Hello from France to you all
So yes, as a good newbie I'm going to bother some of you with questions.. (hoping you will untertand me..)
First to comply with the forum rules, find hereafter an autoscan of my recently bought GTI:
So as you can notice the car comes with a MIB2, which seems to cause the error 66052 in address 19 Can Gateway. Is this right?
I'd like to get the performance monitor showing onto the MIB2 along wtih the (useless) Think Blue Monotor..
I could not find any answer yet, except that MIB2 should be able to make it, but how?
Thank you for your help
Regards
Hugo
Tuesday,18,February,2020,17:13:03:12329
VCDS Version: 19.6.2.2 (x64) HEX-V2 CB: 0.4508.4
VIN: WVWZZZAUZGW1xxxxx License Plate: WW
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 10 14 15 16 17 19 42 44 52 55 5F A5 A9
VIN: WVWZZZAUZGW168719 Mileage: 66441km-41284miles
Address 01: Engine (J623-CHHB) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 C HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 091D00122424050B2000
ASAM Dataset: EV_ECM20TFS0205G0906259C 001005
ROD: EV_ECM20TFS0205G0906259C.rod
VCID: 2E05F06A009447E76B9-807A
Part No SW: 0D9 300 041 C HW: 02E 927 770 AQ
Component: DQ250-6F MQB H53 4902
Revision: 06253104 Serial number: TFK01510020740
ROD: EV_TCMDQ250021.rod
VCID: 186936B29210A957115-804C
Part No SW: 3Q0 907 379 AA HW: 3Q0 907 379 F
Component: ESC H42 0623
Revision: 00000000 Serial number: 62835000002808
Coding: 01FA6BA134262974077E0601C1CCA980D62C94E0608395F7004200F8C209
ROD: EV_Brake1UDSContiMK100IPB_034_VW37.rod
VCID: 79AF1336895A505F8EB-802C
Part No SW: 5G0 907 044 BD HW: 5G0 907 044 BD
Component: Climatronic H03 1001
Revision: 00001K08
Coding: 00020004200100011105000000101002
ROD: EV_ACClimaBHBVW37X_004_VW37.rod
VCID: 6A8D3C7AFCFCEBC7771-803E
Air quality sensor:
Part No SW: 5Q0 937 084 AS HW: 5Q0 937 084 AN
Component: BCM MQBAB H H24 0175
Serial number: 01061529400465
Coding: 00001E46C24122F34BE44000001C07281000000000000000000000000000
ROD: EV_BCMBOSCH_015.rod
VCID: 094F63F6D9BA40DF9EB-805C
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 151002 043 0551
Serial number: 151012095952
Component: RLHS 037 0059
Serial number: S5Y15M11D03H11M45S02
Coding: 90A8DD
Part No SW: 5Q0 919 294 K HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0054
Revision: -------- Serial number: 39391529904871
Coding: 0031151011
VCID: 43D3B1DEBB16DA8F947-8016
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 A HW: 5Q0 907 376 A
Component: DAEMPFUNGS-SG H17 0120
Serial number: 03101541350302
ROD: EV_DRCONTITEMIC_VW37.rod
VCID: 372BD50EFFCE862F38F-8062
Part No SW: 5Q0 959 655 AA HW: 5Q0 959 655 AA
Component: AirbagVW20 015 0388
Serial number: 003MLR16Y8E7
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 7F5BFD2E977E7E6FB0F-802A
Belt Pretensioner left:
Component: BeltPretRevFL H36 0350
Serial number: 34169667B30101580940
Coding: 333135
Belt Pretensioner right:
Component: BeltPretRevFR H36 0350
Serial number: 34169668B27101541016
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 001 610 15
Serial number: 35767000000A907D371Z
Subsystem 4 - Part No SW: ----------- HW: 480 001 610 15
Serial number: 358670000004BB25E61/
Subsystem 5 - Part No SW: ----------- HW: 480 402 310 15
Serial number: 35165029B1CF1D23E29S
Subsystem 6 - Part No SW: ----------- HW: 480 402 310 15
Serial number: 3526502AB1CF1D22A13I
Subsystem 7 - Part No SW: ----------- HW: 480 402 310 15
Serial number: 35565029B1CF1D24514I
Part No SW: 5Q0 953 521 P HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0195
Revision: FF033033 Serial number: 20151031400407
Coding: 0410
ROD: EV_SMLSVALEOMQB.rod
VCID: 3FDBBD2ED7FEBE6FF0F-806A
Part No SW: 5G1 920 756 A HW: 5G1 920 756 A
Component: KOMBI 302 6420
Coding: 07AD09083B80000801086A001400000000000000
VCID: 2B03F97E338632CF4C7-807E
Part No SW: 5Q0 907 530 AJ HW: 5Q0 907 530 M
Component: GW MQB High 212 2246
Revision: -------- Serial number: 19101510803418
Coding: 030100043F085900FB00026E9C0F00010001050000000000000000000000
ROD: EV_GatewConti_013.rod
Subsystem 2 - Part No SW: 5G0 959 442 M HW: 5G0 959 442 M Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0103
Serial number: 29150002141630105441
Coding: 29FFFF
Subsystem 3 - Part No SW: 5Q0 915 181 G HW: 5Q0 915 181 G
Component: J367-BDMHella H04 8050
Serial number: 9085888203
Component: TSG FS 020 0041
Serial number: 270715BGR09063
Coding: 003F0320D000048000001000
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000007840140
Coding: 110000
Part No SW: 3Q0 909 144 J HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5063
Coding: 8103
VCID: 392FD336C9DA905FCEB-806C
Component: TSG BFS 020 0041
Serial number: 310715BGU13442
Coding: 003F0120DE00048000801000
VCID: 42DDB4DAA40CD3879F1-8016
Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000007866442
Coding: 090000
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Coding: 029203104F000200
VCID: 40D9BED2AA00C197895-8014
Subsystem 1 - Part No SW: 3D0 941 329 D HW: 3D0 941 329 D Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0002
Coding: 900000
Subsystem 2 - Part No SW: 3D0 941 329 D HW: 3D0 941 329 D Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0002
Coding: 900000
Part No SW: 3Q0 035 846 HW: 3Q0 035 846
Component: MU-S-N-ER 820 0627
Coding: 02730001FF00000051110001000808001F02039401200100CF
ROD: EV_MUStd4CDELP_VW37.rod
VCID: 6E85306AC01407E72B9-803A
Subsystem 1 - Part No SW: 3G0 919 605 D HW: 3G0 919 605 D
Component: ABT_Std-2_Nav H43 4064
Serial number: VWZ6Z9R3001219
Subsystem 2 - Part No SW: 5NA 919 866 AR HW: -----------
Component: ECE AS 20/21 --- 1430
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 5Q0-980-653.clb
Part No SW: 5Q0 980 653 G HW: 5Q0 980 653
Component: MQB_MFK H06 0060
Serial number: 10000453803
Coding: 0000020001020306000400000000000100
ROD: EV_MFKBoschAU370.rod
VCID: 3C21CA22C6E8A577D5D-8068
Part No SW: 5G0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0014
Serial number: 150827202038
VCID: 6B83397EF306F2CF0C7-803E
End----------(Elapsed Time: 01:39, VBatt start/end: 12.1V/12.1V)-----------
Regards
Hugo
