Good afternoon all from Summer in Ireland, where the rain is still warm.
I'm looking for a steer before I get the spanners out. The above vehicle is reporting fault code 00778, mechanical failure of the steering angle sensor. This is the type where it's built into the steering rack and not the steering column. It has history with the steering angle sensor as when the car was bought the dash was lit up like a Christmas tree. A new steering column control sorted most of the warning lights and a calibration of the steering angle sensor put out the TPMS and ESP warning lights. But now, some three months later, the TPMS and ESP lights are back on and the scan shows mechanical failure. The steering wheel also is no longer pointing dead ahead either. It's about a couple of degrees out clockwise. It did rip a tyre from a protruding fallen tree branch but not enough to damage the steering components but I cant be sure the jolt wasn't behind the current issue. Nothing is obviously out of whack, other than the steering wheel.
Before I tear everything down anyone had experience of this code and or working on this type of steering rack?
p.s. I'm sure it wasn't the little folk either.
Sunday,13,September,2020,12:43:29:23705
VCDS Version: 20.4.2.0 (x64) HEX-V2 CB: 0.4526.4
VIN: VSSZZZ1PZAR068638 License Plate:
Chassis Type: 1P-SE35 (1K0)
Scan: 01 03 08 09 15 16 17 19 25 2E 42 44 46 52 56 61 77
VIN: VSSZZZ1PZAR068638 Mileage: 276930km-172076miles
Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 GP HW: 03L 906 023 GG
Component: R4 1.6l TDI H23 9979
Revision: --H23--- Serial number:
Coding: 00114014030501080000
ASAM Dataset: EV_ECM16TDI02103L906023GP 003013
ROD: EV_ECM16TDI02103L997557R.rod
VCID: 7AADF778EC5A904B1C7-802E
Part No SW: 1K0 907 379 AJ HW: 1K0 907 379 AJ
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 133B201209280002C81104E790210091350800
Shop #: WSC 04941 000 00000
VCID: 7AADF778ECDA904B1C7-802E
003 - Mechanical Failure
Fault Status: 01100011
Reset counter: 0
Mileage: 275934 km
Date: 2015.01.22
Time: 01:41:35
Count: 32768
Count: 4608
Count: 288
Count: 51524
Count: 65281
Count: 64513
Part No SW: 5P0 820 047 P HW: 5P0 820 047 P
Component: Climatic PQ35 014 0707
Revision: 00014014 Serial number: 00000000000000
VCID: 3A2D3778A05A504B5C7-806E
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
Part No SW: 5K0 937 085 D HW: 5K0 937 085 D
Component: BCM PQ35 B+ 011 0029
Revision: BB011001
Coding: 46180A3E9005B0904688008091000004050100A8425D81605C80C7000001
VCID: 343119408E3EA63B86B-8060
Subsystem 1 - Part No: 1P0 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 25031 22 0611
Coding: 00DB90
Subsystem 2 - Part No: 1P0 951 171
Component: Innenraumuebe 010 4971
01598 - Drive Battery Voltage
Reset counter: 31
Mileage: 276930 km
Date: 2015.02.04
Time: 19:43:44
Voltage: 12.00 V
Part No SW: 5N0 959 655 J HW: 5N0 959 655 J
Component: J234__A0E VW10 HI 1916
Revision: 20013000 Serial number: 003E2P20Q3C1
Coding: 0012357
Shop #: WSC 06402 785 00200
VCID: 44D14980D29E16BB36B-8010
Subsystem 1 - Serial number: 6332MTS646180470
Subsystem 2 - Serial number: 6342MTS643450470
Subsystem 3 - Serial number: 6351HTS6H55M69KJ
Subsystem 4 - Serial number: 6361HTS6OH4O69KJ
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CF HW: 1K0 953 549 CF
Component: J0527 856 0111
Coding: 0000502
VCID: 78A9ED70DED6825B6A3-802C
Subsystem 1 - Part No: 1P0 959 538 D Labels: 3C8-959-537.CLB
Component: E221__MFL-TAP H02 0101
Coding: 00000226
Part No SW: 1P0 920 953 B HW: 1P0 920 953 B
Component: KOMBI H07 0307
Coding: 410A00
VCID: 2F3B162C679885E3FB9-807A
Part No SW: 1K0 907 530 AF HW: 1K0 907 951
Component: J533 Gateway H17 0233
Revision: H17 Serial number: 1521J1031902A6
Coding: E9801F06000612040203
VCID: 6B83C23C9F8039C3971-803E
Component: IMMO H07 0307
VCID: 6A8DC7389CFA20CBEC7-803E
Part No SW: 5N0 035 342 B HW: 5N0 035 342 B
Revision: A1001003 Serial number: 7667937155
Coding: 020000
VCID: 2615F30848E2C4AB08F-8072
Part No SW: 1T0 959 701 AD HW: 3C0 959 793
Component: TUER-SG FT 002 0306
Revision: 13101005 Serial number: 0000216149
Coding: 020230
ROD: EV_DCU42BroseDriveSide.rod
VCID: 79AFE874E95C9B5315D-802C
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 65 3001
Revision: 00H17000
VCID: 313F10547D2C9313EDD-8064
Part No SW: 1T0 959 702 AB HW: 3C0 959 792
Component: TUER-SG BT 002 0306
Revision: 15101005 Serial number: 0000435963
Coding: 020230
ROD: EV_DCU52BrosePasseSide.rod
VCID: 78A9ED70D256825B6A3-802C
Part No SW: 1P0 035 153 B HW: 1P0 035 153 B
Component: Radio G3 UL H59 0060
Revision: 0H001001 Serial number: SEZ1Z2K6546968
Coding: 0102040004
VCID: 2411E9003EDE36BB16B-8070
Part No SW: 1K0 907 534 HW: 1K0 907 951
Component: Batt.regelung H17 0233
Revision: -------- Serial number: 1521J1031902A6
Coding: 030B085A
VCID: 6889BD30827612DBFA3-803C
Subsystem 1 - Part No SW: 1K0 915 181 C HW: 1K0 915 181 A
Component: J367-BDM H07 0125
Serial number: 00000000002790170325
00458 - Control Module for Battery Monitoring (J367)
014 - Defective
Fault Status: 01101110
Reset counter: 31
Mileage: 276930 km
Date: 2015.02.04
Time: 19:45:47
Address 77: Telephone Labels: 5P0-862-335.lbl
Part No SW: 1Z0 035 729 E HW: 1Z0 035 729 E
Component: FSE_2P8x H40 0190
Revision: 00000000 Serial number: 00000005235817
Coding: 0010555
End----------(Elapsed Time: 01:18, VBatt start/end: 12.3V/12.1V)-----------
