VW Golf 7R DQ500 RS3 - Haldex RS3 install
320i24vv
Romania
C?ID=304666
Hope my message finds you well!
I own a 2015 VW Golf 7R with a DQ500 RS3 gearbox conversion.
Today I have installed the RS3 Haldex to match the DQ500 RS3 gearbox.
After the install, the car appears to drive OK at first review. Will check more details later.
But I noticed that I am currently encountering the following error codes on the AWD module, after installing it, and they won't go away.
As always, any advice is more than welcome and I thank each and everybody for your time and help!
They are really appreciated.
Part No SW: 0CQ 907 554 C HW: 0CQ 525 130
Component: Haldex4Motion H52 7755
Serial number: HA1-00019.12.15
Coding: 0701
Shop #: WSC 06745 128 28888
VCID: 45D45899C5299DAFBA1-8010
17502 - Databus
[Bremsensteuergerät - TO -- ESP_18]
Reset counter: 236
Mileage: 143478 km
Date: 2019.11.28
Time: 11:28:51
17503 - Databus
[Bremsensteuergerät - TO -- ESP_23]
Reset counter: 236
Mileage: 143478 km
Date: 2019.11.28
Time: 11:28:51
17504 - Databus
[Bremsensteuergerät - TO -- ESP_29]
Reset counter: 236
Mileage: 143478 km
Date: 2019.11.28
Time: 11:28:51
Part No SW: 3Q0 907 379 AB HW: 3Q0 907 379 G
Component: ESC H42 0723
Revision: 00000000 Serial number: 62155000001290
Coding: 01FA6BA15420296D077E070541CA6980D62A94E0E08296F7184250F8C288
Shop #: WSC 47196 003 1048576
VCID: 7AAEFB65FC572257873-802E
hadez16
C?ID=289891
Before digging into ABS coding, have you tried other codings for AWD?
0601 or 0001 ?
320i24vv
Romania
C?ID=304666
0601 or 0001 ?
No, I did not try any codings yet.
I just installed it on the car.
I looked at the coding previously on my car and it was 0001. With the old Golf Haldex.
Please see below:
Serial number: HA1-00010.01.17
Coding: 0001
VCID: 4ACE6BA5EC3772D7573-801E
Do you think this could be the culprit?
320i24vv
Romania
C?ID=304666
0601 or 0001 ?
Fast update. Tried to update the codings to either one of 0001, 0601 or 0701. All give the same three already indicated error messages. :)
hadez16
C?ID=289891
Okay.
Honestly I have no clue....
No other people that did the same retrofit?
320i24vv
Romania
C?ID=304666
Okay.
I do not know. I will look around more.
After last night checks I noticed that it works perfectly. But have these three error messages.
Looks to me like the firmware in the RS3 AWD module is expecting extra messages?
320i24vv
Romania
C?ID=304666
Exactly my thoughts. And I know that the Golf 7 Haldex works with 7V and 9A current. The RS3 with 9V and 11A current. I currently have recorded 7.2 V and 8.9 A. So it still treats it like a Golf Haldex. I have performed basic settings of the Haldex Pump. Will test again.
If it still works like this i believe i can safely ignore the errors or switch back to the old Golf Haldex controller on this RS3 Haldex. That should work also.
Vrt
Ottawa, Canada
C?ID=86955
I didnt think there was a difference between the 2 haldex units
