Tuesday,19,November,2019,15:41:16:51983
VCDS Version: 19.6.2.0 (x64) HEX-NET CB: 0.4508.4
VIN: TMBJJ7NS6L8006704 License Plate:
Mileage: 3718km-2310mi Repair Order:
Chassis Type: NS-SK37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 2B 42 44 52 5F 75 BB BC
VIN: TMBJJ7NS6L8006704 Mileage: 3718km-2310miles
Address 01: Engine (J623-DFGA) Labels: None
Part No SW: 04L 906 027 D HW: 04L 907 309 P
Component: R4 2.0l TDI H26 9615
Revision: B4H26---
Coding: 0125001203241D083000
Shop #: WSC 00033 790 00188
ASAM Dataset: EV_ECM20TDI01104L906027D 004005
ROD: EV_ECM20TDI01104L906027D.rod
VCID: AC148705C7C0B82FAB-80F8
Part No SW: 0GC 300 044 G HW: 0GC 927 711 H
Component: GSG DQ381 H06 2401
Revision: 00H06V07
ROD: EV_TCMDQ381061_VW37.rod
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 5Q0 614 517 ER HW: 5Q0 614 517 BN
Component: ESC H35 0190
Revision: 00000000 Serial number: 61789000003278
Coding: 60076A9F40200B72477E060062C749065602D0E2604692713061F078D2024A0B00002E64121A03102F35351919323200
Shop #: WSC 00033 790 00111
ROD: EV_Brake1UDSContiMK100IPB_038.rod
VCID: 854212A104EAA96714-80D0
Part No SW: 3Q0 959 435 K HW: 3Q0 959 435 K
Component: VWKESSYMQB 027 1204
Revision: 00027000 Serial number: 0518304434
Coding: 000F0F0723
ASAM Dataset: EV_KessyHellaMQBAB 004046
ROD: EV_KessyHellaMQBAB_VW48.rod
VCID: C2C8C9BD55445E5F71-8096
Part No SW: 565 907 044 CE HW: 565 907 044 CE
Component: Climatronic H04 2202
Revision: 00001K00
Coding: 16010104000110011005000800101022
ASAM Dataset: EV_ACClimaBHBVW37X 006150
VCID: E08C2335FB882C4F47-80B4
Air quality sensor:
Subsystem 3 - Part No SW: 5Q0 907 659 C HW: 5Q0 907 659 C
Component: G238 _AQS H30 0119
Serial number: 99490362
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5Q0 937 086 CC HW: 5Q0 937 086 BN
Component: BCM PQ37BOSCH 038 0303
Revision: -------- Serial number: J53F10061900IO
ASAM Dataset: EV_BodyContrModul1UDSBosc 020001
ROD: EV_BCMBOSCH_020_VW27.rod
VCID: FDB27A416C3AE1A74C-80A8
Subsystem 1 - Part No SW: 566 955 119 HW: 566 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS326 190606 051 0910
Serial number: 887353F0401915703577
Coding: 164DDD
Subsystem 2 - Part No SW: 5Q0 955 547 C HW: 5Q0 955 547 C Labels: 5Q0-955-547.CLB
Component: RLHS 051 0205
Serial number: S6Y19M06D19H01M58S11
Coding: 00885D
Steering Column Switch:
Subsystem 4 - Part No SW: 5Q1 953 521 P HW: 5Q1 953 569 A
Component: Lenks.Modul H13 0170
Serial number: 0100150620190C401092
Part No SW: 3Q0 919 294 E HW: 3Q0 919 294
Component: PDC 8 Kanal H08 0046
Serial number: 002405197498030
Coding: 0071051011
ASAM Dataset: EV_EPHBO18VW3260000 007021
ROD: EV_EPHBO18VW3260000_007.rod
VCID: BB36B45932AE2F9732-80EE
Part No SW: 2Q0 907 572 R HW: 2Q0 907 572 B
Component: ACCCONTIMQB H03 0372
Coding: 3204600158FF8728749C814500408700000000000000000004
ROD: EV_ACCMRRCONTIVW376_003_VW37.rod
VCID: C3C6CCB94A5E57577A-8096
Part No SW: 3Q0 959 655 CM HW: 3Q0 959 655 CM
Component: Airbag VW21 006 0720
Revision: -------- Serial number: 003Z2PC6HE5X
Coding: 98CCC0C0000000005C5400CF000840000065
ROD: EV_AirbaVW21TS6VW48X.rod
VCID: 8B562499228EDF1742-80DE
Subsystem 1 - Part No SW: ----------- HW: 454 000 406 19
Serial number: 35700000000B14950C3H
Subsystem 2 - Part No SW: ----------- HW: 454 000 406 19
Serial number: 35800000000FE7BC0C34
Subsystem 3 - Part No SW: ----------- HW: 454 800 206 19
Serial number: 3510074D7E218000000M
Subsystem 4 - Part No SW: ----------- HW: 454 800 206 19
Serial number: 352009C97E018000000R
Subsystem 5 - Part No SW: ----------- HW: 454 802 505 19
Serial number: 355003D8F6B18000000Z
Part No SW: 565 920 790 C HW: 565 920 790 C
Component: KOMBI 502 4191
Coding: 04A4011C23800008018C62011001000880000000
ASAM Dataset: EV_DashBoardVDDMQBA0 001042
ROD: EV_DashBoardVDDMQBA0_VW37.rod
VCID: 9E705DCD817C5ABF35-80CA
Part No SW: 3Q0 907 530 AC HW: 3Q0 907 530 C
Component: GW MQB High 521 5388
Serial number: 29061910522498
Coding: 030100045F08730023100240100F00010001070000000000000000000000
Shop #: WSC 00033 790 00141
ROD: EV_GatewNF.rod
VCID: F0AC53752B689CCFD7-80A4
Component: 4-01-13-01-04
Subsystem 2 - Part No SW: 3V0 919 719 F HW: 3V0 919 719 F
Component: E221__MFL-PR6 H03 0180
Serial number: 000000000B1423150619
Subsystem 3 - Part No SW: 5QA 915 181 C HW: 5QA 915 181 C
Component: J367-BDMConti H03 1051
Serial number: 75886103001905231BC8
Part No SW: 3Q0 905 861 B HW: 3Q0 905 861 B
Component: ELV-MQBB H05 0020
Serial number: 19000168207003
Coding: 0800000000000000
ROD: EV_ELVMarqMQBA0_AU37.rod
VCID: B3269C791AFEE7D7EA-80E6
Part No SW: 5Q4 959 593 K HW: 5Q4 959 593 K
Component: TSG FS 007 0480
Serial number: 0000379649271
Coding: 00150120D000020000001100
VCID: CDD2EA819C1A91279C-8098
Subsystem 1 - Part No SW: 5Q0 959 407 A HW: 5Q0 959 163
Component: FOND_FHSG_DRV 007 0010
Serial number: 00000000000031227476
Coding: 010200
Address 44: Steering Assist (J500) Labels:| 5Q0-910-143.clb
Part No SW: 5Q0 910 143 C HW: 5Q0 910 143
Component: MQB_VWBS_GEN2 212 2211
Serial number: 954035 00
Coding: 0100001000400010
ASAM Dataset: EV_SteerAssisVWBSMQBGen2 002119
ROD: EV_SteerAssisVWBSMQBGen2_002_VW48.rod
VCID: AB168419C2CEBF17A2-80FE
Part No SW: 5Q4 959 592 K HW: 5Q4 959 592 K
Component: TSG BFS 007 0480
Serial number: 0000379544576
ROD: EV_DCU2PasseSideMAXHCONT_SK37.rod
VCID: CCD4E7856700982F8B-8098
Subsystem 1 - Part No SW: 5Q0 959 408 A HW: 5Q0 959 164
Component: FOND_FHSG_PSG 007 0010
Serial number: 00000000000031368579
Coding: 190200
Part No SW: 565 035 874 HW: 565 035 874
Component: MU-S-ND-ER H41 0477
Serial number: SKZAZ2W0456054
Coding: 03231601FF0000004111120100880A002F0208E401200400CE
ROD: EV_MUStd4CTSAT_VW41.rod
VCID: DBF614D9D2EE0F9712-808E
Subsystem 1 - Part No SW: 565 919 605 B HW: 565 919 605 B
Component: ABT_Std-2_Nav H52 8130
Serial number: SKZ6ZHW1740157
Subsystem 2 - Part No SW: 5L0 051 236 BA HW: -----------
Component: ECE AS 19/20 --- 1115
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5NA 035 284 C HW: 5NA 035 284 C
Component: OCULowMQBLGE H19 0825
Revision: --------
Coding: 03231601EA421A0D3F1C9E000045400382E608
ASAM Dataset: EV_OCULowMQBLGE 004049
ROD: EV_OCULowMQBLGE_004_VW25.rod
VCID: BD32BA412CBA21A70C-80E8
Address BB: Door Rear Drv
Address BC: Door Rear Pass
End----------(Elapsed Time: 01:44, VBatt start/end: 12.2V/12.1V)-----------
