Meas. Block is grey
khaledabdulaziz
Israel
C?ID=394371
hello all
i'm working on skoda 2013 with hex-v2 3VIN and waiting, paid and waiting for upgrade, anyways i want to check egr values in it but i cant cos measure block is greyed and the car has uds protocol
here the autoscan, what might be the problem
update, tried it on another and still the same problem
Thursday,13,February,2020,10:30:38:04619
VIN: TMBAG7NE9D0019598   License Plate:
Chassis Type: NE-SK37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 5F
VIN: TMBAG7NE9D0019598   Mileage: 334946km-208125miles
Address 01: Engine (J623-CLHA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 N    HW: 04L 907 309 B
   Component: R4 1,6L EDC   H22 4946
   Revision: 84H22---
   Coding: 01250012032401090000
   Shop #: WSC 73430 031 00207
   ASAM Dataset: EV_ECM16TDI01104L906021N 002007
   ROD: EV_ECM16TDI01104L906021N_002.rod
   VCID: 303916FB1AA27337797-8064
5188 - Diesel Particle Filter
          P2463 00 [167] - Excessive Soot Accumulation
                    Mileage: 334946 km
                    Date: 2020.01.26
                    Time: 11:48:15
                    Coolant temperature: 76 °C
                    Intake air temperature: 62 °C
                    Voltage terminal 30: 12.380 V
                    Counter for regeneration time of diesel particle filter: 0.00 s
                    Particle filter: kilometers since last regeneration: 1981963 m
                    Particle filter: soot mass measured: 9.71 g
                    Particle filter: soot mass calculated: 50.00 g
                    Particl.filt.: differential pressur.sensor 1 bank 1: dyn.offset: 3 hPa
20557 - Heater support pump
          P16C7 00 [039] - locked
                    Mileage: 334946 km
                    Date: 2020.01.26
                    Time: 11:48:19
                    Heater support pump 1 bank 1 second.circuit: activat.: 95.00 %
                    Extern.temp.sens.1 bank 1: raw value: 24.5 °C
                    Shut-off timer: last engine shut-off time: 409 s
          U0428 00 [039] - -
                    Mileage: 334946 km
                    Date: 2020.01.26
                    Time: 11:48:15
17158 - Databus
                    Mileage: 334946 km
                    Date: 2020.01.26
                    Time: 11:48:14
                    Drivetrain coordinator: brake fault status-Bits 0-7: 4
                    Acceleration: 0.000 m/s²
   Part No SW: 0CW 300 047 R    HW: 0AM 927 769 G
   Component: GSG DQ200-MQB H43 5210
   Revision: 00043014    Serial number: CU501411085892
   Shop #: WSC 04940 001 00001
   ROD: EV_TCMDQ200021_VW31.rod
   VCID: 4ACD64139C3E29E7573-801E
   Part No SW: 5Q0 907 379 A    HW: 5Q0 907 379 A
   Component: ESC           H75 0333
   Coding: 1A07629120210A75007C060901CB245846045000608024F000490020C0
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 008020
   ROD: EV_Brake1UDSContiMK100ESP_008_SK37.rod
   VCID: 3A2D34D3CCDEB967C73-806E
0295 - Steering angle sensor
                    Reset counter: 0
                    Mileage: 334946 km
                    Date: 2020.01.26
                    Time: 11:48:31
16390 - Display for Tire Pressure Monitoring
                    Reset counter: 0
                    Mileage: 334946 km
                    Date: 2020.01.26
                    Time: 11:48:40
16401 - Tire Pressure Warning
          C102D 00 [136] - -
                    Reset counter: 40
                    Mileage: 334946 km
                    Date: 2020.01.26
                    Time: 11:48:40
   Part No SW: 5E0 907 044     HW: 5E0 907 044
   Component: Climatronic   H02 0604
   Revision: 00001K06
   Coding: 00010104000100011005000000100000
   ROD: EV_ACClimaBHBVW37X_002_VW37.rod
   VCID: 629DACB304CE91A7BF3-8036
263425 - Air Quality Sensor
          B10AF 04 [008] - Internal System Fault
                    Fault Frequency: 96
                    Reset counter: 36
                    Mileage: 333155 km
                    Date: 2020.01.10
                    Time: 03:02:35
   Part No SW: 5Q0 937 084 N    HW: 5Q0 937 084 N
   Component: BCM MQBAB M   H14 0106
   Serial number: 00011306600594
   Coding: 0C001842424702FB07A04000000407080000000000000000000000000000
   Shop #: WSC 73430 790 00207
   ROD: EV_BCMBOSCH_010.rod
   VCID: 43D34937BB14F8AF945-8016
   Subsystem 1 - Part No SW: 5E1 955 119     HW: 5E1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 130302  041 0570
   Serial number:         130307002938
   Coding: 065DDD
   Component: RLFS  024 0042
   Serial number: Y13M03D16H21M00S00S4
   Coding: 02805D
7 Faults Found:
9482 - Statiionary Cornering Lamp Right
          B1222 15 [009] - Open or Short to Plus
                    Reset counter: 191
                    Mileage: 333165 km
                    Date: 2020.01.10
                    Time: 04:59:15
10515 - Bulb for Left Tail Light
          B12BE 01 [008] - Electrical Failure
                    Fault Frequency: 17
                    Reset counter: 32
                    Mileage: 333239 km
                    Date: 2020.01.11
                    Time: 03:15:05
11786 - Bulb for Rear Left Fog Light
          B12C7 15 [009] - Open or Short to Plus
                    Reset counter: 191
                    Mileage: 333155 km
                    Date: 2020.01.10
                    Time: 03:04:53
12298 - License Plate Light
          B12CA 15 [009] - Open or Short to Plus
                    Reset counter: 191
                    Mileage: 333155 km
                    Date: 2020.01.10
                    Time: 03:04:53
12554 - Bulb for Left Back-up Light
          B12CB 15 [009] - Open or Short to Plus
                    Reset counter: 191
                    Mileage: 333155 km
                    Date: 2020.01.10
                    Time: 03:10:13
204546 - Remote key 2
          B147A 18 [008] - Current Too Low
                    Reset counter: 36
                    Mileage: 334788 km
                    Date: 2020.01.25
                    Time: 09:28:28
539925 - Databus
          [Kombi_02 Datenbus fehlende Botschaft]
                    Reset counter: 23
                    Mileage: 333250 km
                    Date: 2020.01.11
                    Time: 09:26:51
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-283.clb
   Part No SW: 5Q0 919 283 A    HW: 5Q0 919 283
   Component: PARKHILFE 4K  009 0026
   Revision: --------    Serial number: 60831306500776
   Coding: 0001050011
   ASAM Dataset: EV_EPHVA14AU3700000 002015
   VCID: 372B2DE7FFCCA40F38D-8062
1079060 - Center Rear Left Parking Aid Sensor
          B1077 14 [008] - Open or Short to Ground
                    Reset counter: 191
                    Mileage: 333155 km
                    Date: 2020.01.10
                    Time: 03:10:13
1079316 - Center Rear Right Parking Aid Sensor
          B1078 14 [008] - Open or Short to Ground
                    Reset counter: 191
                    Mileage: 333155 km
                    Date: 2020.01.10
                    Time: 03:10:13
13637426 - Databus
                    Fault Frequency: 7
                    Reset counter: 0
                    Mileage: 333155 km
                    Date: 2020.01.10
                    Time: 02:58:30
   Part No SW: 3Q0 959 655 AB    HW: 3Q0 959 655 AB
   Component: Airbag VW20   011 0188
   Revision: --------    Serial number: 003P3P53SCBT
   Coding: 98CCC0000C0000005C5400CC000800000065
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 7EA5F8C390765547BBB-802A
   Subsystem 1 - Part No SW: -----------    HW: 454 000 403 13
   Serial number: 3576U000000BCBF43C0X
   Subsystem 2 - Part No SW: -----------    HW: 454 000 503 13
   Serial number: 3586U00000030D3DBC0L
   Subsystem 3 - Part No SW: -----------    HW: 454 800 503 13
   Serial number: 3516R15A73201000000S
   Subsystem 4 - Part No SW: -----------    HW: 454 800 603 13
   Serial number: 3526RA7372101000000V
   Subsystem 5 - Part No SW: -----------    HW: 454 800 503 13
   Serial number: 3556V43B20E01000000%
   Pedestrian Protection Driver:
   Subsystem 6 - Part No SW: -----------    HW: 454 801 602 13
   Component: PedP_Sensor_D  114 0149
   Serial number: 2286VD822CD00000000D
   Subsystem 7 - Part No SW: -----------    HW: 454 801 502 13
   Component: PedP_Sensor_P  114 0149
   Serial number: 2296VE433CD00000000D
   Pedestrian Protection Center:
   Subsystem 8 - Part No SW: -----------    HW: 454 801 502 13
   Component: PedP_Sensor_C  114 0149
   Serial number: 2306VCD3AF900000000I
9451547 - Igniter 1 for pedestrian protection
          B1038 1B [137] - Resistance Too High
                    Mileage: 334758 km
                    Date: 2020.01.24
                    Time: 19:59:28
9451803 - Igniter 2 for pedestrian protection
          B1039 1B [137] - Resistance Too High
                    Mileage: 334758 km
                    Date: 2020.01.24
                    Time: 19:59:28
   Part No SW: 5Q0 953 507 AJ    HW: 5Q0 953 549 A
   Revision: --------    Serial number: 18031304221317
   Coding: 1400
   Part No SW: 5E0 920 860 D    HW: 5E0 920 860 D
   Component: KOMBI         227 0555
   Coding: 07A402082180000801082A00040000
   VCID: 270BFDA72F6C348FA8D-8072
   Part No SW: 5Q0 907 530 E    HW: 5Q0 907 530 E
   Component: GW MQB Mid    124 1109
   Revision: --------    Serial number: 0000452288
   Coding: 030100040B087300EF0002481C0F00010001000000000000000000000000
   ASAM Dataset: EV_GatewLear 006010
   ROD: EV_GatewLear_006.rod
   VCID: 333319F7EBB4482F045-8066
   Subsystem 2 - Part No SW: 5E0 919 719 A    HW: 5E0 919 719 A
   Component: E221__MFL-PR6  H04 0100
   Serial number: 000000000A0333270213
   Serial number: 5434670103
          U1101 00 [008] - Active
                    Reset counter: 28
                    Mileage: 334683 km
                    Date: 2020.01.23
                    Time: 23:29:14
                    Supply voltage: Terminal 30: 11.8 V
                    Terminal 15: On
   Part No SW: 5Q4 959 393     HW: 5Q4 959 393
   Serial number: 0000055770042
   Coding: 001000208000020000001100
   VCID: 55F7876F4580761FCA1-8000
   Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  005 0004
   Serial number: 00000000000000119081
   Coding: 010200
65588 - Motor for Window Regulator
          B1487 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 242
                    Mileage: 334597 km
                    Date: 2020.01.23
                    Time: 21:13:01
589833 - Window Regulator Switch; Rear Driver Side
          B1323 29 [009] - Signal Implausible
                    Reset counter: 0
                    Mileage: 333155 km
                    Date: 2020.01.10
                    Time: 02:58:15
   Component: EPS_MQB_ZFLS  126 1063
   Coding: 0103
   Shop #: WSC 73430 790 12345
   VCID: 44D14A2BBE1AFF97ADF-8010
16897 - Function Limitation due to Missing Initialization
          B2020 00 [008] - -
          [Rutschkupplungerkennung.  Allgemein]
                    Reset counter: 40
                    Mileage: 334758 km
                    Date: 2020.01.24
                    Time: 20:05:21
                    Motor status: 02
                    System status: Driving mode
                    Supply voltage: 12.50 V
                    Temperature: 53.0 °C
                    KFC: 42
                    KFA: 00 01
                    Environmental conditions: 21
                    nApplI_RotorSpeedFilt_xds16: -6 /min
                    mApplI_LimitedMotorTorque_xds16: 3.800 Nm
                    icuCurrentPhase_U_IRQ_xds16: -96.75 A
                    icuCurrentPhase_W_IRQ_xds16: 49.00 A
                    mApplI_TorsionBarTorque_xds16: 9.50 Nm
                    wrsCurrRotorPosIRQ_xdu16: 152.9 °
15873 - Steering angle sensor
                    Reset counter: 249
                    Mileage: 334758 km
                    Date: 2020.01.24
                    Time: 20:05:21
                    Motor status: 02
                    KFC: 3E
                    KFA: 00 01
                    Environmental conditions: 5F
                    uioUdNotFilt_xdu16: 12.50 V
                    uAdSensI_SwitchedKl30_xdu16: 12.49 V
   Part No SW: 5Q4 959 392     HW: 5Q4 959 392
   Serial number: 0000055311973
   VCID: 7F5B05C7977C5C4FB0D-802A
   Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  005 0004
   Serial number: 00000000000000133953
   Coding: 190200
65593 - Switch for Central Locking
          B122D 29 [008] - Signal Implausible
                    Reset counter: 24
                    Mileage: 333380 km
                    Date: 2020.01.12
                    Time: 15:13:36
589853 - Window regulator motor; front passenger side
          B1322 29 [008] - Signal Implausible
                    Reset counter: 34
                    Mileage: 334780 km
                    Date: 2020.01.24
                    Time: 23:26:53
Address 5F: Information Electr. (J794)       Labels:| 5E0-035-MIB-ENT1.clb
   Part No SW: 5E0 035 875     HW: 5E0 035 875
   Component: MU-E--ER      164 0141
   Revision: --------    Serial number: 000031094114000
   Coding: 03730100FF00000011110001000000002F0000840000010000
   Shop #: WSC 73430 790 00063
   ASAM Dataset: EV_MUEnt4CCONT 004052
   ROD: EV_MUEnt4CCONT.rod
   VCID: 6695B0A3E8E6ED8753B-8032
1539 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
          [Function restriction due to insufficient voltage - lower limit value not reached]
                    Reset counter: 23
                    Mileage: 334401 km
                    Date: 2020.01.21
                    Time: 11:53:38
                    Voltage terminal 30: 8.6 V
          U1101 00 [024] - Active
          [Anti-theft protection - component protection active (0xEA6200)]
                    Reset counter: 28
                    Mileage: 334683 km
                    Date: 2020.01.23
                    Time: 23:29:14
                    Voltage terminal 30: 11.8 V
End----------(Elapsed Time: 01:08, VBatt start/end: 12.5V/12.4V)-----------
khaledabdulaziz
Israel
C?ID=394371
Thanks for your reply.
If you may help how can I get standard values like the meas block when the car has uds protocol
You can't, the firmware in the modules in the car don't support them so you MUST use Advanced Measuring Values.
TBAx
C?ID=287144
Not exactly true, the standard or target values came from the label files. I am not sure if VCDS currently supports these type of information for adv. measuring values. If those are supported someone needs to create label files for this.
