Function Restricted due to Missing Message
C?ID=187160
What does 'Function Restricted due to Missing Message' mean at address 75 in scan below?
Friday,03,April,2020,14:54:46:39636
VCDS Version: 20.4.0.1 (x64)  HEX-V2 CB: 0.4508.4
VIN: WVWZZZ3CZLE048230   License Plate:
Chassis Type: 3C-VW48 (3Q0)
Scan: 01 03 05 08 09 10 13 15 17 19 23 2B 42 44 52 5F 65 75 A5 CA
VIN: WVWZZZ3CZLE048230   Mileage: 6906km-4291miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DSRA)       Labels: None
   Part No SW: 05L 906 022 BJ    HW: 05L 907 309 B
   Component: R4 2.0l TDI   H30 9737
   Revision: E3H30---
   Coding: 011904120344050830000000000000000000000000000000
   Shop #: WSC 05311 115 00312
   ASAM Dataset: EV_ECM20TDI01105L906022BJ 006004
   ROD: EV_ECM20TDI01105L906022BJ_006_VW48.rod
   VCID: 70B9D7D03A2ABECBA32-8024
Readiness: 0 0 0 1 1
   Part No SW: 5Q0 614 517 FA    HW: 5Q0 614 517 BR
   Component: ESC           H82 0190
   Revision: 00000000    Serial number: 62799000003903
   Coding: 0EECBA8F31243B744779060360C349705D8CDCE2600692713460F00850224A0B0003000012121212B835351919323200
   Shop #: WSC 00015 115 08193
   VCID: 75B7E6C445489BE3704-8020
   Part No SW: 3Q0 959 435 M    HW: 3Q0 959 435 M
   Component: VWKESSYMQB    027 1307
   Revision: 00027000    Serial number: 0529356985
   Coding: 002F0F0623
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 44D14B005E12726B37A-8010
   Part No SW: 5G0 907 044 ER    HW: 5G0 907 044 ER
   Component: Climatronic   H04 2202
   Revision: 00001K10
   Coding: 1112011420011001111500008010D836
   ASAM Dataset: EV_ACClimaBHBVW37X 006150
   VCID: 7BA3F0FC636CCD93060-802E
   Air quality sensor:
   Part No SW: 5Q0 937 086 CE    HW: 5Q0 937 086 BQ
   Component: BCM PQ37BOSCH 038 0303
   Revision: --------    Serial number: J53F22091900EP
   ASAM Dataset: EV_BodyContrModul1UDSBosc 020001
   ROD: EV_BCMBOSCH_020.rod
   VCID: 7F5B04EC7774D1B32A8-802A
   Subsystem 1 - Part No SW: 3G2 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    190823  043  0607
   Serial number:         190913094057
   Component: RLHS  051  0206
   Serial number: SBY19M10D10H01M04S38
   Coding: 0008DD
   Component: E1 - LDS MQB  H01  0032
   Serial number: 11 10 2019  10001133
   Component: Sensor, DWA  005  0316
   Serial number: 000000000ZY192550TNA
   Subsystem 5 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
   Component: Sirene, DWA  004  0007
   Serial number: 00000000000000637664
   Steering Column Switch:
   Subsystem 7 - Part No SW: 5Q1 953 521 BC    HW: 5Q1 953 569
   Component: Lenks.Modul  H03  0170
   Serial number: 0100160920190C100917
   Part No SW: 5QA 919 294 G    HW: 5QA 919 294
   Component: PDC 8 Kanal   H08 0061
   Serial number: 000150058319278
   Coding: 0471051801
   Shop #: WSC 05311 115 00091
   ASAM Dataset: EV_EPHVA18AU3700000 009046
   VCID: 50F977509A6A9ECB832-8004
   Part No SW: 5Q0 907 572 R    HW: 3Q0 907 567 A
   Component: ACC BOSCH MQB H01 0771
   Coding: 2A0178C251FFC728949C812461400600000000000000000066
   ASAM Dataset: EV_ACCBOSCHVW416 003014
   ROD: EV_ACCBOSCHVW416_003.rod
   VCID: 46D55108682E407B29E-8012
   Part No SW: 3Q0 959 655 CP    HW: 3Q0 959 655 CP
   Revision: --------    Serial number: 003Z4PHKNN0L
   Coding: 98FCC0C0000000005C5400CF008840000065
   Shop #: WSC 05311 000 08193
   ROD: EV_AirbaVW21TS6VW48X.rod
   VCID: 0E45A92840DEC83BD1E-805A
   Belt Pretensioner left:
   Component: BeltPretRevFL  106 1040
   Serial number: 3G0857705B0277T01240
   Coding: 80000D
   Belt Pretensioner right:
   Component: BeltPretRevFR  106 1040
   Serial number: 3G0857706B0287T01049
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 454 002 208 19
   Serial number: 3570000000056A58FE3
   Subsystem 4 - Part No SW: -----------    HW: 454 002 108 19
   Serial number: 358000000002F328FE3Z
   Subsystem 5 - Part No SW: -----------    HW: 454 802 708 19
   Serial number: 35100FB788A19000000Z
   Subsystem 6 - Part No SW: -----------    HW: 454 802 708 19
   Serial number: 35200966B8A19000000R
   Subsystem 7 - Part No SW: -----------    HW: 454 802 108 19
   Serial number: 35500DD696319000000U
   Part No SW: 3G0 920 951 F    HW: 3G0 920 951 F
   Component: KOMBI         304 6700
   Coding: 27A401906684060001886A071001000880600000
   VCID: 2A0D05B8DC76841B2D6-807E
   Component: GW MQB High   442 4388
   Revision: --------    Serial number: 0000100722
   Coding: 030900045F087300F900425C080F00000001070000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   Component: 5-01-14-01-04
   Subsystem 2 - Part No SW: 3G0 959 442 J    HW: 3G0 959 442 J
   Component: E221__MFL-PR6  H06 0110
   Serial number: PR6-0440036272190387
   Coding: 2C0B00
   Serial number: 758860030019100418D1
Address 23: Brake Booster (J539)       Labels: None
   Part No SW: 3Q0 909 059 G    HW: 3Q0 909 059 A
   Component: EBKV          H06 0069
   Serial number: BPA085270919013
   Coding: 0102C500340000C618638C31000049922449920400
   ASAM Dataset: EV_BrakeBoostG2BoschVW48X 011019
   ROD: EV_BrakeBoostG2BoschVW48X_011_VW41.rod
   VCID: 3B2330FC23EC0D93460-806E
   Serial number: 19000256970006
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 333318DC0BBCC5D39E0-8066
   Part No SW: 5Q0 959 593 K    HW: 5Q0 959 593 F
   Component: TSG FS002 0325
   Serial number: YE007SI309168
   Coding: 00350A20D001028000001000
   ROD: EV_DCU2DriveSideMAXHKLO.rod
   VCID: 49CF5A347930AF03C4C-801C
   Subsystem 1 - Part No SW: 5Q4 959 811 H    HW: 5Q4 959 811 H
   Serial number: 00000000000013263331
   Coding: 0D0000
   Part No SW: 5Q0 909 144 AB    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  130 1082
   Coding: 911F0000
   Shop #: WSC 00015 115 00312
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 74B1DBC04E3282EB47A-8020
Address 52: Door Elect, Pass. (J387)       Labels:* Redir Fail!
   Part No SW: 5Q0 959 592 K    HW: 5Q0 959 592 F
   Component: TSG BFS002 0325
   Serial number: YE007SI40229D
   Coding: 00350020DC01028000001000
   ROD: EV_DCU2PasseSideMAXHKLO.rod
   VCID: 48C95F30623A560BDB2-801C
   Subsystem 1 - Part No SW: 5Q4 959 812 H    HW: 5Q4 959 812 H
   Serial number: 00000000000013349501
   Coding: 050000
   Part No SW: 3G5 035 820     HW: 3G5 035 820
   Component: MU-O-ND-EU    H12 0152
   Serial number: VWZAZ2W1159028
   Coding: 24810008000020000000000000000000000000000000000000
   ASAM Dataset: EV_MUOIMQB 001001
   ROD: EV_MUOIMQB_VW48.rod
   VCID: 619FA294E1C007433CC-8034
   Serial number: 30000000339166
   ROD: EV_RDKBERU30_006_VW37.rod
   VCID: 34311BC00EB2C2EB87A-8060
   Part No SW: 5WA 035 284     HW: 5WA 035 284
   Component: OCUGen3High   H20 0083
   Serial number: 0000000907VIQS3
   Coding: 024810001968AC209005460160002607
   ASAM Dataset: EV_OCUGen3High 002115
   ROD: EV_OCUGen3High_002_VW37.rod
   VCID: 0353881C1B9CB5534E0-8056
7170 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Multi Function Display (0x0F) - Funktionseinschränkung wegen Kommunikationfehler - BapErr_RetryNotSuccessful]
                    Reset counter: 40
                    Mileage: 6906 km
                    Date: 2020.04.03
                    Time: 14:52:43
                    Voltage terminal 30: 11.8 V
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* None
   Part No SW: 2Q0 980 653     HW: 2Q0 980 653
   Component: MQB MFK 3.0   H11 1027
   Serial number: E33417011192890
   Coding: 00000808114C4020109E00001020000000410000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 005035
   ROD: EV_MFK3ValeoMQB_005_VW27.rod
   VCID: 72BDDDD834268CDB556-8026
   Part No SW: 4K0 907 594 AD    HW: 4K0 907 594
   Coding: 708000748101
   ROD: EV_SunRoofCONTIAU736_009_VW37.rod
   VCID: 76B5E1C8584E90FB79E-8022
End----(Elapsed Time: 01:46, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
In the UK the telematics has been disabled by instruction of VW.
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
          U1111 00 [008] - -
                    Reset counter: 40
                    Mileage: 6906 km
                    Date: 2020.04.03
                    Time: 14:52:43
75 - Telematics is in charge of the Audi Connect telematics features on your vehicle. The fault means the module couldn't carry out some unspecified part of its job role because some CAN message it expected did not arrive. In this case, it's a BAP message to what I believe is your infotainment unit, or possibly instrument cluster. BAP is German for "operating and display protocol", basically when a given control module needs to interact with a human, it talks to something in the car with a UI (like the infotainment or cluster) using the BAP protocol to display info and alerts, show menus, get settings, retrieve driver profile info, etc etc.
Four days ago that conversation broke down. Battery voltage was pretty low so I'd hazard a guess the car went to sleep. It's not unknown to see comms disruption faults like that if the battery is run down very low, or the infotainment unit is rebooted manually, etc. It's not a physical fault, and unless it happens again there's not even anything to troubleshoot further. I'd clear it and not worry about it further if I were you.
C?ID=187160
Thanks jyoung8607 for the detailed explanation. The scan was made when the engine was not running. I note your point about the battery voltage but this is typical over several scans that I have performed with engine not running. A scan taken with engine running showed a voltage of 14.6V at the end of the scan. This is a November 2019 Passat so would have thought the battery should be in excellent condition so don't know why the voltage is so low when engine not running. I have run the clear DTCs several times but this fault always reappears.
C?ID=187160
PetrolDave, Are you sure that telematics is disabled in the UK as I have managed to clear this fault?
Many owners have reported on various websites that dealers have told them that VAG have disabled telematics in the UK for an unconfirmed reason - that's all I know.
