2019 GTI - Instruments Output Tests - Component CP
corradokid
CA, USA
C?ID=32540
I think I just made a stupid mistake with my new 2019 GTI. I was going through output tests for module 17 - Instruments and I ended up testing all of the tests available to my car, including the last test Component CP :cry: Now I have flashing instrument lighting, warning lights on, airbag error, and my MIB2 says "Component Protection." After researching this I've realized my mistake and there should never be a reason to test this function!
Is the only way to go to a dealer and have them connect with ODIS to reactivate the functions in my car? I'm already trying to figure out how to explain this to them if so. :facepalm:
Thank you for insight on what next steps to take.
-Alden
Sunday,02,August,2020,19:15:13:41546VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(Parallels)
VCDS Version 20.4.2.0 (x64)  HEX-NET CB: 0.4526.4
VIN: 3VW5T7AU7KM035767   License Plate:
Mileage: 1422km-883mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 05 08 09 10 13 14 15 17 19 29 2B 32 39 3C 42 44 47 4B
          52 5F 75 A5 A9 D6 D7
VIN: 3VW5T7AU7KM035767   Mileage: 1422km-883miles
Address 01: Engine (J623-DKFA)       Labels: None
   Part No SW: 5G0 906 259 Q    HW: 06K 907 425 J
   Component: R4 2.0l TFSI  H13 0005
   Revision: --H13---
   Coding: 091900322444002F1000
   Shop #: WSC 00066 790 00072
   ASAM Dataset: EV_ECM20TFS0205G0906259Q 001006
   ROD: EV_ECM20TFS0205G0906259Q.rod
   VCID: 3C341CE4B7C9ED660F-8069
Readiness: 1110 1101
   Part No SW: 5Q0 614 517 FC    HW: 5Q0 614 517 BM
   Component: ESC           H45 0191
   Revision: 00000000    Serial number: 52309000000896
   Coding: 01FA6BA150230971407E020660CA6880D60A900240061636344350D1D0A94B0B0000000012121212B835351919323200
   Shop #: WSC 28436 004 1048576
   VCID: 77BEC3C8CE6F0E3E22-8023
   Part No SW: 3Q0 959 435 N    HW: 3Q0 959 435 N
   Component: VWKESSYMQB    037 1307
   Revision: 00037000    Serial number: 0522422179
   Coding: 132C0C0623
   Shop #: WSC 00066 790 00088
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 45C27900C403ACAE60-8011
   Part No SW: 5GM 907 044 G    HW: 5GM 907 044 G
   Component: Climatronic   H04 2001
   Revision: 00001K05
   Coding: 0002001420011800010400401211100C
   ASAM Dataset: EV_ACClimaBHBVW37X 006146
   VCID: 48DC7034F311B1C69B-801D
   Geber f¸r K‰ltemitteldruck/K‰ltemitteltemperatur:
   Part No SW: 5Q0 937 087 BA    HW: 5Q0 937 087 BA
   Revision: --------    Serial number: C86417091904JL
   Shop #: WSC 00066 790 00239
   ROD: EV_BCMBOSCH_019.rod
   VCID: 7BB6DFF8F2472A5E46-802F
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    190704  043 0551
   Serial number: 97022066190711070557
   Component: RLHS  051 0206
   Serial number: SAY19M07D17H08M56S32
   Coding: 06A8DD
   Sun Roof:
   Subsystem 3 - Part No SW: 5GD 959 591 A    HW: 5GD 959 591 A
   Component: J245 PS60.006  H07 0170
   Serial number: 03691616341912181602
   Coding: 181803
   Steering Column Switch:
   Subsystem 5 - Part No SW: 5Q1 953 521 M    HW: 5Q1 953 569
   Component: Lenks.Modul  H03 0170
   Serial number: 0300060920190C202228
526359 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [Steuerger‰t falsch codiert->Keine Anzeige]
                    Reset counter: 35
                    Mileage: 1422 km
                    Date: 2020.08.02
                    Time: 19:13:00
   Part No SW: 5QA 919 298 D    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0050
   Serial number: 000137089R19231
   Coding: 0271167801
   ASAM Dataset: EV_EPHVA2CAU3700000 009041
   VCID: 51EA5D50004B700ECC-8005
   Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
   Coding: 2D0040C141FFC728949C810510401600000000000000000004
   VCID: 44C46404CF3995A677-8011
   Serial number: 02071941350541
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 383C00F483F1C146EB-806D
   Serial number: 003GCR0CCGJV
   VCID: 47DE7308FE0FBEBE92-8013
   Occupant Detection:
   Component: BF-Gewichtss.  H14 0022
   Serial number: IBH00000000000C1OCDM
   Coding: 303131
   Subsystem 2 - Part No SW: -----------    HW: 480 002 007 19
   Serial number: 35700000000B967C6D3$
   Subsystem 3 - Part No SW: -----------    HW: 480 002 007 19
   Serial number: 35800000000AC861DD3$
   Subsystem 4 - Part No SW: -----------    HW: 480 401 907 19
   Component: SideSensor_Dr  005 6149
   Serial number: 3510001C2F11B85639FC
   Subsystem 5 - Part No SW: -----------    HW: 480 402 007 19
   Component: SideSensor_Pr  005 6149
   Serial number: 3520001AAF11B856C37E
   Subsystem 6 - Part No SW: -----------    HW: 480 400 908 19
   Component: FrontSensor_D  005 6149
   Serial number: 3550001C4F08AF8832ER
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 400 908 19
   Component: FrontSensor_P  005 6149
   Serial number: 3560001C4F08AF88381L
9483008 - Seat Occupied Recognition
          B10B3 00 [137] - Function Restriction due to Implausible Message(s)
                    Reset counter: 35
                    Mileage: 1422 km
                    Date: 2020.08.02
                    Time: 19:13:19
          U1101 00 [137] - Active
          [ATP Inconsistency]
                    Mileage: 1422 km
                    Date: 2020.08.02
                    Time: 19:13:03
   Part No SW: 5G1 920 856 D    HW: 5G1 920 856 D
   Component: KOMBI         351 2700
   Coding: 0BAD0912FD88CF0502887B0B5001000080000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009068
   VCID: 2F2E3BA876BF06FEBA-807B
15361024 - Component Protection
          U1101 00 [009] - Active
                    Reset counter: 35
                    Mileage: 1422 km
                    Date: 2020.08.02
                    Time: 19:13:00
   Part No SW: 3Q0 907 530 AA    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5366
   Serial number: 19091900841687
   Coding: 0101000830085900FB00023B880F00000001070000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 6E90E6ACB1354FF6F1-803B
   Component: 0-00-0d-00-04
   Subsystem 2 - Part No SW: 5G0 959 442 AE    HW: 5G0 959 442 AE  Labels: 3C8-959-537.CLB
   Component: E221__MFL-MD9  H12 0052
   Serial number: 29190001253840049231
   Coding: 2CFFFF
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
   Component: LCM_MLBevoH08 0014
   Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
   Component: ELV-MQBB      H08 0021
   Serial number: 19000208919002
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 312A3DD0608B100EAC-8065
Address 32: Differential Locks (J492)       Labels:* 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 P    HW: 0CQ 907 554 P
   Component: Quersperre    H55 8043
   Serial number: HA1-00021.03.19
   Coding: 0001
   ASAM Dataset: EV_LockElectHA1VW37X 001007
   ROD: EV_LockElectHA1VW37X.rod
   VCID: 52E8525C054D0B16F5-8007
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
   Component: HRE_Master    H12 0081
   Serial number: 0522581830
   Coding: 02011103
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3D3211E0ACD3E46E38-8069
   Component: HRE_Slave  H12 0081
   Serial number: 0525442080
   Coding: 020111
   Part No SW: 5Q4 959 593 M    HW: 5Q4 959 593 F
   Component: TSG FS        006 0247
   Serial number: 42038923401373
   Coding: 003E13200000040000000000
   Shop #: WSC 01383 790 50316
   ROD: EV_DCU2DriveSideMAXHKLO.rod
   VCID: 4FEE5B28167F66FEDA-801B
   Subsystem 1 - Part No SW: 5Q4 959 811 F    HW: 5Q4 959 811 F  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000004066896
   Coding: 011000
   Part No SW: 5QN 909 144 B    HW: 5QN 909 144 A
   Component: EPS_MQB_ZFLS  507 5082
   Coding: 930A0000
   ROD: EV_SteerAssisMQB_015.rod
Address 47: Sound System (J525)       Labels:| 5Q0-035-456.clb
   Part No SW: 5Q0 035 456 A    HW: 5Q0 035 456 A
   Component: MIB2_lite_amp H40 0200
   Revision: 00000001    Serial number: VWZ8Z1KMD05QU22
   VCID: 2E1026AC71B50FF6B1-807B
          [Anti-theft protection - component protection active (0xEA6300)]
                    Reset counter: 35
                    Mileage: 1422 km
                    Date: 2020.08.02
                    Time: 19:12:59
                    Voltage terminal 30: 12.3 V
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V2.clb
   Part No SW: 3Q0 907 338 C    HW: 3Q0 907 338 C
   Component: FCM MQB Low   002 0345
   Serial number: 23081900840006
   Coding: 000000050900210A07110F01030000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 002006
   ROD: EV_MultiModulContiVW48X_002_VW37.rod
   VCID: 352209C094E33C2EF0-8061
   Part No SW: 5Q4 959 592 M    HW: 5Q4 959 592 F
   Component: TSG BFS       006 0247
   Serial number: 46038924501558
   ROD: EV_DCU2PasseSideMAXHKLO.rod
   VCID: 4ED0462C11756FF6D1-801B
   Subsystem 1 - Part No SW: 5Q4 959 812 F    HW: 5Q4 959 812 F  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000004071445
   Coding: 091000
   Part No SW: 3Q0 035 876 B    HW: 3Q0 035 876 B
   Component: MU-S-NS-US    853 0890
   Coding: 027310020000000041220002001808001F0503F401200500C6
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 332637D89A97221EDE-8067
   Subsystem 1 - Part No SW: 5G6 919 605 D    HW: 5G6 919 605 D
   Component: ABT_Std-2_Nav  254 8130
   Serial number: VWZ6ZMW2625263
   Subsystem 2 - Part No SW: 5NA 919 866 E    HW: -----------
   Component: NAR 2018/19  --- 0810
                    Reset counter: 35
                    Mileage: 1422 km
                    Date: 2020.08.02
                    Time: 19:13:01
   Component: OCULowMQBUS   009 0570
   Coding: 02730002C2823A017F1E06000000
   ROD: EV_OCULowMQB.rod
   VCID: 43C66718CA37929E4E-8017
   Part No SW: 3Q0 980 654 L    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H12 0610
   Serial number: 09071915P20826
   Coding: 000307000002020100221354C150490084000E20012000
   ROD: EV_MFKBoschMQBB_002.rod
   VCID: 40CC6814DB21898653-8015
   Part No SW: 5G0 907 159 G    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0001
   Serial number: 190614203113
   VCID: 322832DC658D2B16D5-8067
   Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
   Component: LED1L         H06 0002
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
   VCID: 393A05F0B8FBD84E14-806D
   Component: LED1R         H06 0002
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
   ROD: EV_LEDMinMaxRKEBODVW481.rod
End----------(Elapsed Time: 01:44, VBatt start/end: 12.3V/12.3V)-----------
NEtech
C?ID=56995
Try and post Adaptation Controller maps, from [17-Instrument] and [19-CAN Gateway].
corradokid
CA, USA
C?ID=32540
Adaptation map for 17 - Instruments
[FONT=&quot];SW:5G1-920-856-D HW:5G1-920-856-D --- Instruments[/FONT]
[FONT=&quot];Component:KOMBI 351 2700[/FONT] [FONT=&quot]Coding:0BAD0912FD88CF0502887B0B5001000080000000[/FONT]
[FONT=&quot];EV_DashBoardVDDMQBAB[/FONT] [FONT=&quot]9068[/FONT] [FONT=&quot]EV_DashBoardVDDMQBAB_009_VW37.rod[/FONT]
[FONT=&quot];Monday[/FONT] [FONT=&quot]3[/FONT] [FONT=&quot]August[/FONT] [FONT=&quot]2020[/FONT] [FONT=&quot]08:25:19:41546[/FONT]
[FONT=&quot];VCDS Version: Release 20.4.2 (x64) Data version: 20200730 DS317.0[/FONT]
[FONT=&quot];VCID: 2F2E3BA876BF06FEBA-807B[/FONT]
[FONT=&quot]IDE00295-Oil temperature display[/FONT] [FONT=&quot]On [/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]IDE00301-Distance[/FONT] [FONT=&quot]1425 km[/FONT] [FONT=&quot]3[/FONT]
[FONT=&quot]IDE00342-ESI: Resetting ESI[/FONT] [FONT=&quot]no warning [/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]IDE00343-Language version[/FONT] [FONT=&quot]US English [/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]IDE00345-MAS00234-MFA3-Reset-MFI button RESET / OK[/FONT] [FONT=&quot]Manual reset: not possible [/FONT] [FONT=&quot]3[/FONT]
[FONT=&quot]IDE00345-MAS05463-MFA3-Reset-Refuel detection gasoline / diesel[/FONT] [FONT=&quot]MFA3-Reset[/FONT] [FONT=&quot]3[/FONT]
[FONT=&quot]IDE00345-MAS05464-MFA3-Reset-Refuel detection gas[/FONT] [FONT=&quot]MFA3-Reset[/FONT] [FONT=&quot]3[/FONT]
[FONT=&quot]IDE00345-MAS12879-MFA3-Reset-Electrical refueling detection[/FONT] [FONT=&quot]MFA3-Reset[/FONT] [FONT=&quot]3[/FONT]
[FONT=&quot]IDE00499-Display correction of consumptions and operating range[/FONT] [FONT=&quot]100%[/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]IDE00500-Hour[/FONT] [FONT=&quot]8 H[/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]IDE00501-Minute[/FONT] [FONT=&quot]25 min[/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]IDE00502-Year[/FONT] [FONT=&quot]2020 yr[/FONT] [FONT=&quot]2[/FONT]
[FONT=&quot]IDE00503-Month[/FONT] [FONT=&quot]8 mon[/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]IDE00504-Day[/FONT] [FONT=&quot]3 d[/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]IDE00510-ESI: distance driven from inspection[/FONT] [FONT=&quot]1405 km[/FONT] [FONT=&quot]3[/FONT]
[FONT=&quot]IDE00511-ESI: time from inspection[/FONT] [FONT=&quot]188 d[/FONT] [FONT=&quot]2[/FONT]
[FONT=&quot]IDE00512-ESI: minimum value km-driving distance/inspection[/FONT] [FONT=&quot]15000 km[/FONT] [FONT=&quot]2[/FONT]
[FONT=&quot]IDE00513-ESI: maximum value km-driving distance/inspection[/FONT] [FONT=&quot]30000 km[/FONT] [FONT=&quot]2[/FONT]
[FONT=&quot]IDE00514-ESI: maximum value of time between inspections[/FONT] [FONT=&quot]730 d[/FONT] [FONT=&quot]2[/FONT]
[FONT=&quot]IDE00515-ESI: oil quality[/FONT] [FONT=&quot]poor oil quality [/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]IDE00517-ESI: soot entry[/FONT] [FONT=&quot]0 km[/FONT] [FONT=&quot]2[/FONT]
[FONT=&quot]IDE00518-ESI: thermal load[/FONT] [FONT=&quot]2400 km[/FONT] [FONT=&quot]2[/FONT]
[FONT=&quot]IDE00819-Day counter[/FONT] [FONT=&quot]311 d[/FONT] [FONT=&quot]2[/FONT]
[FONT=&quot]IDE00820-Activating and deactivating all development messages[/FONT] [FONT=&quot]not active [/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]IDE00827-ESI: minimum value of time between inspections[/FONT] [FONT=&quot]365 d[/FONT] [FONT=&quot]2[/FONT]
[FONT=&quot]IDE01153-SIA: maximum value of distance to service[/FONT] [FONT=&quot]16100 km[/FONT] [FONT=&quot]2[/FONT]
[FONT=&quot]IDE01154-SIA: maximum value of time to service[/FONT] [FONT=&quot]365 d[/FONT] [FONT=&quot]2[/FONT]
[FONT=&quot]IDE02489-Display depiction[/FONT] [FONT=&quot]Version 3[/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]IDE02818-IDE02689-Offset for tank calibration values-Complete tank calibration[/FONT] [FONT=&quot]-12.8 l[/FONT] [FONT=&quot]5[/FONT]
[FONT=&quot]IDE02818-MAS02376-Offset for tank calibration values-Offset sensor 1[/FONT] [FONT=&quot]-12.8 l[/FONT] [FONT=&quot]5[/FONT]
[FONT=&quot]IDE02818-MAS02377-Offset for tank calibration values-Offset sensor 2[/FONT] [FONT=&quot]12.7 l[/FONT] [FONT=&quot]5[/FONT]
[FONT=&quot]IDE02818-MAS02378-Offset for tank calibration values-Offset sensor 3[/FONT] [FONT=&quot]12.7 l[/FONT] [FONT=&quot]5[/FONT]
[FONT=&quot]IDE02818-MAS02379-Offset for tank calibration values-Offset sensor 4[/FONT] [FONT=&quot]12.7 l[/FONT] [FONT=&quot]5[/FONT]
[FONT=&quot]IDE03329-Driving profiled for range remaining[/FONT] [FONT=&quot]8.4 l/100km[/FONT] [FONT=&quot]2[/FONT]
[FONT=&quot]IDE03346-IDE00301-Units adjusted-Distance[/FONT] [FONT=&quot]miles [/FONT] [FONT=&quot]3[/FONT]
[FONT=&quot]IDE03346-MAS01230-Units adjusted-Date[/FONT] [FONT=&quot]mm_dd_yy [/FONT] [FONT=&quot]3[/FONT]
[FONT=&quot]IDE03346-MAS01456-Units adjusted-Speed[/FONT] [FONT=&quot]Miles per hour [/FONT] [FONT=&quot]3[/FONT]
[FONT=&quot]IDE03346-MAS02201-Units adjusted-Temperature[/FONT] [FONT=&quot]Degrees Fahrenheit [/FONT] [FONT=&quot]3[/FONT]
[FONT=&quot]IDE03346-MAS02957-Units adjusted-Time[/FONT] [FONT=&quot]12h AM_PM[/FONT] [FONT=&quot]3[/FONT]
[FONT=&quot]IDE03346-MAS03032-Units adjusted-Volume[/FONT] [FONT=&quot]gallons (US) [/FONT] [FONT=&quot]3[/FONT]
[FONT=&quot]IDE03346-MAS03034-Units adjusted-Pressure[/FONT] [FONT=&quot]psi [/FONT] [FONT=&quot]3[/FONT]
[FONT=&quot]IDE03346-MAS05637-Units adjusted-Operating range consumption: CNG (compressed natural gas)[/FONT] [FONT=&quot]kg per 100 km[/FONT] [FONT=&quot]3[/FONT]
[FONT=&quot]IDE03346-MAS05638-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas)[/FONT] [FONT=&quot]Miles per gallon (US) [/FONT] [FONT=&quot]3[/FONT]
[FONT=&quot]IDE03346-MAS05875-Units adjusted-Average consumption: electric drive[/FONT] [FONT=&quot]kWh per 100 km[/FONT] [FONT=&quot]3[/FONT]
[FONT=&quot]IDE03346-MAS13665-Units adjusted-Trailer/support load ground[/FONT] [FONT=&quot]kilogram (kg) [/FONT] [FONT=&quot]3[/FONT]
[FONT=&quot]IDE03348-MAS01456-Speed warning-Speed[/FONT] [FONT=&quot]0[/FONT] [FONT=&quot]2[/FONT]
[FONT=&quot]IDE03348-MAS01561-Speed warning-Unit[/FONT] [FONT=&quot]Miles per hour [/FONT] [FONT=&quot]2[/FONT]
[FONT=&quot]IDE03348-Speed warning-[/FONT] [FONT=&quot]not active [/FONT] [FONT=&quot]2[/FONT]
[FONT=&quot]IDE03349-FIX: Max. distance until next mileage-related inspection[/FONT] [FONT=&quot]32200 km[/FONT] [FONT=&quot]2[/FONT]
[FONT=&quot]IDE03350-FIX: Maximum time until next time-dependent inspection[/FONT] [FONT=&quot]730 d[/FONT] [FONT=&quot]2[/FONT]
[FONT=&quot]IDE03351-FIX: Distance covered since last mileage-dependent inspection[/FONT] [FONT=&quot]1400 km[/FONT] [FONT=&quot]2[/FONT]
[FONT=&quot]IDE03352-FIX: Time since last time-dependent inspection[/FONT] [FONT=&quot]188 d[/FONT] [FONT=&quot]2[/FONT]
[FONT=&quot]IDE03372-Source for synchronization of time[/FONT] [FONT=&quot]GPS [/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]IDE03568-ENG119828-Service-key settings-p_deactivate_SK_Function[/FONT] [FONT=&quot]On [/FONT] [FONT=&quot]5[/FONT]
[FONT=&quot]IDE03568-ENG99943-Service-key settings-p_forcewrite_qual_time[/FONT] [FONT=&quot]10 s[/FONT] [FONT=&quot]5[/FONT]
[FONT=&quot]IDE03568-ENG119827-Service-key settings-p_main_switch_Basic[/FONT] [FONT=&quot]On [/FONT] [FONT=&quot]5[/FONT]
[FONT=&quot]IDE03568-ENG102414-Service-key settings-p_main_switch_keyless[/FONT] [FONT=&quot]On [/FONT] [FONT=&quot]5[/FONT]
[FONT=&quot]IDE03568-ENG102611-Service-key settings-p_write_delay_speed[/FONT] [FONT=&quot]20 km/h[/FONT] [FONT=&quot]5[/FONT]
[FONT=&quot]IDE03568-ENG103545-Service-key settings-p_write_delay_time[/FONT] [FONT=&quot]40 s[/FONT] [FONT=&quot]5[/FONT]
[FONT=&quot]IDE03568-ENG104099-Service-key settings-p_write_distance[/FONT] [FONT=&quot]20 km[/FONT] [FONT=&quot]5[/FONT]
[FONT=&quot]IDE03867-Deactivate seat belt warning[/FONT] [FONT=&quot]No [/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]IDE05930-Service notification in days[/FONT] [FONT=&quot]30 d[/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]IDE05931-FIX: Reset value for next mileage-dependent inspection[/FONT] [FONT=&quot]32200 km[/FONT] [FONT=&quot]2[/FONT]
[FONT=&quot]IDE05932-FIX: Reset value for next time-dependent inspections[/FONT] [FONT=&quot]730 d[/FONT] [FONT=&quot]2[/FONT]
[FONT=&quot]IDE05971-Vehicle Positioning System Interface Control Module[/FONT] [FONT=&quot]not installed [/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]IDE06425-Roller test bench mode: functional[/FONT] [FONT=&quot]not activated [/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]IDE06588-Ignition active message: actuator[/FONT] [FONT=&quot]No display [/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]IDE06922-No-voltage display[/FONT] [FONT=&quot]Unknown (2)[/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]IDE07221-Cylinder shut-off[/FONT] [FONT=&quot]Display [/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]IDE11086-Service notification[/FONT] [FONT=&quot]30 d[/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]IDE11932-MAS01877-Display of colour adjustment-Red[/FONT] [FONT=&quot]0[/FONT] [FONT=&quot]3[/FONT]
[FONT=&quot]IDE11932-MAS01878-Display of colour adjustment-Green[/FONT] [FONT=&quot]0[/FONT] [FONT=&quot]3[/FONT]
[FONT=&quot]IDE11932-MAS01879-Display of colour adjustment-Blue[/FONT] [FONT=&quot]0[/FONT] [FONT=&quot]3[/FONT]
[FONT=&quot]IDE12226-MAS03686-Display of longitudinal regulation coordinator-Automatic distance regulation[/FONT] [FONT=&quot]active [/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]IDE12226-MAS05203-Display of longitudinal regulation coordinator-CCS[/FONT] [FONT=&quot]not active [/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]IDE12226-MAS10720-Display of longitudinal regulation coordinator-Speed limiter[/FONT] [FONT=&quot]not active [/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]IDE14220-Vehicle speed warning for India-[/FONT] [FONT=&quot]No [/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]IDE14220-Vehicle speed warning for India-[/FONT] [FONT=&quot]0 s[/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]MAS03555-Lap counter[/FONT] [FONT=&quot]No display [/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]MAS03685-Digital speedometer[/FONT] [FONT=&quot]Display [/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]ENG117917-BAP_Debug_Mode_Release[/FONT] [FONT=&quot]not_released [/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1[/FONT] [FONT=&quot]OFF [/FONT] [FONT=&quot]20[/FONT]
[FONT=&quot]ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10[/FONT] [FONT=&quot]OFF [/FONT] [FONT=&quot]20[/FONT]
[FONT=&quot]ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11[/FONT] [FONT=&quot]OFF [/FONT] [FONT=&quot]20[/FONT]
[FONT=&quot]ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12[/FONT] [FONT=&quot]OFF [/FONT] [FONT=&quot]20[/FONT]
[FONT=&quot]ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13[/FONT] [FONT=&quot]OFF [/FONT] [FONT=&quot]20[/FONT]
[FONT=&quot]ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14[/FONT] [FONT=&quot]OFF [/FONT] [FONT=&quot]20[/FONT]
[FONT=&quot]ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15[/FONT] [FONT=&quot]OFF [/FONT] [FONT=&quot]20[/FONT]
[FONT=&quot]ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16[/FONT] [FONT=&quot]OFF [/FONT] [FONT=&quot]20[/FONT]
[FONT=&quot]ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17[/FONT] [FONT=&quot]OFF [/FONT] [FONT=&quot]20[/FONT]
[FONT=&quot]ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18[/FONT] [FONT=&quot]OFF [/FONT] [FONT=&quot]20[/FONT]
[FONT=&quot]ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19[/FONT] [FONT=&quot]OFF [/FONT] [FONT=&quot]20[/FONT]
[FONT=&quot]ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2[/FONT] [FONT=&quot]OFF [/FONT] [FONT=&quot]20[/FONT]
[FONT=&quot]ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20[/FONT] [FONT=&quot]OFF [/FONT] [FONT=&quot]20[/FONT]
[FONT=&quot]ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21[/FONT] [FONT=&quot]OFF [/FONT] [FONT=&quot]20[/FONT]
[FONT=&quot]ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22[/FONT] [FONT=&quot]OFF [/FONT] [FONT=&quot]20[/FONT]
[FONT=&quot]ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23[/FONT] [FONT=&quot]OFF [/FONT] [FONT=&quot]20[/FONT]
[FONT=&quot]ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24[/FONT] [FONT=&quot]OFF [/FONT] [FONT=&quot]20[/FONT]
[FONT=&quot]ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25[/FONT] [FONT=&quot]OFF [/FONT] [FONT=&quot]20[/FONT]
[FONT=&quot]ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26[/FONT] [FONT=&quot]OFF [/FONT] [FONT=&quot]20[/FONT]
[FONT=&quot]ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27[/FONT] [FONT=&quot]OFF [/FONT] [FONT=&quot]20[/FONT]
[FONT=&quot]ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28[/FONT] [FONT=&quot]OFF [/FONT] [FONT=&quot]20[/FONT]
[FONT=&quot]ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29[/FONT] [FONT=&quot]OFF [/FONT] [FONT=&quot]20[/FONT]
[FONT=&quot]ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3[/FONT] [FONT=&quot]OFF [/FONT] [FONT=&quot]20[/FONT]
[FONT=&quot]ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30[/FONT] [FONT=&quot]OFF [/FONT] [FONT=&quot]20[/FONT]
[FONT=&quot]ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31[/FONT] [FONT=&quot]OFF [/FONT] [FONT=&quot]20[/FONT]
[FONT=&quot]ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32[/FONT] [FONT=&quot]OFF [/FONT] [FONT=&quot]20[/FONT]
[FONT=&quot]ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33[/FONT] [FONT=&quot]OFF [/FONT] [FONT=&quot]20[/FONT]
[FONT=&quot]ENG119877-ENG125183-Configuration of Development CAN-Messages-Block 34[/FONT] [FONT=&quot]OFF [/FONT] [FONT=&quot]20[/FONT]
[FONT=&quot]ENG119877-ENG125184-Configuration of Development CAN-Messages-Block 35[/FONT] [FONT=&quot]OFF [/FONT] [FONT=&quot]20[/FONT]
[FONT=&quot]ENG119877-ENG125185-Configuration of Development CAN-Messages-Block 36[/FONT] [FONT=&quot]OFF [/FONT] [FONT=&quot]20[/FONT]
[FONT=&quot]ENG119877-ENG125186-Configuration of Development CAN-Messages-Block 37[/FONT] [FONT=&quot]OFF [/FONT] [FONT=&quot]20[/FONT]
[FONT=&quot]ENG119877-ENG125187-Configuration of Development CAN-Messages-Block 38[/FONT] [FONT=&quot]OFF [/FONT] [FONT=&quot]20[/FONT]
[FONT=&quot]ENG119877-ENG125188-Configuration of Development CAN-Messages-Block 39[/FONT] [FONT=&quot]OFF [/FONT] [FONT=&quot]20[/FONT]
[FONT=&quot]ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4[/FONT] [FONT=&quot]OFF [/FONT] [FONT=&quot]20[/FONT]
[FONT=&quot]ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5[/FONT] [FONT=&quot]OFF [/FONT] [FONT=&quot]20[/FONT]
[FONT=&quot]ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6[/FONT] [FONT=&quot]OFF [/FONT] [FONT=&quot]20[/FONT]
[FONT=&quot]ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7[/FONT] [FONT=&quot]OFF [/FONT] [FONT=&quot]20[/FONT]
[FONT=&quot]ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8[/FONT] [FONT=&quot]OFF [/FONT] [FONT=&quot]20[/FONT]
[FONT=&quot]ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9[/FONT] [FONT=&quot]OFF [/FONT] [FONT=&quot]20[/FONT]
[FONT=&quot]ENG119875-defuel_threshold[/FONT] [FONT=&quot]9 l[/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]ENG105831-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_day-X1[/FONT] [FONT=&quot]0[/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG105831-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_day-X2[/FONT] [FONT=&quot]32[/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG105831-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_day-X3[/FONT] [FONT=&quot]66[/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG105831-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_day-X4[/FONT] [FONT=&quot]96[/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG105831-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_day-X5[/FONT] [FONT=&quot]DC [/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG105831-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_day-X6[/FONT] [FONT=&quot]FD [/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG105831-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_day-Y1[/FONT] [FONT=&quot]0[/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG105831-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_day-Y2[/FONT] [FONT=&quot]0[/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG105831-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_day-Y3[/FONT] [FONT=&quot]0[/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG105831-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_day-Y4[/FONT] [FONT=&quot]5[/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG105831-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_day-Y5[/FONT] [FONT=&quot]14[/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG105831-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_day-Y6[/FONT] [FONT=&quot]64[/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG105832-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_night-X1[/FONT] [FONT=&quot]0[/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG105832-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_night-X2[/FONT] [FONT=&quot]0A[/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG105832-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_night-X3[/FONT] [FONT=&quot]32[/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG105832-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_night-X4[/FONT] [FONT=&quot]64[/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG105832-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_night-X5[/FONT] [FONT=&quot]96[/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG105832-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_night-X6[/FONT] [FONT=&quot]FD [/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG105832-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_night-Y1[/FONT] [FONT=&quot]2[/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG105832-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_night-Y2[/FONT] [FONT=&quot]2[/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG105832-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_night-Y3[/FONT] [FONT=&quot]0E[/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG105832-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_night-Y4[/FONT] [FONT=&quot]1E[/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG105832-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_night-Y5[/FONT] [FONT=&quot]32[/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG105832-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_night-Y6[/FONT] [FONT=&quot]64[/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG105834-ENG101574-dimming_characteristic_curve_adjustment_gauge-X1[/FONT] [FONT=&quot]0[/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG105834-ENG99557-dimming_characteristic_curve_adjustment_gauge-X2[/FONT] [FONT=&quot]0A[/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG105834-ENG102140-dimming_characteristic_curve_adjustment_gauge-X3[/FONT] [FONT=&quot]32[/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG105834-ENG102936-dimming_characteristic_curve_adjustment_gauge-X4[/FONT] [FONT=&quot]64[/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG105834-ENG103548-dimming_characteristic_curve_adjustment_gauge-X5[/FONT] [FONT=&quot]DC [/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG105834-ENG113992-dimming_characteristic_curve_adjustment_gauge-X6[/FONT] [FONT=&quot]FD [/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG105834-ENG99777-dimming_characteristic_curve_adjustment_gauge-Y1[/FONT] [FONT=&quot]3[/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG105834-ENG100480-dimming_characteristic_curve_adjustment_gauge-Y2[/FONT] [FONT=&quot]3[/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG105834-ENG100773-dimming_characteristic_curve_adjustment_gauge-Y3[/FONT] [FONT=&quot]10[/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG105834-ENG100631-dimming_characteristic_curve_adjustment_gauge-Y4[/FONT] [FONT=&quot]1E[/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG105834-ENG102174-dimming_characteristic_curve_adjustment_gauge-Y5[/FONT] [FONT=&quot]55[/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG105834-ENG113993-dimming_characteristic_curve_adjustment_gauge-Y6[/FONT] [FONT=&quot]64[/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG105835-ENG101574-dimming_characteristic_curve_adjustment_indicator_lights-X1[/FONT] [FONT=&quot]0[/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG105835-ENG99557-dimming_characteristic_curve_adjustment_indicator_lights-X2[/FONT] [FONT=&quot]0A[/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG105835-ENG102140-dimming_characteristic_curve_adjustment_indicator_lights-X3[/FONT] [FONT=&quot]32[/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG105835-ENG102936-dimming_characteristic_curve_adjustment_indicator_lights-X4[/FONT] [FONT=&quot]64[/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG105835-ENG103548-dimming_characteristic_curve_adjustment_indicator_lights-X5[/FONT] [FONT=&quot]96[/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG105835-ENG113992-dimming_characteristic_curve_adjustment_indicator_lights-X6[/FONT] [FONT=&quot]FD [/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG105835-ENG99777-dimming_characteristic_curve_adjustment_indicator_lights-Y1[/FONT] [FONT=&quot]5[/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG105835-ENG100480-dimming_characteristic_curve_adjustment_indicator_lights-Y2[/FONT] [FONT=&quot]5[/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG105835-ENG100773-dimming_characteristic_curve_adjustment_indicator_lights-Y3[/FONT] [FONT=&quot]0C[/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG105835-ENG100631-dimming_characteristic_curve_adjustment_indicator_lights-Y4[/FONT] [FONT=&quot]17[/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG105835-ENG102174-dimming_characteristic_curve_adjustment_indicator_lights-Y5[/FONT] [FONT=&quot]32[/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG105835-ENG113993-dimming_characteristic_curve_adjustment_indicator_lights-Y6[/FONT] [FONT=&quot]64[/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG119878-ENG101574-dimming_characteristic_curve_adjustment_internal_phototransistor-X1[/FONT] [FONT=&quot]00 00[/FONT] [FONT=&quot]20[/FONT]
[FONT=&quot]ENG119878-ENG99557-dimming_characteristic_curve_adjustment_internal_phototransistor-X2[/FONT] [FONT=&quot]00 32[/FONT] [FONT=&quot]20[/FONT]
[FONT=&quot]ENG119878-ENG102140-dimming_characteristic_curve_adjustment_internal_phototransistor-X3[/FONT] [FONT=&quot]00 64[/FONT] [FONT=&quot]20[/FONT]
[FONT=&quot]ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4[/FONT] [FONT=&quot]00 C8[/FONT] [FONT=&quot]20[/FONT]
[FONT=&quot]ENG119878-ENG103548-dimming_characteristic_curve_adjustment_internal_phototransistor-X5[/FONT] [FONT=&quot]01 F4[/FONT] [FONT=&quot]20[/FONT]
[FONT=&quot]ENG119878-ENG99777-dimming_characteristic_curve_adjustment_internal_phototransistor-Y1[/FONT] [FONT=&quot]00 00[/FONT] [FONT=&quot]20[/FONT]
[FONT=&quot]ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2[/FONT] [FONT=&quot]00 0E[/FONT] [FONT=&quot]20[/FONT]
[FONT=&quot]ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3[/FONT] [FONT=&quot]00 41[/FONT] [FONT=&quot]20[/FONT]
[FONT=&quot]ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4[/FONT] [FONT=&quot]00 C8[/FONT] [FONT=&quot]20[/FONT]
[FONT=&quot]ENG119878-ENG102174-dimming_characteristic_curve_adjustment_internal_phototransistor-Y5[/FONT] [FONT=&quot]00 FD[/FONT] [FONT=&quot]20[/FONT]
[FONT=&quot]ENG105836-ENG101574-dimming_characteristic_curve_adjustment_middle_display_main_field-X1[/FONT] [FONT=&quot]0[/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG105836-ENG99557-dimming_characteristic_curve_adjustment_middle_display_main_field-X2[/FONT] [FONT=&quot]0A[/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG105836-ENG102140-dimming_characteristic_curve_adjustment_middle_display_main_field-X3[/FONT] [FONT=&quot]32[/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG105836-ENG102936-dimming_characteristic_curve_adjustment_middle_display_main_field-X4[/FONT] [FONT=&quot]64[/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG105836-ENG103548-dimming_characteristic_curve_adjustment_middle_display_main_field-X5[/FONT] [FONT=&quot]96[/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG105836-ENG113992-dimming_characteristic_curve_adjustment_middle_display_main_field-X6[/FONT] [FONT=&quot]FD [/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG105836-ENG99777-dimming_characteristic_curve_adjustment_middle_display_main_field-Y1[/FONT] [FONT=&quot]1[/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG105836-ENG100480-dimming_characteristic_curve_adjustment_middle_display_main_field-Y2[/FONT] [FONT=&quot]1[/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG105836-ENG100773-dimming_characteristic_curve_adjustment_middle_display_main_field-Y3[/FONT] [FONT=&quot]7[/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG105836-ENG100631-dimming_characteristic_curve_adjustment_middle_display_main_field-Y4[/FONT] [FONT=&quot]0E[/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG105836-ENG102174-dimming_characteristic_curve_adjustment_middle_display_main_field-Y5[/FONT] [FONT=&quot]1E[/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG105836-ENG113993-dimming_characteristic_curve_adjustment_middle_display_main_field-Y6[/FONT] [FONT=&quot]64[/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG119874-Gas_functionality[/FONT] [FONT=&quot]not active [/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim[/FONT] [FONT=&quot]terminal_58xd_log_bus_parkinglight[/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]ENG125906-ENG126396-Illumination_algorithm-Scale_switching_algorithm[/FONT] [FONT=&quot]lds [/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]ENG119882-init_fuel_algorithm[/FONT] [FONT=&quot]No [/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]ENG130585-Leaving_warning_delay[/FONT] [FONT=&quot]1.6 s[/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]ENG102605-ENG103211-outside_temperature-p_blocking_time_after_v_bigger_0[/FONT] [FONT=&quot]15 s[/FONT] [FONT=&quot]16[/FONT]
[FONT=&quot]ENG102605-ENG100239-outside_temperature-p_ice_warning_entry_temperature[/FONT] [FONT=&quot]4 °C[/FONT] [FONT=&quot]16[/FONT]
[FONT=&quot]ENG102605-ENG103023-outside_temperature-p_ice_warning_exit_temperature[/FONT] [FONT=&quot]6 °C[/FONT] [FONT=&quot]16[/FONT]
[FONT=&quot]ENG102605-ENG102658-outside_temperature-p_kmt_at_delta[/FONT] [FONT=&quot]25 °C[/FONT] [FONT=&quot]16[/FONT]
[FONT=&quot]ENG102605-ENG99866-outside_temperature-p_mileage_after_v_bigger_0[/FONT] [FONT=&quot]5.0 km[/FONT] [FONT=&quot]16[/FONT]
[FONT=&quot]ENG102605-ENG103631-outside_temperature-P_speed_threshold[/FONT] [FONT=&quot]20 km/h[/FONT] [FONT=&quot]16[/FONT]
[FONT=&quot]ENG102605-ENG99450-outside_temperature-p_storage_time_engine_off[/FONT] [FONT=&quot]180 min[/FONT] [FONT=&quot]16[/FONT]
[FONT=&quot]ENG102605-ENG104179-outside_temperature-p_tendency_damping[/FONT] [FONT=&quot]15 s[/FONT] [FONT=&quot]16[/FONT]
[FONT=&quot]ENG102605-ENG103335-outside_temperature-p_tendency_threshold[/FONT] [FONT=&quot]1.0 °C[/FONT] [FONT=&quot]16[/FONT]
[FONT=&quot]ENG102605-ENG100500-outside_temperature-p_time_constant_pt1[/FONT] [FONT=&quot]40 s[/FONT] [FONT=&quot]16[/FONT]
[FONT=&quot]ENG102605-ENG103256-outside_temperature-p_time_constant_slow_damping[/FONT] [FONT=&quot]2.0[/FONT] [FONT=&quot]16[/FONT]
[FONT=&quot]ENG119825-Picture_Upload_Download[/FONT] [FONT=&quot]not active [/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]ENG126396-Scale_switching_algorithm[/FONT] [FONT=&quot]auto_lowbeam_sidelight [/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]ENG119876-Service_Key_Clear_All_Counter[/FONT] [FONT=&quot]Yes [/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]ENG130584-Statistic_phev_mileage[/FONT] [FONT=&quot]5 km[/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]ENG109442-ENG119793-time_parameter_display-hmi_t_Dreiter_ms[/FONT] [FONT=&quot]2.0 s[/FONT] [FONT=&quot]18[/FONT]
[FONT=&quot]ENG109442-ENG119794-time_parameter_display-hmi_t_dummyMenuTimeout_ms[/FONT] [FONT=&quot]5 s[/FONT] [FONT=&quot]18[/FONT]
[FONT=&quot]ENG109442-ENG119802-time_parameter_display-hmi_t_FondGurt[/FONT] [FONT=&quot]35 s[/FONT] [FONT=&quot]18[/FONT]
[FONT=&quot]ENG109442-ENG119804-time_parameter_display-hmi_t_FTuerAUF[/FONT] [FONT=&quot]300 ms[/FONT] [FONT=&quot]18[/FONT]
[FONT=&quot]ENG109442-ENG119796-time_parameter_display-hmi_t_MenuTimeout_ms[/FONT] [FONT=&quot]255 s[/FONT] [FONT=&quot]18[/FONT]
[FONT=&quot]ENG109442-ENG119799-time_parameter_display-hmi_t_NextServiceAnz_ms[/FONT] [FONT=&quot]5 s[/FONT] [FONT=&quot]18[/FONT]
[FONT=&quot]ENG109442-ENG119798-time_parameter_display-hmi_t_NextWarning_ms[/FONT] [FONT=&quot]6 s[/FONT] [FONT=&quot]18[/FONT]
[FONT=&quot]ENG109442-ENG119805-time_parameter_display-hmi_t_P1Pause_ms[/FONT] [FONT=&quot]20 s[/FONT] [FONT=&quot]18[/FONT]
[FONT=&quot]ENG109442-ENG119800-time_parameter_display-hmi_t_P2Pause_ms[/FONT] [FONT=&quot]900 s[/FONT] [FONT=&quot]18[/FONT]
[FONT=&quot]ENG109442-ENG119801-time_parameter_display-hmi_t_Quit_ms[/FONT] [FONT=&quot]10 s[/FONT] [FONT=&quot]18[/FONT]
[FONT=&quot]ENG109442-ENG119797-time_parameter_display-hmi_t_TWSAnz_ms[/FONT] [FONT=&quot]3 s[/FONT] [FONT=&quot]18[/FONT]
[FONT=&quot]ENG109442-ENG119795-time_parameter_display-hmi_t_UhrTimeout_ms[/FONT] [FONT=&quot]10 s[/FONT] [FONT=&quot]18[/FONT]
[FONT=&quot]ENG109442-ENG119803-time_parameter_display-hmi_t_USZ[/FONT] [FONT=&quot]0.40 s[/FONT] [FONT=&quot]18[/FONT]
[FONT=&quot]ENG109442-ENG119806-time_parameter_display-rollierblockgroesse[/FONT] [FONT=&quot]3[/FONT] [FONT=&quot]18[/FONT]
[FONT=&quot]ENG109442-ENG101663-time_parameter_display-tDD15_off[/FONT] [FONT=&quot]0.30[/FONT] [FONT=&quot]18[/FONT]
[FONT=&quot]ENG109442-ENG103975-time_parameter_display-tDD15_on[/FONT] [FONT=&quot]0.00[/FONT] [FONT=&quot]18[/FONT]
[FONT=&quot]ENG109442-ENG100026-time_parameter_display-tDDWUP[/FONT] [FONT=&quot]0.00[/FONT] [FONT=&quot]18[/FONT]
[FONT=&quot]ENG112418-ENG112412-total_range_gas-consumption_factor[/FONT] [FONT=&quot]0.000[/FONT] [FONT=&quot]4[/FONT]
[FONT=&quot]ENG112418-ENG112411-total_range_gas-consumption_profile[/FONT] [FONT=&quot]consumption_profile_calculation [/FONT] [FONT=&quot]4[/FONT]
[FONT=&quot]ENG112418-ENG112410-total_range_gas-selection_consumption_factor[/FONT] [FONT=&quot]consumption_factor_CAN [/FONT] [FONT=&quot]4[/FONT]
[FONT=&quot]ENG112418-ENG99298-total_range_gas-State[/FONT] [FONT=&quot]not active [/FONT] [FONT=&quot]4[/FONT]
[FONT=&quot]Elapsed Time: 00:28[/FONT]
corradokid
CA, USA
C?ID=32540
19 - CAN Gateway
[FONT=&quot];SW:3Q0-907-530-AA HW:3Q0-907-530-C --- CAN Gateway[/FONT]
[FONT=&quot];Component:GW MQB High 521 5366[/FONT] [FONT=&quot]Coding:0101000830085900FB00023B880F00000001070000000000000000000000[/FONT]
[FONT=&quot];EV_GatewNF[/FONT] [FONT=&quot]13025[/FONT] [FONT=&quot]EV_GatewNF_VW37.rod[/FONT]
[FONT=&quot];Monday[/FONT] [FONT=&quot]3[/FONT] [FONT=&quot]August[/FONT] [FONT=&quot]2020[/FONT] [FONT=&quot]08:30:51:41546[/FONT]
[FONT=&quot];VCID: 6E90E6ACB1354FF6F1-803B[/FONT]
[FONT=&quot]IDE00001-ENG124491-Production mode-p_mode_deactivate_mfl_keys[/FONT] [FONT=&quot]Deactivating [/FONT] [FONT=&quot]3[/FONT]
[FONT=&quot]IDE00001-ENG118694-Production mode-p_mode_deactivate_recuperation[/FONT] [FONT=&quot]Deactivating [/FONT] [FONT=&quot]3[/FONT]
[FONT=&quot]IDE00002-Transport mode[/FONT] [FONT=&quot]not active [/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]IDE00820-MAS01172-Activating and deactivating all development messages-Development messages[/FONT] [FONT=&quot]not active [/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]IDE00820-ENG98891-Activating and deactivating all development messages-Reserved[/FONT] [FONT=&quot]0[/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]IDE01211-Static current measuring mode[/FONT] [FONT=&quot]not activated [/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]IDE01457-Energy management deactivation stage[/FONT] [FONT=&quot]Mode not active [/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]IDE01459-Energy management heat output control status[/FONT] [FONT=&quot]Mode not active [/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]IDE01844-Increase idle speed request[/FONT] [FONT=&quot]Mode not active [/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]IDE01847-ENG118685-Auxiliary heater activation restriction request-Set_point_target_time[/FONT] [FONT=&quot]-- [/FONT] [FONT=&quot]3[/FONT]
[FONT=&quot]IDE01847-ENG118684-Auxiliary heater activation restriction request-Switch_on_ban_activation[/FONT] [FONT=&quot]Mode not active [/FONT] [FONT=&quot]3[/FONT]
[FONT=&quot]IDE01860-Generator specified voltage value variable[/FONT] [FONT=&quot]10.6 V[/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]IDE01996-SFT00001-Installation list: specified installations-Engine Control Module 1[/FONT] [FONT=&quot]coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-SFT00002-Installation list: specified installations-Transmission Control Module[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-SFT00003-Installation list: specified installations-Brakes 1[/FONT] [FONT=&quot]coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-SFT00006-Installation list: specified installations-Seat Adjustment Passenger Side[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-SFT00008-Installation list: specified installations-Air Conditioning[/FONT] [FONT=&quot]coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-SFT00009-Installation list: specified installations-Central Electrics[/FONT] [FONT=&quot]coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-SFT00011-Installation list: specified installations-Auxiliary Air Heater[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-SFT00014-Installation list: specified installations-Media Player Position 1[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-SFT00019-Installation list: specified installations-Adaptive Cruise Control[/FONT] [FONT=&quot]coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-SFT00020-Installation list: specified installations-Wheel Dampening Electronics[/FONT] [FONT=&quot]coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-SFT00021-Installation list: specified installations-Airbag[/FONT] [FONT=&quot]coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-SFT00022-Installation list: specified installations-Steering Column Electronics[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-SFT00023-Installation list: specified installations-Dash Board[/FONT] [FONT=&quot]coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-SFT00024-Installation list: specified installations-Auxiliary Parking Heater[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-SFT00025-Installation list: specified installations-Gateway[/FONT] [FONT=&quot]1[/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-SFT00028-Installation list: specified installations-Vehicle Position Detection[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-SFT00032-Installation list: specified installations-High Beam Assistance[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-SFT00033-Installation list: specified installations-Battery Energy Control Module 2[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-SFT00034-Installation list: specified installations-All Wheel Control[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-SFT00035-Installation list: specified installations-Brake Boost[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-SFT00038-Installation list: specified installations-Electronic Roof Control[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-SFT00043-Installation list: specified installations-Steering Column Locking[/FONT] [FONT=&quot]coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-SFT00048-Installation list: specified installations-Special Function 2[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-SFT00050-Installation list: specified installations-Lock Electronics[/FONT] [FONT=&quot]coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-SFT00054-Installation list: specified installations-Seat Adjustment Driver Side[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-SFT00060-Installation list: specified installations-Lane Change Assistant[/FONT] [FONT=&quot]coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-SFT00061-Installation list: specified installations-Special Function[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-SFT00064-Installation list: specified installations-Air Conditioning Compressor[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-SFT00066-Installation list: specified installations-Door Electronics Driver Side[/FONT] [FONT=&quot]coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-SFT00068-Installation list: specified installations-Steering Assistance[/FONT] [FONT=&quot]coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-SFT00071-Installation list: specified installations-Sound System[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-SFT00075-Installation list: specified installations-Multifunction module[/FONT] [FONT=&quot]coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-SFT00081-Installation list: specified installations-Drive Motor Control Module[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-SFT00082-Installation list: specified installations-Door Electronics Passenger Side[/FONT] [FONT=&quot]coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-SFT00085-Installation list: specified installations-Headlight Regulation[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-SFT00086-Installation list: specified installations-Radio[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-SFT00087-Installation list: specified installations-TV Tuner[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-SFT00095-Installation list: specified installations-Information Control Unit 1[/FONT] [FONT=&quot]coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-SFT00096-Installation list: specified installations-Tachograph[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-SFT00101-Installation list: specified installations-Tire Pressure Monitoring 1[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-SFT00105-Installation list: specified installations-Trailer Function[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-SFT00108-Installation list: specified installations-Camera System Rear View[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-SFT00109-Installation list: specified installations-Deck Lid Control Unit[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-SFT00117-Installation list: specified installations-Telematics Communication Unit[/FONT] [FONT=&quot]coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-SFT00118-Installation list: specified installations-Parking Assistance[/FONT] [FONT=&quot]coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-SFT00128-Installation list: specified installations-Battery Regulation Auxiliary Accumulator 1[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-SFT00130-Installation list: specified installations-Head Up Display[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-SFT00140-Installation list: specified installations-Battery Energy Control Module[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-SFT00165-Installation list: specified installations-Front Sensors Driver Assistance System[/FONT] [FONT=&quot]coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-SFT00166-Installation list: specified installations-Microphone Control Unit[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-SFT00169-Installation list: specified installations-Actuator For Structure-borne Sound[/FONT] [FONT=&quot]coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-SFT00183-Installation list: specified installations-Access Startsystem Interface[/FONT] [FONT=&quot]coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-SFT00187-Installation list: specified installations-Door Electronics Rear Driver Side[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-SFT00188-Installation list: specified installations-Door Electronics Rear Passenger Side[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-SFT00189-Installation list: specified installations-High Voltage Battery Charge Management[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-SFT00190-Installation list: specified installations-Sliding Door Rear Left[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-SFT00191-Installation list: specified installations-Sliding Door Rear Right[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-SFT00192-Installation list: specified installations-Actuator For Exterior Noise[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-SFT00197-Installation list: specified installations-Thermal management[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-SFT00198-Installation list: specified installations-Battery Charger Control Module[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-SFT00202-Installation list: specified installations-Control module for sunroof[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-SFT00204-Installation list: specified installations-Starter / Generator Control Module[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-SFT00207-Installation list: specified installations-Control Unit Lane Change Assistant 2[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118226-Installation list: specified installations-Node_0x01[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118227-Installation list: specified installations-Node_0x02[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118228-Installation list: specified installations-Node_0x03[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118229-Installation list: specified installations-Node_0x04[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118230-Installation list: specified installations-Node_0x05[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118231-Installation list: specified installations-Node_0x06[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118232-Installation list: specified installations-Node_0x07[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118233-Installation list: specified installations-Node_0x08[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118235-Installation list: specified installations-Node_0x0D[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118236-Installation list: specified installations-Node_0x11[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118237-Installation list: specified installations-Node_0x16[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118238-Installation list: specified installations-Node_0x17[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118239-Installation list: specified installations-Node_0x1A[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118241-Installation list: specified installations-Node_0x1D[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118242-Installation list: specified installations-Node_0x1F[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118243-Installation list: specified installations-Node_0x20[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118244-Installation list: specified installations-Node_0x21[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118245-Installation list: specified installations-Node_0x22[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118246-Installation list: specified installations-Node_0x24[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118247-Installation list: specified installations-Node_0x25[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118248-Installation list: specified installations-Node_0x26[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118249-Installation list: specified installations-Node_0x27[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118250-Installation list: specified installations-Node_0x28[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118251-Installation list: specified installations-Node_0x29[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118252-Installation list: specified installations-Node_0x2A[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118253-Installation list: specified installations-Node_0x2E[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118254-Installation list: specified installations-Node_0x2F[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118255-Installation list: specified installations-Node_0x35[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118256-Installation list: specified installations-Node_0x36[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118257-Installation list: specified installations-Node_0x37[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118258-Installation list: specified installations-Node_0x38[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118259-Installation list: specified installations-Node_0x39[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118260-Installation list: specified installations-Node_0x3A[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118261-Installation list: specified installations-Node_0x3C[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118262-Installation list: specified installations-Node_0x3D[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118263-Installation list: specified installations-Node_0x40[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118264-Installation list: specified installations-Node_0x41[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118265-Installation list: specified installations-Node_0x43[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118266-Installation list: specified installations-Node_0x45[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118267-Installation list: specified installations-Node_0x48[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118268-Installation list: specified installations-Node_0x49[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118269-Installation list: specified installations-Node_0x51[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118270-Installation list: specified installations-Node_0x52[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118271-Installation list: specified installations-Node_0x53[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118272-Installation list: specified installations-Node_0x55[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118273-Installation list: specified installations-Node_0x56[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118274-Installation list: specified installations-Node_0x58[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118275-Installation list: specified installations-Node_0x59[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118276-Installation list: specified installations-Node_0x5A[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118277-Installation list: specified installations-Node_0x5B[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118278-Installation list: specified installations-Node_0x5C[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118279-Installation list: specified installations-Node_0x5D[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118280-Installation list: specified installations-Node_0x5E[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118281-Installation list: specified installations-Node_0x5F[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118282-Installation list: specified installations-Node_0x60[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118283-Installation list: specified installations-Node_0x61[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118284-Installation list: specified installations-Node_0x62[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118285-Installation list: specified installations-Node_0x66[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118286-Installation list: specified installations-Node_0x68[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118287-Installation list: specified installations-Node_0x6B[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118288-Installation list: specified installations-Node_0x6C[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118289-Installation list: specified installations-Node_0x6E[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118290-Installation list: specified installations-Node_0x74[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118291-Installation list: specified installations-Node_0x75[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118292-Installation list: specified installations-Node_0x78[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118293-Installation list: specified installations-Node_0x79[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118294-Installation list: specified installations-Node_0x7A[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118295-Installation list: specified installations-Node_0x7D[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118296-Installation list: specified installations-Node_0x7E[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118297-Installation list: specified installations-Node_0x7F[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118298-Installation list: specified installations-Node_0x80[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118299-Installation list: specified installations-Node_0x81[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118300-Installation list: specified installations-Node_0x82[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118301-Installation list: specified installations-Node_0x83[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118303-Installation list: specified installations-Node_0x86[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118304-Installation list: specified installations-Node_0x87[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118305-Installation list: specified installations-Node_0x88[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118306-Installation list: specified installations-Node_0x89[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118307-Installation list: specified installations-Node_0x8B[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118308-Installation list: specified installations-Node_0x8C[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118309-Installation list: specified installations-Node_0x8D[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118310-Installation list: specified installations-Node_0x8E[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118311-Installation list: specified installations-Node_0x8F[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118312-Installation list: specified installations-Node_0x90[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118313-Installation list: specified installations-Node_0x91[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118314-Installation list: specified installations-Node_0x92[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118315-Installation list: specified installations-Node_0x93[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118316-Installation list: specified installations-Node_0x94[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118317-Installation list: specified installations-Node_0x95[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118318-Installation list: specified installations-Node_0x96[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118319-Installation list: specified installations-Node_0x97[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118320-Installation list: specified installations-Node_0x98[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118321-Installation list: specified installations-Node_0x99[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118322-Installation list: specified installations-Node_0x9A[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118323-Installation list: specified installations-Node_0x9B[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118325-Installation list: specified installations-Node_0x9D[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118326-Installation list: specified installations-Node_0x9E[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118327-Installation list: specified installations-Node_0x9F[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118328-Installation list: specified installations-Node_0xA0[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118329-Installation list: specified installations-Node_0xA1[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118330-Installation list: specified installations-Node_0xA2[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118331-Installation list: specified installations-Node_0xA3[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118333-Installation list: specified installations-Node_0xA5[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118334-Installation list: specified installations-Node_0xA6[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118335-Installation list: specified installations-Node_0xA7[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118336-Installation list: specified installations-Node_0xA8[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118338-Installation list: specified installations-Node_0xAA[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118339-Installation list: specified installations-Node_0xAB[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118340-Installation list: specified installations-Node_0xAC[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118341-Installation list: specified installations-Node_0xAD[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118343-Installation list: specified installations-Node_0xAF[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118344-Installation list: specified installations-Node_0xB0[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118345-Installation list: specified installations-Node_0xB1[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118346-Installation list: specified installations-Node_0xB2[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118347-Installation list: specified installations-Node_0xB3[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118348-Installation list: specified installations-Node_0xB4[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118349-Installation list: specified installations-Node_0xB5[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118350-Installation list: specified installations-Node_0xB6[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118351-Installation list: specified installations-Node_0xB7[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118352-Installation list: specified installations-Node_0xB8[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118353-Installation list: specified installations-Node_0xB9[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118354-Installation list: specified installations-Node_0xBA[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118355-Installation list: specified installations-Node_0xBB[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118356-Installation list: specified installations-Node_0xBC[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118357-Installation list: specified installations-Node_0xBD[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118358-Installation list: specified installations-Node_0xBE[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118359-Installation list: specified installations-Node_0xBF[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118360-Installation list: specified installations-Node_0xC0[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118361-Installation list: specified installations-Node_0xC1[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118362-Installation list: specified installations-Node_0xC2[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118363-Installation list: specified installations-Node_0xC3[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118364-Installation list: specified installations-Node_0xC4[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118365-Installation list: specified installations-Node_0xC5[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118366-Installation list: specified installations-Node_0xC6[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118367-Installation list: specified installations-Node_0xC7[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118368-Installation list: specified installations-Node_0xC8[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118369-Installation list: specified installations-Node_0xC9[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118370-Installation list: specified installations-Node_0xCA[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118371-Installation list: specified installations-Node_0xCB[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118372-Installation list: specified installations-Node_0xCC[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118373-Installation list: specified installations-Node_0xCD[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118374-Installation list: specified installations-Node_0xCE[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118375-Installation list: specified installations-Node_0xCF[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118376-Installation list: specified installations-Node_0xD0[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118377-Installation list: specified installations-Node_0xD1[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118378-Installation list: specified installations-Node_0xD2[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118379-Installation list: specified installations-Node_0xD3[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118380-Installation list: specified installations-Node_0xD4[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118381-Installation list: specified installations-Node_0xD5[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118382-Installation list: specified installations-Node_0xD6[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118383-Installation list: specified installations-Node_0xD7[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118384-Installation list: specified installations-Node_0xD8[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118385-Installation list: specified installations-Node_0xD9[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118386-Installation list: specified installations-Node_0xDA[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118387-Installation list: specified installations-Node_0xDB[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118388-Installation list: specified installations-Node_0xDC[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118389-Installation list: specified installations-Node_0xDD[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118390-Installation list: specified installations-Node_0xDE[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118391-Installation list: specified installations-Node_0xDF[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118392-Installation list: specified installations-Node_0xE0[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118393-Installation list: specified installations-Node_0xE1[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118394-Installation list: specified installations-Node_0xE2[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118395-Installation list: specified installations-Node_0xE3[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118396-Installation list: specified installations-Node_0xE4[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118397-Installation list: specified installations-Node_0xE5[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118398-Installation list: specified installations-Node_0xE6[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118399-Installation list: specified installations-Node_0xE7[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118400-Installation list: specified installations-Node_0xE8[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118401-Installation list: specified installations-Node_0xE9[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118402-Installation list: specified installations-Node_0xEA[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118403-Installation list: specified installations-Node_0xEB[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118404-Installation list: specified installations-Node_0xEC[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118405-Installation list: specified installations-Node_0xED[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118406-Installation list: specified installations-Node_0xEE[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118407-Installation list: specified installations-Node_0xEF[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118408-Installation list: specified installations-Node_0xF0[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118409-Installation list: specified installations-Node_0xF1[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118410-Installation list: specified installations-Node_0xF2[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118411-Installation list: specified installations-Node_0xF3[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118412-Installation list: specified installations-Node_0xF4[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118413-Installation list: specified installations-Node_0xF5[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118414-Installation list: specified installations-Node_0xF6[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118415-Installation list: specified installations-Node_0xF7[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118416-Installation list: specified installations-Node_0xF8[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118417-Installation list: specified installations-Node_0xF9[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118418-Installation list: specified installations-Node_0xFA[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118419-Installation list: specified installations-Node_0xFB[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118420-Installation list: specified installations-Node_0xFC[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118421-Installation list: specified installations-Node_0xFD[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118422-Installation list: specified installations-Node_0xFE[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE01996-ENG118423-Installation list: specified installations-Node_0xFF[/FONT] [FONT=&quot]Not coded [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]IDE02332-Deactivate production mode[/FONT] [FONT=&quot]0[/FONT] [FONT=&quot]3[/FONT]
[FONT=&quot]IDE03256-MAS06105-Battery adaptation-Rated battery capacity[/FONT] [FONT=&quot]60 Ah[/FONT] [FONT=&quot]15[/FONT]
[FONT=&quot]IDE03256-MAS06106-Battery adaptation-Battery technology[/FONT] [FONT=&quot]Wet [/FONT] [FONT=&quot]15[/FONT]
[FONT=&quot]IDE03256-MAS06107-Battery adaptation-Battery manufacturer[/FONT] [FONT=&quot]JCB [/FONT] [FONT=&quot]15[/FONT]
[FONT=&quot]IDE03256-MAS06108-Battery adaptation-Battery Serial Number[/FONT] [FONT=&quot]1111111111[/FONT] [FONT=&quot]15[/FONT]
[FONT=&quot]IDE03903-Production process data 1[/FONT] [FONT=&quot]00 00[/FONT] [FONT=&quot]2[/FONT]
[FONT=&quot]IDE04159-Deactivation of start-stop function[/FONT] [FONT=&quot]Mode not active [/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]IDE04186-Battery terminal recognition[/FONT] [FONT=&quot]connected [/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]IDE04330-Transfer of release code for a SWaP function[/FONT] [FONT=&quot]0[/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]IDE04331-Selection of release codes for a SWaP function[/FONT] [FONT=&quot]FF FF FF FF [/FONT] [FONT=&quot]4[/FONT]
[FONT=&quot]IDE06530-Distance left for deactivation of static current measuring mode[/FONT] [FONT=&quot]2[/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]IDE06541-Distance left for deactivation of transport mode[/FONT] [FONT=&quot]50[/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]IDE06753-MAS06278-Efficiency program display-Live tip air resistance: close window/sunroof[/FONT] [FONT=&quot]activated [/FONT] [FONT=&quot]4[/FONT]
[FONT=&quot]IDE06753-MAS06279-Efficiency program display-Live tip engine brake: uncouple not until below 1300 RPM[/FONT] [FONT=&quot]activated [/FONT] [FONT=&quot]4[/FONT]
[FONT=&quot]IDE06753-MAS06280-Efficiency program display-Live tip do not operate gas pedal during engine start[/FONT] [FONT=&quot]activated [/FONT] [FONT=&quot]4[/FONT]
[FONT=&quot]IDE06753-MAS06281-Efficiency program display-Live tip adhere to switch display (only manual switch)[/FONT] [FONT=&quot]activated [/FONT] [FONT=&quot]4[/FONT]
[FONT=&quot]IDE06753-MAS06282-Efficiency program display-Live tip use start-stop-system[/FONT] [FONT=&quot]activated [/FONT] [FONT=&quot]4[/FONT]
[FONT=&quot]IDE06753-MAS06283-Efficiency program display-Live tip switch on start-stop-system[/FONT] [FONT=&quot]activated [/FONT] [FONT=&quot]4[/FONT]
[FONT=&quot]IDE06753-MAS06284-Efficiency program display-Live tip air conditioning: close window/sunroof[/FONT] [FONT=&quot]activated [/FONT] [FONT=&quot]4[/FONT]
[FONT=&quot]IDE06753-MAS06285-Efficiency program display-Live tip use gearshift position D[/FONT] [FONT=&quot]activated [/FONT] [FONT=&quot]4[/FONT]
[FONT=&quot]IDE06753-MAS06286-Efficiency program display-Live tip Do not press accelerator pedal at standstill[/FONT] [FONT=&quot]activated [/FONT] [FONT=&quot]4[/FONT]
[FONT=&quot]IDE06753-MAS06287-Efficiency program display-Live tip sunroof open: switch of A/C (AC button)[/FONT] [FONT=&quot]activated [/FONT] [FONT=&quot]4[/FONT]
[FONT=&quot]IDE06753-MAS06288-Efficiency program display-Live tip avoid engine warm-up at standstill[/FONT] [FONT=&quot]activated [/FONT] [FONT=&quot]4[/FONT]
[FONT=&quot]IDE06753-MAS06289-Efficiency program display-Comfort use A/C[/FONT] [FONT=&quot]activated [/FONT] [FONT=&quot]4[/FONT]
[FONT=&quot]IDE06753-MAS06290-Efficiency program display-Comfort use parking heater[/FONT] [FONT=&quot]activated [/FONT] [FONT=&quot]4[/FONT]
[FONT=&quot]IDE06753-MAS06291-Efficiency program display-Comfort use rear window heater[/FONT] [FONT=&quot]activated [/FONT] [FONT=&quot]4[/FONT]
[FONT=&quot]IDE06753-MAS06292-Efficiency program display-Comfort use front seat heater[/FONT] [FONT=&quot]activated [/FONT] [FONT=&quot]4[/FONT]
[FONT=&quot]IDE06753-MAS06293-Efficiency program display-Comfort use front seat ventilation[/FONT] [FONT=&quot]activated [/FONT] [FONT=&quot]4[/FONT]
[FONT=&quot]IDE06753-MAS06294-Efficiency program display-Comfort use rear heater[/FONT] [FONT=&quot]activated [/FONT] [FONT=&quot]4[/FONT]
[FONT=&quot]IDE06753-MAS06295-Efficiency program display-Comfort use fog light[/FONT] [FONT=&quot]activated [/FONT] [FONT=&quot]4[/FONT]
[FONT=&quot]IDE06753-MAS06296-Efficiency program display-Comfort use rear fog light[/FONT] [FONT=&quot]not activated [/FONT] [FONT=&quot]4[/FONT]
[FONT=&quot]IDE06753-MAS06297-Efficiency program display-Comfort use parking heater consumption emission[/FONT] [FONT=&quot]activated [/FONT] [FONT=&quot]4[/FONT]
[FONT=&quot]IDE06753-MAS06298-Efficiency program display-Comfort use windshield heater[/FONT] [FONT=&quot]activated [/FONT] [FONT=&quot]4[/FONT]
[FONT=&quot]IDE06753-MAS06299-Efficiency program display-Comfort use steering wheel heater[/FONT] [FONT=&quot]activated [/FONT] [FONT=&quot]4[/FONT]
[FONT=&quot]IDE06753-MAS06300-Efficiency program display-Comfort use mirror heater[/FONT] [FONT=&quot]activated [/FONT] [FONT=&quot]4[/FONT]
[FONT=&quot]IDE06753-MAS06301-Efficiency program display-Comfort use rear seat heater[/FONT] [FONT=&quot]activated [/FONT] [FONT=&quot]4[/FONT]
[FONT=&quot]IDE06753-MAS06302-Efficiency program display-Comfort use rear seat ventilation[/FONT] [FONT=&quot]activated [/FONT] [FONT=&quot]4[/FONT]
[FONT=&quot]IDE06753-MAS14430-Efficiency program display-Dependence of ECO tips on driver profile selection[/FONT] [FONT=&quot]ECO tips independent of driver profile selection [/FONT] [FONT=&quot]4[/FONT]
[FONT=&quot]IDE06753-MAS19094-Efficiency program display-Rear A/C System blower convenience consumption[/FONT] [FONT=&quot]activated [/FONT] [FONT=&quot]4[/FONT]
[FONT=&quot]IDE06753-MAS19095-Efficiency program display-Convenience consumption outer mirror heater dependency[/FONT] [FONT=&quot]Until temperature threshold: with after-run: with switch [/FONT] [FONT=&quot]4[/FONT]
[FONT=&quot]IDE07838-Counter for inconsistent states[/FONT] [FONT=&quot]0[/FONT] [FONT=&quot]2[/FONT]
[FONT=&quot]IDE08348-Start/stop start voltage limit[/FONT] [FONT=&quot]7.8 V[/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]IDE08624-MKE Check box[/FONT] [FONT=&quot]activated [/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]IDE10735-Number requests autonomous recharging[/FONT] [FONT=&quot]3[/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]IDE10736-Cyclization limitation request battery service[/FONT] [FONT=&quot]0[/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]IDE10748-MAS11262-Range gain-Range gain AC system[/FONT] [FONT=&quot]activated [/FONT] [FONT=&quot]3[/FONT]
[FONT=&quot]IDE10748-MAS11263-Range gain-Range gain auxiliary heater[/FONT] [FONT=&quot]activated [/FONT] [FONT=&quot]3[/FONT]
[FONT=&quot]IDE10748-MAS11264-Range gain-Range gain window defogger[/FONT] [FONT=&quot]activated [/FONT] [FONT=&quot]3[/FONT]
[FONT=&quot]IDE10748-MAS11265-Range gain-Range gain seat heater front[/FONT] [FONT=&quot]activated [/FONT] [FONT=&quot]3[/FONT]
[FONT=&quot]IDE10748-MAS11266-Range gain-Range gain front set ventilation[/FONT] [FONT=&quot]activated [/FONT] [FONT=&quot]3[/FONT]
[FONT=&quot]IDE10748-MAS11267-Range gain-Range gain rear heater[/FONT] [FONT=&quot]activated [/FONT] [FONT=&quot]3[/FONT]
[FONT=&quot]IDE10748-MAS11268-Range gain-Range gain fog light[/FONT] [FONT=&quot]activated [/FONT] [FONT=&quot]3[/FONT]
[FONT=&quot]IDE10748-MAS11269-Range gain-Range gain rear fog light[/FONT] [FONT=&quot]not activated [/FONT] [FONT=&quot]3[/FONT]
[FONT=&quot]IDE10748-MAS11270-Range gain-Range gain windshield heating[/FONT] [FONT=&quot]activated [/FONT] [FONT=&quot]3[/FONT]
[FONT=&quot]IDE10748-MAS11271-Range gain-Range gain steering wheel heater[/FONT] [FONT=&quot]activated [/FONT] [FONT=&quot]3[/FONT]
[FONT=&quot]IDE10748-MAS11272-Range gain-Range gain mirror heater[/FONT] [FONT=&quot]activated [/FONT] [FONT=&quot]3[/FONT]
[FONT=&quot]IDE10748-MAS11273-Range gain-Range gain rear seat heater[/FONT] [FONT=&quot]activated [/FONT] [FONT=&quot]3[/FONT]
[FONT=&quot]IDE10748-MAS11274-Range gain-Range gain rear seat heater[/FONT] [FONT=&quot]activated [/FONT] [FONT=&quot]3[/FONT]
[FONT=&quot]IDE10748-MAS11275-Range gain-Windshield heater consumption in AC system[/FONT] [FONT=&quot]not activated [/FONT] [FONT=&quot]3[/FONT]
[FONT=&quot]IDE10748-MAS11276-Range gain-Windshield heater range gain in AC system[/FONT] [FONT=&quot]not activated [/FONT] [FONT=&quot]3[/FONT]
[FONT=&quot]IDE10748-MAS11277-Range gain-PTC(low voltage) consumption[/FONT] [FONT=&quot]not activated [/FONT] [FONT=&quot]3[/FONT]
[FONT=&quot]IDE10748-MAS11278-Range gain-PTC(low voltage) range gain[/FONT] [FONT=&quot]not activated [/FONT] [FONT=&quot]3[/FONT]
[FONT=&quot]IDE10748-MAS11279-Range gain-List at engine still stand[/FONT] [FONT=&quot]activated [/FONT] [FONT=&quot]3[/FONT]
[FONT=&quot]IDE10748-MAS12689-Range gain-Catalogue range display[/FONT] [FONT=&quot]activated [/FONT] [FONT=&quot]3[/FONT]
[FONT=&quot]IDE10748-MAS12690-Range gain-Loading condition catalogue range display[/FONT] [FONT=&quot]activated [/FONT] [FONT=&quot]3[/FONT]
[FONT=&quot]IDE10748-MAS13161-Range gain-List display absolute values ??with weighting[/FONT] [FONT=&quot]activated [/FONT] [FONT=&quot]3[/FONT]
[FONT=&quot]IDE10748-MAS19099-Range gain-Convenience consumption socket[/FONT] [FONT=&quot]activated [/FONT] [FONT=&quot]3[/FONT]
[FONT=&quot]IDE10748-MAS19100-Range gain-A/C System blower manual convenience consumption[/FONT] [FONT=&quot]not activated [/FONT] [FONT=&quot]3[/FONT]
[FONT=&quot]IDE10748-MAS19132-Range gain-Outer mirror heater consumption in rear window heating[/FONT] [FONT=&quot]not activated [/FONT] [FONT=&quot]3[/FONT]
[FONT=&quot]IDE11689-48V-System: locking[/FONT] [FONT=&quot]regular operation [/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]IDE13756-Diagnosis filter: activation[/FONT] [FONT=&quot]not active [/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]IDE13757-MAS16868-Diagnosis filter: kilometer thresholds-Kilometer threshold: production[/FONT] [FONT=&quot]200 km[/FONT] [FONT=&quot]2[/FONT]
[FONT=&quot]IDE13757-MAS16869-Diagnosis filter: kilometer thresholds-Kilometer threshold: customer service[/FONT] [FONT=&quot]20 km[/FONT] [FONT=&quot]2[/FONT]
[FONT=&quot]MAS16372-Security version number[/FONT] [FONT=&quot]3[/FONT] [FONT=&quot]2[/FONT]
[FONT=&quot]SFT271921-IDE02583-Multi Function Steering Wheel Control Module-Steering wheel Tiptronic switch[/FONT] [FONT=&quot]not installed [/FONT] [FONT=&quot]3[/FONT]
[FONT=&quot]SFT271921-MAS02311-Multi Function Steering Wheel Control Module-Steering wheel heating button[/FONT] [FONT=&quot]not active [/FONT] [FONT=&quot]3[/FONT]
[FONT=&quot]SFT271921-MAS04733-Multi Function Steering Wheel Control Module-Two-stage[/FONT] [FONT=&quot]Unknown (3)[/FONT] [FONT=&quot]3[/FONT]
[FONT=&quot]SFT271921-MAS06614-Multi Function Steering Wheel Control Module-Version[/FONT] [FONT=&quot]ACC [/FONT] [FONT=&quot]3[/FONT]
[FONT=&quot]SFT271921-MAS09758-Multi Function Steering Wheel Control Module-Temperature sensor[/FONT] [FONT=&quot]not installed [/FONT] [FONT=&quot]3[/FONT]
[FONT=&quot]SFT271921-MAS13892-Multi Function Steering Wheel Control Module-Platform[/FONT] [FONT=&quot]Unknown (3)[/FONT] [FONT=&quot]3[/FONT]
[FONT=&quot]SFT271921-MAS19104-Multi Function Steering Wheel Control Module-Alarm horn wake-up function[/FONT] [FONT=&quot]active [/FONT] [FONT=&quot]3[/FONT]
[FONT=&quot]SFT271921-ENG258379-Multi Function Steering Wheel Control Module-clamp behaviour[/FONT] [FONT=&quot]active with terminal 58[/FONT] [FONT=&quot]3[/FONT]
[FONT=&quot]SFT271921-ENG260738-Multi Function Steering Wheel Control Module-FoD ACC[/FONT] [FONT=&quot]activated [/FONT] [FONT=&quot]3[/FONT]
[FONT=&quot]SFT271921-ENG258784-Multi Function Steering Wheel Control Module-FoD Travel Assist[/FONT] [FONT=&quot]activated [/FONT] [FONT=&quot]3[/FONT]
[FONT=&quot]SFT271921-ENG262857-Multi Function Steering Wheel Control Module-Kombi_02_gueltig[/FONT] [FONT=&quot]active [/FONT] [FONT=&quot]3[/FONT]
[FONT=&quot]ENG118777-ENG118712-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Counter_Master_Reset[/FONT] [FONT=&quot]active [/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG118777-ENG118710-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Limit_Adaptation[/FONT] [FONT=&quot]100[/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG118777-ENG118711-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Lock_Adaptation[/FONT] [FONT=&quot]60000 ms[/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG118777-ENG118709-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Time_Adaptation[/FONT] [FONT=&quot]10000 ms[/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG118777-ENG118705-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Indication_Control_Adaption[/FONT] [FONT=&quot]3000 ms[/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG118777-ENG118706-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Kombi_Offset_Adaption[/FONT] [FONT=&quot]0 ms[/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG118777-ENG118708-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Request_Repetition_Time_Adaptation[/FONT] [FONT=&quot]255000 ms[/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG118777-ENG118707-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Sync_Time_Adaptation[/FONT] [FONT=&quot]1500 ms[/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG118777-ENG118703-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation[/FONT] [FONT=&quot]500 ms[/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG118777-ENG118704-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Touch_Contact_Time_Adaption[/FONT] [FONT=&quot]2500 ms[/FONT] [FONT=&quot]12[/FONT]
[FONT=&quot]ENG137060-ENG113874-EM_energy_management_warning_displays-Batteriemeldungen[/FONT] [FONT=&quot]Mode not active [/FONT] [FONT=&quot]4[/FONT]
[FONT=&quot]ENG137060-ENG98711-EM_energy_management_warning_displays-Charge level[/FONT] [FONT=&quot]Mode not active [/FONT] [FONT=&quot]4[/FONT]
[FONT=&quot]ENG137060-ENG113873-EM_energy_management_warning_displays-Generatormeldungen[/FONT] [FONT=&quot]Mode not active [/FONT] [FONT=&quot]4[/FONT]
[FONT=&quot]ENG137060-ENG118686-EM_energy_management_warning_displays-MMI Vorwarnungen[/FONT] [FONT=&quot]Mode not active [/FONT] [FONT=&quot]4[/FONT]
[FONT=&quot]ENG137075-EM_heating_power_quota_adjustment[/FONT] [FONT=&quot]1000 W[/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]ENG137061-EM_nominal_voltage_limitation_low_beams[/FONT] [FONT=&quot]12.1 V[/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]ENG137064-EM_requirement_cyclic_time_voltage_measurement[/FONT] [FONT=&quot]0 s[/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]ENG137063-EM_requirement_reduction_air_blowers[/FONT] [FONT=&quot]Mode not active [/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]ENG137058-SFT00001-GW_Enable_CAN_Timeout_DTC-Engine Control Module 1[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-SFT00002-GW_Enable_CAN_Timeout_DTC-Transmission Control Module[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-SFT00003-GW_Enable_CAN_Timeout_DTC-Brakes 1[/FONT] [FONT=&quot]not enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-SFT00006-GW_Enable_CAN_Timeout_DTC-Seat Adjustment Passenger Side[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-SFT00008-GW_Enable_CAN_Timeout_DTC-Air Conditioning[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-SFT00009-GW_Enable_CAN_Timeout_DTC-Central Electrics[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-SFT00011-GW_Enable_CAN_Timeout_DTC-Auxiliary Air Heater[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-SFT00014-GW_Enable_CAN_Timeout_DTC-Media Player Position 1[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-SFT00019-GW_Enable_CAN_Timeout_DTC-Adaptive Cruise Control[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-SFT00020-GW_Enable_CAN_Timeout_DTC-Wheel Dampening Electronics[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-SFT00021-GW_Enable_CAN_Timeout_DTC-Airbag[/FONT] [FONT=&quot]not enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-SFT00022-GW_Enable_CAN_Timeout_DTC-Steering Column Electronics[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-SFT00023-GW_Enable_CAN_Timeout_DTC-Dash Board[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-SFT00024-GW_Enable_CAN_Timeout_DTC-Auxiliary Parking Heater[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-SFT00025-GW_Enable_CAN_Timeout_DTC-Gateway[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-SFT00028-GW_Enable_CAN_Timeout_DTC-Vehicle Position Detection[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-SFT00032-GW_Enable_CAN_Timeout_DTC-High Beam Assistance[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-SFT00033-GW_Enable_CAN_Timeout_DTC-Battery Energy Control Module 2[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-SFT00034-GW_Enable_CAN_Timeout_DTC-All Wheel Control[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-SFT00035-GW_Enable_CAN_Timeout_DTC-Brake Boost[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-SFT00038-GW_Enable_CAN_Timeout_DTC-Electronic Roof Control[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-SFT00043-GW_Enable_CAN_Timeout_DTC-Steering Column Locking[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-SFT00048-GW_Enable_CAN_Timeout_DTC-Special Function 2[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-SFT00050-GW_Enable_CAN_Timeout_DTC-Lock Electronics[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-SFT00054-GW_Enable_CAN_Timeout_DTC-Seat Adjustment Driver Side[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-SFT00060-GW_Enable_CAN_Timeout_DTC-Lane Change Assistant[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-SFT00061-GW_Enable_CAN_Timeout_DTC-Special Function[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-SFT00064-GW_Enable_CAN_Timeout_DTC-Air Conditioning Compressor[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-SFT00066-GW_Enable_CAN_Timeout_DTC-Door Electronics Driver Side[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-SFT00068-GW_Enable_CAN_Timeout_DTC-Steering Assistance[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-SFT00071-GW_Enable_CAN_Timeout_DTC-Sound System[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-SFT00075-GW_Enable_CAN_Timeout_DTC-Multifunction module[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-SFT00081-GW_Enable_CAN_Timeout_DTC-Drive Motor Control Module[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-SFT00082-GW_Enable_CAN_Timeout_DTC-Door Electronics Passenger Side[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-SFT00085-GW_Enable_CAN_Timeout_DTC-Headlight Regulation[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-SFT00086-GW_Enable_CAN_Timeout_DTC-Radio[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-SFT00087-GW_Enable_CAN_Timeout_DTC-TV Tuner[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-SFT00095-GW_Enable_CAN_Timeout_DTC-Information Control Unit 1[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-SFT00096-GW_Enable_CAN_Timeout_DTC-Tachograph[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-SFT00101-GW_Enable_CAN_Timeout_DTC-Tire Pressure Monitoring 1[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-SFT00105-GW_Enable_CAN_Timeout_DTC-Trailer Function[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-SFT00108-GW_Enable_CAN_Timeout_DTC-Camera System Rear View[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-SFT00109-GW_Enable_CAN_Timeout_DTC-Deck Lid Control Unit[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-SFT00117-GW_Enable_CAN_Timeout_DTC-Telematics Communication Unit[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-SFT00118-GW_Enable_CAN_Timeout_DTC-Parking Assistance[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-SFT00128-GW_Enable_CAN_Timeout_DTC-Battery Regulation Auxiliary Accumulator 1[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-SFT00130-GW_Enable_CAN_Timeout_DTC-Head Up Display[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-SFT00140-GW_Enable_CAN_Timeout_DTC-Battery Energy Control Module[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-SFT00165-GW_Enable_CAN_Timeout_DTC-Front Sensors Driver Assistance System[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-SFT00166-GW_Enable_CAN_Timeout_DTC-Microphone Control Unit[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-SFT00169-GW_Enable_CAN_Timeout_DTC-Actuator For Structure-borne Sound[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-SFT00183-GW_Enable_CAN_Timeout_DTC-Access Startsystem Interface[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-SFT00187-GW_Enable_CAN_Timeout_DTC-Door Electronics Rear Driver Side[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-SFT00188-GW_Enable_CAN_Timeout_DTC-Door Electronics Rear Passenger Side[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-SFT00189-GW_Enable_CAN_Timeout_DTC-High Voltage Battery Charge Management[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-SFT00190-GW_Enable_CAN_Timeout_DTC-Sliding Door Rear Left[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-SFT00191-GW_Enable_CAN_Timeout_DTC-Sliding Door Rear Right[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-SFT00192-GW_Enable_CAN_Timeout_DTC-Actuator For Exterior Noise[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-SFT00197-GW_Enable_CAN_Timeout_DTC-Thermal management[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-SFT00198-GW_Enable_CAN_Timeout_DTC-Battery Charger Control Module[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-SFT00202-GW_Enable_CAN_Timeout_DTC-Control module for sunroof[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-SFT00204-GW_Enable_CAN_Timeout_DTC-Starter / Generator Control Module[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-SFT00207-GW_Enable_CAN_Timeout_DTC-Control Unit Lane Change Assistant 2[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118664-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x00[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118466-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x01[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118467-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x02[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118468-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x03[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118469-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x04[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118470-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x05[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118471-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x06[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118472-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x07[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118473-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x08[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118475-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x0D[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118476-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x11[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118477-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x16[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118478-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x17[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118479-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1A[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118481-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1D[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118482-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1F[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118483-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x20[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118484-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x21[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118485-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x22[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118486-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x24[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118487-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x25[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118488-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x26[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118489-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x27[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118490-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x28[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118491-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x29[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118492-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2A[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118493-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2E[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118494-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2F[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118495-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x35[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118496-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x36[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118497-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x37[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118498-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x38[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118499-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x39[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118500-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3A[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118501-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3C[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118502-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3D[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118503-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x40[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118504-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x41[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118505-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x43[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118506-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x45[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118507-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x48[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118508-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x49[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118509-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x51[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118510-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x52[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118511-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x53[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118512-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x55[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118513-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x56[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118514-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x58[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118515-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x59[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118516-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5A[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118517-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5B[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118518-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5C[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118519-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5D[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118520-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5E[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118521-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5F[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118522-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x60[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118523-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x61[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118524-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x62[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118525-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x66[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118526-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x68[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118527-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6B[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118528-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6C[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118529-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6E[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118530-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x74[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118531-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x75[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118532-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x78[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118533-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x79[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118534-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7A[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118535-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7D[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118536-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7E[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118537-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7F[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118538-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x80[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118539-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x81[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118540-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x82[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118541-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x83[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118543-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x86[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118544-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x87[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118545-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x88[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118546-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x89[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118547-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8B[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118548-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8C[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118549-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8D[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118550-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8E[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118551-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8F[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118552-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x90[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118553-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x91[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118554-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x92[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118555-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x93[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118556-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x94[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118557-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x95[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118558-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x96[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118559-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x97[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118560-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x98[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118561-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x99[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118562-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9A[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118563-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9B[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118565-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9D[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118566-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9E[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118567-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9F[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118568-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA0[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118569-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA1[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118570-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA2[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118571-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA3[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118573-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA5[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118574-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA6[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118575-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA7[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118576-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA8[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118578-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAA[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118579-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAB[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118580-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAC[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118581-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAD[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118583-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAF[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118584-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB0[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118585-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB1[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118586-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB2[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118587-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB3[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118588-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB4[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118589-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB5[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118590-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB6[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118591-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB7[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118592-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB8[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118593-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB9[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118594-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBA[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118595-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBB[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118596-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBC[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118597-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBD[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118598-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBE[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118599-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBF[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118600-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC0[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118601-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC1[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118602-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC2[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118603-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC3[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118604-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC4[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118605-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC5[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118606-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC6[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118607-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC7[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118608-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC8[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118609-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC9[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118610-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCA[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118611-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCB[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118612-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCC[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118613-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCD[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118614-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCE[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118615-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCF[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118616-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD0[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118617-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD1[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118618-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD2[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118619-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD3[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118620-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD4[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118621-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD5[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118622-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD6[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118623-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD7[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118624-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD8[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118625-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD9[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118626-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDA[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118627-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDB[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118628-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDC[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118629-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDD[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118630-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDE[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118631-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDF[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118632-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE0[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118633-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE1[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118634-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE2[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118635-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE3[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118636-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE4[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118637-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE5[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118638-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE6[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118639-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE7[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118640-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE8[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118641-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE9[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118642-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEA[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118643-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEB[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118644-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEC[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118645-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xED[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118646-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEE[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118647-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEF[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118648-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF0[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118649-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF1[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118650-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF2[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118651-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF3[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118652-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF4[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118653-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF5[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118654-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF6[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118655-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF7[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118656-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF8[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118657-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF9[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118658-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFA[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118659-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFB[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118660-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFC[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118661-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFD[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118662-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFE[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137058-ENG118663-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFF[/FONT] [FONT=&quot]Enabled [/FONT] [FONT=&quot]32[/FONT]
[FONT=&quot]ENG137059-ENG118464-GW_mirror_mode-mirror_mode_bus[/FONT] [FONT=&quot]Databus drivetrain [/FONT] [FONT=&quot]2[/FONT]
[FONT=&quot]ENG137059-ENG118465-GW_mirror_mode-mirror_mode_typ[/FONT] [FONT=&quot]not active [/FONT] [FONT=&quot]2[/FONT]
[FONT=&quot]ENG152379-MV-EM_adaption_48V_zero_potential[/FONT] [FONT=&quot]regular operation [/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]ENG137850-MVK_Warning[/FONT] [FONT=&quot]regular operation [/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]ENG118774-ENG98345-WakeUpMonitor_Activation-Activation[/FONT] [FONT=&quot]activated [/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]ENG118774-ENG152567-WakeUpMonitor_Activation-Open_Filter_Activate[/FONT] [FONT=&quot]activated [/FONT] [FONT=&quot]1[/FONT]
[FONT=&quot]ENG118773-ENG99074-WakeUpMonitor_Configuration-Max_Num_Keeping_Awake_Events[/FONT] [FONT=&quot]100[/FONT] [FONT=&quot]8[/FONT]
[FONT=&quot]ENG118773-ENG103057-WakeUpMonitor_Configuration-Max_Num_Logical_WakeUp_Events[/FONT] [FONT=&quot]20[/FONT] [FONT=&quot]8[/FONT]
[FONT=&quot]ENG118773-ENG104006-WakeUpMonitor_Configuration-Max_Num_Physical_WakeUp_Events[/FONT] [FONT=&quot]20[/FONT] [FONT=&quot]8[/FONT]
[FONT=&quot]ENG118773-ENG154846-WakeUpMonitor_Configuration-Open_Filter_Time[/FONT] [FONT=&quot]45 min[/FONT] [FONT=&quot]8[/FONT]
[FONT=&quot]ENG118773-ENG103852-WakeUpMonitor_Configuration-Sample_Time_Keeping_Awake_Events[/FONT] [FONT=&quot]12 s[/FONT] [FONT=&quot]8[/FONT]
[FONT=&quot]ENG118773-ENG127936-WakeUpMonitor_Configuration-WakeUpMonitor_Start_Delay[/FONT] [FONT=&quot]0 s[/FONT] [FONT=&quot]8[/FONT]
[FONT=&quot]Elapsed Time: 00:25[/FONT]
corradokid
CA, USA
C?ID=32540
Oddly enough after scanning the CAN Gateway for adaptations I noticed my dash lighting stopped flashing. I cleared all faults and ran another auto scan and everything is back to as it was before the Instrument CP output test. Maybe it just needed to be opened?
Monday,03,August,2020,08:39:55:41546VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(Parallels)
VCDS Version 20.4.2.0 (x64)  HEX-NET CB: 0.4526.4
VIN: 3VW5T7AU7KM035767   License Plate:
Mileage: 1425km-885mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 05 08 09 10 13 14 15 17 19 29 2B 32 39 3C 42 44 47 4B
          52 5F 75 A5 A9 D6 D7
VIN: 3VW5T7AU7KM035767   Mileage: 1425km-885miles
Address 01: Engine (J623-DKFA)       Labels: None
   Part No SW: 5G0 906 259 Q    HW: 06K 907 425 J
   Component: R4 2.0l TFSI  H13 0005
   Revision: --H13---
   Coding: 091900322444002F1000
   Shop #: WSC 00066 790 00072
   ASAM Dataset: EV_ECM20TFS0205G0906259Q 001006
   ROD: EV_ECM20TFS0205G0906259Q.rod
   VCID: 3C341CE4B7C9ED660F-8069
Readiness: 1110 1101
   Part No SW: 5Q0 614 517 FC    HW: 5Q0 614 517 BM
   Component: ESC           H45 0191
   Revision: 00000000    Serial number: 52309000000896
   Coding: 01FA6BA150230971407E020660CA6880D60A900240061636344350D1D0A94B0B0000000012121212B835351919323200
   Shop #: WSC 28436 004 1048576
   VCID: 77BEC3C8CE6F0E3E22-8023
   Part No SW: 3Q0 959 435 N    HW: 3Q0 959 435 N
   Component: VWKESSYMQB    037 1307
   Revision: 00037000    Serial number: 0522422179
   Coding: 132C0C0623
   Shop #: WSC 00066 790 00088
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 45C27900C403ACAE60-8011
   Part No SW: 5GM 907 044 G    HW: 5GM 907 044 G
   Component: Climatronic   H04 2001
   Revision: 00001K05
   Coding: 0002001420011800010400401211100C
   ASAM Dataset: EV_ACClimaBHBVW37X 006146
   VCID: 48DC7034F311B1C69B-801D
   Part No SW: 5Q0 937 087 BA    HW: 5Q0 937 087 BA
   Revision: --------    Serial number: C86417091904JL
   Shop #: WSC 00066 790 00239
   ROD: EV_BCMBOSCH_019.rod
   VCID: 7BB6DFF8F2472A5E46-802F
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    190704  043 0551
   Serial number: 97022066190711070557
   Component: RLHS  051 0206
   Serial number: SAY19M07D17H08M56S32
   Coding: 06A8DD
   Sun Roof:
   Subsystem 3 - Part No SW: 5GD 959 591 A    HW: 5GD 959 591 A
   Component: J245 PS60.006  H07 0170
   Serial number: 03691616341912181602
   Coding: 181803
   Steering Column Switch:
   Subsystem 5 - Part No SW: 5Q1 953 521 M    HW: 5Q1 953 569
   Component: Lenks.Modul  H03 0170
   Serial number: 0300060920190C202228
526359 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [Steuergerät falsch codiert->Keine Anzeige]
                    Reset counter: 35
                    Mileage: 1425 km
                    Date: 2020.08.03
                    Time: 08:37:36
   Part No SW: 5QA 919 298 D    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0050
   Serial number: 000137089R19231
   Coding: 0271167801
   ASAM Dataset: EV_EPHVA2CAU3700000 009041
   VCID: 51EA5D50004B700ECC-8005
   Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
   Coding: 2D0040C141FFC728949C810510401600000000000000000004
   VCID: 44C46404CF3995A677-8011
   Serial number: 02071941350541
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 383C00F483F1C146EB-806D
   Serial number: 003GCR0CCGJV
   VCID: 47DE7308FE0FBEBE92-8013
   Occupant Detection:
   Component: BF-Gewichtss.  H14 0022
   Serial number: IBH00000000000C1OCDM
   Coding: 303131
   Subsystem 2 - Part No SW: -----------    HW: 480 002 007 19
   Serial number: 35700000000B967C6D3$
   Subsystem 3 - Part No SW: -----------    HW: 480 002 007 19
   Serial number: 35800000000AC861DD3$
   Subsystem 4 - Part No SW: -----------    HW: 480 401 907 19
   Component: SideSensor_Dr  005 6149
   Serial number: 3510001C2F11B85639FC
   Subsystem 5 - Part No SW: -----------    HW: 480 402 007 19
   Component: SideSensor_Pr  005 6149
   Serial number: 3520001AAF11B856C37E
   Subsystem 6 - Part No SW: -----------    HW: 480 400 908 19
   Component: FrontSensor_D  005 6149
   Serial number: 3550001C4F08AF8832ER
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 400 908 19
   Component: FrontSensor_P  005 6149
   Serial number: 3560001C4F08AF88381L
   Part No SW: 5G1 920 856 D    HW: 5G1 920 856 D
   Component: KOMBI         351 2700
   Coding: 0BAD0912FD88CF0502887B0B5001000080000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009068
   VCID: 2F2E3BA876BF06FEBA-807B
   Part No SW: 3Q0 907 530 AA    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5366
   Serial number: 19091900841687
   Coding: 0101000830085900FB00023B880F00000001070000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 6E90E6ACB1354FF6F1-803B
   Component: 0-00-0d-00-04
   Subsystem 2 - Part No SW: 5G0 959 442 AE    HW: 5G0 959 442 AE  Labels: 3C8-959-537.CLB
   Component: E221__MFL-MD9  H12 0052
   Serial number: 29190001253840049231
   Coding: 2CFFFF
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
   Component: LCM_MLBevoH08 0014
   Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
   Component: ELV-MQBB      H08 0021
   Serial number: 19000208919002
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 312A3DD0608B100EAC-8065
Address 32: Differential Locks (J492)       Labels:* 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 P    HW: 0CQ 907 554 P
   Component: Quersperre    H55 8043
   Serial number: HA1-00021.03.19
   Coding: 0001
   ASAM Dataset: EV_LockElectHA1VW37X 001007
   ROD: EV_LockElectHA1VW37X.rod
   VCID: 52E8525C054D0B16F5-8007
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
   Component: HRE_Master    H12 0081
   Serial number: 0522581830
   Coding: 02011103
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3D3211E0ACD3E46E38-8069
   Component: HRE_Slave  H12 0081
   Serial number: 0525442080
   Coding: 020111
   Part No SW: 5Q4 959 593 M    HW: 5Q4 959 593 F
   Component: TSG FS        006 0247
   Serial number: 42038923401373
   Coding: 003E13200000040000000000
   Shop #: WSC 01383 790 50316
   ROD: EV_DCU2DriveSideMAXHKLO.rod
   VCID: 4FEE5B28167F66FEDA-801B
   Subsystem 1 - Part No SW: 5Q4 959 811 F    HW: 5Q4 959 811 F  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000004066896
   Coding: 011000
   Part No SW: 5QN 909 144 B    HW: 5QN 909 144 A
   Component: EPS_MQB_ZFLS  507 5082
   Coding: 930A0000
   ROD: EV_SteerAssisMQB_015.rod
Address 47: Sound System (J525)       Labels:| 5Q0-035-456.clb
   Part No SW: 5Q0 035 456 A    HW: 5Q0 035 456 A
   Component: MIB2_lite_amp H40 0200
   Revision: 00000001    Serial number: VWZ8Z1KMD05QU22
   VCID: 2E1026AC71B50FF6B1-807B
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V2.clb
   Part No SW: 3Q0 907 338 C    HW: 3Q0 907 338 C
   Component: FCM MQB Low   002 0345
   Serial number: 23081900840006
   Coding: 000000050900210A07110F01030000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 002006
   ROD: EV_MultiModulContiVW48X_002_VW37.rod
   VCID: 352209C094E33C2EF0-8061
   Part No SW: 5Q4 959 592 M    HW: 5Q4 959 592 F
   Component: TSG BFS       006 0247
   Serial number: 46038924501558
   ROD: EV_DCU2PasseSideMAXHKLO.rod
   VCID: 4ED0462C11756FF6D1-801B
   Subsystem 1 - Part No SW: 5Q4 959 812 F    HW: 5Q4 959 812 F  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000004071445
   Coding: 091000
   Part No SW: 3Q0 035 876 B    HW: 3Q0 035 876 B
   Component: MU-S-NS-US    853 0890
   Coding: 027310020000000041220002001808001F0503F401200500C6
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 332637D89A97221EDE-8067
   Subsystem 1 - Part No SW: 5G6 919 605 D    HW: 5G6 919 605 D
   Component: ABT_Std-2_Nav  254 8130
   Serial number: VWZ6ZMW2625263
   Subsystem 2 - Part No SW: 5NA 919 866 E    HW: -----------
   Component: NAR 2018/19  --- 0810
   Component: OCULowMQBUS   009 0570
   Coding: 02730002C2823A017F1E06000000
   ROD: EV_OCULowMQB.rod
   VCID: 43C66718CA37929E4E-8017
   Part No SW: 3Q0 980 654 L    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H12 0610
   Serial number: 09071915P20826
   Coding: 000307000002020100221354C150490084000E20012000
   ROD: EV_MFKBoschMQBB_002.rod
   VCID: 40CC6814DB21898653-8015
   Part No SW: 5G0 907 159 G    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0001
   Serial number: 190614203113
   VCID: 322832DC658D2B16D5-8067
   Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
   Component: LED1L         H06 0002
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
   VCID: 393A05F0B8FBD84E14-806D
   Component: LED1R         H06 0002
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
   ROD: EV_LEDMinMaxRKEBODVW481.rod
End----------(Elapsed Time: 01:43, VBatt start/end: 12.3V/12.3V)-----------
DV52
C?ID=194404
^^^corradokid: Yes, selecting Component CP certainly is a courageous thing to do - but as I understand, the enforced errors (and the CP state, itself) on the instrument cluster only apply for the current ignition cycle.
It kind-of makes sense for this to happen because the test for CP is automatically performed by the CP master module (i.e. the CAN Gateway module @ address hex19) immediately after ignition switch-on. This means that at the next ignition switch-on after your selection of the "courageous" option, the hex19 module sends-out a request for the identities of all the modules in the CP constellation. Since the identity of the hex17 module is exactly equal to the identity that is recorded in the encrypted CP module list - the test is successfully completed and the CP errors are cleared - I reckon!!
