010F3000
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_ECM20TFS0205G0906259Q 001003
   ROD: EV_ECM20TFS0205G0906259Q.rod
   VCID: 3C21313366EB6E3B4EB-8068
19868 - No Communication with Instrument Cluster
          U0155 00 [039] - -
                    Mileage: 14482 km
                    Date: 2020.11.28
                    Time: 11:19:36
                    Engine speed: 803.25 /min
                    Normed load value: 12.5 %
                    Coolant temperature: 54 ∞C
                    Intake air temperature: 12 ∞C
                    Voltage terminal 30: 12.500 V
                    Engine: operating status: IS
                    ECU_STATE: SYN_ENG_IGK_ON
                    Engine oil temperature: 15.0 ∞C
                    Time since engine start: 284.6 s
                    T_ES: 0 min
                    Cruise control switch actuation-Main switch: not activated
                    Cruise control switch actuation-Setting: not activated
                    Cruise control switch actuation-Activation: not activated
                    Cruise control switch actuation-Status: OK
                    Cruise control switch actuation-Accelerate: not activated
                    Cruise control switch actuation-Decelerate: not activated
                    Cruise control switch actuation-Cancel: not activated
                    Cruise control switch actuation-Main switch hardware: not activated
                    Cruise control switch actuation-Coding: plausible
                    Cruise control switch actuation-Limit function: not selected
                    Cruise control switch actuation-Limit button: not activated
                    Cruise control switch actuation-Main switch CAN: not activated
                    Cruise control switch actuation-Large increment: not activated
                    Cruise control switch actuation-Control component verified: Yes
                    T_AST_SAE: 0 s
23079 - Control unit for information electronics 1
          U1054 00 [039] - No Communication
                    Mileage: 14482 km
                    Date: 2020.11.28
                    Time: 11:19:36
                    T_ES: 0 min
                    T_AST_SAE: 0 s
Readiness: 1110 1101
   Part No SW: 0GC 300 013 M    HW: 0GC 927 711 H
   Component: GSG DQ381     H06 2402
   Revision: 00H06V09
   ROD: EV_TCMDQ381061.rod
   VCID: 2E050B7BA0978CABF0F-807A
   Part No SW: 5Q0 614 517 FH    HW: 5Q0 614 517 BS
   Component: ESC           H82 0191
   Revision: 00000000    Serial number: 61709000000162
   Coding: 13FF6B9250232275897E0B03A0C469C8D60A4491D005967C1841505492A84A0B0000000012121212B835351919323200
   Shop #: WSC 00046 000 00000
   VCID: 7CA1F133266BAE3B0EB-8028
   Part No SW: 3Q0 959 435 N    HW: 3Q0 959 435 N
   Component: VWKESSYMQB    037 1307
   Revision: 00037000    Serial number: 0533132295
   Coding: 030C0C1720
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 45D754D715212FF3215-8010
   Part No SW: 8V0 820 043 AL    HW: 8V0 820 043 AL
   Component: AC Automat    H03 0161
   Revision: 20001000    Serial number: 00000001931597
   Coding: 03000014010000001000000000001400
   Shop #: WSC 06335 790 00021
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008026
   Subsystem 1 - Part No SW: 4H0 907 658 D    HW: 4H0 907 658 D
   Component: G935 MuFu  H04 0010
   Serial number: 2510191409PAG0MUFU05
   Part No SW: 5Q0 937 085 CB    HW: 5Q0 937 085 BF
   Component: BCM MQBAB MNA H40 0312
   Serial number: 01001931300722
   Shop #: WSC 06324 790 00021
   ASAM Dataset: EV_BCMMQB 020001
   ROD: EV_BCMBOSCH_020.rod
   VCID: 7BA3F22F2365A903071-802E
   Component: WWS371 190823  043  0585
   Serial number:         190913083158
   Coding: 0A47F7
   Component: G397_RLFS  H06  0002
   Serial number: 22072612X81A955547A0
   Coding: 00006C
   Component: E1 - LDS MQB  H06  0032
   Serial number: 28 08 2019  20001138
   Component: Sensor, DWA  005  0316
   Serial number: 000000000ZY1928019A7
   Component: Sirene, DWA  005  0314
   Serial number: 00000000000031914425
   Sun Roof:
   Subsystem 6 - Part No SW: 8V3 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS73.404  H04  0005
   Serial number: 0000FST002FEBW200000
   Coding: 101F00
   Steering Column Switch:
   Subsystem 7 - Part No SW: 82A 953 521 CQ    HW: 5Q1 953 549
   Component: J527 SMLS MQB  004  0070
   Serial number: 00000026101904401337
   Part No SW: 5QA 919 298 H    HW: 5QA 919 298 A
   Component: PLA 3.0 12K   H08 0061
   Serial number: 000150057319291
   Coding: 0270167851
   ASAM Dataset: EV_EPHVA2CAU3700000 009048
   ROD: EV_EPHVA2CAU3700000_009_AU37.rod
   VCID: 55F78497E5819F73515-8000
   Part No SW: 5Q0 907 572 P    HW: 5Q0 907 572 J
   Coding: B50087C111FFC428949C815580302600000000000000000004
   VCID: 44D149D31E1B16FB36B-8010
   Component: AirbagVW20    012 0830
   Serial number: 003GCR0GXXFQ
   Coding: 9DCCFCC0000000005000001AC248000000C5
   ROD: EV_AirbaVW20SMEVW37X_VW48.rod
   VCID: 47CB5EDF2F2D3DE3D39-8012
   Belt Pretensioner left:
   Component: BeltPretRevFL  H37 0350
   Serial number: 34230167A25101920306
   Coding: 333135
   Belt Pretensioner right:
   Component: BeltPretRevFR  H37 0350
   Serial number: 34230168A22101920366
   Coding: 333135
   Occupant Detection:
   Serial number: 694000000000001X8DVJ
   Coding: 303430
   Subsystem 4 - Part No SW: -----------    HW: 480 003 010 19
   Serial number: 357000000002F3512044
   Subsystem 5 - Part No SW: -----------    HW: 480 003 010 19
   Serial number: 35800000000DF658BF36
   Subsystem 6 - Part No SW: -----------    HW: 480 400 511 19
   Component: SideSensor_Dr  002 6149
   Serial number: 35100012A62E7526950Z
   Subsystem 7 - Part No SW: -----------    HW: 480 400 511 19
   Component: SideSensor_Pr  002 6149
   Serial number: 35200012A62E7524816Z
   Subsystem 8 - Part No SW: -----------    HW: 480 402 210 19
   Component: FrontSensor_D  004 6149
   Serial number: 35500012C62E74E485CI
   Front Sensor Passenger:
   Subsystem 9 - Part No SW: -----------    HW: 480 402 210 19
   Component: FrontSensor_P  004 6149
   Serial number: 35600012C62E74E2F40B
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI2
   Part No SW: 8V0 920 790     HW: 8V0 920 790
   Component: FBenRDW       H13 0045
   Coding: 048418506F80CE080085E8001000500000000000
   ASAM Dataset: EV_DashBoardFPKAU37X 001023
   ROD: EV_DashBoardFPKAU37X.rod
   VCID: 79AFE82729599B1315D-802C
          U1014 00 [009] - -
          [ECU incorrectly coded]
                    Reset counter: 132
                    Mileage: 14482 km
                    Date: 2020.11.28
                    Time: 11:19:34
   Component: GW MQB High   442 4388
   Revision: --------    Serial number: 0000233123
   Coding: 030100043F0859005B00005E180B00000001010000000000000000000000
   ROD: EV_GatewNF_AU37.rod
   VCID: 70B9D5037A23DA5BA23-8024
   Component: 4-01-0D-01-04
   Subsystem 2 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
   Component: J453 MFL  H04 0004
   Serial number: 20200122020402 20064
   Serial number: 75886003911910250CF1
   Part No SW: 0CQ 907 554 J    HW: 0CQ 525 130
   Component: Haldex4Motion H55 7084
   Serial number: HA1-00025.09.19
   Coding: 0001
   Shop #: WSC 06325 790 00021
   VCID: 4CC161F3364BDEBBFEB-8018
Address 29: Left Light (J1018)       Labels: 8S0-907-397.clb
   Part No SW: 8S0 907 397 D    HW: 8S0 907 397 D
   Component: LCM_MQB       H07 0022
   VCID: 42DD4FCB040F18CB047-8016
   Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
   Component: ELV-MQBB      H08 0021
   Serial number: 19000307431007
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_AU37.rod
   VCID: 313F1007B1A99353EDD-8064
Address 39: Right Light (J1023)       Labels: 8S0-907-397.clb
   Part No SW: 3Q0 907 566 J    HW: 3Q0 907 566
   Component: MRR1Rear      H25 0640
   Revision: --------
   Coding: 04C002
   VCID: 3FDB463F77FD75236B9-806A
   Part No SW: 5Q0 959 593 K    HW: 5Q0 959 593 F
   Component: TSG FS002 0325
   Serial number: YE007SIU1030A
   Coding: 005E1B204000008000000002
   ROD: EV_DCU2DriveSideMAXHKLO.rod
   VCID: 49CF58E73939CB93C5D-801C
   Part No SW: 5Q0 909 144 AB    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  130 1082
   Coding: 931F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 74B1D9130E3BE67B46B-8020
Address 47: Sound System (J525)       Labels:| 81A-035-466.clb
   Part No SW: 81A 035 466 B    HW: 81A 035 466
   Component: MIB2_amp_P_A3 H10 0440
   Revision: 00000001    Serial number: AUZ8ZAK5F02TC51
   Coding: 0173030000AAAA2AAA0000010000
   ASAM Dataset: EV_AMPMst16C9Gen2ALPI 001002
   ROD: EV_AMPMst16C9Gen2ALPI.rod
   VCID: 2411E953FE5B36FB16B-8070
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V2.clb
   Part No SW: 3Q0 907 338 E    HW: 3Q0 907 338 E
   Component: FCM MQB Low   003 0367
   Serial number: 02111910802027
   Coding: 000000050900147200112300040000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 003003
   ROD: EV_MultiModulContiVW48X_003_VW41.rod
   VCID: 372B2E1F5FCD4D63A39-8062
Address 52: Door Elect, Pass. (J387)       Labels:* Redir Fail!
   Part No SW: 5Q0 959 592 K    HW: 5Q0 959 592 F
   Component: TSG BFS002 0325
   Serial number: YE007SJ112625
   Coding: 005E13204000008000000002
   ROD: EV_DCU2PasseSideMAXHKLO.rod
   VCID: 48C95DE32233329BDA3-801C
   Part No SW: 8V1 035 652 D    HW: 8V1 035 652
   Component: MU-HS-S-US    050 0185
   Coding: 017301000000000011220002061A00232F002DE401F001040A
   ASAM Dataset: EV_MUHigScl6C3DELP 001011
   ROD: EV_MUHigScl6C3DELP.rod
   VCID: 38292D2352D3421BAA3-806C
   Subsystem 1 - Part No SW: 8V0 919 604 C    HW: 8V0 919 604 C
   Component: DU High  H49 0014
   Serial number: AUZ8Z9K1Y0LRB2
   Multimedia Operating Unit:
   Subsystem 2 - Part No SW: 8V0 919 614 BR    HW: 8V0 919 614 BR
   Component: ControlUnit_B  H50 0106
   Serial number: ALJAL112091900050238
   Component: RVC Compact   H18 0231
   Coding: 0273010102002001400040
   ROD: EV_CamSysRVRVCPANAMQBAB.rod
   VCID: 392F282769D95B1355D-806C
   Part No SW: 3Q0 980 654 L    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H12 0610
   Serial number: 08111915P10142
   Coding: 040307010000020101220046C14E490080000E20012000
   ROD: EV_MFKBoschMQBB_002.rod
   VCID: 40D945C30A030ADB123-8014
   Part No SW: 5Q0 959 395 K    HW: 8W1 959 395 D
   Component: TSG HFS004 0325
   Serial number: YE007SJ51109E
   Coding: 000C13204000008000000002
   ASAM Dataset: EV_DCU2RearDriveMAXHKLO 001018
   Component: TSG HBFS004 0325
   Serial number: YE007SJ51109B
   ASAM Dataset: EV_DCU2RearPasseMAXHKLO 001018
   Part No SW: 3Q0 907 590 J    HW: 3Q0 907 590
   Revision: --------
   Coding: 04C002
   ASAM Dataset: EV_RearRadarS2BoschVW48X 001007
   Part No SW: 7PP 941 572 AC    HW: 7PP 941 572 A
   Component: LED1L         H09 0008
   ROD: EV_LEDModLeftMELCOAU736_AU37.rod
   VCID: 176BCE9F3F0D6D63839-8042
   Component: LED1R         H09 0008
End----------(Elapsed Time: 01:43, VBatt start/end: 12.6V/12.6V)-----------
New MMI Navigation Plus Radio:
Saturday,28,November,2020,11:42:57:03229
Mileage: 14482km-8998mi   Repair Order:
Scan: 01 02 03 05 08 09 10 13 15 17 19 22 29 2B 39 3C 42 44 4B 52
   Revision: --H13---
          U0155 00 [039] - -
                    Mileage: 14482 km
                    Date: 2020.11.28
                    Time: 11:19:36
                    T_ES: 0 min
                    T_AST_SAE: 0 s
          U1054 00 [036] - No Communication
                    Mileage: 14482 km
                    Date: 2020.11.28
                    Time: 11:19:36
                    T_ES: 0 min
                    T_AST_SAE: 0 s
Readiness: 1010 1101
   Revision: 00H06V09
   Coding: 030C0C1720
   Coding: 0A47F7
   Coding: 00006C
   Sun Roof:
   Coding: 101F00
   Coding: 0270167851
0803 - Databus
          [FAULT_BV1_FEHLER]
                    Reset counter: 132
                    Mileage: 14482 km
                    Date: 2020.11.28
                    Time: 11:33:25
                    Control Module temperature: 17 ∞C
                    Voltage terminal 15: 11.7 V
                    Longitudinal_acceleration_vehicle_reference: 0.00 m/s≤
                    Status_ACC_System: ACC_Off_MainSwitch_Off
   Coding: 333135
   Coding: 333135
   Occupant Detection:
   Coding: 303430
          U1014 00 [009] - -
                    Reset counter: 132
                    Mileage: 14482 km
                    Date: 2020.11.28
                    Time: 11:19:34
          U1101 00 [009] - Active
                    Reset counter: 132
                    Mileage: 14482 km
                    Date: 2020.11.28
                    Time: 11:34:13
                    Supply voltage: Terminal 30: 11.6 V
                    Terminal 15: On
   Coding: 0001
   Revision: --------
   Coding: 04C002
   Coding: 931F0000
Address 5F: Information Electr. (J794)       Labels:* Redir Fail!
   Part No SW: 8V1 035 880 B    HW: 8V1 035 880
   Component: MU-P-LNS-US   054 1110
   Serial number: A702K0H2505876
   Coding: 01730102FF0A000011220001041A00002F0026C4017001047E
   Shop #: WSC 06385 790 00016
   ROD: EV_MUHig6C3Gen2HBAS_VW37.rod
   Subsystem 1 - Part No SW: V03 959 801 GH    HW: -----------
   Component: NAR 2017/2018  --- 0060
   Subsystem 3 - Part No SW: 8V0 919 614 BR    HW: 8V0 919 614 BR
   Component: Gracenote2  --- 3012
15 Faults Found:
          B201A 00 [009] - -
          [Check software version management]
                    Reset counter: 80
                    Mileage: 76021 km
                    Date: 2018.12.28
                    Time: 07:01:15
                    Voltage terminal 30: 12.8 V
                    Status_Software_Version_Management-module_name: ADUA201/Front
          [Anti-theft protection - component protection active (0xEA6300)]
                    Reset counter: 80
                    Mileage: 2081 km
                    Date: 2020.05.06
                    Time: 17:29:58
                    Voltage terminal 30: 12.3 V
0020 - Tuner for Satellite Radio
          B11CF 53 [009] - Deactivated
                    Reset counter: 45
                    Mileage: 76021 km
                    Date: 2018.12.28
                    Time: 07:08:07
                    Voltage terminal 30: 14.8 V
                    Satellite radio tuner status-Satellite radio antenna status: Electrical OK
                    Satellite radio tuner status-Channel selection for satellite radio: 0
                    Satellite radio tuner status-Audio Signal: Not available
                    Satellite radio tuner status-Antenna current: 0 mA
                    Satellite radio tuner status-Reception quality: Not available
                    Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
                    Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
0512 - Rear Right Bass Speaker
          B1067 13 [009] - Open Circuit
          [Tieftonlautsprecher Kanal 1: Unterbrechung]
                    Reset counter: 45
                    Mileage: 76021 km
                    Date: 2018.12.28
                    Time: 07:01:16
0513 - Rear Right Treble Speaker
          B1068 13 [009] - Open Circuit
          [Hochtonlautsprecher Kanal 1: Unterbrechung]
                    Reset counter: 45
                    Mileage: 76021 km
                    Date: 2018.12.28
                    Time: 07:01:14
0517 - Front Right Bass Speaker
          B1062 13 [009] - Open Circuit
          [Tieftonlautsprecher Kanal 2: Unterbrechung]
                    Reset counter: 45
                    Mileage: 76021 km
                    Date: 2018.12.28
                    Time: 07:01:16
0522 - Front Left Bass Speaker
          B105F 13 [009] - Open Circuit
          [Tieftonlautsprecher Kanal 3: Unterbrechung]
                    Reset counter: 45
                    Mileage: 76021 km
                    Date: 2018.12.28
                    Time: 07:01:16
0527 - Rear Left Bass Speaker
          B1065 13 [009] - Open Circuit
          [Tieftonlautsprecher Kanal 4: Unterbrechung]
                    Reset counter: 45
                    Mileage: 76021 km
                    Date: 2018.12.28
                    Time: 07:01:16
                    Voltage terminal 30: 12.7 V
0528 - Rear Left Treble Speaker
          B1066 13 [009] - Open Circuit
          [Hochtonlautsprecher Kanal 4: Unterbrechung]
                    Reset counter: 45
                    Mileage: 76021 km
                    Date: 2018.12.28
                    Time: 07:01:14
0532 - Subwoofer
          B106C 13 [009] - Open Circuit
          [Tieftonlautsprecher Kanal 5: Unterbrechung]
                    Reset counter: 45
                    Mileage: 76021 km
                    Date: 2018.12.28
                    Time: 07:01:16
0537 - Center speaker
          B1069 13 [009] - Open Circuit
          [Tieftonlautsprecher Kanal 6: Unterbrechung]
                    Reset counter: 45
                    Mileage: 76021 km
                    Date: 2018.12.28
                    Time: 07:01:16
0005 - Antenna Amplifier 1 for Radio
          B126D 13 [008] - Open Circuit
                    Reset counter: 172
                    Mileage: 2164 km
                    Date: 2020.05.18
                    Time: 16:18:41
                    Voltage terminal 30: 12.2 V
                    Status of antenna 1 for radio-Antenna current: 0 mA
                    Status of antenna 1 for radio-Connection between radio and antenna amplifier: Open circuit
                    Status of antenna 1 for radio-Connection between antenna amplifier and antenna: Not available
                    Status of antenna 1 for radio-Reception level antenna 1: 255 dBµV
0006 - Antenna Amplifier 2 for Radio
          B126E 13 [008] - Open Circuit
                    Reset counter: 172
                    Mileage: 2164 km
                    Date: 2020.05.18
                    Time: 16:18:41
                    Status of antenna 2 for radio-Antenna current: 0 mA
                    Status of antenna 2 for radio-Connection between radio and antenna amplifier: Open circuit
                    Status of antenna 2 for radio-Connection between antenna amplifier and antenna: Not available
                    Status of antenna 2 for radio-Reception level antenna 2: 255 dBµV
0009 - Antenna for Satellite Radio
          B10F4 13 [008] - Open Circuit
                    Reset counter: 172
                    Mileage: 2164 km
                    Date: 2020.05.18
                    Time: 16:19:02
                    Voltage terminal 30: 12.1 V
                    Satellite radio tuner status-Satellite radio tuner: pre-activation status: Initial_value_forMPFA_not_coded
2565 - GPS Antenna
          B1054 13 [008] - Open Circuit
          [GPS aerial - open circuit]
                    Reset counter: 172
                    Mileage: 76058 km
                    Date: 2018.12.28
                    Time: 07:51:30
                    Voltage terminal 30: 13.0 V
0646 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [Variant_coding_failure]
                    Reset counter: 132
                    Mileage: 14482 km
                    Date: 2020.11.28
                    Time: 11:33:24
                    Control Module temperature: 24 ∞C
                    Outside air temperature: 8.5 ∞C
                    Vehicle speed: 0.00 km/h
                    System run time: 2.9 s
                    mid: 00 29
                    Status of camera: operational
                    Engine_Running_Info: 0
                    Software_Info_4: 0
                    Software_Info_3: 1
                    Software_Info_2: 6
                    Software_Info_1: 0
   Revision: --------
   Coding: 04C002
End----(Elapsed Time: 01:51, VBatt start/end: 11.9V/11.8V. VIgn 11.8V)-----
DV52
C?ID=194404
@hro0250 : Yes, your first task is certainly to deal with the Component Protection error. Alas, this DTC can only be deleted (in the official manner) by a visit to a dealer or any workshop that has access to VAG's FAZIT facility (there are "unofficial" service providers that are sometimes used to hack CP errors, but I can't recommend any of these).
The other observation that I would make regarding your 2 x auto-scans is the long code string comparison below for the hex5F module:
ByteFactoryFactoryNew MMINew MMI
HexBinaryHexBinary
001000000010100000001
173011100117301110011
201000000010100000001
300000000000200000010
40000000000FF11111111
500000000000A00001010
600000000000000000000
700000000000000000000
811000100011100010001
922001000102200100010
1102000000100100000001
1206000001100400000100
131A000110101A00011010
1400000000000000000000
1523001000110000000000
162F001011112F00101111
1700000000000000000000
182D001011012600100110
19E411100100C411000100
2001000000010100000001
21F0111100007001110000
2201000000010100000001
2304000001000400000100
240A000010107E01111110
As you can see, there are lots of differences in the Byte values. Clearly the "new MMI" is much more functionally rich than the factory unit - however some of the facilities that are enabled in the new MMI will need matching software switches (and perhaps adaptation channels) enabled in other modules to work successfully)
But, in respect of new digital instrument cluster (and the factory fitted hex47 module - which is strangly missing from your 2nd auto-scan?), I note that Byte 19, Bit 5 (highlighted) on the new MMI is not set. This is the software switch that enables MOST - which is the optical fiber protocol that runs both the digital version of the hex17 module and the hex47 module. I suggest that you set this Bit. And to complete the alignment of the new MMI to the hex47 module, perhaps set Byte 4 and Byte 5 to hex00 - then clear the DTCs and re-post another autoscan.
PS: I hope that you had the good fortune to make an admap of your factory fitted hex5F module before its removal because it will be useful in aligning the adaptation channel settings on your new MMI. If not, perhaps you might consider temporarily re-connecting the old module and making an admap.
hro0250
Washington, USA
C?ID=409496
That is great info, thank you!
Fortunately I just had the new module plugged in long enough to grab this scan, my OEM unit is back in now so I can grab an admap. Can any programming be done before I have the component protection removed? This step is intimidating to me because I paid for a service to remove it from the company I purchased my VC from, and I haven't had a great experience with them. Are dealerships usually understanding/helpful with removing component protection?
DV52
C?ID=194404
@hro0250 : New information; "I paid for a service to remove it [CP] from the company I purchased my VC from" - I wasn't aware that the new unit had been "hacked" (i.e. I had assumed that the new unit was a virgin-MIB straight-out of another car) !!
Dealing with CP errors using unofficial service providers varies greatly and the effects likewise can vary greatly - but "hacked" units often can leave CP errors present in diagnostic scans whilst resolving the more practical effects of these DTCs - like the usual problem of no sound!
Given that you have had the CP error "hacked", perhaps the more prudent way forward is to proceed with fixing the other issues first - that is, proceed as if there were no CP errors!!
EDIT:
I don't know what the dynamic for CP removal is like up there in the land-of-the-free!! However, down here in the Antipodes where dealers tend to be more hmm........... let me tactfully say "self-important", CP removal can be problematic. Some won't provide the service at all if the dealer doesn't also retrofit the radio (and in some cases, if the retrofit isn't with a brand new unit)!
But more importantly, if your new unit has been hacked by an unofficial service provider and depending on how the module firmware was modified - the dealer's process might not work anyway - because the official ODIS guided process for CP removal assumes the standard VAG firmware in the MIB unit
  • Agree
hro0250
Washington, USA
C?ID=409496
I am going to skip the dealership because around here they aren't super willing to help, but there are a lot of VW/Audi independent specialists who might be able to help. Right now I have a VC with the DTC saying it lost communication with the engine control module, and to my understanding, that can only be solved with a brand new VC programmed for my car before it reaches 100km. I currently have the factory radio in and it is working perfectly, however the VC requires an additional connection to be fully functional, so I purchased a full spec MMI out of a salvaged A3 with VC.
I have no idea if they used an unofficial software to install/unlock my virtual cockpit. I tried to be hands-off and let them do it for me because that was the only upgrade I planned for this car. Then after they left it unfinished it left me searching for how to fix it myself, and lead me here. I was then made aware of a higher spec MMI unit, so I decided to add that because they made it seem as though that would solve my VC issues. I was told, on this forum, that the only way to fix my VC is to buy a brand new one instead of the one out of a salvage car that the company provided me, and have it configured for my car as new. I'm in a bit of a bind because I have a half-functional VC with DTCs and no idea how to fix it. I would ideally like to have both functional, I just am learning on the fly. So I appreciate all the help.
hro0250
Washington, USA
C?ID=409496
Oh, I should mention, the DTC on the virtual cockpit leaves the check engine light on. I had my first oil change on the car this weekend, which I always do myself, so I went in with VCDS to reset my service internal reminder, and I was alerted by VCDS that the action cannot be preformed because the module is not configured. So now I have a check engine light, and a service reminder warning perpetually stuck on.
I would put my OEM gauge cluster back at this point and cut my losses if I didn't have to Dremel out and cut the dash behind the old gauge cluster to make the VC unit fit...
I'm really up a creek here, no paddles in sight.
