Can anyone help me, I already try to copy ABS coding from other VW Scirocco into this car but is show out of range.
where is the relay for aux coolant pump locate?
Vin: WVWZZZ13ZBV017354
Regard
Regard
Wednesday,02,December,2020,19:52:33:22104
VCDS Version: 20.12.0.0 (x64)
Data version: 20201124 DS322.0
VIN: WVWZZZ13ZBV017354 License Plate: 808
Mileage: 98120km-60968mi Repair Order:
Chassis Type: 13-VW36 (7N0)
Scan: 01 02 03 08 09 10 14 15 16 17 19 25 42 44 46 4F 52 55 56 77
B9
VIN: WVWZZZ13ZBV017354 Mileage: 98120km-60968miles
B9-Aux. Display -- Status: OK 0000
Address 01: Engine (CCZ) Labels:. 06J-907-115-CCZ.clb
Part No SW: 5K0 907 115 HW: 1K0 907 115 AA
Component: 2.0l R4/4V TFSI 0050
Revision: AAH18--- Serial number:
Coding: 0403000C1C070060
Shop #: WSC 66565 257 00032
VCID: 67DD7A8D563B8CBCA2-8032
006439 - Relay for Aux Coolant Pump (J496)
P1927 - 000 - Open Circuit
Mileage: 95651 km
Date: 2015.04.12
Time: 00:04:54
RPM: 756 /min
Load: 2.7 %
Temperature: 71.0°C
Temperature: 43.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.589 V
Readiness: 0110 0000
Part No SW: 02E 300 053 N HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2207
Revision: 05151112 Serial number: 00001008271321
Shop #: WSC 44551 111 44551
VCID: 204F2191F395BB8423-8074
Part No SW: 1K0 907 379 BE HW: 1K0 907 379 BE
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Shop #: WSC 06385 790 00016
VCID: 76E327C9C191653429-8022
03306 - Coding Not Valid
Reset counter: 94
Mileage: 98123 km
Date: 2015.04.25
Time: 19:28:22
Count: 3
Count: 28672
Count: 4161
Count: 51200
Reset counter: 94
Mileage: 98123 km
Count: 3
Count: 28672
Count: 195
Count: 51200
Fault Status: 01100101
Reset counter: 94
Mileage: 98123 km
Date: 2015.04.25
Time: 19:02:27
Count: 3
Count: 28672
Count: 279
Count: 51200
Count: 256
Reset counter: 94
Mileage: 98123 km
Date: 2015.04.25
Time: 19:02:27
Count: 3
Count: 28672
Count: 295
Count: 51200
Count: 256
Reset counter: 94
Mileage: 98123 km
Date: 2015.04.25
Time: 19:02:27
Count: 3
Count: 28672
Count: 270
Count: 51200
Count: 256
Part No SW: 5K0 907 044 BT HW: 5K0 907 044 BT
Component: Climatronic H15 0709
Revision: 00003001
Coding: 0000001002
Shop #: WSC 00020 999 00000
VCID: 7EF33FE9E1A12D7471-802A
9471761 - Temperature Sensor for Left Vent
B1087 11 [009] - Short to Ground
Reset counter: 94
Mileage: 98123 km
Date: 2020.12.02
Time: 02:12:49
Part No SW: 5K0 937 087 H HW: 5K0 937 087 H
Component: BCM PQ35 H 011 0035
Revision: BE011001
Coding: 40100A3B8025080040080000100048E443050088724D8D20648000000040
Shop #: WSC 15909 123 104857
VCID: 3A7BF3F9B509C1540D-806E
Subsystem 1 - Part No SW: 1K8 955 119 G HW: 1K8 955 119 G Labels: 1KX-955-119.CLB
Component: Wischer 21071 10 0603
Coding: 009795
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 94
Mileage: 98123 km
Date: 2015.04.25
Time: 02:13:56
Voltage: 13.10 V
Reset counter: 94
Mileage: 98123 km
Date: 2015.04.25
Time: 02:13:56
Voltage: 13.10 V
Address 10: Park/Steer Assist (J446) Labels:. 1K0-919-475.clb
Part No SW: 1K0 919 475 L HW: 1K0 919 475 L
Component: PARKHILFE 005 1806
Revision: 00005000 Serial number: 0 263 004 450
Coding: 100101
Shop #: WSC 00020 790 00000
VCID: 3B75F6FDBA33F85C16-806E
Address 14: Susp. Elect. (J250) Labels:. 3C0-907-376.clb
Part No SW: 3C0 907 376 A HW: 3C0 907 376
Component: DAEMPFUNGS-SG H07 0070
Revision: 00000000 Serial number: 23091000510001
Coding: 000180
VCID: 275D3A8D56BB4CBC62-8072
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 94
Mileage: 98123 km
Date: 2015.04.25
Time: 02:13:48
Bin. Bits: 00000000 00001000
03262 - Comfort Restriction
Reset counter: 94
Mileage: 98123 km
Date: 2015.04.25
Time: 02:13:60
Error Code: 2
Bin. Bits: 00000000
00141 - Rear Body Acceleration Sensor (G343)
003 - Mechanical Failure
Fault Status: 01100011
Reset counter: 94
Mileage: 98123 km
Date: 2015.04.25
Time: 02:13:60
Bin. Bits: 00000000 00000010
Bin. Bits: 00000000 00000000
Part No SW: 1K0 909 605 AE HW: 1K0 909 605 AE
Component: 0H AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 003D1D0304A4
Coding: 0012360
VCID: 6FED12AD7ECB54FCEA-803A
Subsystem 1 - Serial number: 6332MSME56251132$
Subsystem 2 - Serial number: 6342MSME56250B2EH
Subsystem 3 - Serial number: 6352QSME717109305
Subsystem 4 - Serial number: 6362QSME0D702D28N
Part No SW: 5K0 953 521 AR HW: 5K0 953 569 A
Component: LENKS.MODUL 009 0136
Revision: FF010038 Serial number: 20100918301719
Coding: 1892040000
Shop #: WSC 15909 000 1048576
ASAM Dataset: EV_SMLSNGVOLWS A01004
ROD: EV_SMLSNGVOLWS.rod
VCID: 7CF735E1F7BD3F645F-8028
Subsystem 1 - Part No SW: 5K0 959 542 HW: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H08 0010
Coding: 830000
Part No SW: 1K8 920 872 HW: 1K8 920 872
Component: KOMBI H20 0420
Coding: 170F01
VCID: 70EF11D1ABF54B04F3-8024
Part No SW: 7N0 907 530 AR HW: 7N0 907 530 AM
Component: J533 Gateway H55 1653
Revision: H55 Serial number: 270914F2000564
Coding: 350001
VCID: 000F411193555B8403-8054
Reset counter: 94
Mileage: 98123 km
Date: 2015.04.25
Time: 02:12:53
Component: IMMO H20 0420
VCID: 6ADB03B98D29B1D4BD-803E
Part No SW: 1Q0 959 701 H HW: 1Q0 959 701 H
Component: Tuer-SG 009 2130
Coding: 0016949
VCID: 3979ECF5700FCA4C04-806C
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 184 3001
Revision: 00H17000
VCID: 3169D4D5A87F020CBC-8064
Fault Status: 11100101
Mileage: 98123 km
Date: 2015.04.25
Time: 02:12:47
Battery Volts: 14.0 V
DU
Temperature: 36.0°C
Count: 3
Steering Angle: 0.00°
Count: 1
SteerAng n.Init
Part No SW: 7N0 907 532 HW: 7N0 907 530 AM
Component: EZE_2 H55 1653
Coding: 01030100
VCID: 6FED12ADBECB54FCEA-803A
Subsystem 1 - Part No SW: 6R0 959 591 HW: 6R0 959 591
Component: J245/J878 H04 0054
Serial number: 035300052408
Coding: 000005
Part No SW: 1Q0 959 702 H HW: 1Q0 959 702 H
Coding: 0016948
VCID: 3A7BF3F97509C1540D-806E
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 K
Component: Dynamische LWR H01 0010
Coding: 0000016
VCID: 428B8B191DD9899455-8016
Reset counter: 94
Mileage: 98120 km
Date: 2015.04.25
Time: 02:12:48
Fault Status: 11101010
Reset counter: 94
Mileage: 98120 km
Date: 2015.04.25
Time: 02:12:48
Reset counter: 94
Mileage: 98120 km
Date: 2015.04.25
Time: 02:12:48
Part No SW: 6RD 035 187 B HW: 6RD 035 187 B
Component: MIB2-S-R-CN 036 0317
Revision: -----001 Serial number: VWZ6Z2R7404794
Coding: 1E00040004000A
VCID: 46839709F1F1B5B479-8012
Reset counter: 4
Mileage: 93219 km
Date: 2015.03.13
Time: 02:24:57
Reset counter: 4
Mileage: 93219 km
Date: 2015.03.13
Time: 02:24:57
Address 77: Telephone
Address B9: Aux. Display (J285) Labels:* 5C5-919-527.clb
Part No SW: 1K8 919 527 HW: 1K8 919 527
Component: ZUSATZANZEIGE H08 0003
Coding: 05
ASAM Dataset: EV_Auxi_Disp_Unit_UDS_VDD 001010
ROD: EV_Auxi_Disp_Unit_UDS_VDD.rod
VCID: 75E120C5D4976E2C20-8020
End-------------------------(Elapsed Time: 02:39)--------------------------
