2020 Atlas Cross Sport - Cornering lamp
rocamet
Rancho Cucamonga, CA, USA
C?ID=419570
Does anyone know if the "cornering lamp" function uses the fog lights to lighten up the sides when turning or does it activate some other light?
I currently have my fog lights set to come on for each respective blinker. Would activating the channel below (4B Multifunc. Module) do something different?
IDE13611-Cornering lamp in operation
AutoScan:
Wednesday,07,October,2020,21:57:57:21681
VIN: 1V2NE2CA0LC213197   License Plate:
Chassis Type: CA-VW41 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 22 36 3C 42 44 47 4B 52 5F
          69 6C 6D 75 A5 CA D6 D7
VIN: 1V2NE2CA0LC213197   Mileage: 859km-533miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CDVC)       Labels: None
   Part No SW: 03H 906 026 AG    HW: 03H 907 309 K
   Component: VR6 3.6l FSI  H21 9970
   Revision: 52H21000
   Coding: 012A003244740108F0000000000000000000000000000000
   Shop #: WSC 06050 062 00200
   ASAM Dataset: EV_ECM36FSI01103H906026AG 001006
   ROD: EV_ECM36FSI01103H906026AG.rod
   VCID: 6A8DC661CCFAA24BEC7-803E
   CAN Converter 01:
22593 - Fuel Level Sensor Circuit
          P0461 00 [096] - Implausible Signal
                    Mileage: 203 km
                    Date: 2020.09.20
                    Time: 13:54:22
                    Engine speed: 1495.00 /min
                    Normed load value: 39.6 %
                    Vehicle speed: 85 km/h
                    Coolant temperature: 83 °C
                    Intake air temperature: 34 °C
                    Ambient air pressure: 940 mbar
                    Voltage terminal 30: 12.740 V
                    Unlearning counter according OBD: 18
                    Outside air temperature: 31 °C
                    Air mass: actual value:: 17.22 g/s
                    Engine torque: 133.1 Nm
                    Fuel: tank fill level: 70.0 l
                    Oxygen sensor bank 1 sensor 1: specified value: 1.0000
                    Intake camshaft bank1 active operating mode-Bits 0-7: 0
                    Overrun cut-off-Bits 0-7: 0
   Part No SW: 09G 927 158 DR    HW: 09G 927 158
   Component: AISIN AQ8     206 3742
   Coding: 0000000100000000000000000000000000000000
   ROD: EV_TCMAQ450031_VW37.rod
   VCID: 065592D1F8A2662B68F-8052
   Part No SW: 5Q0 614 517 DL    HW: 5Q0 614 517 BP
   Component: ESC           H35 0113
   Revision: 00000000    Serial number: 50410000000867
   Coding: 85FC6B8D80211A6FC5780309A2CA69A1D60158A3C045967638415058D2AA4A0B004023641C12141A1D8DDB45506CC8CF
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 049012
   ROD: EV_Brake1UDSContiMK100IPB_049_VW27.rod
   VCID: 7EA5FA31A0723EEB20F-802A
   Part No SW: 3Q0 959 435 N    HW: 3Q0 959 435 N
   Component: VWKESSYMQB    037 1307
   Revision: 00037000    Serial number: 0536888289
   Coding: 1F20000723
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 45D755DD8524AD33215-8010
   Subsystem 1 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Serial number: 14277850
Address 08: Auto HVAC (J255)       Labels:* None
   Part No SW: 3CM 907 044 B    HW: 3CM 907 044 B
   Component: Climatronic   H05 2401
   Revision: 00001K04
   Coding: 1402002620001C0C1104010C9210D52C
   ASAM Dataset: EV_ACClimaBHBVW416 002015
   ROD: EV_ACClimaBHBVW416.rod
   VCID: 3D273D3DEDF4E5F3795-8068
   Part No SW: 5Q0 937 085 CC    HW: 5Q0 937 085 BG
   Component: BCM MQBAB HNA H40 0312
   Serial number: 0032036602ÿÿÿÿ
   ASAM Dataset: EV_BCMMQB 020001
   ROD: EV_BCMBOSCH_020.rod
   VCID: 7CA1F039B66E2CFB0EB-8028
   Subsystem 1 - Part No SW: 5Q0 955 555 A    HW: 5Q0 955 555 A
   Component: RLHSS  051  0207
   Serial number: S7Y19M12D17H18M00S56
   Coding: 0018DD
   Steering Column Switch:
   Subsystem 2 - Part No SW: 5Q1 953 521 AC    HW: 5Q1 953 569 B
   Component: Lenks.Modul  H23  0170
   Serial number: 0300070220200C200538
   Seat Backrest Fan 1 Front Left:
   Subsystem 3 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Component: SysNameFanLin  014  0101
   Serial number: ESE0646341
   Seat Cushion Fan 1 Front Left:
   Subsystem 4 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE0567928
   Seat Backrest Fan 1 Front Right:
   Subsystem 5 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE0935201
   Seat Cushion Fan 1 Front Right:
   Subsystem 6 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE0537213
   Part No SW: 5QA 919 298 H    HW: 5QA 919 298 A
   Component: PLA 3.0 12K   H08 0061
   Serial number: 000259541119268
   Coding: 0271267951
   ASAM Dataset: EV_EPHVA2CAU3700000 009048
   ROD: EV_EPHVA2CAU3700000_VW41.rod
   VCID: 55F7859D75841DB3515-8000
   Part No SW: 2Q0 907 572 R    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H03 0372
   Coding: 320007CB58FF8728949C810530409700000000000000000004
   ROD: EV_ACCMRRCONTIVW376_003_VW27.rod
   VCID: 43D34BC58B1093030F1-8016
0858 - Databus
          [FAULT_KAMERA_SYSTEMZUSTAND_KAMERA_IM_INIT]
                    Reset counter: 67
                    Mileage: 31 km
                    Date: 2020.04.16
                    Time: 18:36:25
                    Voltage terminal 15: 13.3 V
                    Control Module temperature: 43 °C
                    Vehicle speed: 4.16 m/s
                    Longitudinal acceleration: -0.03 m/s²
                    Adaptive distance regulation: status: ACC_StandBy
0836 - Databus
          [FAULT_PREDICTIVE_ROUTEDATA_SIGNALERROR_RECEIVED]
                    Reset counter: 90
                    Mileage: 793 km
                    Date: 2020.10.03
                    Time: 18:48:31
                    Voltage terminal 15: 13.2 V
                    Control Module temperature: 74 °C
                    Vehicle speed: 0.00 m/s
                    Longitudinal acceleration: 0.03 m/s²
   Part No SW: 3Q0 959 655 DB    HW: 3Q0 959 655 DB
   Component: Airbag VW21   006 0720
   Revision: --------    Serial number: 00310M37QVXe
   Coding: 8CCCFC00000000005000001AC20840000065
   ROD: EV_AirbaVW21TS6VW48X.rod
   VCID: 015F81CDD18C41135DD-8054
   Occupant Detection:
   Component: Occ.Detection  H14 0022
   Serial number: IBH0000D19000CPOO00P
   Coding: 303030
   Subsystem 2 - Part No SW: -----------    HW: 454 002 711 19
   Serial number: 35700000000E1B3D224M
   Subsystem 3 - Part No SW: -----------    HW: 454 002 010 19
   Serial number: 358000000001B8600144
   Subsystem 4 - Part No SW: -----------    HW: 454 802 801 20
   Serial number: 3510003CF1F1B000000O
   Subsystem 5 - Part No SW: -----------    HW: 454 802 801 20
   Serial number: 3520096B99E1A000000-
   Subsystem 6 - Part No SW: -----------    HW: 454 802 801 20
   Serial number: 355000365161B0000003
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 454 802 801 20
   Component: FrontSensor_P  304 0149
   Serial number: 356004160161B0000001
   Part No SW: 3G0 920 890 E    HW: 3G0 920 890 E
   Component: KOMBI         503 4193
   Coding: 00A438086F8CCF050288630B50010000A0001009
   ASAM Dataset: EV_DashBoardVDDMQBA0 001042
   ROD: EV_DashBoardVDDMQBA0_VW37.rod
   VCID: 2B03036503807B43D71-807E
   Part No SW: 3Q0 907 530 AC    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5388
   Serial number: 07022000842261
   Coding: 0B0500347F087300FB03225A1E0F00010001070000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 70B9D409EA26589BA23-8024
   Component: 4-01-0e-01-04
   Subsystem 2 - Part No SW: 3G0 959 442 H    HW: 3G0 959 442 H
   Component: E221__MFL-PR6  H06 0110
   Serial number: PR6-0440036015201830
   Coding: 2E0B00
   Serial number: 0621947100
   Power Converter DC AC:
   Subsystem 4 - Part No SW: 3CN 907 155     HW: 3CN 907 155
   Component: U13DCAC  H23 0890
   Serial number: B060193
   Component: Haldex4Motion H55 7084
   Serial number: HA1-00014.11.19
   Coding: 0101
   VCID: 4CC160F9A64E5C7BFEB-8018
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 5Q0 959 760 E    HW: 5Q0 959 760 E
   Component: Sitzmemory    H09 0026
   Serial number: Y0007TA930554
   Coding: 0010000000000500018280808080000000008100000000F400
   ASAM Dataset: EV_SeatMemorDriveSide 002022
   VCID: 3FDB4735E7F8F7E36B9-806A
Address 3C: Lane Change (J1086)       Labels:* None
   Part No SW: 2Q0 907 686 B    HW: 2Q0 907 686 B
   Component: HRE3_Kl15_Mst H06 0148
   Serial number: 11230022775113
   Coding: 62954640
   ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
   ROD: EV_HREntryHellaGen3Kl15.rod
   VCID: 392F292DF9DCD9D355D-806C
   Part No SW: 5Q0 959 593 K    HW: 5Q0 959 593 F
   Component: TSG FS002 0325
   Serial number: YA008TAO00GC1
   Coding: 003B1B205200020000040000
   VCID: 49CF59EDA93C4953C5D-801C
   Subsystem 1 - Part No SW: 5Q4 959 812 G    HW: 5Q4 959 812 G
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000005277632
   Coding: 011000
   Part No SW: 3QF 909 144 B    HW: 3QF 909 144 A
   Component: EPS_MQB_ZFLS  570 1582
   Coding: 9B1F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 47CB5FD5BF28BF23D39-8012
   Part No SW: 5Q0 035 456 A    HW: 5Q0 035 456 A
   Component: MIB2_lite_amp H40 0200
   Revision: 00000001    Serial number: VWZ8Z1KMD06V9D+
   Coding: 2200000002A2AAAA000000000000
   ROD: EV_AMPMst12C1Gen2ALPI.rod
   VCID: 2E050A7130920E6BF0F-807A
   Part No SW: 3Q0 907 338 E    HW: 3Q0 907 338 E
   Component: FCM MQB Low   003 0367
   Serial number: 27012000840740
   Coding: 000000070900135202112300030000000000000000000000000000000000
   ROD: EV_MultiModulContiVW48X_003_VW41.rod
   VCID: 372B2F15CFC8CFA3A39-8062
Address 52: Door Elect, Pass. (J387)       Labels:* Redir Fail!
   Part No SW: 5Q0 959 592 K    HW: 5Q0 959 592 F
   Component: TSG BFS002 0325
   Serial number: YA008TBD002X6
   Coding: 003B13205E00020000040000
   VCID: 48C95CE9B236B05BDA3-801C
   Subsystem 1 - Part No SW: 5Q4 959 811 G    HW: 5Q4 959 811 G
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000005273537
   Coding: 091000
   Part No SW: 2GM 035 876 C    HW: 2GM 035 876 C
   Component: MU-S-NS-US    854 0523
   Coding: 022436020000000051220002001808211F0500E40120040586
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 46D552D1B822A62B28F-8012
   Subsystem 1 - Part No SW: 5G6 919 605 D    HW: 5G6 919 605 D
   Component: ABT_Std-2_Nav  261 8214
   Serial number: VWZ6ZMX0465846
   Subsystem 2 - Part No SW: 5NA 919 866 AF    HW: -----------
   Component: NAR 2020  --- 1320
Address 69: Trailer (J345)       Labels:* None
   Part No SW: 5H0 907 383     HW: 5H0 907 383
   Component: Anhaenger     H09 0040
   Serial number: 000000000005379
   Coding: 0200000200001300
   ASAM Dataset: EV_TrailFunctGener3Hella 001009
   ROD: EV_TrailFunctGener3Hella_VW27.rod
   VCID: 6B83C365C300BB43971-803E
   Part No SW: 5Q0 907 556 C    HW: 5Q0 907 556
   Component: Areaview 2    H13 0608
   Serial number: C854707JG068730
   Coding: 01140600A30F20003000400C
   ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
   ROD: EV_CamSysRVAV2ARCE2MQBAB.rod
   Part No SW: 5Q0 959 107 S    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0271
   Revision: --------    Serial number: A2-C758-8680-4
   Coding: 2F88
   Part No SW: 5WA 035 283     HW: 5WA 035 283
   Component: OCUGen3Low    H10 0295
   Serial number: 0000000911NVWP6
   Coding: 0241602019682C208005461160500607
   ASAM Dataset: EV_OCUGen3Low 002036
   ROD: EV_OCUGen3Low_002_VW41.rod
   VCID: 025D8EC1D48A5A0B447-8056
1644017 - Online Services
          B1915 F1 [008] - Temporary Function Restriction due to Battery Budget
          [Functional restriction due to insufficient power budget]
                    Reset counter: 4
                    Voltage terminal 30: 12.2 V
                    Remaining long term energy budget: 0 mAh
                    Remaining short term energy budget: 936 mAh
                    Wake up cycles counter: 115
   Part No SW: 2Q0 980 653     HW: 2Q0 980 653
   Component: MQB MFK 3.0   H11 1029
   Serial number: E33417011193400
   Coding: 00000A081178C020B09F00001020002000210000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 005035
   ROD: EV_MFK3ValeoMQB_005_VW27.rod
   VCID: 72BDDE01E42A6A8B547-8026
1124198 - Development code 1
          B2F01 00 [008] - -
          [VZF_Init]
                    Fault Priority: 9
                    Reset counter: 26
                    Mileage: 164 km
                    Date: 2020.09.17
                    Time: 09:19:33
   Coding: 00804074161C
   ROD: EV_SunRoofCONTIAU736_009_VW37.rod
   VCID: 75B7E51D95447DB3715-8020
Address D6: Light Ctrl Left 2 (A31)       Labels: None
   Part No SW: 992 941 572 AA    HW: 992 941 572 A
   Component: LED1L         H08 9002
   ROD: EV_LLPGen3LKEBODPO68X_VW27.rod
   VCID: 629DAE4134CAFA0B247-8036
Address D7: Light Ctrl Right 2 (A27)       Labels: None
   Component: LED1R         H08 9002
End----------(Elapsed Time: 01:52, VBatt start/end: 12.2V/12.2V)-----------
